Results 1 to 11 of 11
    Sep 2014
    New chain has a kinked link!
    I was lubing up the new chain and noticed it has one link that doesn't straighten out after going around the gears...should I replace it with another master link or go for another ride and see if it loosens up? I don't want to ruin the AB oval ring I just put on.
    Reputation: JesusJuice's Avatar
    Dec 2014
    Wiggle it ... just a little bit.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Kinky^^^.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Sep 2014
    Tried that; doesn't seem to help. I think it's a mfg defect.
    is buachail foighneach me
    Reputation: sean salach's Avatar
    You tried wiggling it side to side? perpendicular to the way it's supposed to move? Stiff links are common when connecting chains with a pin and that's the way to loosen them up.
    Is it a shimano chain? Did you push the pin in just too far or just not enough? Try putting the chain tool back on it and push it just a hair to either side.
    Never argue with an idiot. They'll bring you down to their level and beat you with experience every time.
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    Take it back and get another one?
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Reputation: watts888's Avatar
    Oct 2012
    Quote Originally Posted by sean salach View Post
    So this. I've had new chains, and ones where I pushed a pin out and back in, where they were stiff and wouldn't bend. Just grabbed the chain and put a little torque on it side to side (90 degrees off the direction the chain should bend) and it loosed the chain up. Of course, you don't want to man-bear-pig the thing. bend it a little, see if it works, bend it a little more, see if it works.
    "a hundred travel books isn't worth one real trip"
    Sep 2014
    It's a KMC chain I had to cut some links off to get the correct length and use a master link to connect the ends. I'll try wiggling it some more. Doubt if they'll take it back since I shortened it and have a few rides on it also.
    Wiggle/bend it perpendicular to the rotational axis, as mentioned above. You can also insert it back into the jaws of the chain tool, with the teeth between the links as if you were making a cut, next to the trouble spot and use that as leverage as you bend the links at the trouble spot.
    If the masterlink is stiff you might have gotten the wrong masterlink.
  1. Chain skip - fixed it - chipped a chain link?
    By davez26 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-14-2013, 11:40 PM
  2. XX1 Chain link?
    By bassn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-16-2013, 09:12 AM
  3. How many link in your chain?
    By inter in forum General Discussion
    Last Post: 01-04-2013, 10:13 PM
  4. Link/Chain Connector for 10sp Shimano Chain?
    By Affe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-09-2012, 02:25 PM
  5. HALF link link needed ,using 9spd sram geared chain
    By zippy895 in forum Singlespeed
    Last Post: 02-05-2011, 08:25 PM
