Results 1 to 30 of 30
    Reputation: Mapkos13's Avatar
    Smile My Rolling Daryll Rim Drilling Project
    Hopefully this will be helpful for those of you that wish to do it.
    It wasn't that bad as long as you have some time and the right tools.
    I used a impact drill, 1 3/8" metal core bit, 1/2" metal drill bit, sanding bit, template, hammer, punch, and marker.
    I would just say to take your time when doing this. Measure it out and make a template. It will be much easier.
    Step 1- Strip down the rim
    Step 2- Take template and place mark for your holes. **Remember not to drill a hole across from the valve stem where the weld is.
    Step 3- Punch holes with hammer. This will allow a good center for the drill to start
    Step 4- Pre-drill a bit of the hole but just start removing some metal. Don't go through and don't use a bit larger then the drill bit on the core bit.
    Step 5- Once everything is pre-drilled start knocking out your holes with the core bit. Also, I then went back and hit the small holes with the 1/2" bit. **Be careful when it's about to punch through so you don't hit the spokes
    Step 6- Use the sanding bit or file to smooth out the edges and remove and metal burrs.
    Step 7- Replace the rim strip- I only had one red at this time and install the tube and tire and pump up.
    Step 8- Enjoy the new look of your sweet rims!
    That just about covers it. This really isn't a bad project once you get going. I would recommend getting a strong drill with a cord. I used my 18v cordless and it was taking a while. I went and rented a nice big drill and they were popping out like butter.
    Probably saved a good couple of pounds of rolling weight which is awesome!
    Attached Thumbnails Attached Thumbnails My Rolling Daryll Rim Drilling Project-0.jpg
    Ellsworth Epiphany SST2 SRAM XO
    Trek Madone 6.9 SSL
    9:Zero:7 SRAM X7
    aka bOb
    Reputation: bdundee's Avatar
    I use one of these to deburr the holes takes just a couple of minutes to do a rim and costs about $6.00 at Menards. Also I drilled 1.5" and it took an undrilled RD down to about 760 grams (about 280 grams per rim).
    Nicely done! You just need to get a black Sharpie to touch up the edges of the holes to match the rest of the rim (jk!)
    Not a bad idea. I was thinking about doing something with those!
    Trek Madone 6.9 SSL
    9:Zero:7 SRAM X7
    Reputation: lamard's Avatar
    Feb 2010
    not enough holes... drill the valve hole with your larger bit and the put the valve hole by the WELDED seam
    your 29er may float over roots and rocks, but my superlight 26 just plain floats
    aka bOb
    Quote Originally Posted by lamard View Post
    Hey that's a swell idea!!! Why didn't I think of that
    Reputation: Crit Rat's Avatar
    Nice work OP!
    I might have to do this with a set and then get them powder coated.
    Quote Originally Posted by Crit Rat View Post
    Nice work OP!
    That's a great idea. I'd love to see some different rim color options. My guess is it'll only be a matter of time as the popularity increases.
    Trek Madone 6.9 SSL
    9:Zero:7 SRAM X7
    pug biker
    Reputation: miesj's Avatar
    Dec 2011
    looks good, great idee to reduse some grams
    Quote Originally Posted by Mapkos13 View Post
    Great write up and better looking ride! I've got the same bike shipping to me this week Speaking of rim colors, I think the white RD's would look awesome on the black 907. I thought about trying to track down a set of them, but I couldn't wait any longer...I want to ride!
    aka bOb
    They do/did red, green, and white RD's
    Nemophilist
    Reputation: TrailMaker's Avatar
    And...
    Don't forget flipflops on your wardrobe list. Sharp metal shaving between your toes is a joy not to be missed.
    Dec 2011
    Nice. I looks great. Have you been able to ride it? and does it feel different?
    Quote Originally Posted by TrailMaker View Post
    And...
    Hahaha- got the hot metal I between the toes. It was great!
    Haven't been out to ride yet but will tomorrow so I'll post after.
    Trek Madone 6.9 SSL
    9:Zero:7 SRAM X7
    aka bOb
    Quote Originally Posted by couchman View Post
    He lost about + or - 200 grams per wheel the weight will be the only thing that might be noticeable.
    Oct 2011
    I just drilled out my front rim on the weekend, I drilled 1.5" holes all around and took the pieces to work and weighed them here you go...
    aka bOb
    Reputation: GTR2ebike's Avatar
    May 2010
    I drilled mine with 1.5 inch holes yesterday. Front wheel went from 1546 to 1268 (278 grams) rear went from 2220 to 1944 (276 grams).
    Feb 2010
    Quote Originally Posted by bdundee View Post
    sarcasm?
    aka bOb
    sarcasm?
    No very good idea I wish I would've done that. There has been a ton of rims drilled on here including a bunch by me and I have never seen it done.
    Oct 2011
    If I didnt read this post first, I wouldnt have thought of drilling the valve hole on the weld either. Im glad I read this post before drilling.
    May 2010
    Quote Originally Posted by angryx View Post
    I debated it when drilling mine on monday but I figured their is a reason every rim manufacturer leaves them that way. If you're drilling 1.5 inch holes it's just over 9 grams.
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Can we get this stickied?
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    exactly!! my marge lites will be orange when done however sourcing the OEM stickers may be a chore.....bueller??
    Reputation: firefighterdirt's Avatar
    I completed the drilling of my Large Marge.
    My Rolling Daryll Rim Drilling Project-holey-marge-015.jpgMy Rolling Daryll Rim Drilling Project-holey-marge-024.jpgMy Rolling Daryll Rim Drilling Project-holey-marge-011.jpg
    So how much did you lose from those beasts? I still have a set, but they don't get used very often, so I never got around to it. That your Iceman bike?
    About 5-6 lbs total on the bathroom scale, I remounted them with Bontrager 26x 2.5-2.8 tubes they were about 9oz compared to the Surly toobs at over a pound on a kitchen scale. I am thinking about using it for Iceman now. Made a big difference!
    My Rolling Daryll Rim Drilling Project-1276837_10101424870290578_966604249_o.jpg
    Just finished with my front wheel with 1.5" holes. Rolling Darryl & Salsa Mukluk 3 hub. No issues of banging the spokes because my new hammer/drill has a depth gauge. Yes, this project killed my old $10 "workforce" drill after 6 holes with a spectacular cloud of fire and smoke.
    Used a paddle-wheel sander and some 80-grit sandpaper to finish the holes. Wheel stayed perfectly true after the cut-outs. I didnt weigh anything, but I've got the cutout discs on a string as a "trophy". Too bad you cant see my Riverwest24 Ed Gein Bible Revival Spoke card. It really brings the wheel together. I'll post some more pics when I get around to finishing the project.
    Looks good
    Quote Originally Posted by falkry05 View Post
    Rep points given due to the fact you worked in Ed Gein on a Fat Bike thread.
  1. Drilling
    By tnevaneb in forum Weight Weenies
    Last Post: 01-26-2015, 06:29 PM
  2. Spam: Surly Rolling Daryll rims......in GREEN!
    By donkey in forum Fat bikes
    Last Post: 12-21-2011, 06:11 PM
  3. Replies: 2
    Last Post: 10-05-2011, 11:34 AM
  4. Rolling resistance / rolling faster
    By MultiRider in forum Wheels and Tires
    Last Post: 07-21-2010, 04:49 PM
  5. Q about Drilling.
    By I Like Bikes in forum Weight Weenies
    Last Post: 01-21-2005, 01:05 PM
