This is for a Mukluk 2: I was sent home from the shop with a 5 mm spacer that's too wide, looks like a 2.5 mm would be about right. Also looks like I need a mount spacer as the body of the brake hits the fork between the mounting bolts.
I'll go to the shop to get these things, but I want to know if I'm on the right track?
Go to the Carver website for instructions. When I mounted my o'beast fork on my Muk with the stock wheel set, I used the 5mm spacer Carver included and my Juicy 5s with a 160 rotor installed easily.
Using a regular front spaced hub my rotors just hit the fork. I had to grind down the fork slightly so the rotor would clear. I wasn't thrilled to grind on the fork but it has not caused any problems so far. No problem with BB 7 caliper hitting the fork but I use 185 mm rotors so that puts the brake caliper in a different place.
Reason: spelling
I was wrong about the caliper hitting the fork, got that part working. As above, the rotor just rubs the fork, not too excited about shaving it down either.
I can't find any instructions on the Carver site, but I think there is an actual clearance issue.
Theres a few of us that were in the same boat, i cut up an old brake rotor.... cut the centre out of it and used it as a 2mm spacer. Then ordered a couple of Hope 2mm spacers from CR.
My issue was using Hope Floating rotors, if i was using regular rotors i would have been ok with the 5mm spacer, the Hope rotors are fat and the rivet joiners from the alu to steel braking surface stick out wanting to shave your fork.
Using a regular front spaced hub my rotors just hit the fork. I had to grind down the fork slightly so the rotor would clear. I wasn't thrilled to grind on the fork but it has not caused any problems so far..
I had the same issue with the carver fork and salsa enabler hub, the carver supplied spacer was too thick, it would mount but then all of the adjustment space for the caliper was used up (bb7's)
I ended up using some 2mm nylon washers behind the rotor, no more issues
Mounting of brakes on the carver fork is not a precision operation, there is a fair bit of slop in the barrel nuts inside the carbon fork. I thought mine was off at first but ended up working perfectly. A simpler option would be to use 6 aluminum washers instead if it just won't fit. (after all, the spacer puts the rotor closer to the fork) Just make sure the screws don't bottom out before they tighten up properly.
It should fit fine. I mounted mine with the same setup. O'Beast carbon fork, their supplied spacer, Salsa stock front hub, stock Avid brake rotor, and BB7 (and then XO hydros). No clearance issues of any kind. Something is amiss.
Thank you all for your concern but I think my fork will be OK. I only had to remove a tiny bit of carbon around where you can see the exposed barrel bolt. It did not get anwhere near the fork legs and did not take more than .03" away from the surface around the barrel bolt. It is an early fork and I suspect they built that area up more than they intended. It is a 185 rotor so both posts were in the way.
That said it is never fun to have to customize new anything let alone carbon fiber things.
"We run into this occasionally. Since they are hand molded, there can also be some variation between forks, as well as hub setup.
There is actually quite a bit of variation among front hubs. The gap between the rotor and caliper mount is as small as we could make it, for braking rigidity. Occasionally we will encounter a rotor hitting the caliper mounting studs. Sanding the rotor spacer a bit or gently sanding the caliper mount will take care of the problem, and won’t affect the performance or warranty. Depending on the hub, a very thin shim washer behind the locknut will work as well."
I'm using a salsa hub, o'beast fork, and bb7's as well. After installing the 5mm spacer my rotor comes within a rotors width of the fork. Even when flexed while turning there is no rub, but it was disconscerting at first. My solution would have been to use some smaller washers as spacers to bring the rotor back to center within the caliper. As it sits now my bb7's caliper adjustment is maxed out distally.
After filing down the spacer about .5 mm I got the clearance I needed. I like c/f weave, but the gloss black without decals looks really good on the Muk 2.
Post a pic of that beauty!
.. If I see this bike on display with those GT bars, I am bringing my hacksaw!!
