Page 3 of 18 FirstFirst 123456713 ... LastLast
Results 201 to 300 of 1718
  1. #201
    Fat & Single
    Reputation: ozzybmx's Avatar
    Quote Originally Posted by dfiler View Post
    That tape is only 48mm wide. I've always used tape wide enough that the tire bead sits on top. That way, air pressure isn't trying to force air or stans under the tape edge. Does that not matter?
    It only needs to adhere to the carbon surface and cover the spoke holes, the carbon rim shape does the rest.
    To get the tape down in the "valley" and sticking perfectly with no air bubbles requires forearm popping effort, the 8898 tape will stretch slightly and this helps... but the last few bubbles need to be smoothed out with a heat gun.
    Good luck using any wider
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  2. #202
    Quote Originally Posted by ozzybmx View Post
    Hmmm, so we've got recommendations both ways. Full width tape is necessary and full width tape is not necessary.
    I've always done full width in the past with the reasoning that it doesn't rely on the tape sticking to keep an air tight seal. Instead it is just the tire bead needing to be pressed against the tape/side-wall to form a seal.
    Have you done up a pair of nextie rims this way ozzybmx?
  3. #203
    Instead of tape, has anybody tried a sealant such as 3 m 5200? Maybe seat the spokes in the rim with a dab in each hole? I have to idea if the spokes move around once in use...
  4. #204
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by AnimalBikeman View Post
    If you want to run sealant that would make a mess between the double walls and not sure if it would work very good.
  5. #205
    Hmmm, didn't think about the double walls. I wonder about bedding the spokes with a small patch of butal rubber with a tiny spoke hole like a wAsher but flexible and capable of being drawn up to a low pressure seal by spoke tension. Maybe I'll try something like that when I get my rims.
  6. #206
    aka bOb
    Just have em drilled for internal nipples and be done with it. Extra time feeding them in but in the end no tape needed.
  7. #207
    Fat & Single
    Yes, yellow ones are done this way now and I've tried one of the greens with a Bud. When the spokes arrive, both my nextie sets will be tubeless this way.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  8. #208
    Aug 2013
    Hello,
    So for Belgium is it impossible to get the nexties. We mailed, phoned again and again for three weeks and still we still have no wheels ordered
    No nexties for me anymore
  9. #209
    Fat & Single
    Ok gents, being a bit of the pioneers on carbon fat bike rims... its all trial and error. We are buying the new rims and basically testing them for the suppliers with our different tyre combos, temperature and terrain.
    I originally set up my Nexties with 8898 tape but the tape is too wide, this is not immediately obvious as its stretches slightly and and can be shaped by heat to leave a smooth looking job.
    The reality is that it starts to peel back and lets stans under the tape as it peels back under the tightness applied to make its stick in the first place.
    So I stripped it off and used some of my old fave, Fibreglass reinforced tape (filament tape/strapping tape), at 25mm wide and zero stretch it can be applied very tight and make an awesome seal.
    I did this 2 weeks ago and now have about 200km on the wheel (the back has still 8898), will be doing the rear in the next few days before it fails.
    Here's a few pics of it covering the spoke access holes just before I sealed it up.
    I am 100% confident on this set-up this time, apologies to anyone who bought 8898 tape for these wheels on my recommendation... as I said, we are the testers.
    EDIT: There is about 4 wraps of tape weighing bugger all, prob ~10-15g . One wrap in the middle, one high right, one high left and another in the middle for luck.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  10. #210
    Thanks for the update. Not having a 150mm hub to build the front wheel, I haven't bought any tape yet and am interested in how this works out.
    So it's the non-stetchable nature of the fiber reinforced strapping tape that makes it preferable to the 8898 tape? That seems counter-intuitive given how the outer edges of the tape will need to stretch over a larger circumference than the middle part of the tape. I've got no experience in tubeless on such wide rims so this is just pondering on my part rather than criticism.
    Is that the optimal tape or would you buy something different if you didn't already have that type?
    It seems like something full width would be good so that it doesn't rely on the tape adhesive to form a seal. But I'm not sure how that can be done with the deep channel in the middle of the this rim.
  11. #211
    Fat & Single
    Its very very slightly stretchable and can stretch just enough to stick to the "off camber" wall of the rim. The narrow width is the ticket to fill the valley, wide tape is not an option IMO. It will peel off over time and once stans gets under it, its a fail waiting to happen.
    I will be buying some more filament tape for my other set, pretty confident this is the way to go.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  12. #212
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Okay Ozzy, one more test for you do to since you are the "OFFICIAL TESTER". We need to know how the bead holds at temps between 0 and -30 F. If you can get that done, that would really help those of us who are waiting until all the tests are in before purchasing.
  13. #213
    Fat & Single
    OK... I don't believe my testing chambers (Southern Hemisphere, Australia) drops below +3... that's the coldest it gets here, im relying on Mike C to fill them gaps in
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  14. #214
    Apr 2014
    I know all you Fat Bikers are nice and cool and all.. But lets let some others chime in on the new 40mm Nextie hookless!!! I was about to get some 35mm from LB but having seen these and with actual test data.. I'm more inclined to go this route!!
    Carbon Fiber 650B/27.5" MTB Rim 40mm width Clincher Hookless Tubeless Compatible Mountain Bike [NXT650BH01]
  15. #215
    Reputation: brankulo's Avatar
    Aug 2005
    i am having a friend coming over and test his 40mm wheels on my bike converted to 650b, to make sure there is enough clearance, and if there is, i am pulling trigger on fat rims and these new 40mm hookless.
  16. #216
    Reputation: bikeny's Avatar
    Quote Originally Posted by icdesign View Post
    I have a set of the Derby 40mm 27.5 rims, and just found out about the Nextie ones. The light layup Derby rim weighs 440 grams, and the Nextie claims 360 grams. I emailed them about it and they said that weight is correct and it passes all of their testing. But he also said they were considering adding another layer of carbon and then they would weigh 380 grams. The price is right, but I am glad I went with a tested rim from a company with excellent customer service.
  17. #217
    Aug 2005
    good point, i also inquired about heavy duty build as the weight seemed too light against derbys and ibis, i havent got answer back yet. 380g might still not be strong enough.
  18. #218
    Apr 2014
    My responce from Brian at Nextie re layup options etc.
    "Our 380g version would be used for AM. When we did technology tests, we use rims weight around 360g. They worked well. So 380g version with one more carbon layer would be stronger.
    If youíd like to use it for DH, we would add the rim with carbon fibers up to 440g. But cost is USD10 more for each one.
    This design used to be used on other mtb rims. But we just make it hookless, also add a small embossment at the bead, which you may notice from the profile drawing. This design would keep the tire edge stably staying on the rim bead. We also have applied this design on our 90mm fat bike rim, the wild dragon rim. It works great.
    As a fact, we just listed this product on our site days ago. We only got 6pcs of this rims order from three riders, two of which are our regular customers.
    But there were several customers have asked about it, but didnít place an order. I guess they might be afraid of the quality before we release the technology tests report, after all this product is newly emerged. While, I believe this product would be greatly performanced. It passed all tests, also itís a great design and light weight.
    As itís new and only several rims order, no failures yet.
    We could complete an order in 7 workdays."
    Hope that helps!
    Quote Originally Posted by brankulo View Post
  19. #219
    Clueless Bastard
    Reputation: WA-CO's Avatar
    Nov 2013
    You're welcome to post anywhere, however this IS the FATBIKE section....All FAT, ALL THE TIME.
  20. #220
    Here is ancillary info re a carbon 29" rim SIMILAR but not the same as the
    40 mm 27.5'' rim mentioned above. I test rode a boreales
    Echo today in Anchorage. It was built up with 29er+
    35mm carbon mtn bike rims and 3" Knard's. Rims and tires performed well on muddy single track - which was An eye opening experience of sorts. Both because the rims were narrow and because the rims caused the Knards to ballon into a more round shape for trail riding. Unusual but seems like an effective way to ride with some decent float while not carry the big weight and profile penalty. Only negative was the tires kind of sucked the molten core of the earth along behind while riding pavement, but did demonstrate for me the utility of narrower rims and small fat for summer xcrosscountry riding. All in all, Iam going with
    80 mm carbon rims with tubeless Nates as my utility tire but only because I expect to do some significant off road riding where I want the extra floatations. Otherwise the 35 to 40mm rims would be very interesting.
  21. #221
    does anyone know reason for price hike for fat rim? i was in between nextie and light bike fat rim, this surely made the decision bit easier, even though not much report on setting light bike rims tubeless. anyways, just wandering what is $40 hike for?
  22. #222
    aka bOb
    Quote Originally Posted by cavo View Post
    I have a set of Light Bikes and even though I have exactly zero miles on em they set up tubeless awesome and I have no worries about them on the trail. Now if I could only get the tires off
  23. #223
    Quote Originally Posted by bdundee View Post
    ok, now thats bummer. xmiplay rims should be up soon is what i hear. will see.
  24. #224
    aka bOb
    They supposedly fixed the design, mine where the original ones. I have an email into them we will see what they say
    Edit: I am in no way saying the lb rims are better just stating my experiences.
  25. #225
    Fat & Single
    They were $268 each... now $320, so $52 a rim hike.
    Maybe because he has them down to 650g, they work well tubeless and mounting/removing tyres... possibly an introductory price till stuff was sorted.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  26. #226
    Red Nextie Tubless
    These are setup tubless, used Gorilla tape. Had to use a tube to get the tire seated first. Took out tube and setup after that was pretty easy. Used 4oz of Stans in each. Have held air for 2 days now.
  27. #227
    Fat & Single
    Nice one ! Rims look awesome... BTW I had to use a tube for one of mine, if you can jag it... it works with both sides, i have inflated both on 3 occasions out of 4 but its better to be safe than sorry, inflate and pop one side, the other airs up easily.
    BTW all done with a track pump ! Air compressor would be a different matter.
    I am using a track pump only as I have a race coming up that is very minimalistic.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  28. #228
    Quote Originally Posted by rczarnecki View Post
    Did you cover just the spoke holes in the center chanel or did you go full width?
    I tried a couple types of tape I had in my basement but none would sit flat enough to eliminate wrinkles and completely adhere to the rim. It seems that narrow tape in the very center might be the only possible method with tape. (as has been successful for ozzybmx)
    Previously I thought that this was doomed to fail because tubeless fluid could seep under the edge of the tape or eventually the edge could peel up. However, looking at the design of Stan's newest rim, the hugo, maybe that isn't a problem after all. Check out the cross section of the hugo, it is designed to use a narrow strip of tape that doesn't sit underneath the tire bead. In fact, that profile kind of matches the center grove of the nextie rims. Hope is renewed. I'll give it a shot this week and see how it works out.
    Stan's Hugo
    This rim design could become the norm and we might start to see narrow/partial-width tape become the standard. Time will tell though. I still feel better when the tire bead holds down the tape so that the air-tight seal doesn't rely on the tape sticking to the rim.
  29. #229
    Fat & Single
    Weight and stiffness is the way forward here, with 29, 27.5 and 26... Stan has just released carbon wheels at $1900 a set... too little too late IMO.
    I like the loom of the new rim profile but cant see a weight saving. The 52 Hugo rim you post is basically nothing short of Margelite weight, 520g-622g. You can go 90mm carbon for 650g and soon 65mm carbon for 450g'ish.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  30. #230
    Oct 2013
    I am scratching my head, I have the same set up as other, Husker Du tyres on the Dragon rims and they just wont seal. I have tried putting a tube in first to seal one side, I have tried the washing up liquid etc I have also tried front and back swapping the tyres but get the same result. The tyre pops on nicely but as soon as I get it up to 10psi the stand fluid starts to bubble out and I can not get the tyre and harder. As soon as I stop pumping the tyre holds the pressure (10psi). I have left the tyres inflated like this and they hold this pressure but as soon as I put any weight on the tyre (ie lean on it) the air bubbles out. I just cant get it to hold air above 10psi...any ideas.
    I have just taped the central holes over with stans tape and this seems to be holding air tight (as the stans is not bubbling out her)
    Travers Bikes.com
  31. #231
    Agreed, I think Stans rims are overpriced and heavy compared to the inexpensive carbon options.
    The comparison I was aiming for was how the rims are taped. All tubeless setups I'd seen previously used full width tape. The hugo makes that impossible yet is intended for tubeless and is from a leading name in tubeless rims. That's what is giving me hope that nextie fat rims can be taped in a similar manner, with just a narrow strip in the center. The profile of that center channel is quite similar to the hugo center channel. If Stan thinks it'll work, that's a pretty weighty endorsement.
    Not to ignore your success with narrow tape. But rather Stans is likely to have already extensively tested the setup for an extended period. We'll still name it after you since you got your solution to market first.
  32. #232
    Aug 2005
    when i asked them about the price hike, they apologized and gave me coupon for $80 off to offset $40 hike per rim. they said that the factory that makes the rim underestimated the cost and raised the price on them.
  33. #233
    Fat & Single
    Traverbikes, if you have the original rims (before the amendment)
    Get a tub of Mold Builder latex, it goes off like a ho in a brothel.
    Paint it around the bead with no stans in the tyre, inflate and the tyre should seal, remove valve core and inject stans. In my case i am now confident it will seal and i put stans in there before hand.
    When it seals, hose/wash the side walls down with some water.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  34. #234
    Fat & Single
    I sealed my "original Yellow" rims like this. My new fluro rims seal first time with Hudu's... no spokes yet, should be here in a day or two.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  35. #235
    Oct 2013
    thanks ozzybmx, I have ordered some mold builders latex. I dont like doing stuff like this as you are stuck if it all goes wrong out on the trail but I have tried everything else so...
    Travers Bikes.com
  36. #236
    Apr 2014
    Theres an additive you can add to Stans sealant that creates a foam. Its a canadian company that LB makes rims for initially. I canŤt seem to find the site quickly.
    It basically stops the sealant from spewing out of the "leaks" like stans does which eventually seals the hole. But it rather clogs it from the start. Allegedly losing a lot less air in the process. To be clear I have not tried this stuff.. and the site is pretty crude.. but maybe woth a try before you go through the nightmare of latex being as described above.
    Edit:
    Found link.
    Welcome to lbs. bikes
    Quote Originally Posted by TraversBikes View Post
  37. #237
    Oct 2013
    The mold latex worked perfectly and the tyre sealed straight away on both front and back rims. It was a little messy to put on but a quick wipe with a cloth after they were pumped up sorted it out.
    I will look into the additive, thanks icdesign
    Travers Bikes.com
  38. #238
    Fat & Single
    Nightmare !! We look forward to more of your great experiences here in the future icdesign.
    Good to hear TraversBikes, you dont need that much of it, just a slight covering around the rim bead area. Pretty simple solution to seal a stubborn tyre... also if you ever need to remove the tyre again, it should seal up first time without any additional latex.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  39. #239
    Clueless Bastard
    Nov 2013
    I'm thinking my timetable on Nextie's (and a Bluto Fork) just moved up.
    Rim Toast?
  40. #240
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by WA-CO View Post
    Rim Toast?
    Looks like.
  41. #241
    PRETENDURO
    I love the look of those things in colours with Buds and Lous mounted to them. They look like gigantic all-terrain donuts. Got to get me some of that action once my Echo gets built up.
    QUOTE from MTBR.COM: You have given Brewtality too much Reputation in the last 24 hours, try again later.
  42. #242
    Reputation: MuruCycles's Avatar
    Sep 2012
    just received some custom Nexties for a customers build.
    good lordy... they're light. Finish quality is nice too.
    Mr Muru
  43. #243
    Fat & Single
    Very nice !!!
    Like'n the stencilled lizard.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  44. #244
    May 2014
    Hi ozzy
    Where did you get the mold latex builder here in oz?
    Cheers
    Ip
  45. #245
    Fat & Single
    Hey IP, i bought it in a local shop here in Adelaide, they have a website Brush Latex - 500ml [BLATEX-500] - $15.45 : Adelaide Moulding & Casting Supplies
    You should be able to get it locally, but if not... these guys will ship it.
    Its good for other wheels too AND if you "water" it down with windscreen washer fluid you can use it as tubeless sealant instead of stans but it doesn't last long before needing replaced, the plus side is that it seals better than stans but the tyre needs cleaning out as this stuff goes off fast !
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  46. #246
    May 2014
    Thanks ozzy
    I'll chase it up
    Is it water based? And will 500ml be enough if you end up using it on a few rims
    Do You only paint it on the bead of the tyre only, or the rim as well?
    Cheers
    Ip
  47. #247
    Fat & Single
    Just give the RIM bead a slap, after you have sealed them up... you wouldn't even notice the amount gone from the jar, there's enough for probably a 1000 wheels in 500g.
    Its a token gesture, no weight incurred !!!
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  48. #248
    May 2014
    Cool
    Thanks I'm hopeing I won't need it but I'll get some just in case
    You can never have TOO much stuff in the shed "just in case you need it sometime"
    Lol
    Cheers
    Ip
  49. #249
    I built a front wheel up last night. 244mm spokes were perfect for a fatsno 150mm hub with these nextie rims. I always try a few calculators and some said these spokes would be a bit short. They weren't.
  50. #250
    Aug 2005
    i got my rims yesterday, boy are they looking great. went with UD matte. when i was picking up the delivery, i thought i am picking empty box.
    i also chatted with brian from nextie and they have couple things coming up. 65mm 26" rims in 2 or so weeks. next 50mm 29" hookless rims and right after that 40 or 45mm hookless 26" rims. i might be getting pair of 29" rims for summer conversion of my not yet existing fatty
  51. #251
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Mmmmm perfect! (Not for my wallet....)
  52. #252
    Quote Originally Posted by Shark View Post
    I agree!Waiting to see the price and weight.
  53. #253
    Fat & Single
    Set #2, built with Sapim CX Ray bladed and Polyax black brass nipples. My Yellow set will be getting the alu nipples removed and brass fitted as I wont go through this ENVE wheel nipple corrosion. again.
    Main reason for my recent decision is that the void inside carbon rims lets water in and there's quite a bit gets inside fatbike rims with nowhere to go, in my case this is seawater from riding on the beach. It can be heard sloshing around inside when the wheel is rotated.
    Just finished these tonight, tyre on, air compressor popped both beads on and instantly sealed. They way tubeless should be
    Believe me... these pics in the dark really dull down these wheels, they are friggin bright in daylight.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  54. #254
    Reputation: quickKarl's Avatar
    should have in my hands next tuesday
  55. #255
    Feb 2006
    Geez guys.... Those are nice
  56. #256
    Fat & Single
    X post from the fatbike pic thread.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  57. #257
    aka bOb
    Man Bill those friggen cool!! I wish I had an adventurous side to dabble in color, well done Sir!
  58. #258
    PRETENDURO
    Those things are freakiní goddamn obnoxious, I soooooooo want to get a set!!!
  59. #259
    Feb 2006
    Wait a sec... Did you line up the logos just for the pic?
  60. #260
    Fat & Single
    Awwwww... they are a bit out. If I'd have lined them up, the tyre logos would be sitting pretty too
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  61. #261
    Clueless Bastard
    Nov 2013
    Whoa. Grey rocks, grey bike, MOTHERFOOKING BIG FAT GREEN RIMS. Nice.
  62. #262
    Reputation: Ottoreni's Avatar
    NEXTIE Warranty?
    Howdy, Curious if anyone has dealt with Nextie regarding a warranty issue?
    What was there response time? Did they honor the warranty?
    I am curious because I sent them an email with oictures regarding cracks beginning to show around several nipple holes of my rim. Rim is less than a year old.
    You cannot go against nature, because when you do, its part of nature too.
  63. #263
    PRETENDURO
    I hadnít even noticed the colour of the frame! Beige would even look good with rims of such obnoxiousicity.
  64. #264
    aka bOb
    Titanium Baby!!
  65. #265
    Just to add to my original post.
    Have been dealing with Nextie about my warranty.
    So far, they have been great.
    I sent them pictures of the rim and a scan of my receipt.
    The only other thing they asked for was the serial number. Might be a good idea to take a picture of the serial number prior to putting tape or a rim strip over it. That was the most difficult part of the process. Removing the rim strip after eight month of use and tubeless sealant.
    $45 for shipping and 7-10 days and my replacement rim should be coming to me.
    Great warranty experience so far!
  66. #266
    PRETENDURO
    Wow! Great to hear of a good warranty experience on these rims.
  67. #267
    Jul 2014
    Ozzybmx, what length polyax did you end up going with? And is the packing tape still holding up?.
    Just ordered a set of nextie rims for my first wheel build and any help or advice is greatly appreciated, would like to get it on the first go
    Thanks,
    Derrick
  68. #268
    Fat & Single
    Derrick, they were 14mm black alu polyax that came with the spokes, so I ordered 14mm black brass polyax to build the wheels.
    Packing tape is 100%, the small strip over the spoke holes is easily enough. Just waiting on new brass DT's to rebuild my other set.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  69. #269
    Feb 2006
    Anyone have an update regarding the 65mm rims yet?
    Got my bonus this week, perfect time for new wheels....
  70. #270
    Fat & Single
    Got a fakebook account Shark ? Have a look there, the Nextie Bike page is updated regular by the nextie blokes and they answer questions promptly... I think a mate of mine asked only the other day, can rem the response.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  71. #271
    aka bOb
    And we get to drink when someone asks the question. It's a fun game try it out!!
  72. #272
    Feb 2006
    I sent an email on website and got reply in under 5 mins. They said pre order rims would be shipping next week. Under 520 grams. Nice
  73. #273
    Apr 2014
    65 mm rims and spec on these Facebook page
  74. #274
    aka bOb
    Fighting the urge!!!
  75. #275
    How come when I go to the Facebook page the latest update is from October 2013?
  76. #276
    Feb 2006
    Quote Originally Posted by Slow Danger View Post
    Was wondering the same thing.....
  77. #277
    aka bOb
    Did you friend them? Brian has it set up as a personal page, I think?
  78. #278
    Feb 2006
    No, I don't do fb, tried to get my wife to go on the page, she wouldn't "like" them for me lol. I ended up emailing instead
  79. #279
    Quote Originally Posted by mortenste View Post
    Have to be friend.
    Will you post up what you found about the 65mm rims here? The specs and price and whatnot. Whatever has shown up on the page.
  80. #280
    Apr 2014
    Have to be friend.
  81. #281
    Apr 2014
    No price yet,520 grams.
    Attached Thumbnails Attached Thumbnails Nextie-Bike carbon rims-img_20140728_171327.jpg
  82. #282
    Aug 2005
    next are 50mm 29" rims
  83. #283
    Feb 2006
    Joined the nextie club.... Now I wait
  84. #284
    Apr 2014
    My 2.5 40mm just landed. So sweet! Cant wait to make some custom decals. couldnt design or make up my mind at the time of order.. Finish is quite nice! Just waiting on my damn spokes.
    Sorry fro crashing the FAT party BTW! lol
    2015 Nomad.
    Wrenching 18 yrs.
  85. #285
    Sep 2013
    Which length of spokes are you guys using with Hope fatsno 135/190 hubs?
  86. #286
    Fat & Single
    Built 2 sets of 135/170 to fatsnos, 244mm all round. The front will be the same obviously, back will be slightly longer.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  87. #287
    Oct 2011
    I'm getting ready to build a 135/170 wheelset. Do you mind telling me which spokes and hole size you selected? Order page for the 90mm Wild Dragon rim offers a choice of 4.5mm, 2.3mm, and 5.7mm holes for different nipple types.
    I also have to decide whether to go with stealthy black fatsno hubs and UD rims or maybe sparkly blue hubs and blue painted rims to complement the blue accents on my 2013 Aluminum Beargrease.
    That lime green paint is awesome but I just don't think it will go with the blue on my Beargresase. Opinions?
  88. #288
    Feb 2006
    I did black hubs last time around because the shop said they were quicker to get, or maybe they had a set kicking around already.....
    boring! lol....
    I am doing silver hubs this go-around. Shiny, and goes with any color
  89. #289
    Apr 2014
    For those of you wanting the Not so Fat fat rims. Here's the 40mm weights I received.
    Got mine Tuesday.
    Removed the decal on one. Matte, no decals, 28H. Just waitin on my darn spokes and nips!!!!
    Attachment 912216Attachment 912217Attachment 912218
    2015 Nomad.
    Wrenching 18 yrs.
  90. #290
    Fat & Single
    Quote Originally Posted by FrY10cK View Post
    The spokes i have on the 2 sets are Sapim CX Rays and DT Comps. The nipple holes are just the regular 4.5mm, 2.3mm is for internal nipples and i have no idea (without googling it) what 5.7mm is used for.
    Black hubs are a safe choice, I dont really do much bling colour as if it doesn't match it looks like a dogs dinner... dont mind going another completely different colour, I try to keep things simple with black/silver components then there's no clashed colour issues. Nothing worse than 3 reds/blues/purples that dont match, there's is such a thing as trying too hard.
    BTW, just ordered black DT Brass nipples to rebuild the yellow set of wheels, there's a lot of water gets inside the nipple chamber... in my case its seawater and the alu nipples will corrode quite quickly being exposed to a wet and salty environment.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  91. #291
    Fat & Single
    White or yellow rims an option for your blue beargrease ? Post a pic and we'll give you opinions
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
  92. #292
    Oct 2011
    Mine will see some road salt so brass nipples it is. All good info thanks.
    White or yellow rims? Maybe I'll photoshop a mock-up and post it.
  93. #293
    74 & 29 pilot
    Reputation: MTB Pilot's Avatar
    Oct 2010
    UUUUUUUMMMMMMMMMM! A couple of weeks!!!!
    MTBP
    "GIVE ME LIBERTY OR GIVE ME DEATH!"
    Turn on the truth: http://www.ronpaulchannel.com/
  94. #294
    Reputation: Johanneson's Avatar
    May 2012
    [QUOTE=ozzybmx;11317655]
    I've wondered about this with the double wall construction. Have you been able to blow it out with a compressor or what? Not that you have to worry about it but a big block of ice in a wheel could be a drag as well.
  95. #295
    Feb 2006
  96. #296
    Apr 2014
    Nextie 650b 40mm Wagon
    For those of you on the 40mm wagon. I built mine up and found the ERD to be closer to 544 than 547 as specified by Brian. I had just enough to work with with my spokes but was close!!
    Profile of rim seems to be a bit different than the sample image provided by Brian as well. but looks descent to me!
    The HRII are not as squared off as much as I had thought they'd be from people's feedback and the fact the rim doubled in width! I'll run them for a while...
    Built with CX-Rays and Sapims locking nipples.
    I may recommend a longer than 35 mm valve though. Not much left for pumps to grab.
    21 mm wide Stans tape.
    Seated easy peasy!
    2015 Nomad.
    Wrenching 18 yrs.
  97. #297
    Feb 2006
    Look good!
  98. #298
    Apr 2014
    Waiting for my 65 rims and tune hubs,1 week or 2 i get my bike rolling
  99. #299
    Reputation: bikefat's Avatar
    Nov 2013
    Wow dfiler, those are not rims I would be happy with. I'm pretty fed up with waiting for my Carbondales but if the Nextie rims look like this, raw, I'm still looking.
    I'm in the same boat. I've been wanting Carbondales for months, now I see Borealis shipped different rims to most Yampa buyers. Their website now says Carbondale rims "coming soon" with a product pic showing a "v2" graphic and speccing 85mm, not the 80mm examples which do seem to have gotten out there in limited quantities. But, only on prebuilt bikes? I don't see anyone who's gotten the first Carbondale aftermarket, certainly weren't attainable for me even after placing an order through my LBS.
    These Nextie rims are looking more attractive the closer we get to the snow flying (July's the only month I haven't been snowed on in the CO rockies), as they have the snow-shedding "section" and (apparently, now that it's fixed) easy tubeless setup which attracted me to the Carbondales in the first place.
    I'm starting to feel let down by Borealis, wondering if I should wait for them to get their act together, or order Nexties now so I'll at least have a wheelset for my Alubooyah build come winter? What to do...
    Denver Broncos: 101-3 since 1975 when scoring 30+ at home.
    C.J. Anderson career YPC = 5.67
  100. #300
    Reputation: dRjOn's Avatar
    icdesign: what tyre is that? it looks mahoosive!.....nice wheels!
  1. Carbon rims...
    By mattsavage in forum 27.5
    Last Post: 01-10-2016, 08:15 AM
  2. The New Carbon Rims vs Surly Rims For Offset Use?
    By Sand Rat in forum Fat bikes
    Last Post: 10-06-2013, 11:08 PM
  3. Carbon rims: which?
    By bmxconvert in forum All Mountain
    Last Post: 05-30-2012, 07:23 PM
  4. Carbon Rims
    By speedyd in forum Wheels and Tires
    Last Post: 04-04-2012, 10:44 AM
  5. Replies: 75
    Last Post: 01-13-2011, 03:09 PM
Members who have read this thread: 317
