Results 1 to 11 of 11
    Mar 2012
    Need Help: Drilled Rims Insert Colors
    So I just recently got my rims drilled and now want to put something fun for colors or patterns or whatever in the holes instead of a rim strip. Any ideas?
    Pics would be awesome.... Lets see your rims!
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    There is a big thread on this somewhere....
    Last time I was at Michaels, they had a great selection of duct tape with patterns...
    Anchorage, AK
    Reputation: anortherncrazy's Avatar
    Clear packaging tape on the main holes and orange reflective tape from Identi-Tape on the smaller ones.
    Red reflective 3M tape. Expensive..
    Sent from my wireless communication apparatus
    two wheel livin'..
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I've had good success taking whatever material and cutting it into small squares that go over the holes, then two tiny pieces of tape to hold them in place, then after they are all (so 32 or whatever squares over the holes) there put a couple layers of packing tape over the entire thing. It's light and allows you more flexibility with materials, like alternating, or putting it lengthwise if the material isn't available in the width needed the other way.
    Anchorage, AK
    That's exactly what I did with the reflective tape on the smaller holes. Took some time, but a six pack and some patience made it worth it!
    two wheel livin'..
    Quote Originally Posted by Shark View Post
    Fat rims with cutouts, show us your mods
    sky is the limit.
    some tubeless carbon fiber rim strips i just made.
    Feb 2012
    kidd thats cool can you give us info on how you made them?
    Mar 2012
    Quote Originally Posted by kidd View Post
    Second that. How did ya make those? Thats a cool look!
    Reputation: dudeist's Avatar
    Apr 2013
    kidd that is badass like from The Andromeda Strain movie or a moon rover. A-north both 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 33333333333333333333333333333333333333333333333333 3333333333333333333333333333333333333333333exellen t
    the foam is leftover from when i had siding installed on my house. i glued the carbon fiber cloth to it from off of ebay. you can get all different colors. over the carbon i put some automotive door sill protection. also off of ebay, the cheap stuff from china. after it's wrapped around the rim. it's all a matter of layering gorilla tape to seal the bead. although if i did it again i would order twice as much of the 4" door protection tape and use it as the final wrap around the rim also. after reading about all the gorilla tape failures it seems like a good idea.
  1. tubeless and drilled rims
    By stesteste in forum Fat bikes
    Last Post: 10-22-2013, 10:20 PM
  2. Custom drilled spoke pattern fat rims?
    By Sand Rat in forum Fat bikes
    Last Post: 04-11-2012, 06:39 PM
  3. Drilled rims can take more than snow and sand?
    By pläski in forum Fat bikes
    Last Post: 03-02-2012, 01:36 PM
  4. Lightweight / Drilled rims for AZ Desert?
    By urbanseeds in forum Fat bikes
    Last Post: 12-19-2011, 04:52 PM
  5. NoTubes Presta on Shrader drilled rims?
    By nampla in forum Wheels and Tires
    Last Post: 08-26-2011, 07:58 AM
