Results 1 to 20 of 20
    Reputation: x3speed's Avatar
    Offset 29er wheels ona Moonlander?
    What would be the ideal set of 29er/27.5er/26er wheels, if you wanted to use the Moonlander in the summer for a little faster riding? Please post opinions or if you've done something like this, show us!
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    a shimano xt hub has a disk side flange spacing of about 33.5 mm from center
    once you take off the 28mm offset you are left with about 5.5mm of dish
    I don't want to burst your bubble but I do not know how you could build a strong rear wheel with so little dish
    I do wish surly would roll a 29er marge lite
    Sj
    I am slow therefore I am
    Answered my question, thanks! Hopefully things change.
    Feb 2012
    Quote Originally Posted by SlowerJoe View Post
    Sj
    marge lite 29er would be AWESOME!
    Apr 2005
    Quote Originally Posted by ApocalypseMaow View Post
    marge lite 29er will be AWESOME!
    Fixed that for ya
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Why not just put some Black Floyds on when you want to go FAST
    Life IS a Beach and then you Corrode
    aka RossC
    Reputation: ocean breathes salty's Avatar
    Not that I know anything about wheel building, but do high flange hubs go anyway to assisting in getting a better dish?
    Chub SS/DJ Rear | the Hive
    Feb 2012
    Quote Originally Posted by Sverre View Post
    Fixed that for ya
    whaaaaaa...
    Sup
    Dec 2008
    Quote Originally Posted by ocean breathes salty View Post
    flange height only reduces torque load at the the spoke head
    It has very little to do with dish
    Sj
    aka bOb
    Reputation: bdundee's Avatar
    Sj
    Nice SJ, glad to see you're off the bourbon today
    Dr Gadget is IN
    Reputation: wadester's Avatar
    Someone had posted an online spoke length calculator that gave you a graphic showing the spoke angles as well as listing them. I think it also gave the tension difference. Can't find it now.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
    Reputation: Tibor's Avatar
    freespoke... i use it very often!
    Sup
    Dec 2008
    Quote Originally Posted by bdundee View Post
    I felt a cold coming on that day and was doing my best to make my body an uninhabitable host
    It didn't work
    Sj
    Reputation: Velobike's Avatar
    At first thought a 29er offset for the Moonlander looks like a recipe for disaster.
    But maybe if you took a wide 29er rim (eg Kris Holm), redrilled it and used a crossover spoking (lhs flange to rhs set of holes) it may work.
    Personally I'd sooner put on Black Floyds, an incredibly versatile tyre. I'll be trying them on a long ride shortly, but my experience so far suggests that there's no real penalty to using them*. It would be much cheaper to do than building a set of 29er wheels.
    My Kris Holm rims weigh 801gms each, thus the 29er wheels would be about the same weight as a lightweight fat wheel build anyway, and the only weight difference would come down to tyre choice.
    *If you're a heads down racer then you may have a different opinion, but my observations are based on ordinary use.
    Latitude: 5736' Highlands, Scotland
    Are the BFs wide enough to fit a moonlander rim?
    Nov 2007
    Quote Originally Posted by x3speed View Post
    Oh yeah. Any fat tire will work ok on a hundie. It'll just yield a more spread out profile (square or more flat across.)
    aka RossC
    Grave dig.
    Has anyone figured out a solution for this yet? Waiting for a custom frame to replace my 29er and would like to de-fat the moonie for trail riding while I wait.
    Reputation: kyttyra's Avatar
    Mar 2012
    29x3" slicks would be AWESOMEST!1
    Fixed that for ya
    ditto
    About Black Floyds on Moonlander (clownshoes): I wonder how they would steer, as I have mixed experience about them on 82 mm rims. >1 bar: smooth and fast; terrible self steering on "normal" fatbike tire pressures. I would think the self steer could be worse with broader rims? Too bad that I sold my pair before I decided to buy a fatbike with 65 mm rims as I hear BF's work better on narrower rims (confirm/deny?).
    Before you decide that this will not work... ask yourself...
    are road wheels exploding left and right out there? Even at paris-roubaix or flanders or cross racing....
    because the bracing angle of a 10s road wheel on the drive side is around 3.3-4
    my pugsley 29er wheels are doing just fine thank you...
    g
    anyone done rabbit holes on a moonie - wouldnt they work?
