Page 9 of 9 FirstFirst ... 56789
Results 401 to 433 of 433
  1. #401
    Oct 2016
    One day maybe
  2. #402
    Reputation: Dilligaff's Avatar
    Nov 2015
    I'm still loving my NTB Ti and smile every time I ride it, even after almost a year. ive put it though its paces many times, probably more so than most people. I've upgraded a few things on it but still have a ways to go.
    Here it is with rear FBR and front Bud on 100mm tubeless wheels, Sunrace 11-42 rear and 22/32 front. Does anyone know if a 2XL clears in the back? It looks like it might. The Bud clears the front ok but I had to remove the fender. I have a straight fork for winter to run a larger tire.
    I even went bikepacking with it this year on an 80 mile long ATV trail. It looks positively massive compared to my wife's Trek with 26x2.2's on it.
    It it wasn't exactly svelt but the bike handled it well and the wider tires were perfect with the crappy trail surface. My wife kept washing out with her 'thin' tires.
    I cant can't wait to go again but next time whenever it's warmer so we can leave the 0° sleeping bags at home.
    Nothing to see here, move along folks.
  3. #403
    Sep 2015
    @Dilligaf what rear rack is that?
    Sent from my iPhone using Tapatalk Pro
  4. #404
    Nov 2015
    This one.
    Ibera Rack IB-RA4 (for Non-Disc Brake Mounts).
  5. #405
    Nov 2016
    I have a dilemma I need some help with. I have FINALLY convinced myself to buy a Fattie, and after much research I settled on the night train bullet (aluminum). I just tried to order today, and its out of stock. Do I step up and hit the titanium for another 500? Or do I drop back to Sturgis bullet at 1500? Any suggestions ?
  6. #406
    Jul 2016
    I can't see you ever regretting the Ti if you can afford it.
  7. #407
    Nov 2015
    I am not sorry at all and would buy the same bike again in a minute.
  8. #408
    Nov 2016
    I think I'm finally convinced to pull the trigger. Anyone aware of a better derailleur hanger option for these things? I saw a better machined option for the aluminum frame out there, but haven't seen one for this Ti frame. Or perhaps these are a little higher quality than the aluminum frame's hangers in the first place?
    Here's the seller for the other frame:
    Motobecane Derailleur Hangers
    Won't stop me from buying, just curious.
  9. #409
    Nov 2015
    I have not had an issue with mine at all and it came with a spare that I keep on the bike just in case.
  10. #410
    Nov 2016
    Glad to hear it! I caved in last night and bought the NTB Ti. I've been thinking about it way too long, so I decided I need to quit wasting time.
    Thanks for the info on this forum! I'm sure I'll be back with questions.
  11. #411
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Has anyone ran their Night Train ti with 27.5 plus wheels?
    Cheers
  12. #412
    Nov 2016
    Received the bike on Thursday and have been loving it! It's exceeding my expectations. I'm really digging the titanium, although it probably wasn't necessary. I'm considering a rigid fork replacement for the salty minnesota winter, but I haven't decided yet.
    @Dilligaff, out of curiosity, what size is your frame and what size is your frame bag? Just trying to get a reference so I can pick a size of that bag.
    Nov 2015
    It's a large frame and the large frame bag. I have the medium as well which gives a little more room for a water bottle but for this trip I wanted more space.
    I picked up a rigid fork for $50 used (with axle) just for winter to run a 2XL in the front.
  14. #414
    Nov 2016
    Quote Originally Posted by Dilligaff View Post
    Great, thanks for the info! Is that a steel fork that you're running? I'm not crazy about the idea of carbon. I might grab a Framed aluminum fork or something on the cheap end, but I need to do a little more research at this point to see what's out there.
  15. #415
    Nov 2015
    No, it's aluminum. It was a take-off from someone who switched to a Bluto. I'd love a carbon but the $$$ just isn't there.
  16. #416
    Nov 2016
    First snow day with the new bike--what a blast! I love this thing, just need to find a good rigid option before I salt the Bluto to death.
  17. #417
    Nov 2015
    Well, I couldn't find anyone who tried to fit a Vee Snowshoe 2XL on the rear of a Night Train Titanium, which are not the same as the aluminum version. I am sorry to say they don't fit on 100mm wheels, but I have not tried them on 80mm wheels yet.
    But it is a tad larger than my FBR tires, which measure out to be 4.7" almost exactly (100mm wheels) and work flawlessly. The 2XL measures 5.03" on the same rim, which doesn't sound like a lot until you put them next to one another.
    Just thought I'd provide an update. I have a take-off rigid aluminum fork it will fit on easily that I'll swap on for winter.
  18. #418
    Nov 2016
    Thanks for the update, I was hoping the XXL would fit! I'm still on the 80mm rims, but I'm still probably out of luck.
    Which aluminum fork are you running? I go back and forth between just running the Bluto in winter and grabbing the Framed alloy fork for a seasonal swap. Loving the Bluto, I just don't want to wreck it with salt.
  19. #419
    Merendon Junkie
    Dec 2011
    This is my Night Train with plus wheels and tires. I really like how it rides with them. It will be my default configuration from now on, leaving the fat tires for those extra chunky trials or beach rides.
    There was some bb drop vrs the fat wheels but the BB is still about 1 cm higher than my El Mariachi 29er with 2.4 tires.
  20. #420
    Dec 2010
    I've had mine almost one year now and have been riding it year round.. tight technical, off-camber rock climbing, dirt, snow.. anything in the way. Love the bike!
    Tonight I mounted a new rear tire, Origin 8 Tsunami and over-tightened / broke the rear thru axle (so damn worried about a loose axle ruining the rear hub / freehub as discussed in the Motobecane Night Train thread).. Does anyone have a good source for a couple replacement rear thru axles?
    Thx!
    Update: Axle is M12x1.75x229 -- found some options online after lots of searching. You can go back to Bikes Direct for a replacement, but would encourage the SRAM Maxle Ultimate RR as it looks like a lot better quality. I have the latter on the the way for a back-up.
    I did run by the hardware store and picked up their smallest EZ-OUT / drill bit set and took my time w/ it and was able to get the broken bolt out. Then I chased the threads w/ my tap set, ran the new screw through the die to make sure it had good threads, and slapped everything back together w/ a few drops of blue lock-tight -- took it for a quick ride in the neighborhood and it was great w/o loosening.
    Happy riding all...
  21. #421
    Hooligan
    Reputation: dirtdawg21892's Avatar
    Motobecanes Titanium FatBike final specs and release date.
    I swapped out my stock hub for a bitex one from bike hub store. This will be my third one, (I sold the others with the bikes they were on.) I would recommend them to anyone. For the price they absolutely can't be beat. 54 engagement points and readily available replacement parts for the win.
    Quote Originally Posted by Optimus View Post
    Hell of a jump, dawg. Even though they're baggy shorts, I'm surprised that you can fit your balls into them.
  22. #422
    Hooligan
    I also put on a carbon fork. It saved bout 2 pounds over the bluto and it rides nice.
    I've also been working on setting up the mule foot rims with kold kutters, and those have been pretty fantastic. I have been running 4.8's on 100mm rims for powder and 4.0 on 80's with spikes after it settles and gets icy.
  23. #423
    Replacement through-axles?
    Quote Originally Posted by th1npower View Post
    Hey th1npower,
    Sorry for the creative editing of your post, but was wondering if you received/have some time on the SRAM replacement axle. If so, still recommend it?
    All,
    Anyone else have to replace their rear axle/have a recommendation for one?
    Mine is behaving strangely, and I'd rather replace it before it forces me to do so.
    Paul
  24. #424
    Dec 2010
    ..I didn't get the Maxle in the end b/c it was delayed, out of stock, and said the hell w/ waiting since mine was fixed.
    a mtn bike & dirt bike buddy is a helluva machinist and will make me a new one if/when needed.
    I still think the Maxle looks a LOT more durable and well-built compared to the stock Kinesis axle. Almost all the reviews from on here say the Maxle is the way to go (kind of like a Hope rear hub)...
    ..sleep is good...
  25. #425
    Reputation: Captain_America1976's Avatar
    Mar 2005
    Quote Originally Posted by dirtdawg21892 View Post
    I have been running one of these hubs on my Mukluk for 1.5 years with zero issues.
  26. #426
    ..I didn't get the Maxle in the end ...
    Thanks th1npower,
    Glad your solution has worked out well for you.
    I appreciate the lead on the Maxles, and the thread spec you gave above. Will follow up once I've ordered/used a replacement. For now, the Kinesis one is still hanging in there, but just barely.
    Thanks,
    Paul
  27. #427
    Reputation: scottspark60's Avatar
    Feb 2013
    Happy riding all...
    I'm also looking for a better quality replacement rear axle for my Sturgis which is also a 12x1.75x229. The SRAM Maxle being sold at ebay are 12x1.5x229.
    Any leads as to where I could get the 12x1.75x229 SRAM Maxle if there are any?
    Thanks.
  28. #428
    Quote Originally Posted by scottspark60 View Post
    Dear Mr. Spark,
    With th1npower's suggestion/spec in hand, I found a Maxle Ultimate on amazon.
    Will report back when I have it in hand and have put some time on it if you can wait a bit.
    Otherwise, I see that Bike Parts | Road Bicycle Parts | Bicycle Repair Parts - Niagara Cycle also have them, and I have heard good things about them in the past (have never used them).
    Good luck,
    Paul
  29. #429
    Dec 2010
    .. Any leads as to where I could get the 12x1.75x229 SRAM Maxle if there are any?
    Thanks.
    As JPaul suggested go w/ Amazon. Otherwise, http://robertaxleproject.com/ ...looks like a great bolt-on axle.
    Best of luck!
    Micah
    ..sleep is good...
  30. #430
    Feb 2013
    Best of luck!
    Micah
    Thanks Paul and Micah.
  31. #431
    Quick follow up on ordering a through axle from Amazon:
    Ordered per specs discussed above (12x1.75x229), but received an axle with 1.5 pitch.
    I'm assuming it is a pick/ship error based on the item description (see details below), but can't for the life of me figure out how to communicate w/Amazon that I would just want to exchange for the correct item.
    Will be returning it tomorrow, and likely order from Niagara once I return from holiday.
    Paul
    -------FWIW, The specifics of what I ordered in case anyone is feeling lucky------
    https://www.amazon.com/SRAM-Ultimate...229&th=1&psc=1
    - Product description includes: "RockShox Maxle Ultimate 20mm Thread M12x1.75 Rear"
    - One of the answered questions also specifically touches on the 1.75mm threading
  32. #432
    Sep 2015
    Quote Originally Posted by JPaul View Post
    Paul
    I just had and issue with them shipping me a rear derailleur instead of a front derailleur. They actually did it on the original order and replacement order. The manufacturer boxes were correctly marked. Someone had put the wrong Amazon sticker on it.
    Returns/exchanges go something like this. Go into your orders. Click on the item in question. Select return/replace. Fill in the radio box for incorrect item. I think it then pops up a box to fill in with comments on the item, issue, and if you want a refund or replacment. Somewhere in there you can either choose to do the return by email, chat, or phone call. I did phone call on the original and then followed up with an email because they wouldn't 1 day ship or give me anything for their mixup (they changed it to 1 day shipping and gave me $5 credit). When the replacement showed up wrong they didn't have anymore in stock so I did email and complained about their repeated mixup and got another $10 credit. And then I ordered from somewhere else.
  33. #433
    Quote Originally Posted by Cerpss View Post
    Thanks, Cerpss, will look for that next time. A phone call or e-mail would have been ideal.
    Cheers,
    Paul
  1. 2106 FOX 34 release date?
    By SUB1647 in forum Shocks and Suspension
    Last Post: 04-05-2015, 03:31 PM
  2. Marzocchi 350 NCR Release Date?
    By staz in forum 27.5
    Last Post: 06-24-2014, 01:24 PM
  3. Fox 34 release date?
    By capslayer in forum All Mountain
    Last Post: 03-30-2012, 04:43 PM
  4. Fox 34 release date?
    By capslayer in forum Shocks and Suspension
    Last Post: 03-29-2012, 03:49 AM
  5. Fox DHX-air release date?
    By Renegade in forum Shocks and Suspension
    Last Post: 06-28-2011, 11:55 AM
