Results 1 to 10 of 10
    Reputation: NOBBY605's Avatar
    Offset wheel on rear of Salsa Mukluk---Pics?
    Sorry if this has been covered already.. Has anybody used the offset adapter on a Muk?Pics and thoughts appreciated.
    Reputation: GTR2ebike's Avatar
    May 2010
    I'd be yawning to if my Fatback weighed 38 pounds!
    May 2010
    Quote Originally Posted by NOBBY605 View Post
    I can't make it lighter, because if I did what excuse would I have when I can't keep up with you? Besides not having a 15 lb road bike
    Why do you want a pic of the muk adaptor anyway...to try and use the clownshoes on the fatback?
    Drilled Darryl's...American Classic hubs.
    Interesting 165mm hub
    In the middle of the above thread is a picture of some WTB hubs I modded to make them fit a 165 rear end. I have since done it with a carbon tube that fits over the entire hub barrel from flange to flange. I think the American classic hubs are similar to the WTB's so would be very east to mod. It adds about 40 to 50 grams to the weight of the hub. I have many miles on these hubs with no failures. Dont ask about the bottom bracket I tried to widen though.
    Latitude 61
    Very nice! I was hoping that Fatback would make a 135 rear adapter..like for a IGH, but getting info on this is like squeezing water from a rock. I am alittle afraid of cutting a new set of AC hubs.
    Hey, that's my bike...I ran the adapter for 6 or so months through the summer and into the fall, until we had 170 hubs to test and ride. It performed flawless and I still have it tucked away in a box somewhere.
    I don't see saving any weight using the adapter and a 135. The weight of the part and bolts will offsetmthe hub weight. Ease of rear wheel removal also diminishes with the 135 spacing.
    I would run this if I already had a rear offset wheel. That was the intent of building it anyway.
    You can pick up a WTB Laserlite on EBay for pretty cheap sometimes. Also Rotaz is similar, axles and hubshell but the cassette teeth don't wear as well as the WTB or I expect the ACs.
    Latitude 61
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by sryanak View Post
    Yeah I really don't want to have that brought up again either.
