Page 4 of 5 FirstFirst 12345 LastLast
Results 301 to 400 of 415
  1. #301
    Dec 2008
    Thanks Schmed, Colorado looks amazing as well.
  2. #302
    after countless emails last week with the Bike shop on checking out and picking up the Big Jon and was set on this past Saturday, the shop sold the bike before I even get there. I was all set on getting it. bummer ..
  3. #303
    Quote Originally Posted by tigerteeuwen View Post
    I got my fat Jon yesterday, I haven't really lowered the psi anything crazy yet but from what I have lowered it too... Insane amount of traction and I really love the roll over of the wider tire.
    I come from riding 700c cross and 29er so I'm used to the roll over, but with the larger contact patch on the bike its roll over is super fun!
    I am 6' 5" and the bike is an XL and it fits good though I have the seat post near its limit and I could have done with a Bit higher of a bar height though i do run my 29er with an inverted stem so I may not change anything about it.
    Can you post more pictures? Im looking to get the XL as well. Side view would be nice to see the top tube and standover.
    Reputation: BIGFAT29's Avatar
    Jun 2012
    new 2016 big jon back on ebay make offers free shipping 3 days left
    Quote Originally Posted by nismosr View Post
    Nismosr don't be bummed if you live in the us ride a size medium your new big jon is back on ebay waiting for you.heck I think they still have a large. auction has 3 days left they are taking offers plus free shipping for one of the best valued and equipped fat bikes of 2016. WINTER IS COMING .
  5. #305
    Oct 2015
    Quote Originally Posted by rideeatrepeat View Post
    I'm not quite as tall as tigerteeuwen but I have an XL Big Jon. There are some pics earlier in the thread:
    New Scott fat bike: Big Jon-1030762d1448270248-new-scott-fat-bike-big-jon-image1.jpg
    New Scott fat bike: Big Jon-1041803d1452503848-new-scott-fat-bike-big-jon-image2.jpg
    New Scott fat bike: Big Jon-1045273d1453714550-new-scott-fat-bike-big-jon-img_1014.jpg
    New Scott fat bike: Big Jon-1100348d1476692664-new-scott-fat-bike-big-jon-img_1699.jpg
    For me at 6'2" 34" inseam there's sufficient standover. The shop had a size L in at the same time and I was able to try it around the car park it felt like every other mountain bike I've bought - slightly too small.
    The XL is a big old gate at least 6'6" from end-to-end but I'm glad I didn't get the smaller size. Sizing chart if you haven't seen it:
    New Scott fat bike: Big Jon-176130_original_1.jpg
    HTH
  6. #306
    Jun 2012
    Raceface ride crank with a 30 t narrow wide ring will it work
    Has anyone did the 1x10 conversion using a narrow wide ring on a raceface ride crank with a 30t ? I want to replace my 32t with a 30t . will it work since its quite a bit smaller ? I thought I would see if I could get just a little bit more out of my lowest gear. before I buy one I was hoping to find out if the 30t would fit over the crank arm on to the spider without removing and messing with the arm or crank itself . putting on the 32t was pretty easy as it slipped right over the arm .
  7. #307
    Oct 2015
    The 30T RF n/w is available with a 104 BCD so it should fit. Whether you can slide it on over the crank arm is another question.
    FWIW the crank arm comes off very easily. When I removed the little ring I took the driveside arm off and the spindle is attached to the non-driveside so all you need to do is remove the hex bolt with an 8mm key and then use a standard ISIS puller to remove the arm. Fit the new ring, slide the arm back on and tighten the bolt.
    My own experience is that 2 teeth less on the front doesn't make *that* much difference to the riding experience. It puts the 2nd biggest cog at the back somewhere between your old 1st and 2nd (if that makes sense) and a similar reduction in 1st so it's like half-a-gear lower. HTH
  8. #308
    Jun 2012
    Thanks max . When I had the bike converted to a 1x 10 and adding the 32t a guy I know at a bike shop helped me do it on the side so it just cost me some beer.he knew more than me about the conversion so I just let him do most of it. he has since moved away to a different state so I thought I would buy a 30t and do it myself. even if its only a half gear lower Im still gonna go ahead buy one and put it on and see if I can even tell the difference. Max you are the man ! thanks again for your help and the great link.
  9. #309
    Oct 2015
    Forgot to say the crank puller you need is a Park CWP-6 but any ISIS puller will do. The retaining bolt needs to be 45 ft/lbs which is very tight but not insanely tight
    Edit: instructions are attached Ride_XC_Crank-1.compressed.pdf
  10. #310
    Jun 2012
    Thanks Max I just ordered the ring and found a source for the park tool.
  11. #311
    Jun 2012
    Just finished putting the 30t ring on .wasn't that bad of a job but did get a little help .after test ride the 2 hills that were killing me that I ride a lot in my mind and legs are a little better now with the 30t ? before when I got to the lowest gear and was climbing those hills I keep wanting to shift more even going one more by mistake as it started to shift back up. it must be better because that didn't happen on those hills with the 30t this time. maybe it was the Wheaties I had for breakfast ? I will have to ride more but it seems to be better with just a slight half tad more of lower gear.bikes a mess it got real dirty and got a flat tire.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-scott30ring-001.jpg
    New Scott fat bike: Big Jon-scott30ring-002.jpg
  12. #312
    Oct 2015
    Nice work glad you got it sorted. Sometimes half a gear makes all the difference!
    I've been riding round on my hardtail for the last few weeks and *thought* I'd gone back to the thin tyre religion but I got Big Jon out at the weekend and realised I hadn't
  13. #313
    Jun 2012
    Max Fat is where its at ! oh and some of us plus +
  14. #314
    Dec 2016
    There is a used one available here I think I am going to get it -only bad point is the non-tubeless rims
  15. #315
    Jun 2012
    There is a lot you can do if your worried about the extra weight.there are much lighter inner tubes you can buy and a few components that will save you some weight and it wont cost that much. ebay is a good source for slightly used or new take off fat bike rims.I almost bought a new take off specialized fat bike wheelset for 300.00 bucks with tires but didn't know much about if they were a lot lighter or could be tubeless.they look like dt swiss with the specialized name on them ? please post your big jon bike if you buy it.
  16. #316
    Dec 2016
    Well i bough it.... a used 2016, medium frame. I am 5f 10.5 in, could have fitted on a large according to the chart, the inseam is cleared, hard to imagine having it higher, but the top tube feels short, it is shorter than my 18 inches XC bike (26 wheels) but the bikes are so different anyway... feels a lot smaller than I anticipated, I do not feel on top but into the bike, the wheels are some much closer to the rider than on a 26 bike. Feels like a playful bike. hard to know if I will enjoy logging miles on it.
    had a little go on my favorite local trail system, the seller lived nearby.... so I could not resist. There was fresh powder, and ice under it, pretty difficult to ride, I hope it gets easier. I puked some of my lunch 20min into it.
    I don't even know how much pressure there was in the tires.
    It is a mixed system with XC skis, snowshoes, and fat bikes in the winter. I met a couple each on their 2017 big johns and they spotted my bike and said great bike
    So the trail had a thin line in the middle you could ride.
    Touch a bit on the side and you fall off trail and you are waist deep in show.
    A very small section was open/rideable, cause it snowed a bunch the night before. A good time for skis and snowshoes who could go anywhere.
    Anyway I am so excited to be able to try a fatbike, I tried renting but on a good day they are all gone... or the trails are closed because of fresh snow. I rode a lot in the winter on my kona stuff hardtail with 2.5 tires, when the conditions are good it was awesome in snowmobile tracks. So I know I had to try a fatbike after I looked at all the youtube videos. I have been dedicated to mtbiking for 10 years, some almost fulltime, until 2010. Last bike I purchased was a 2008 kona "the king" XC dually with is now a hei hei 100 thanks to frame warranty.
    ...anyway I will try a fatbike for a year on snow, rough wilderness beaches in the summer and see if I like it. That was the plan, I really could not resist, not at all.
  17. #317
    Reputation: scottspark60's Avatar
    Feb 2013
    2017 Scott Big Jon
    The 2017 Scott Big Jon looks nice!
    New Scott fat bike: Big Jon-interbike-2016-show-floor-2023-47-600x400.jpg
  18. #318
    Jun 2016
    Man those tires are massive.
  19. #319
    Dec 2016
    I agree the 2017 looks a lot nicer in person than on the webpage. There is some nice purples in there.
  20. #320
    Quote Originally Posted by Montrealrider View Post
    It's a different animal for sure but I think you got the right size. I'm your height exactly and I've got a medium as well. On the Scott 27.5+ the large was a better fit, but the large on the Big Jon was just a hair oversized. Hope you enjoy the new toy.
  21. #321
    Jun 2012
    congrats ! you will love your fat bike. the q factor takes a little while to get used to but other than that its all good.
  22. #322
    Dec 2016
    the q-factor:
    first time climbing a mountain, half hour steady climb, yeah I could feel somthing weird in my knees, it is a strange rotation.... but that was the first time I tried clipped pedals on the fattie and they were shimanos not times, I hate them.... I,ll try with times.. and flats did not give me that feeling.
    the bike:
    I had the chance of firmer snow conditions and tried well groomed trails I have done in the summer and boy that bike is fast! I could not belive how fast I went a moderate flowy downhill on snow, I mean I think I do not go as fast on my xc bike in the summer! cause I would slip on the gravel in the turns!
    I tried a very steep twisty chute and the bike was super manoeuvrable and stable.
    Living in Montreal we have a long and snowy winter and even urban is super fun. Parks and back alleys are great and the public stomps the tracks for us
    Mind you a lot of people ride 700c city bikes all winter here. Riding a fattie makes you looks like you are really afraid of slipping I guess.
    But I know how a fat bike opens up the riding in the winter now. Looks like a good week ahead of us snow wise.
    I went to a dealer for sizing. He said I am better with the medium frame but with a longer stem. I can sell the bike for a profit right now if I need to I have a buyer.
    There is a sasquatch 6.2 large here at a great price, I could swap it for 600$ more but since I am not ritch I am kind of opting to keep the big jon but I will have to upgrade some components. But that is the good side of it, having bought used I can invest some in better components. I did not ride the sasquatch but I bet I could buy it new, ride it a week and sell it for profit or even. (400$ sale) But I am way too afraid I would keep the two and bust my visa till the end of summer
  23. #323
    Reputation: tigerteeuwen's Avatar
    Jul 2014
    Still riding my 2015 Scott big John, it has been a good bike thus far, having close to 3000km total on it over the two riding seasons I have owned it.
    I have only replaced the cassette and chain for maintenance, and had the brakes bleed with CHF 7.1 which seems to help with the modulation.
    I replaced the rear tire with a maxxis Colossus, it's a good tire in some ways, being traction in packed snow, though it's heavier and doesn't offer as good of float as the scwalble jumbo Jim 4.8 that came stock, I will go back to running a Jim once I have a good excuse.
    The front derailleur is on the way out, spring has lost tension... Or something like that, doesn't want to return to position when shifting to the small ring, so I will probably replace that ASAP with an XT front post mount.
    All in all, I would definitely recommend this bike based on my km's ridden also with my general opinion made from riding with other people with a variety of other fat bikes, it's a very capable bike from commuting, to the Nordic centre in Canmore to riding some downhill in brag Creek it has served well.
    Sent from my Nexus 6P using Tapatalk
  24. #324
    Dec 2016
    Well I sold the medium, witch was too small for me. In the descents I felt I had the steerer between the knees.
    Got the Sasquatch 6.2 new on sale 500$ off, came in only 80$ more than a new big jon -also on sale. I am very confy on the large. I never could try or see a large big jon but the stand over height looks high for me on paper. Would love to try one to compare to the Norco after I ride it more.
  25. #325
    Jan 2017
    I picked up a Big Jon back in November off of Ebay. I believe the bike I bought was talked about on page 6 of this thread. (Medium at a bike shop in Florida) I finally got to ride some trails last week. This is my first fatbike, so I'm pretty new to all this. It was lots of fun to ride out in the snow.
    New Scott fat bike: Big Jon-aqggchg.jpg
  26. #326
    Jun 2012
    I had seen that ebay listing and posted here and glad you got that new big jon at such a great deal.looks like a sweet bike they are lots of fun.
  27. #327
    Oct 2015
    Yeah Big John is a cool bike I hope you enjoy it zachaput
    Having said my last fat ride was new year's eve it was dry and not too cold but since then it's been wet and our local trails have turned to mush.
    After getting the fatty in Oct 2015 I hardly used my HT in 2016. After robbing it of what I could for Big Jon I was going to sell it but somehow after One Last Ride it felt pretty good. Not as good as Big Jon obv but not that bad either especially in mud.
    And so this year I have only ridden the HT. Strava says it's a bit slower than the fatty but given the current conditions that's to be expected. It remains to be seen how close they are when the trails dry up and I get the chance to make a fair comparison.
    Gotta love bikes
  28. #328
    Oct 2015
    How's it going folks I hope you all still have your Big Jons
    I started riding mine again at the end of March and it has cleaned up on Strava. To put some values on it, it's between 10 and 40 seconds/mile quicker than my other bikes which is amazing. My Voltage FR is quicker on some descents (but not much) and my Jekyll has the edge on some twitchy climbs but the fatty is still faster from A-B
    I haven't changed anything on the fat bike since last year. I got a new 4.8 JJ after Christmas but I haven't fitted it yet the 4.0s are staying on until it gets dry and rubbly around here.
    I have grown to love the bike's simplicity. A 1x drivetrain and no suspension means I can put it away and it's ready to go next time. The BB and hubs are wearing well and the point-and-shoot Zee brakes are hardly touched.
    Given the choice I'd take the fat bike any time but I've imposed a rota so that I still use my other bikes. They're good in their own right but Big Jon is as addictive as crack cocaine
  29. #329
    Nice to see this thread still kicking. The time change couldn't come fast enough around here. I've been riding my --- off and doing stuff on this bike at 40 I wasn't doing in my 20's. I've been thinking about a Bucksaw as of late, not as a replacement but as an addition. Otherwise the Big Jon has held up great. I had a clicking in the BB that I couldn't nail down. I finally took it to the LBS and had them tear the whole thing apart front to back and re-grease & tighten everything. It hasn't returned since. The stock JJ's are holding up great as well. My only complaint is that the spacing between the knobbies seems to allow for a lot of slippage when they're wet, and one of the main trail networks I ride has a couple of creek crossings. After making a crossing I've got to be careful to choose just the right gear. Beyond that, I think I blew the lockout on the Bluto over the weekend but that's another issue... and another trip to the LBS.
  30. #330
    Dec 2008
    I guess this thread just needed a bump.
    I recently converted to a 11-42 Sunrace cassette, to go along with the Race Face 30t NW ring. Other than some Niner carbon bars the rest of my Big Jon is stock. I've owned it for over a year now but the honeymoon hasn't ended. Love.the thing!
  31. #331
    May 2012
    Guess I`ll leave my Big Jon here.
    It`s a 2017 model with a drivetrain upgrade, the rest is stock.
    The new drivetrain consists of:
    Shimano XT M8000 RD
    Shimano SLX M7000 shifter
    Sunrace 11-46 cassete
    Absoluteblack 34t oval chainring (yes, it is mounted the wrong way around, will get it fixed tomorrow)
    New Scott fat bike: Big Jon-17837792_1078775365561671_642054954_o_zpsjdp5s6ml.jpg
  32. #332
    Oct 2015
    ^^ Magaiver your 2017 bike looks great
    What do you think about the oval chainring
  33. #333
    Jun 2012
    scott big jon fat bike
    Nice 2017 magaiver. just cleaned and detailed the old big jon nice to see action on this forum again . hi max.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-fatjonnewstuf-002.jpg
    New Scott fat bike: Big Jon-fatjonnewstuf-005.jpg
    New Scott fat bike: Big Jon-fatjonnewstuf-012.jpg
    New Scott fat bike: Big Jon-fatjonnewstuf-011.jpg
  34. #334
    May 2012
    I run Absolute Black oval`s on all of my MTB`s, a geared XC 29er, a single speed 29er and the Jon.
    I`m not sure if they make that much of a performance difference, as I don`t have any way to directly compare them to a round ring. But for me, they feel great, look cool and the Absolute Black rings have superb build quality. On all my bikes when I moved to the oval rings I also made major changes to the entire drive train so everything felt different not just the chainrings.
    And you will still fall on really steep technical climbs if do something stupid and cannot unclip fast enough... I`m a master at that.
    By the way, the chainring has been flipped to the right position.
  35. #335
    Jun 2012
    guy on a fat bike competes in texas ironman
    Some guy rode a cannondale fat bike in the texas ironman last month and did pretty good considering he is on a Fat bike ! check out the aero bars on the bike.he finished 78th of 160 for the older group and finished 1854th of 2671 overall. go to Bicycling for full story.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-scott-ironman-texas.jpg
  36. #336
    Jun 2012
    Big jons on ebay
    Fyi on ebay currently there is a new 2016 medium big jon and a large 2017 big jon demo at pretty good prices.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-s-l1600.jpg
  37. #337
    Oct 2015
    Quote Originally Posted by BIGFAT29 View Post
    Looking as clean and green as ever big fella
    Here in England we have DUST:
    New Scott fat bike: Big Jon-big-jon.jpg
  38. #338
    Jun 2012
    Max all we had this past winter was dust ! it was a mild winter again 2 years in a row. there wasnt much snow at all here in good old ohio usa.again I gotta say I didn't mind. its nice to have had some mild winters for a change .not much snow is pretty rare here. the problem is not getting to enjoy the bike in the white stuff. looks like your ride is holding up well.
  39. #339
    Jun 2012
    Scott big jon fat bike pics lets see some !
    Its time again for the scott fat bike owners to post some more pics. please don't be shy.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-scotbeamup38-007.jpg
    New Scott fat bike: Big Jon-scotbeamup38-025.jpg
    New Scott fat bike: Big Jon-scotbeamup38-005.jpg
  40. #340
    Oct 2015
    New BB
    Looking good big fella wish mine was that clean
    Despite what people say I've not had any problems with RF BBs and this one has been no exception. It was a free-spinning unit right from day one (Oct 2015) but more recently 'free spinning' = 'loose' most noticeable when standing on the pedals. I was going to fit a Shimano BB (does the tube in the middle actually do anything?) but I spotted a stainless Hope Fatsno unit for a (relatively) reasonable price.
    First step was to remove the RF BB:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-35.jpg
    Drive side unbolts and pulls off:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-36.jpg
    Keep the two fibre washers between the BB and the cranks.
    Tap the cranks out:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-37.jpg
    There was a fair bit of threadlock in there but it came out easily enough:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-38.jpg
    Hope cups went in easily up to finger tight then just a quarter turn with the old BBT-9:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-39.jpg
    Cranks back in:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-41.jpg
    Stealth black:
    New Scott fat bike: Big Jon-photo%402017-05-22-08-40-42.jpg
    There was a little bit of drag to begin with but I've done a few miles over the weekend and the bearings have settled in. The feel through the cranks is good there's a solid connection to the bike.
  41. #341
    Jun 2012
    BBQ bb
    Quote Originally Posted by max gnarcore View Post
    Tap the cranks out:
    Cranks back in:
    Stealth black:
    Max , thanks for the dyi tips on the bb.very good info as my bb needs to be a little more bbq (quiet.) my big jons bb sometimes makes a slight ticking sound (mostly when standing up on the pedals) so not sure whats up or how long till it goes. I m told more grease will help but a bb upgrade in the future might be in the works. just noticed sorry for quote reply repeating your bb photos.
  42. #342
    Oct 2015
    Mine had a creak which came on during a ride and just got louder and louder with every pedal stroke. At first I thought it was the pedals so I swapped them and although the creak wasn't as loud it was still there. After a bit of experimentation with tightening the pedals I decided to drown the crank inserts in wet lube and leave them overnight, and that cured it.
  43. #343
    Nice! Good info on the cranks. The stock BB on mine mine had a click in it, it was very strange. Sounded like there was a loose ball rolling around in them on the upstroke. Obviously not, but that's what it sounded like. I had the LBS pull them and completely re-do them and the issue went away. No trouble since. Only thing now is trying to decide whether or not to go 1x (pretty sure I want to) and if so, which chainring/size. I'm thinking Raceface Cinch looks like the way to go. The option of changing chainrings semi-easily would be a nice feature.
    On the subject of tubeless... I've done some fooling around on this thing. There was a comment made a while back that Gorilla tape would sort it out, and I'm sure that's true. I tried to do it with Sunringle tape, and it's too hard to work with and/or I'm doing it wrong. Also, you really need to trim the rim strip back so that you can get the tape stuck down well on both sides of the rim strip. If you don't, the whole thing stays semi-permiable and wont hold air. I went ahead and threw the tube back in it and will wait until after Father's day. I've registered for an Enduro race (it's a beginner, family level "fun" event). We'll see how the bike holds up as is. I'll try to get some pics posted after. After testing the tubeless setup, I think that the Fatty Stripper would work perfect. The only real issue I had when I tested it was leaking around the rim strip, and the rim seams. The Fatty Stripper band covers all that up. Getting the bead to seat was a snap. No issues there at all.
  44. #344
    Oct 2015
    Quote Originally Posted by Kingfisher2011 View Post
    I thought the same thing until I realised the standard cranks are joined on the drive side. The drive side comes off easily with an 8mm hex key and an ISIS puller. They're actually Not That Heavy either although I agree the Cinch cranks look cool and I think they allow you to go really small on the chainring. Having said that the standard cranks also have spacers for the outer ring so it really is just a matter of binning the shifter + mech, unbolting the inner ring and fitting a n/w
    Hmm this is what puts me off more than anything. I have 4.8 and 4.0 Jumbo Jims and they are both baggy as hell on the rims they literally fall off both sides when refitting them even with a tube in. Did you use JJs or a different tyre?
    Good luck with the Enduro race btw
  45. #345
    Thanks Max, I'm going to give'er hell. Like I said, I joined the beginner class. I'm just not that competitive at my age. I want to do it for fun, but not feel like I'm holding someone up.
    So... the bead. This is with the stock 4.8 JJ's. I know what you're saying... and you're right. The guy that came over to help was like "Do you have tire levers?" me - "You don't need them." lol So just looking at it, you're like "There's no way in hell this is ever going to seat. It's just too sloppy." Spoiler alert... it does. If you blow enough pressure into it, the dang bead will seat pretty darn quick/easy... and surprisingly straight. We had to fool with it just a little and wiggle it around, then POP. Done. I thought the bead was going to be the big holdup, and it was probably one of the easiest parts.
    Something else I found in my garage that I think would seal these rims up pretty quick that I don't see anyone having ever mentioned, aluminum HVAC tape. The stuff sticks like crazy, and it's MADE to hold air in. It's also just the right width to fit in the ditch of the 80mm rims. Only issue is that just like the Sunringle tape, the rim strip really needs to be trimmed back so that you can actually stick the tape down to race of the rim properly, otherwise the air just blows under the tape, through the strip... done. I might experiment with the HVAC tape at a later time down the road, but in the meantime I'm 99% convinced that that the Fatty Stripper bands will be a one & done deal on these rims, and they even call out the Syncros rims on their website (they recommend you use the backer rod).
  46. #346
    Oct 2015
    Kingfisher you've got me interested. Does the tape keep the bead in place while you inflate the tyre? What do you use to inflate it
  47. #347
    Max... keep in mind that it ultimately was a failure, but I know why. However, to your question no... the bead was tape free. I used the 78 mm Sunringle tape which comes almost up to the bottom of the rim edge but doesn't go up to the bead area. I have a friend who loaned me a blow gun with a piece of clear tubing on the end and used that to blow air into the tire to get it to seat. With the compressor at about 125-140 PSI, you have to fool with the tire a little to get it closer to the rim but as soon as the air hits it, it generally wants to pop in to place. I'm confident you could also do it with a Schrader adapter and a standard chuck, given enough PSI. When we did it initially I pulled the valve core, but with the way the little piece of tubing goes over the stem, at high pressure the air goes into the tire anyway... even with the core in.
    If I went through the trouble of taking a razor/cutter and trimming the rim strip to make it more narrow, then re-taping with the Sunringle tape. I'm relatively confident the thing would go just fine. For $20 though, the Fatty Stripper setup just seems like it's a hell of a lot easier and cleaner and I don't have to jump through the hoops.
  48. #348
    Big Jon loses a tube... take 2... Fatty Stripper
    So I did round 2 of the tubeless today. After having a dismal failure with the Sunringle rim tape, seeing why it failed etc. I decided the Fatty Stripper setup was the way to go. I was right.
    To be clear, the Sunringle tape probably would've worked fine if I had removed the rim strip and gone back with something that was more narrow or if I had trimmed the factory one. That said, the Fatty Stripper setup skips all that and is quite a bit easier.
    I ended up with a tiny leak after about a 3 hour ride in the sticks yesterday so I figured today was a good day to go ahead and sort it out. The rim strip goes on just like in the video. I did go ahead and chop a piece of another tube as a spacer, again... just as in the video. I went ahead and got the tire all the way on the rim, greased the bead with dish soap and added the Stans. Since I'm working with a makeshift stand this was a PITA, but doable. After putting the air to the wheel and massaging the tire momentarily to get the bead to seat the thing aired right up. It's had 20-30 PSI in it all day without as much as a bubble or a hiss. The thing has been ridden, shook, and spun... no trouble.
    One item of note, I did go ahead and use the backer rod since they recommended it for the Syncros rims. I think this almost made the install more of a pain as it seemed to want to move around under the band as I was getting the tire adjusted to seat, then again I didn't try it without so that may have a been a bunch worse.
    Hope this helps.
  49. #349
    Oct 2015
    Hmm thanks for that Kingfisher
    I'm guessing a compressor is pretty much essential?
  50. #350
    Max, it might be possible to do it by hand but man it'd be tough.
    On related note, after my last post I went ahead and did the rear as well. The front seems to be holding air consistently while I've had a tiny amount bleed out of the rear. I've had to top it off a couple of times but nothing major. I've noticed it bubbling out of the seam but it's intermittent and it's not enough to cause me any major grief. I keep the pump handy just in case.
    I actually ran the bike in a local "Funduro" event this weekend that was setup as a family event. Obviously I wasn't competitive, but I had a hell of a lot of fun doing it and it was a good test of the Fatty Stripper setup... trial by fire I suppose. I didn't have a single burp or issue of any kind. I did however get lots of funny looks and a few comments.
    "That looks like fun."
    "What PSI do you run in those things?"
    and one of my favs...
    Seriously equipped Enduro rider - "Hey man, I think you need air."
    Me - "Oh you mean the rear tire? No, it's supposed to be like that."
    Enduro rider - [mystified look] I don't remember exactly what he said at this point, but he was shocked obviously.
  51. #351
    Oct 2014
    Anyone know who makes the syncros hubs? I want to change the freehub on my big ed to XD. Thanks!
  52. #352
    Jun 2012
    Quote Originally Posted by Averbuks View Post
    I searched the old innerwebs on the hubs cant help .maybe alex brand ? sorry good luck.
  53. #353
    Aug 2005
    Syncros is owned by Scott now, so it's their house brand. I've read the rims are made by Alex, maybe the hubs too?
  54. #354
    Oct 2015
    New wheel(s)?
    Hey fellas how's it going
    My rear wheel has started making that cartridge-bearing-breaking-up noise. The wheel itself is otherwise OK (except maybe the join in the rim is starting to come apart slightly) and I wondered if anyone had replaced the bearings in their hub?
    On the other hand I could be tempted by some new wheels. DT BR710s on Hope Fatsnos seem (relatively) popular over here. I want to keep the 80 mm rim, 150x15 and 197x12 setup. Has anyone changed their wheels?
  55. #355
    Man I'd rock the hell out of those. No wheel change here but if I upgraded, BR 2250 was the direction I was looking.
  56. #356
    Jun 2012
    Max Dt swiss I wish ! those are awesome rims go for it. I would buy em if I had your money lol !
  57. #357
    Mar 2016
    Formula apparently.
    Front Hub: Syncros CT150 / 15 x 150mm made by Formula
    Rear Hub: Syncros CT197 / 197 ◊ 12mm RWS axle / made by Formula
  58. #358
    Jul 2017
    Is it just me or is the color combo on the 2016 way better looking than the 2017 Big Jon?
    Just love that grey & green of the 16.
  59. #359
    Oct 2015
    Must admit the colour was pretty low on my list of priorities when I was buying but I think the grey & green is OK
    New Scott fat bike: Big Jon-image1.jpg
    Still like the black & orange 2017s though
  60. #360
    Oct 2014
    This is my Big Ed with upgraded 1x11 XT, sunrace 11-46, 28t e thirteen narrowide (negative fatbike offset) and jumbo jim 3.8 tires. Running tubeless. Also has haven 35 carbon bars. Bike weighs 30lb with pedals.
  61. #361
    Jun 2012
    2018 scott big jon is blue in color !
    Just saw the 2018 big jon and its blue .saw it on the scott website it has the same specs as the 2017.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-sct_mtb_-2512_2000x2000_2018_bike_scott-sports_215707_jpg_original_zoom_1.jpg
  62. #362
    Oct 2015
    Thanks for the heads up BF29. Surprised to see a 2018 version they must be selling OK
  63. #363
    Jun 2012
    I really like the blue .it looks like the 2016 felt dd30 shown here in the photo.its one of the better looking fat bikes out there.anyone try a new 27.5 x 4.5 fat tire bike yet ? I take it they are very fast.
  64. #364
    Oct 2015
    Fat and plus bikes seem to have been and gone here in Middle England. Lots of ebikes and gravel bikes this year
  65. #365
    Jun 2012
    Max Not many full on fat bikes showing up around here in ohio but the plus bikes are very popular.not seeing any ebikes but lots of gravel bikes. I'm going to the local bike shop this weekend and test ride a 27.5 trek fat bike as I'm curious how different they are.let you know the results next week.
  66. #366
    Jun 2012
    More pics of 2018 scott big jon fat bike.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-di9zjdvxkaadiiz.jpg
    New Scott fat bike: Big Jon-21435889_117468812291947_610314689552842752_n.jpg
    New Scott fat bike: Big Jon-21148909_1282552628521458_537645114214842368_n.jpg
  67. #367
    Pretty bike! Thanks for posting
  68. #368
    Sep 2017
    Hello everyone, first post here.. excuse me if its in the wrong place... I have a question... Last year I purchased a Scott Big Jon, and upgraded the fork to a 120mm Bluto. I only just realized there is a weight limit on the bike at 128kg, and with all my gear I'm closer to 148 kg... I dont really care about warranty, but with safety in mid, do you think the frame will be ok? I know how to ride, and can absorb shocks quite well.. using my legs as suspension so as not to rely on the frame too much... but I worry...
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-img_1911.jpg
  69. #369
    I'm not a mechanical engineer but I can tell you that they pad the numbers. Considerably. I can't think of any reason you'd have any problems unless you were entering an Enduro and doing huge jumps etc. (unlikely)
  70. #370
    Sep 2017
    Thank you so much!! Im more of the flow trail and cross country ride style... and not the huge jump kind..
  71. #371
    Jun 2012
    Nice bike drebbin ! love those maxxis tires.welcome to the forum.
  72. #372
    Sep 2017
    Thank you very much! The tires are great on rocks and trails, but i put the Jumbo Jim's back for snow... I find they float better...
  73. #373
    30# big ed is impressive.
  74. #374
    Oct 2015
    Cool bike Drebbin grey/green is the best colour *cough*
    I like the tyres as well are they Minions?
    Quote Originally Posted by Drebbin View Post
    ...with safety in mid, do you think the frame will be ok?
    Big Jons sold in Europe have to meet/exceed EN 14766/ISO 4210 and there are many tests on the frame related to pulling the head tube away from the top/downtubes and vertical forces on the BB shell. The shock tests are in excess of the point where bones would break so you should be good to go
  75. #375
    Aug 2016
    My Big Jon
    Since there were not many reviews online for the Scott Big Jon, this thread and a great price at LL Beans helped me pull the trigger and purchase a Big Jon last month. I am looking forward to riding this winter. I have over a hundred miles of riding at the NHC here in northern Maine and have enjoyed every mile so far. Here are some pics with a few upgrades.
    XT shadow plus derailauer
    XT 11-46 cassette
    XT trigger shifter
    Race face 30 tooth narrow wide chainring
    KMC X11SL Ti Nitride chain
    Old bars with 30mm rise
    Replaced the seat of course
    New Scott fat bike: Big Jon-20170925_100933.jpgNew Scott fat bike: Big Jon-20170925_100948.jpgNew Scott fat bike: Big Jon-20170925_101011.jpg
  76. #376
    Jun 2012
    Nice ride and upgrades brewbacca. dont see many 2017 big jons on the forum thanks for posting.
  77. #377
    Jun 2012
    I never got to try a trek farley 9.6 as no shop has any .cant find one in stock to try. just was curious about a 27.5 x 4.5 tire fat bike and how quick they are.anyone try one yet ?
  78. #378
    Oct 2015
    I've never seen one but there are some reviews online
    Trek Farley 9.8 review review - BikeRadar
    https://hallbicycle.com/2015/10/08/t...-depth-review/
    and some on here as well
    2017 Farley 27.5 x 4.5
    2017 Farley 9.6
    It should be fast but personally I think bigger undamped tyres put energy back into the ride that narrower tyres can't. That was my feeling with 4.0s. Nimble yeah, lighter sure, faster no.
    Not sure how much choice there is in 27.5 x 4.5 tyres
  79. #379
    Jun 2012
    Max I also hear the 27.5 x 4.5 tire is quite a bit heavier than the 26 x 4.0.that size is very limited right now. I wonder if thats the trend for new fat bikes in the future ? I would still like to try one demo days are coming soon !
  80. #380
    Hi, I'm looking at getting a 2017 big jon from one of my friends, it has the stock race face 2x 10 cranks but I want to go 1 x 10. Do you have to get a new crank in order to do this or can you take the current crank and convert it to 1x? Are there any other upgrades that you guys recommend? Thanks.
  81. #381
    Aug 2016
    Quote Originally Posted by Frost458 View Post
    Hi Frost, I used the stock crank and replaced the small chainring up front with a 30t 104mm narrow wide ring when I went 1x11, cost $38 dollars on amazon. If you want to stay 1x10 and expand your range a little in the rear you could look at adding a larger sprocket to your 10 speed cassette from one up or wolftooth.
    Hope this helps
  82. #382
    Thanks Brew, I was looking at your pics when you first posted and was trying to figure out if that was the stock crank or not. I even priced everything out that you put on it through Jenson USA. For now I'm just going to put a 32 up front and see how that goes. Then eventually try to figure out if I can make it go tubeles.
  83. #383
    Oct 2015
    ...it has the stock race face 2x 10 cranks but I want to go 1 x 10. Do you have to get a new crank in order to do this or can you take the current crank and convert it to 1x?
    Race Face have made it as easy as possible
    The spindle is attached to the non-drive side and the driveside crank arm can be removed with a standard tool e.g. Park CWP-7. Remove the rings and fit a n/w of your choice. RF have thoughtfully provided shims so you don't even have to buy shorter chainring bolts. Remove the mech and godawful bracket, cable and shifter (350g). Bolt the crank arm back on and go ride.
    The n/w will keep the chain on but for maximum quietness a Zee clutch mech is Shimano's only short cage 10sp mech apart from Saint.
    Saint shifter very nice indeed.
    The standard centrelock rotors are surprisingly heavy and Shimano's own RT81s are a fine replacement.
    Keep an eye on the hanger bolts they can work loose New Scott fat bike: Big Jon - Page 3- Mtbr.com
  84. #384
    Jun 2012
    C'dale fat caad 2 2018
    Saw one of these saturday at a bike shop. I was just looking and curious about the 2018s. Im not really interested in buying a new bike but saw this 2018 cannondale fat caad 2 fatty and it was pretty cool.it looks like the big jon a little. at 1,899 bucks it has the narrow q factor ,was very light and was similar to the fat caad 1 just no lefty olaf fork and it has a slx rear der. with lighter tubes or tubeless it would weigh about 29 lbs. it was barely 31 lbs on the scale size medium no pedals.test rode it and its pretty sweet.I love the big jon but this rode a little better with my legs not so far apart. I thought the q factor talk was all hype but for me there really was a diffrence. I asked what kind of deal I could get but the best they could do is 1,800 out the door because its so new. kinda thinking about it .I did find out while I was there that the 2017 fat caad 1 with the olaf lefty fork at 3,500 bucks has been discounted by cannondale big time .its up to the selling dealers but cannondale has approved 2,399 ! I called a few dealers and they will get you one for that price as there are a lot left in warehouses.I dont think I want a fat bike with suspension but wow thats a hell of a price.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-p1090329_800x600.jpg
    New Scott fat bike: Big Jon-11671-fatcaad-1.jpg
  85. #385
    Oct 2015
    Ahh the lure of a new bike. Cannondales are similarly expensive over here and then hugely discounted at the end of the year
    The Fat CAAD does look a lot like a more modern version of Big Jon esp in the first pic. I've owned a few Cannondales and they've been pretty good apart from the Cannondale-specific (SI) parts when they wear out, usually BBs and headsets. It can be expensive/a long wait for what would be an ordinary component on a different bike.
    Maybe Cannondale are using proprietary cranks to get a narrow q-factor but if the bike feels better could the shop arrange a demo bike for you to hire for a day?
  86. #386
    Jun 2012
    Max I dont think they would let me try it to ride more than the parking lot ride I took.however as these new bikes are starting to arrive at dealers it will be worth a call to the bigger big city shops to see if I could spend more time on one.I read that the si bb's can wear out quick. how hard on the cranks were you when you had your c'dales.I dont have the money you do to tear up stuff LoL .
  87. #387
    Oct 2015
    lol I blame it on the rain
    The SI parts lasted just as long as anything else but when they needed replacing it was always a headache. We have one reliable supplier in the UK who actually stocks Cannondale parts but they're never inexpensive. There are international suppliers but the postage is a killer so my choice is go with an expensive (and sometimes rare) SI part or bite the bullet and get some sort of adaptor so I can use a standard component. I guess the situation is better in the USA.
    Test rides are pretty much the same here although I did hire a Specialized Fatboy for £50/day before I got Big Jon.
    Do you find the q-factor obtrusive? I guess back-to-back with a narrower bike the difference is quite noticeable.
  88. #388
    Jun 2012
    Good job!
    Max the big jon is a awesome bike but I am a old timer in my 50's so every now and then one or the other knee gives me a little discomfort then after a day or two it goes away.its not really a problem yet.Im used to the big jon and love it but down the road who knows.I just didnt think a narrower pedaling area would really be diffrent but it felt like riding my old 29er.of course it would be nice to have a little more riding time on one.I see now what your saying about c'dale parts being hard to get they are easier to get here .I promise not to mention the c'dale name on here much more as this is a forum dedicated to the awesome Scott big jon bike.
  89. #389
    Oct 2015
    keep us posted bud
    I like Cannondales
  90. #390
    '16 Big Jon owners, does anyone have a stock seatpost (Medium frame if it matters) that they're willing to part with? I was tinkering with mine yesterday and I guess the freaking tube didn't have enough grease in it or something. Ended up scratching the hell out of it, apparently from where one of the stays meets the seat tube. Total noob mistake. I'm due to upgrade to a dropper anyway, but it'd be nice to have a stock one that isn't totally screwed.
  91. #391
    Dec 2016
    Hi,
    Any difference between the 2016 and 2017 Big Jon? Also, Im 5 10 with a 31,5 inseam so in between Large and Medium. Any recommendations on sizing ? I ride a large Stache 7 and it fits great.
  92. #392
    Is that true inseam or pant size? I believe the 16's, 17's etc. all have the same geometry. I'm 5' 11" with about a 30" inseam and ride a '16 medium. I normally ride a large but the large was too big for me, and it seems to me that the main issue was standover. My plus bike is a much bigger rig with a lot more reach and now when I jump back on the Big Jon after a while it feels a hair small in the cockpit. That feeling goes away, but I thought it was worth mentioning. If you've got the standover for it, and it sounds like you do I'd probably opt for the large.
  93. #393
    Oct 2015
    This is Scott's sizing chart
    New Scott fat bike: Big Jon-size-chart.jpg
    a Medium is OK for up to 180 cm (5' 9").
    I'm 6'2" 34 IL and was able to try the L and the XL. The L is OK for up to 190 cm (6' 2") and I would agree with that - with the emphasis on 'up to'. It felt like it would be a better fit for someone 6' or less ( I bought the XL btw)
    Unless you have a preference for slightly small bikes with lots of seatpost I would go for the L
  94. #394
    Dec 2016
    Thanks. Im 5 10 which is closer to 177.5 cm. I just tried a used medium. The reach was short (410) compared to the 435 of my 29er hardtail with the same stem length. It felt really cramped so will be looking at a large Big Jon next.
  95. #395
    Oct 2015
    My apologies 180 cm is 5.9 feet. Blame Google
  96. #396
    Reputation: bizango's Avatar
    Mar 2016
    mmmm, check your math. It's ~5' 11"
  97. #397
    Jun 2012
    Big jon is gone say hello to the cannondale fat caad 1
    Scott big jon is gone.sold old jon in just a few days. I didnt think it would take long as its such a great bike.I never thought I would end up with a cannondale fat caad 1 but at what they are selling off the 2017's for I couldnt resist. its a pretty cool bike and has a very sporty ride.the camera wont show it but the stripes and graphics are green not yellow. gotta at least stay with some green. I remember seeing the 2016 fat caad 1's for 3699.00 ! then the 2017's for 3499.00 and I would say cool bike but no way not for that price. well for 2399.00 it aint a bad deal and the fun begins.I guess I wont be able to stay on this form out of respect to scott fat bikes but its been fun.
    Attached Thumbnails Attached Thumbnails New Scott fat bike: Big Jon-img_6008.jpg
  98. #398
    Hard to argue with your reasoning. It's a great looking bike! Congrats and enjoy!
  99. #399
    Jun 2012
    Thanks kingfisher. some bike shops have it as low as 2239.00 but no dealers at that price close to home.the bike shop guy I bought it from said c'dale made way to many of these and they didnt sell well at the full price. he said the size large just sold out at c'dales warehouses but some dealers still have them. I really like the ride so far. I was hoping it would be under 32lbs but its almost 33lbs.cant have everything.
  100. #400
    Oct 2015
    BF29 that looks amazing Cannondale definitely know how to put a bike together
    What are the specs
  1. scott genius 720, not to bad of a bike
    By tim208 in forum 27.5
    Last Post: 08-27-2014, 08:07 PM
  2. Capriolo Bike or Scott
    By Kert Sepa in forum 27.5
    Last Post: 06-22-2014, 02:34 AM
  3. Replies: 9
    Last Post: 05-17-2014, 02:59 PM
  4. Where can I order a Scott bike (in USA)?
    By kosis in forum Scott Sports
    Last Post: 04-29-2013, 04:30 PM
  5. Replies: 50
    Last Post: 03-20-2012, 08:59 AM
Members who have read this thread: 217
