Results 1 to 92 of 92
    New studded fat, 45 north.
    Wrathchild, aggressive 26x4.6, wide spaced big lugs, concave studs.
    Looks like a nice tire - in particular the deep and open tread looks like a big improvement on the D5, but the tubeless ready part makes me sad. I have yet to see a tubeless ready fat bike tire that doesn't roll like I am dragging my brakes when it is cold (like <-10f ). Perhaps that is a small part of their market..
    Human Test Subject
    Reputation: Volsung's Avatar
    Thanks for going through the trouble to provide a picture and link.
    Wrathchild | 45NRTH
    You change your own flats? Support your LBS and pay them to instead.
    Reputation: brentos's Avatar
    Dang, if I had known this was coming, I would have kept my Beargrease. Sold it to buy a bike that could fit studded D5's. (Assuming these are a bit smaller than D5s, and would fit the Beargrease)
    They are supposed to be slightly bigger:
    http://45nrth.com/files/pages/20162_..._Update_VF.pdf
    Reputation: Jeff_G's Avatar
    Oct 2015
    Still can't find the XL studs anywhere. Anyone?
    "At least I'm enjoying the ride"
    16' Trek 8.4 DS
    16' Farley 7
    and I'm OK admitting..
    16' Sturgis
    Minneapolis MN
    Reputation: jpfurn's Avatar
    Oct 2014
    Quote Originally Posted by brentos View Post
    Studded D5's fit on my Beargrease even on hundos!
    Sep 2013
    Quote Originally Posted by jpfurn View Post
    Plenty of room on Beargrease with 80mm wide rims!!! Flow and Dunder fit with room to spare as well. I assume the Wrathchild will fit too...
    Quote Originally Posted by spruceboy View Post
    Isn't everyone running tubeless? Less rolling resistance and not dragging a 1 lb tube in rotating weight? Seriously, what am I missing to your post? I get they have a thicker casing. It's a 4.6" tire at 4-8 psi? Rolling fast? I guess all my fat bike tires are tubeless ready and have only run tubeless. Regular tires with tubes are better/faster/ less draggy?
    Well, damn. 1x11 standard chainline? My measurements indicated it may and should work, but some other posts and threads had me believing it wouldn't.
    At least the new bike is sweet too...
    Quote Originally Posted by leeboh View Post
    I am not sure why, but all the "tubeless ready" tires I have tried (several v-rubber tires, bontrager's barbegazi, and a maxxis tire) all roll really slowly at cold temperatures. Slower than a tubed "normal" fat bike tire, and slower than a tubeless "normal" fat bike tire. This pretty much does away with any advantages of the tubeless part.
    I don't know if it is the thicker casings, different rubber, or whatever - I just know they ride slow in the cold. And it isn't just me - the LBSs in my area have stopped stocking tubeless fatbike tires just for this reason.
    I don't think it is a big deal if you don't ride in cold temperatures. However, where I live, in Fairbanks Ak, it is cold at lot, and having tires that are boat anchors when it is cold isn't fun.
    EDIT: By cold I mean colder than -10f. The colder it is, the more noticeable the difference is.
    Last edited by spruceboy; 09-08-2016 at 01:21 PM. Reason: clarifying what I mean by cold .
    Anyways, looks like a pretty cool tire. Might pair this up front with a studded D5 rear, for lower rolling resistance...
    I do wish they sold a non-studded version, because it is MUCH cheaper to stud them yourself.
    Oct 2015
    Hmmm......
    I think I'll try to do some sort of semi controlled test of my Barbi's soon.
    Paved hill, 10 psi, same weight and get a high mph reading at 70f and 0f before I swap them for studs.
    My uneducated seat o the pants meter was shocked at how much faster I felt when I went from tubed and studded D5's to tubeless Barbis last spring.
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
    Ya, that's what I'm thinking too although I normally like having both tires as similar as possible for more predictable cornering.
    Darn you 45NRTH!
    Jul 2014
    Glad they won't fit on my Bucksaw or I'd have to buy some new tires to try
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    The Wrathchild looks wicked. But thankfully for my pocketbook, I'm still running a perfectly good pair of studded D5s for winter, and they've been great.
    And as much as I think 45N is generally a good company, I'm just going to say it - I think it's totally lame that they are not offering non-studded versions of their tires anymore.
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Interesting. I have been rolling Jumbo Jims (liteskins) this summer they are not marketed as tubeless ready, but they are super easy to set up tubeless and don't lose a drop of sealant. They also have WAY less rolling resistance than any other fat tire (including Floyds). I am strongly considering studding them this winter, but I wonder how they'll really do in cold weather compared to the '16 Dillingers.
    --Peace
    Quote Originally Posted by Lars_D View Post
    Interesting. I have been rolling Jumbo Jims (liteskins) ...They also have WAY less rolling resistance than any other fat tire ...I am strongly considering studding them this winter, but I wonder how they'll really do in cold weather compared to the '16 Dillingers.
    FWIW, I've had similar thoughts to stud the Jumbo Jims. My experience is that, at least for the 2015 4" versions, the non studded JJ did better than the non studded D4.
    AK? Real winter. Boston, MA area rider here. Rubber durometer issues? I run the v rubber snowshoe, D4's, hodags and the Spec. fast track. My cold is not that cold usually. Maybe 10-30F. Lots of freeze thaw here. But rarely that cold. Some rubber science behind this? Any engineers on board?
    Has anybody seen a claimed weight for these?
    Anchorage, AK
    What method did you use to stud them?
    --Peace
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Riders of winter know, studs ain't just for ice. Any tire I run as a winter tire has got to be studded, for powder, roots, hard frozen/frosted dirt, ice, and everything else. Disclaimer: I live north of 45 degrees
    I just have to disagree with this a bit. I totally get riding with studs in the winter for those icy spots that always come up unexpectedly. No real downside to running studs for sure. But for me and how I ride they do not add much in softer than ice conditions. I am not disputing that they do for you, just saying not all riders of winter have the exact same experience.
    Latitude 61
    Norđwegr
    Reputation: Vegard's Avatar
    I'm at 69*, I don't disagree with what you're saying; but I don't see it as a requirement
    WTB an Ibis Ripley frame, small or medium.
    NORWAY
    rth009
    May 2010
    Quote Originally Posted by sryanak View Post
    Agreed. I have not seen any benefit to studs other than on ice, but around here there are few roots and they are usually covered in snow by the time ice is an issue. There's certainly no downside to studs on snow except for when you have a long section pavement showing through. I end up driving to the trailhead more often in the deep winter because of that.
    Along these lines it's getting dark earlier ... ice and darkness will be here soon
    Rippin da fAt
    Werd. @ 10k' elevation and the only ice is under 6+' of powder, I have not witnessed an improvement to having studs. I'll be down to the desert come freeze/thaw season...
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Anyone know about price and availability? These aren't showing up on QBP.
    Jason
    Disclaimer: www.paramountsports.net
    Quote Originally Posted by BansheeRune View Post
    If it's always powder, I wouldn't see much benefit, except that powder falling on a hard surface compresses and I do feel I get some traction boost, but it depends on the powder(how much) and conditions.. Since it's below freezing for all winter here and the ground is always well below freezing (even if the air is above, whatever falls will eventually freeze into ice), it makes a lot of sense. Trails get packed from XC ski use, from foot traffic, and everything else. It's far from "glaze ice" or "solid ice", but you get a ton more traction with the studs, allowing you to lean the bike over in turns and generally have far better control. And then there are the mixed conditions, sometimes involving roots, etc. They just do better everywhere IMO. I have a feeling some of the conditions people are using fatbikes in involve a lot of above-freezing slush, the occasional snow-storm, and so on. In those conditions, yes, probably of marginal use, but in a cold climate, every day and sunday. When the trails get real hard (again, not necessarily solid ice), some people break out the skinny bikes with studded tires. Back in the day, that was the thing to do, fatbikes are far more popular here now and it's a lot easier to grab that "one bike that works all the time" in the winter anyway.
    I just deleted a bunch of my winter videos for some new uploads, but here's one of the races, this one happened to be on snow-machine trails for the most part:
    Damn, makes me want to ride my fatbike on snow right now!
    I would agree - I think the studs only help on ice, but on ice they are pretty magic.
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Love it Alaskans debating snow and ice. I agree with Jayem. My studs help bite wet slick or frosty wood boardwalks, frozen ground (you know the wet mud that freezes into unworldly miniature ice coulombs) and snow that is compressed so firm that anyone outside of a ski resort would call it ice (Alyeska would call it packed powder). I may pick a pair of these up.
    A previous poster said that would run these up front and D5 out back. I was thinking D5 up front and Wrathchild out back.
    You know for the dig dig bite.
    ptarmigan hardcore
    Feb 2015
    Quote Originally Posted by JAGI410 View Post
    fat-bikes.ca has them available on their site for pre-order only, price is listed at $359 Canadian.
    Other sites have them listed as well, apparently $249.99 , which is pretty reasonable, all things considered.
    An example:
    45Nrth 26X4.6 WRATHCHILD 120TPI STUDDED FAT TIRE | Bike Tires | ERIK'S
    An example:
    For brand new to the market studded fat tires from a mainstream company...yeah, it's always disappointing, but you get over it on the bike. Studded fat tires for winter are one of the few things I can actually say was worth it to spend that much on, as compared to things like cranks where you can spend $500, but it doesn't perform 3x better than one that costs 1/3rd the price, or some high end $150 XTR pedals vs $35 PD-520s, you might save weight, but the function is essentially the same. Not so much with these for winter, at least round these parts.
    This is what I think of when I keep hearing the name for these tires:
    Reputation: AlaskaStinson's Avatar
    Jun 2012
    If this Fairbanks winter is like last, we won't get much cold weather riding.
    I remember a quote in the News Miner, I think it was from Rocky. "The most expensive studs are cheaper than the cheapest emergency room visit".
    My JJ LiteSkins seemed pretty good down to -20.
    I have unstudded Jumbo Jim Lite Skins, I end up walking through a lot of overflow/glaciered areas that I could easily ride. My MTB has studs for Fairbanks winter commuting. This winter I'll stud up the Fattie.
    “Maybe, just once, someone will call me 'Sir' without adding, 'You're making a scene’.” -H.J. Simson
    Quote Originally Posted by AlaskaStinson View Post
    I was driving a G-car in Fairbanks this winter and noticed it slipping some on the roads. I thought, "what?" and got out to take a look...no studs? It's ironic that the G-car in Fairbanks had no studs yet our G-cars in ANC have studs. I realize when it's super cold, like -40, you have pretty good traction without studs on the roads, but that just isn't all that common anymore and at the more common mean temp, you can definitely benefit from them and it can be quite "sporty" without them, vs. here in ANC where all the downtown roads were generally clear all winter and studs were of little use on the cars much of the time. Just kind of opposite of what I'd expect with the temps, vs. what has worked in the past.
    Man I hope it doesn't rain again this winter...
    sluice box
    Oct 2013
    fixed it for you.
    ....snip
    Man I hope it doesn't rain dead birds again this winter...
    I would like to see some 45nrth tires named after Steel Panther or Zeke songs. Like "Dolphenwulf" "gloryhole"
    ptarmigan hardcore
    Reputation: kntr's Avatar
    When will the Wrathchild be available?
    Does anyone have pics of the XL stud next to the standard stud?
    Rippin da fAt
    Yay! Vaporware has arrived once more!!
    It would be great if more companies operated like Santa Cruz. They announce a new bike, and voila, it's available the next day. I realize it's tough to keep things under wraps when they are already in production, but come on, these are fat bike parts not iPhone 8's!
    Rippin da fAt
    Pfft! We couldn't be so fortunate. The thing is that the mfg's will do an announcement and a few prototypes to get a feel for the market acceptance and interest in a given product before launching full production.
    Jul 2015
    I really like the idea of the wrathchild but I wish they would put out a D5 w the xl studs. I don't need a more aggressive lug pattern but I do need all the traction I can get on ice. I really like the low rolling resistance of the D5, looks like the wrathchild would be good for serious winter singletrack, maybe not so hot for long distance winter bikepacking. Just some thoughts.
    Om Mani Padme Hung
    Sep 2012
Name:	Screen Shot 2016-09-08 at 9.57.25 AM.jpg
    Start the feeding frenzy. 45nrth tires are hitting dealers. Of course they started with the two "retread" tires people are least excited about (tubeless versions of Husker du and studded Dillinger 4) but hopefully the Wrathchild isn't far behind. If you want a pair of Wrathchildren and live in the snow belt, start calling your LBS daily
    Oct 2015
    My LBS said Wrathchild will be late and in very low quantities. And no Dillienger 5's in stock yet. "November sometime"
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
    Quote Originally Posted by Jeff_G View Post
    Ours has a wait-list. Way too many people signed up so far...Glad my 5s seem to be going strong on their 3rd season.
    New tubeless D4Ss
    The new cornering knob seems to be the biggest difference. Hard to tell if the knobs are any bigger, as my D5S is kind of worn.
    LBS weighed all of the new D4S tires and gave methe two lightest ones. Oh, how well they know me!
    New studded fat, 45 north.-0118a7093eb091279b7640c4bcf3cf15dfa90f4a9e.jpgNew studded fat, 45 north.-0188a1dbb633e3166e98c3bbee552465b2caf4138e.jpg
    Old D5S for comparison.
    Jayem.....what do the new D4's weigh in at?
    Sep 2012
    Quote Originally Posted by the mayor View Post
    I've heard they're around 1368 grams
    Sep 2012
    (written on the side of the box here)
    Quote Originally Posted by Willum View Post
    D'oh! Thanks for pointed out the obvious ( which I obviously missed )
    The other was 1341, but the shop said some of them weighed a bit over 1400.
    For reference....I have 2 new original D4 studdeds( concave)....they weigh 1343 and 1348 with packaging.
    Good to see 45NRTH didn't add a ton of weight while going Tubeless
    Is the Wrathchild available yet?
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    Guys with D4's.... I assume 120 tpi version?
    And question on 60 vs 120 tpi.... Doesn't the former have steel carbide studs, while the 120 use aluminum carbide studs? Any issues with durability/wear on the aluminum carbide studs?
    Santa Cruz Hightower LT
    EVIL Following
    Quote Originally Posted by LCW View Post
    Not steel? First I've heard of this. Pretty sure they are steel. I did lose a stud already from the D4s, running them off and on for just shy of a week. Have not lost a stud on the D5s and this is their 3rd winter. My D4s and D5s are 120 tpi.
    Well, checked the website and lo and behold, they are saying aluminum carbide. I guess they do well because this is the 3rd season on the D5s. I don't commute to work unless there is snow or ice on the ground, but the occasional pavement section doesn't seem to hurt them. Even when there's no snow on the trail doesn't seem to matter, roots, some rocks, etc, they don't seem to hurt the studs. The fat tires spread out the weight a lot, so it's rare to have a problem. Constant use on pavement will grind em down.
    I thought the D4s would be better on ice than the D5s, being narrower and putting more pressure on the studs. So far, I'm not detecting this. The D5s seem just as good, if not better. Not that either is bad, they are both quite good for a fat tire.
    wraithchild is next year territory
    LCW
    LCW is offline
    I wondered this - if the narrower studded D4's had more bite than D5's. Your comment seems to counteract this. Very odd.
    I'm debating getting studded D4's as studded D5's are nowhere in sight.
    EVIL Following
    Quote Originally Posted by jeffscott View Post
    When? How did you hear this?
    LCW
    LCW is offline
    Did 45NRTH pull the tubeless ready version of the D5's from their site? I swear it was there unless I'm dreaming. Only the old style non-tubeless with the older corner knobs (vs the new shape as on the D4's).
    EVIL Following
    Feb 2015
    I don't recall reading about any changes to the D5's for this year, I believe that it was only the D4 and Husker DU that received updates.
    '07 Spec Enduro
    '14 Salsa Mukluk 2
    '16 Salsa Bucksaw GX1
    LCW
    LCW is offline
    Quote Originally Posted by Fat-in-Fundy View Post
    You're probably right. I just find it odd that they wouldn't have updated the D5 to be tubeless ready, when they cleary have the ability (Flow/Dunderbeists, Wrathchild, are said to all share same casing).
    EVIL Following
    Ok, I have the tubeless D4s, I run my D5s tubeless. There's no discernible difference here in the tires. Originally, my D5s were REALLY tight, but I didn't quite know how to deal with tubeless fat rims at first either. The D4 tubeless was "just right" and my D5s are "just right" as well, in terms of fit on the rim and ease of setting up tubeless. Both can go on with a floor pump. Maybe there's a difference, but damn if I can tell. I really can't think of how the D5s could be "more" tubeless ready than they already are, mainly it's the rims that would be the problem IMO, non-tubeless rims may be unacceptably loose.
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    I agree with Jayem. I have D5s and original Dillingers and run them both tubeless with no issues. IMO one of the biggest advantages of carbon rims is how easily they are to set up tubeless.
    Reputation: Dilligaff's Avatar
    Nov 2015
    I have always run my D5's, and other tires, tubeless without a problem.
    Nothing to see here, move along folks.
    The Dog.
    Reputation: Dogdude222's Avatar
    Aug 2005
    FWIW, the tubeless beads on my Vanhelgas have proven far more reliable, particularly at low pressures on my HED Big Deals than my non-tubeless D4's which would weep and slow leak for a long time.
    LCW
    LCW is offline
    As many as I hear that have success with the non-tubeless, there are just as many report issues like dogdude222.
    I run Flow/Dunderbeist now with good tubeless performance on my Other Brother Darryl rims.
    EVIL Following
    Reputation: geop's Avatar
    Jun 2015
    I planned to buy Dillinger 4 studded for a fast roller for mostly singletrack. I hear the Dillingers are not great in soft / fresh snow so I have asked some of the local dealers. Most say Dillinger but all agree not the greatest for soft snow. Two are personally running Dillinger in front and Bontrager Gnarwhal studded in the rear. Gnarwhal has decent rolling resistance but have bigger lugs for soft snow. They are a 3.8" tire but may be the ticket for a great all-round setup for Canada West. Thoughts?
  67. #67
    The Dog.
    Aug 2005
    Quote Originally Posted by geop View Post
    I always want bigger lugs in front. Sure it sucks when you cannot get moving, but it sucks more when you wash in a corner and eat a face full of snow. This is why I avoid running by D4 studs whenever I can in favor of my Vanhelgas.
    I was really looking forward to the Wrathchilds, but typical 45nrth vaporware.
    I did like my Hodag's, but found that the Bontrager casing was way too stiff for the price. This contributed to annoying self steer.
  68. #68
    LCW
    LCW is offline
    Any try the Terrene Wazia? It's available as studded or studdable, 4.0 and 4.6. Tread looks like a good all-around tread.
    EVIL Following
  69. #69
    sluice box
    Oct 2013
    yes
    New tire company, Terrene Tires
    ptarmigan hardcore
  70. #70
    Sep 2012
    FUMBLE! Latest word is that Wrathchild will ship in January WITHOUT STUDS. Can stud them yourself, but the XL studs won't be available.
  71. #71
    My other ride is your mom
    Reputation: Maadjurguer's Avatar
    I have some Wrathchild studded on pre-order and was informed a few days ago that the sales director for 45NRTH informed the shop of some minor issues with getting the tires off the production line and that there would be a very limited quantity available this year with a delivery timeframe pushed back to late January for the rest of us pre-order folks. I have not heard anything about them shipping without studs.
  72. #72
    Oct 2015
    I got it straight from the horse's mouth.
    45North D5, XL Stud, Wrathchild Availibilty Info
    16' Trek 8.4 DS
    16' Farley 7
    16' Sturgis
    Minneapolis MN
  73. #73
    fat guy on a little bike
    Quote Originally Posted by kntr View Post
  74. #74
    Quote Originally Posted by Rodney Jekyl View Post
    Its not in studded form.
  75. #75
    i will take it unstudded.
  76. #76
    My Wrathchild arrived today. I intend to use studs in all stud pockets on this tire and pair this with a custom studded D5 in the rear.
    The casing appears to be the same as the D5, brand new bead to bead measurement is 244mm.
    About 130 grams lighter than the D5.
    First ride should be tomorrow night, the tire looks promising.
  77. #77
    looks awesome. thanks for the update! let us know how she performs.
  78. #78
    I only got one short ride in, it was on soft broken up snow and ice.
    So far so good, the tire seems to track straight and true on really loose surfaces. It has less self-steer than the D5 (which isn't bad to start with). It punches through slushy snow and grab the surface underneath. The studs also seem more effective on ice than the D5, they stand proud of the tread a more, and the base blocks see more rigid. I didn't notice anything that I didn't care for.
  79. #79
    Reputation: Kirkerik's Avatar
    Apr 2016
    Anyone else have any chance to try these, either studded or un-studded? Not only on snow and ice but even on dirt?
  80. #80
    Sep 2015
    I wasn't sure which thread to post this in but I saw the XL studded Wrathchild on the shelf at my LBS yesterday. The studs are defintely larger.New studded fat, 45 north.-wc-xl.jpg
  81. #81
    Ambassador of Chub
    Jul 2015
    Quote Originally Posted by Kirkerik View Post
    Just mounted up a pair on 80mm Mules, and I'm waiting on some studs. Stay tuned...
  82. #82
    Ambassador of Chub
    Jul 2015
    FYI - I've had these mounted and pumped up pretty hard on 80mm Mules for a week now, and this is what I'm getting for max tread width:
  83. #83
    Nov 2015
    Wow, that truly sucks. It sucks because that's what my Nates run on Mulefuts, and those are only a 4" tire. Even my Dillinger 5's run 4.4" wide and those are too narrow at times.
    I am looking at the Wrathchilds because my wife confiscated my D5's last winter for her fatbike.
    So I stopped by my LBS today and they said they ordered 50 of the studded 26x4.6 Wrathchilds and received all of them unstudded. They did get in 5 of the 27.5x3.0 studded Wrathchilds that had the XL concave studs in them. I bought 2 because they were almost the same price as buying just the XL studs, which are $45/100pk. This works out to be $113.40 for 252 of them and the tires were $123.45 with tax. I'll pull the studs and then resell the tires at a discount to recoup some of the money since I don't have 650B.
    Anyway...here are some pictures of the XL stud next to the regular concave 45NRTH stud.
    And the dimensions are as follows:
    The original concave stud is:
    0.229" tall
    0.246" base diameter
    0.139" shoulder diameter
    0.079" carbide stud diameter
    0.175" aluminum base height
    0.054" carbide height
    XL concave stud:
    0.244" tall
    0.249" base diameter
    0.136" shoulder diameter
    0.139" carbide stud diameter
    0.173" aluminum base height
    0.071 carbide height
    I think these will work better for my hefty carcass (220#) than the narrower studs on the D5's. The D5's did not perform well initially due to the studs seating in the pocket and not having a lot of protrusion, so I used some 1/32" (0.0312") automotive fiber gasket material and put it under each stud. This (theoretically) gave each stud an overall height of 0.260", but the gasket material does compress a little, so they are probably more in line with 0.250" or so. I have not lost many despite running them this way now for over a year. They now grip like velcro and are awesome, I just find myself looking for a slightly wider tire with more aggressive tread. I hoped the Wrathchilds would fit the bill, but not if they're that narrow.
  84. #84
    Ambassador of Chub
    Jul 2015
    Yeah, I'm still hopeful they're going to perform well, even if they're turning out to be a bit undersized. Ok, more than a bit...
    Saw some of the pre-studded ones the other day. Those XL studs look downright medieval in person.
  85. #85
    Anchorage, AK
    Quote Originally Posted by Smithhammer View Post
    With tubes or tubeless?
    --Peace
  86. #86
    Ambassador of Chub
    Jul 2015
    Tubeless.
  87. #87
    Quote Originally Posted by Dilligaff View Post
    wrathchild is just shy of 4.5" mounted on an 80mm wheel.
    like you, last year i ran the D5, and in many situations i needed more tread depth. I am hoping the wrathchild solves this.
  88. #88
    Ambassador of Chub
    Jul 2015
    Quote Originally Posted by Rodney View Post
    Interesting. Was that measurement taken right after mounting?
  89. #89
    no, sitting for a month at 20 psi. well, it wnet down a bit, so i rode it around the yard to get the sealant sloshed around again, and topped it off to 20.
  90. #90
    Nov 2015
    That is outstanding if they're almost 4.5" on an 80mm since I run 100mm.
  91. #91
    Sep 2012
    I'd be curious to know if anyone has gone D4 vs Wrathchild in a race scenario?
  92. #92
    Quote Originally Posted by MichaelHumpal View Post
    short of a very sloppy race, i don't the wrathchild doing better than the d4 or even a d5.
    regardless, i have a couple hundred miles on my wrathies, and i am very happy with them. they are tougher rolling than the d4/d5, but excel in the deeper/sloppier conditions. the edge stud has saved my bacon quite a few times when getting greedy with speed on sloppy decents. #thumbup
  1. Replies: 101
    Last Post: 12-26-2017, 01:39 PM
  2. Replies: 57
    Last Post: 09-15-2016, 04:22 PM
  3. 45 North Dillinger 5 Studded Tubeless Question
    By Jeff_G in forum Fat bikes
    Last Post: 12-22-2015, 11:25 PM
  4. Hell of the North (and Heck of the North) 2012
    By jmoote in forum Eastern Canada
    Last Post: 04-11-2012, 04:25 PM
  5. Studded up BFL's
    By lancelot in forum Fat bikes
    Last Post: 01-05-2012, 03:15 PM
Members who have read this thread: 176
