Page 5 of 7 FirstFirst 1234567 LastLast
Results 201 to 250 of 317
  1. #201
    I can say that I have just weighed my just delivered 100 mm Bluto and with the Maxle it was 1848 grams and when I shortened the steerer it was 1830 grams
  2. #202
    turtles make me hot
    Reputation: NYrr496's Avatar
    I did not weigh it while I had it but it was definitely lighter than the Carver fork by a healthy bit.
    I like turtles
  3. #203
    Quote Originally Posted by troutie-mtb View Post
    Quoted as 1796g so pretty much spot on considering scale variance. Thanks.
    So many years in the making, everyone I'd seen with one couldn't wait to throw it on the bike. Scale be damned.
  4. #204
    Reputation: Way2ManyBikes's Avatar
    New Bluto Thread!
    Okay the swap / modification is complete.
    We made two 4mm shims one for each side. I will Tig them on next week.
    Marty
    12 JamisDakar650B
    14 FarleyBlue,Bluto,i9-Hed,4.JumboJims
    14 FarleyBlack,Jackalope
    17 Farley 9.6 Under Construction
  5. #205
    aka bOb
    Reputation: bdundee's Avatar
    Look sweet W2Mb!! Everything go OK and as planned?
  6. #206
    New Bluto Thread!
    I had to dremel the bracket and the offset is close. I have a rotor shim on order and it will be perfect.
    Marty
    12 JamisDakar650B
  7. #207
    Clueless Bastard
    Reputation: WA-CO's Avatar
    Nov 2013
    That is so rockin...
  8. #208
    New Bluto Thread!
    Can't wait to ride it Saturday
    Marty
    12 JamisDakar650B
  9. #209
    New Bluto Thread!
    Rode the bluto today. All I can say is Trek did a great job planning ahead for the Bluto as it forks flawlessly.
    As for the bluto Holy sh!t what an improvement in handling and ride quality. Adding the Bluto to my Farley may have made this bike my go-to bike year round.
    As for the Set Up I ran 10 psi on the front tire and it without a doubt tracked better them it ever has and I put a comfortable 6 psi in the rear.
    It's possible that I may never take this fork off.
    I used the lock feature on a few climbs however I'm not sure it was necessary as the fork barely moved while I was climbing even in the standing position.
    Worth all the effort to get it fitted on the bike and very happy I made the swap.
    Marty
    12 JamisDakar650B
  10. #210
    Nov 2007
    Quote Originally Posted by Way2ManyBikes View Post
    Finally, a review! Any downsides? Any handling quirks? Do you notice the weight?
  11. #211
    New Bluto Thread!
    Absolutely none.
    It's exactly what the fat bike needed. Think back from when you went from a fully rigid bike to a suspension fork.
    Never noticed the weight.
    Marty
    12 JamisDakar650B
  12. #212
    Reputation: thecanoe's Avatar
    New Bluto Thread!
    How about the steamroller effect going over softball size rocks? Can you still just point and pedal or is there any bump steer?
    Santa Cruz Tallboy
    Moonlander
  13. #213
    New Bluto Thread!
    Quote Originally Posted by thecanoe View Post
    I aimed for every rock, tree root & defect in the trail and it was just point and shoot.
    Marty
    12 JamisDakar650B
  14. #214
    Yesterday was the Day !!!!!
    The Bluto turned my fat bike into my go to bike.
    Saturday I rode the normal single track trails and it worked perfectly and Sunday afternoon I went to the technical single track that has every kind of obstacle you can imagine on a trail. From Skinny's to sharp rocks to rollers to fast tight switchbacks. You name it, it happens on this trail. While I was thrashing my bike around in comfort at speeds I personally have never ridden on this trail. My buddy on his 9 Zero 7 was working his ass off and being beat up by the trail. One thing is for sure he is calling Rich at R-Bikes and ordering up a Bluto today. I forgot to mention he even rode my bike on a technical rock bridge and he said it was like cheating it was so easy.
    Thumbs up for SRAM coming out with the Bluto.
    Marty
    12 JamisDakar650B
  15. #215
    Reputation: KingKongKion's Avatar
    May 2014
    The waiting just got harder! My Bluto has been delayed, and will be in my LBS at the end of august -_-
    How much travel is your Bluto?
  16. #216
    End of August - that sucks !!!
    Travel on mine is 100mm
    Marty
    12 JamisDakar650B
  17. #217
    aka bOb
    Glad you stuck with it and it's working out for ya.
  18. #218
    Quote Originally Posted by bdundee View Post
    If it wasn't for your post I would have never stuck with it. Thank you agian sir and I owe you a Beer.
    Marty
    12 JamisDakar650B
  19. #219
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I have a 100mm Bluto for sale here.
    Ridden a handful of times, but in like-new shape.
    Cheers,
    MC
    Handbuilt wheels: www.LaceMine29.com
  20. #220
    Reputation: alshead's Avatar
    Oct 2007
    Holy crap. Took mine out today. Absolutely awesome. Talked about it more here: FatBoy with Bluto?
    Anyone know if the 100 can be extended out to 120?
    "There are two kinds of mountain bikers in the world: those who are faster than me, and me."
  21. #221
    Nov 2007
    Anyone try a Bluto on a non-suspension corrected frame?
  22. #222
    aka bOb
    Quote Originally Posted by SmooveP View Post
    Isn't your 22 made for a 468mm fork and a 44mm headtube? If you set one at 80mm all you would be raising it up is about 15mm the stack height of a lower external cup and a 3 mill difference in a-c if you run 20% ish sag. So that would only drop you H/A to around 69.8 ish with a 80mm and 68.8 with a 100mm. That's if the specs are the same as the new 22.
    Edit: And if it clears your downtube and the tire doesn't hit under full compression.
  23. #223
    Nov 2007
    I have the tapered headtube, but I believe the geo of my frame was designed around a 450mm fork, which is what's on the bike.
  24. #224
    Now you have your Bluto what about protecting the seals from the trail crud
    this is a rough trial using a 5 litre plastic oil container
    I will of course use Black ties if it works ok
  25. #225
    Oct 2007
    New Bluto Thread!
    Sweet
    There are two types of mountain bikers. Those who are faster than me, and me.
  26. #226
    Human Test Subject
    Reputation: Volsung's Avatar
    I don't have as much experience with suspension forks as I do magnesium pedals and winter riding. Should people be worried about the paint chipping and exposing the magnesium of the fork? That kind of sounds like a recipe for disintegration.
  27. #227
    Clueless Bastard
    Nov 2013
    Son of a biatch.....I was so convinced I didn't need to plunk down the 700 for one of these things for my Beargrease...now...well...hell.
  28. #228
    Loser
    Reputation: Jisch's Avatar
    Bluto for $546 from Universal - use bikingisfun15 to get 15% off - I just checked and it seemed to work.
    Just for grins I put a Bluto, Rolling Darryl, Salsa Hub, spokes and nipples in a shopping cart - it came out to $838 with the 15% off. Too much for me right now, have to see how things go later in the year.
  29. #229
    Quote Originally Posted by WA-CO View Post
    Sorry man it's just freaking to Awesome not to have one. If you love fat biking this will make you sell all of your other bikes.
    Last week I was on the Hot Rod Power Tour and planning to return home on Saturday and I was bummed that I didn't have my Fat Bike to ride. It used to be the other way around where my full suspension bike was my go-to bike and now it's my Farley Fat Bike without a doubt.
    I did however ride my full suspension on Sunday and I notice that my Fat now rides exactly like the full suspension bike so there is no learning curve when you go back and fourth between the two bikes.
    Marty
    12 JamisDakar650B
  30. #230
    turtles make me hot
    Cool. What were you driving on Power Tour?
    I like turtles
  31. #231
    New Bluto Thread!
    Quote Originally Posted by NYrr496 View Post
    Bright Yellow 2010 Camaro with black 1le Wheels on it. Next year my bike will be on the back for sure as we were so close to so many cool trails
    Marty
    12 JamisDakar650B
  32. #232
    Oct 2007
    New Bluto Thread!
    I think it's awesome that people are loving the addition of the bluto so much. I know I'm digging the jebus outta mine, but I don't want to mislead anyone. FOR ME, the fatbike with bluto does not ride like a full suspension bike, and I would not sell all of my other bikes. If I lived somewhere where the trails were super buff, there wasn't a lot of chunk/ tech, or rocky/ rooty features, then, yeah, for sure. But then I probably wouldn't need a full sus rig anyway. Don't get me wrong, it can slay the tech/ chunk, but it still very much a hard tail- a soft hard tail, but still a hard tail. It's a different kind of riding- fun and capable, but different for sure.
  33. #233
    New Bluto Thread!
    I agree that it is not a replacement for a full suspension bike. But in the trails near Chicago this bike works great.
    Marty
    12 JamisDakar650B
  34. #234
    Oct 2007
    New Bluto Thread!
    ^totally. Midwest? Hell yes, it could be my one-and-done all-season, all-rides quiver killer.
  35. #235
    Hey Way2manybikes which crown race did u go with on bluto Part# or link to it please.
  36. #236
    New Bluto Thread!
    Quote Originally Posted by BlackMamba2012 View Post
    Marty
    12 JamisDakar650B
  37. #237
    Ok thanks Waytomanybikes
  38. #238
    New Bluto Thread!
    Your welcome
    Marty
    12 JamisDakar650B
  39. #239
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Can someone tell me the outside to outside crown width of the Bluto fork?
  40. #240
    New Bluto Thread!
    8 5/8 wide
    Marty
    12 JamisDakar650B
  41. #241
    New Bluto Thread!
    Still as happy as can be
    Marty
    12 JamisDakar650B
  42. #242
    Reputation: Fat907's Avatar
    Jun 2014
    Has anyone tried to change the travel to 80mm yet?........what air pressure and weight
  43. #243
    Finally checked one out in person. i will stay rigid thank you.
  44. #244
    Nov 2007
    Quote Originally Posted by demondan View Post
    What didn't you like?
  45. #245
    It felt ok but looks low end. Just not for me.Glad people like the ones they are on.
  46. #246
    aka bOb
    Mine pretty much looks like the same quality as every other RS fork, maybe not top shelf cool looking but the price doesn't really reflect that either. I'm more excited to see how it rides.
  47. #247
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    It can be done.
  48. #248
    i'll tell ya how it rides. it goes up and down and stuff. like every other sussy fork has done for the last 25 years. so innovative! :P
    rog
  49. #249
    aka bOb
    Quote Originally Posted by newmarketrog View Post
    rog
    So do you have a lot of experience with suspension equipped fat bikes? Is the Bluto Flexy, does it run through it's whole travel to easy, or does it not use all of it's travel, will 100mm be enough or to much for my frame?
  50. #250
    i don't, but i don't see how it's any different than a suspension fork on a nonfat bike. cept it's wider.
    rog
  1. Bluto - Thread Deleted?
    By dfiler in forum Fat bikes
    Last Post: 04-09-2014, 08:28 PM
  2. Replies: 17
    Last Post: 04-02-2013, 05:48 PM
  3. Bullit photo thread (Merged thread)
    By Pete in forum Santa Cruz
    Last Post: 05-18-2012, 11:49 AM
