Page 5 of 5 FirstFirst 12345
Results 201 to 217 of 217
  1. #201
    Other option besides split tube would be put on additional wraps of gorilla tape cut to full internal rim width. That worked for mine.
  2. #202
    Quote Originally Posted by tri-tele View Post
    Thanks. I *may* have finally gotten it. I put a 12V portable compressor on it and just let it run and run, until every leak sealed. I'll know in the morning after it sits all night. I used my LBS compressor yesterday but kept trying to chase the last few leaks with my floor pump. Mistake! Gotta pick up a compressor for the garage now I see.
  3. #203
    Dec 2010
    Quote Originally Posted by sasquatch rides a SS View Post
    Any tubeless Dually experience with 29+ tires other than the Knard?
    None?
  4. #204
    Not sure there are any other tire options out there in the real world just yet other than the trax and the knard.
  5. #205
    Dec 2010
    Handful of protos out in the wild already
  6. #206
    A guy I know has Duallys on his custom carver, and has had great success with tubeless using one layer of gorilla tape. I have no idea what he actually did with the tape, but I ride with him every once in a while and it seams to work great.
  7. #207
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Split tube W/ HuDu for my summer wheels.
  8. #208
    SVO
    SVO is offline
    Reputation: SVO's Avatar
    May 2005
    Quote Originally Posted by jonshonda View Post
    Cut Gorilla Tape to match rim bed width while still on roll. One layer, wall to wall, does it.
  9. #209
    Must build all the wheels
    Reputation: chriskmurray's Avatar
    Dec 2013
    None?
    The Chronicle works amazing set up tubeless on Duallys. Knards can be hit or miss on initial sealing but every Chronicle we have set up has snapped into place and did not loose a drop of sealant at the bead, unlike the Knard which can spew sealant out of the bead until you get past the initial seal/ride sometimes.
  10. #210
    Reputation: TahoeBC's Avatar
    ^^^ Thats music to my ears, by the time I can buy them I'll probably be fully back to fat tires for the winter, sure wish the Chronicle would have gotten out to consumers at bit earlier but looking forward to shreading on them next summer.
  11. #211
    Dec 2013
    Quote Originally Posted by TahoeBC View Post
    It will be worth the wait!
  12. #212
    nice! this is what I'm thinking of going with Dually and HuDu (my current tire). Did you attempt other tubeless ways other than the split tube?
  13. #213
    sluice box
    Oct 2013
    Quote Originally Posted by JRockF3 View Post
    I just did the split tube and called it a day. 24 inch presta Qtube and one small bottle of Stans with a good floor pump. HuDus are 120 tpi folding bead. I have not burped the tires or rolled the tires with single digit psi riding.
    I put my Uma 90s back on with studded Bud and GC for the winter riding now.
  14. #214
    Any recommendations on what size/type compressor I should buy for my next tire change? I have been looking around, I don't want to spend a ton but want to be sure it has enough umphh to seat the tires. Just a dude working out of his garage. Thanks.
  15. #215
    SVO
    SVO is offline
    May 2005
    Quote Originally Posted by fatlip11 View Post
    Small ones work fine. Porter Cable pancake is about $100. Remove the valve core to seat the bead. Skip the cheap junk (Harbor Freight).
  16. #216
    Thanks SVO just the info I was looking for. Probably pick one up this weekend. Appreciate it.
  17. #217
    -bustin punks
    Reputation: fatchanceti's Avatar
    Jan 2005
    "skinny" wheelset for the Beargrease. I9s and Dually's. Endcaps arrive today to try the rear on.
    Yeah they are a little tall with the Knards on there. Planned to run a 2.4 Ardent or Racing Ralph, maybe some SuperMotos.
  1. Light "click" or "snap" or "clunk" when pressing down hard on pedals
    By VFXterra in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 07:37 AM
  2. Replies: 6
    Last Post: 07-14-2013, 04:38 PM
  3. wet red rims 29" 32h, Velocity Blunt SL classic red anyone?
    By badbushido in forum Wheels and Tires
    Last Post: 05-25-2013, 06:55 AM
  4. Replies: 3
    Last Post: 03-01-2013, 10:15 PM
  5. Shimano XT Niner 29" Velocity Blunt
    By millsj2 in forum Wheels and Tires
    Last Post: 01-25-2011, 06:19 AM
