Page 3 of 3 FirstFirst 123
Results 201 to 214 of 214
  1. #201
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Interesting. Awesome that you've found something to scratch your itch.
    The Warrior tire is marked 3.7". Have you measured casing width? Compared it to a Knard? In your last pic they look very similar in width.
  2. #202
    Reputation: FatBike&SlenderWoman's Avatar
    Apr 2016
    Quote Originally Posted by mikesee View Post
    ...The Warrior tire is marked 3.7". Have you measured casing width? Compared it to a Knard? In your last pic they look very similar in width.
    On the 85mm rim @ 15psi, both casings measure 90mm wide.
    The Knard tread is 79mm (3.1") wide with the Warrior tread at 91mm (3.6") which qualifies for most fat bike races including the Birkie. I suspect that on the 96mm alloy rim, the Warrior would measure 3.7" wide.
    The Warrior was designed to be a low profile fat tire with the tread spread out to take advantage of the larger diameter and lower mass of a 29+. I like to call it 'Bud Light' ...same great diameter with one-third fewer calories.
    The next run of the Warrior tire will have the outer tread enlarged to 3.8", improving traction in deeper snow while also enabling it to qualify for the Fat Bike Nationals.
  3. #203
    Aug 2003
    How easy was that rim to set up tubeless? How reliable at low psi's?
  4. #204
    Oct 2012
    what is the skinniest tire that would work on the Stans Hugo 29? I have a set of these wheels with dirt wizard 3.0 on my fatbike and am thinking of buying a salsa bucksaw frame to swap in. The only issue is on Salsa's website, it says it only has the tire clearance for a 29 by 2.4 wheel. not 29+. So anyone have any rear world experience with these rims with 2.4 tire on it? Thanks.
  5. #205
    bigger than you.
    Reputation: Gigantic's Avatar
    Quote Originally Posted by beachbum1 View Post
    What size Bucksaw? It's been said that the large and extra large will fit some of the smaller plus tires, like the dirt wizard and the tire that panaracer makes
  6. #206
    Oct 2012
    Anyone have any experience with the newer 2.6 tires on Stans Hugo rims? I am wondering how skinny of a tire you can get away this and still have a decent tire shape. Thanks.
  7. #207
    Nov 2014
    I used 2.35" Nicotine on my 50mm rim and the profile looked ok to me, FWIW
    but that was winter - you don't lean much on ice/snow Notubes Hugo 52mm Rim-nicotine-50mm.jpg
  8. #208
    Apr 2016
    No problem. We set up two wheelsets using a FattyStripper with a rim strip covering the holes.
    I have run them at 4-5psi in fresh snow with no problems. They run best at 8-10 psi on groomed snow. FWIW, my bike is 240lbs with me on it.
    BTW, These are hookless rims so I would not recommend running them over 20psi with 120tpi tires that are not 'tubeless ready'.
  9. #209
    Aug 2003
    Good info. But -- I asked about "low" psi's. 4-5 isn't very low -- more like medium/high. Any experience with these at ~1psi?
  10. #210
    Apr 2016
    I am running 2.8 Speedsters on Hugos and would not want to run them on anything narrower but then a again, I am 90% road commuting on that wheelset.
    As for shape, see photos at post #187 this thread.
  11. #211
    Apr 2016
    1psi means the contact patch is 1sq in / 1lb of total bike weight. For a 170lb rider on a 30lb bike, that would be 200 sq in of tire flat on the ground (6.5" x 17" oval contact patch). That would require at least a 100mm wide rim with a 5" tire just to keep the rim afloat inside the tire.
    That's getting into Bud/Lou/Clown Shoe area.
    The Warriors are intended to out perform 4 x 26 tires on a groomed trail.
    As one of the Birkie podium riders put it, "Riding the Warrior compared to a D4 feels like cheating."
  12. #212
    Aug 2003
    Thanks for the lecture. We run less than one PSI probably 80% of our ride time on snow. It is a very good and very rare day that we get above one PSI.
  13. #213
    Apr 2016
    It's just applied physics. Even on an 85mm rim, a pair of 188mm b-b tires will not support more than 100lbs @ 1psi
    We got 7" of fresh heavy snow yesterday so I dropped Bud & Lou down to 3 psi and did a half dozen laps through the Baird Creek Trails to groom them for the 4" bikes.
    Heartrate 150 bpm, speed 2 mph
  14. #214
    Apr 2016
    ...We run less than one PSI probably 80% of our ride time on snow. It is a very good and very rare day that we get above one PSI.
    Well, I went back out today and dropped the pressure until I could push down on the tire with my hand and make the casings start to wrinkle (1.5 - 2.0 psi)
    It was really sluggish and squirmy on groomed snow but I have to admit, it did float better on the deep stuff.
    Definitely can't run Hugos in these conditions. (attempting to stay on topic )
  1. 52mm
    By shoo in forum Fat bikes
    Last Post: 06-18-2014, 09:06 AM
  2. Most common chainline - 47.5mm or 52mm?
    By TooSteep in forum Singlespeed
    Last Post: 04-16-2013, 10:36 PM
  3. First Hugo Chavez and now Paul Bearer needs the Undertaker
    By cyclelicious in forum Off Camber (off topic)
    Last Post: 03-06-2013, 11:17 AM
  4. fox 120 mm fork w/ 52mm offset crown on anthem
    By hakalugis in forum Bike and Frame discussion
    Last Post: 03-31-2011, 03:45 PM
  5. NoTubes.. 2.2 or 2.0?
    By a.brasington in forum Wheels and Tires
    Last Post: 01-31-2011, 09:39 AM
Members who have read this thread: 80
