Page 18 of 18 FirstFirst ... 81415161718
Results 1,701 to 1,708 of 1708
  1. #1701
    Reputation: Kirkerik's Avatar
    Apr 2016
    Quote Originally Posted by mikesee View Post
    That quote doesn't begin to explain nor address the off-angles that so many of the early Nextie's were drilled at.
    I'd like to believe they've sorted it -- but when they toss out trope like that, not even acknowledging the original problem, the last thing I'm going to do is look the other way.
    It does suck they were putting out questionable product (spoke drilling angle) in the beginning. I'm just passing the info i rcvd along.
    My 65mm Black Eagles that i bought last winter laced up real nice. No weird angles FYI
    The tires are the things on your bike that make contact with the trail.
  2. #1702
    1:18
    Reputation: Corvette's Avatar
    Quote Originally Posted by Kirkerik View Post
    My order arrived in about a week/week and a half from what i recall. In the u.s.
    I,d give nextie an email
    They're responsive, but sadly that doesn't help moving the packet forward. It's still stuck somewhere between China and Europe, with no tracking movement since beginning of August - 2 months now.
    Nextie has suggested sending replacement rims so let's see how this works out... Will post an update.
  3. #1703
    Apr 2016
    Can anyone share their measured ERD on the Xiphias 85mm rim?
    They list it as 542mm.
  4. #1704
    Music & Bikes
    Reputation: fokof's Avatar
    I used that number on mine and got the right lenght.
    The number looks right.
    "There is a big difference between kneeling down and bending over" -FZ
  5. #1705
    1:18
    Finally got the rims after more than 2 months of waiting Nextie was responsive during the whole time, but no idea why the courier too so god damn long.
    Long story short, Xiphias' are being built soon. My measurement for ERD was 543 mm, but the spoke length change is minimal compared to officially stated ERD 542 mm.
    For given width they're pretty light, but also with noticeable flex when being squeezed together. Should be fine for snow usage though. Tubeless with Vanhelga inflates OK, just a bit of soap needed.
  6. #1706
    Apr 2016
    Quote Originally Posted by Corvette View Post
    Nice! Glad you finally got your rims!
    Squeezed across the circumference or the cross section?
  7. #1707
    Apr 2016
    So i have some 65mm already and I'm in the budget for a wider pair of rims.
    85mm is a good and little bit lighter all rounder but the 105mm would offer max float.
    Knowing I have the 65's would you folks have more use for 85's or 105's?
  8. #1708
    1:18
    @Kirkerik: yeah It was an awful long wait, but at least the guys are responsive.
    Flex is noticeable when squeezed across the circumference. After all, it's a 85 mm single wall rim with only 520 g. Can't really compare it when you have the same weight rim in a 35-40 mm package for MTB. Those are considerably stiffer.
    If you already have 65 mm my take would be 105 mm for snow & float. Depends on your frame, I'm a bit limited with clearance so I went with 85 mm.
  1. Carbon rims...
    By mattsavage in forum 27.5
    Last Post: 01-10-2016, 08:15 AM
  2. The New Carbon Rims vs Surly Rims For Offset Use?
    By Sand Rat in forum Fat bikes
    Last Post: 10-06-2013, 11:08 PM
  3. Carbon rims: which?
    By bmxconvert in forum All Mountain
    Last Post: 05-30-2012, 07:23 PM
  4. Carbon Rims
    By speedyd in forum Wheels and Tires
    Last Post: 04-04-2012, 10:44 AM
  5. Replies: 75
    Last Post: 01-13-2011, 03:09 PM
Members who have read this thread: 290
