They have a removable spider so you can run their direct mount single or double rings like on their TRS Race cranks. Woulda been cool if they sold a version like that or arms only so you could go that route from the start. Still, looks like a pretty good unit.
Sweet, looks to be about as heavy as the RF turbines and much more expensive too!
um the the std TRS *is* like that. Spider is removable.
We spec them on our bikes. I have a single direct mount ring up front and XX1 down the back.
need to buy cranks and these are top of the list, wish they would hurry up and come out already
Works a treat!
Thanks, I did not know that. So only difference between TRS and TRS+ is a little lighter and gold parts? Do they sell the regular TRS with a single or arms-only?
the only difference is that the TRS+ is lighter and has the gold spindle correct.
I can't comment on what is available aftermarket. We get our cranks OEM from e*thirteen and so we can spec them anyway we want.
So far, we have done double 22/36 combos. But we will start to offer our bikes with X01 and the new single rings I think.
RF Turbine double is 950g and around $320 with rings and BB. e13 can be had for $300 + $50 for BB. I could find the extra $30 under my sofa cushions.
Gunna doubt that, first of all these are all solid metal cranks, no hollow forged, no carbon fiber, so unless E13 has skimped on the cranks, I doubt there's much difference and a granny ring weighs about 25-30g, the 36t weighs 40g, so we got 760+70=830g. Not bad for the set, that's including the arms, BB, rings, etc.
But on the subject of price, you've got to be kidding me. $350 or more for this technology? These ain't carbon cranks. These ain't hollow forged cranks. You can get the RF set for around $200, including BB. Then add some rings, price is still way down there.
Edit: I see where you got the 950g RF weight now, which included a bashguard. Not really apples to apples it seems.
Oops, missed the bashguard. No way of knowing what the actual weights are for either crank unless somebody puts it on a scale. RF chainrings aren't cheap. I just bought a 22/32 set for $80.
I found the direct mount feature interesting, especially the direct mount double. Seems like it might offer meaningful weight reductions, and it looks clean. I was hoping they'd do a fat version of the TRS Race crank:
Bearing durability seem to be an issue for e13 cranks...just saying.
Seems to be true of ALL BB bearings. I've got a couple thousand miles on mine with no problems. The e13's are sensitive to proper setup (shell facing, spacers, pre-load, and torque).
