Results 1 to 14 of 14
    Mar 2017
    Need help picking cogs.
    Will be building a single speed surly wednesday, sometime next week.
    It's the first time I'm building an entire bike and I don't know anything about gear sizes.
    What would you recommend?
    Those fine folks at Surly have you covered. Single Speed Gearing 101 | Spews | The Information Hole | Surly Bikes
    When my Wednesday goes to SS mode, it'll be 30x19. Because that's what I have laying around. That ratio worked well on my old Mukluk.
    Jason
    Disclaimer: www.paramountsports.net
    We have no idea your fitness or the terrain you intend to ride and at what pace. Help us help you.
    Mar 2017
    Quote Originally Posted by bme107 View Post
    Fitness level is decent, I'm about 165lbs with a slightly t-rex muscle distribution. Decent cardio.
    Terrain is gonna be mostly dirt and snow, mountain trails in every season. Hills and such. I'm not going to do any really deep snow. Some road (I will be using the bike to go places, even if it's not gonna be the main use for it), I doubt I would do sand.
    I'm not looking for something extremely fast, I won't do any kind of racing or steep downhill. I'm not planning on taking as much time as possible either. In other words, I'm willing to lose a bit of speed on flat ground for a better climb, without completely killing it. I will be doing long-distance rides.
    Did I miss any important detail?
    Mar 2017
    Quote Originally Posted by JAGI410 View Post
    Will definitely check it out, thanks.
    Nov 2008
    I run a 33-24 with 4.8 tires and it works really well for the local terrain and my riding style. I like to sit and spin. Do you spin or mash?
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    WNC Native
    Reputation: nitrousjunky's Avatar
    What kind of elevation gain per rides?
    I'm rolling 32x22 on my SS fatty, most of my rides are minimum 100' gain per mile. Some trails are 800' gain per mile.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Mar 2017
    Quote Originally Posted by shoo View Post
    I tend to spin more. I havent decided on the tires yet, but they most likely will be 4".
    Mar 2017
    Quote Originally Posted by nitrousjunky View Post
    I don't know how much, I'm not familiar with elevation gain. I'm getting a fatty because I'm tired of riding on road, I'm not planning on a specific kind of terrain or elevation. There's a few mountains I've already planned on climbing, but I also intend to go on longer rides for camping.
    Reputation: SalsaSalsa's Avatar
    Dec 2016
    Are you set on SS? You could solve all these problems by going 1x11. Or at least going dinglespeed gives you two options. The problem with SS on a fatty that you do roads and dirt tracks is how hard it is to get the bike up to speed, but once it is up to speed it wants to go fast. On pavement I regularly go over 35mph, but on dirt singletracks I average closer to 5mph. Those two speeds don't call for the same gear set up. Unless you are doing mostly flat cruising you will be switching from mashing to spinning to coasting on any rides with big elevation changes.
    Is dang happy!
    Reputation: Mr. Doom's Avatar
    Quote Originally Posted by SalsaSalsa View Post
    Agree, "hills" and "road" require different setups, I have four SS bikes for this reason, but only one fatty and it has gears.
    The wheel is a extension of the foot
    Mar 2017
    Quote Originally Posted by Mr. Doom View Post
    I get that, but speeds severely annoy me. I understand it'll be a bit slower on road and bit less efficient on dirt even if I do get a good middle-ground cog setup, but I'd still rather put in a bit more leg than have speeds.
    Momentum Junkie
    Oct 2013
    I agree with Nitrousjunky, 32-34:20-24. It's a low gear but you'll need a lower gear than normal on a fatbike.
    there's a wealth of information on Sheldon Browns website. you should get familiar with Gear Inches. Sheldon Brown's Bicycle Gear Calculator
    You may need to try a couple different ratio's before you get it dialed in which is OK, it never hurts to have a few extra cogs laying around. You'll also want to run a different ratio in summer vs winter. Also if you ride regularly you may notice your fitness increases and you want a bigger gear.
    Get your chainline right from the start. you'll figure out gear ratio's as you go.
    Also, I highly recommend you use a chain tug on the drive side for SS with the Wednesday. My axle slipped no matter how tight i cranked on it, until i installed a tug. now it's solid. The dropouts are a funny shape, i had to modify a tug i already had with a dremel to get it to fit.
    Rigid SS 29er
    Fat Lefty
    SS MonsterCross
    SS cyclocross
    all steel
    Mar 2017
    Quote Originally Posted by *OneSpeed* View Post
    Great, thanks. I will look into all that.
  1. Which cogs? $$
    By dledinger in forum Singlespeed
    Last Post: 08-19-2015, 01:11 PM
  2. JBC cogs?
    By buddhak in forum Singlespeed
    Last Post: 11-14-2012, 09:34 AM
  3. I9 SS hub, how many cogs can you fit on it?
    By Fulton in forum Singlespeed
    Last Post: 12-15-2011, 04:08 PM
  4. Which cogs to buy
    By dw67 in forum Singlespeed
    Last Post: 02-28-2011, 07:43 PM
  5. New cogs
    By OnForm in forum Singlespeed
    Last Post: 02-12-2011, 09:16 AM
