Page 5 of 5 FirstFirst 12345
Results 201 to 207 of 207
  1. #201
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Interesting. Awesome that you've found something to scratch your itch.
    The Warrior tire is marked 3.7". Have you measured casing width? Compared it to a Knard? In your last pic they look very similar in width.
  2. #202
    Reputation: FatBike&SlenderWoman's Avatar
    Apr 2016
    Quote Originally Posted by mikesee View Post
    ...The Warrior tire is marked 3.7". Have you measured casing width? Compared it to a Knard? In your last pic they look very similar in width.
    On the 85mm rim @ 15psi, both casings measure 90mm wide.
    The Knard tread is 79mm (3.1") wide with the Warrior tread at 91mm (3.6") which qualifies for most fat bike races including the Birkie. I suspect that on the 96mm alloy rim, the Warrior would measure 3.7" wide.
    The Warrior was designed to be a low profile fat tire with the tread spread out to take advantage of the larger diameter and lower mass of a 29+. I like to call it 'Bud Light' ...same great diameter with one-third fewer calories.
    The next run of the Warrior tire will have the outer tread enlarged to 3.8", improving traction in deeper snow while also enabling it to qualify for the Fat Bike Nationals.
  3. #203
    Aug 2003
    How easy was that rim to set up tubeless? How reliable at low psi's?
  4. #204
    Oct 2012
    what is the skinniest tire that would work on the Stans Hugo 29? I have a set of these wheels with dirt wizard 3.0 on my fatbike and am thinking of buying a salsa bucksaw frame to swap in. The only issue is on Salsa's website, it says it only has the tire clearance for a 29 by 2.4 wheel. not 29+. So anyone have any rear world experience with these rims with 2.4 tire on it? Thanks.
  5. #205
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by beachbum1 View Post
    What size Bucksaw? It's been said that the large and extra large will fit some of the smaller plus tires, like the dirt wizard and the tire that panaracer makes
  6. #206
    Oct 2012
    Anyone have any experience with the newer 2.6 tires on Stans Hugo rims? I am wondering how skinny of a tire you can get away this and still have a decent tire shape. Thanks.
  7. #207
    Nov 2014
    I used 2.35" Nicotine on my 50mm rim and the profile looked ok to me, FWIW
    but that was winter - you don't lean much on ice/snow Notubes Hugo 52mm Rim-nicotine-50mm.jpg
  1. 52mm
    By shoo in forum Fat bikes
    Last Post: 06-18-2014, 09:06 AM
  2. Most common chainline - 47.5mm or 52mm?
    By TooSteep in forum Singlespeed
    Last Post: 04-16-2013, 10:36 PM
  3. First Hugo Chavez and now Paul Bearer needs the Undertaker
    By cyclelicious in forum Off Camber (off topic)
    Last Post: 03-06-2013, 10:17 AM
  4. fox 120 mm fork w/ 52mm offset crown on anthem
    By hakalugis in forum Bike and Frame discussion
    Last Post: 03-31-2011, 03:45 PM
  5. NoTubes.. 2.2 or 2.0?
    By a.brasington in forum Wheels and Tires
    Last Post: 01-31-2011, 08:39 AM
