Results 1 to 35 of 35
    Smile Moonlander Racks - Show and Tell
    I am looking for ideas on what works for the Surly, Moonlander. Please post up photographs/descriptions on both front and rear racks.
    Thanks,
    Justin
    aka RossC
    Reputation: ocean breathes salty's Avatar
    Salsa minimalist works nicely up front - although I broke it on the first ride. I've ordered some beefier steel to replace the mount that broke and then it should be perfect.
    The rear rack is just some cheapy thing that I bent to make it fit.
    Thanks for the response OBS. I think I am going to try the Salsa Minimalist rack up front. Could you please explain where/why the Minimalist rack failed. I am also eyeing that bag that you have on the Minimalist? Brand/product name?
    On another note I contacted Surly about using there racks and they said that they do not fit the Moonlander. So keep the ideas coming.
    Justin
    Jun 2005
    The Old Man Mountain Cold Springs front rack is over 6 inches wide between the struts. The Cold Springs rear rack is a bit narrower. I think these are the widest production racks available (challenge?) which should make them top candidates for the Moonlander. Their mounting options are very adaptable. I prefer the front Cold Springs rack both front and back on my Pugs because of the maximal clearance and the lack of a raised stop on the deck, allowing for longer gear items like tent poles. But it takes more fiddling to get it mounted.
    check with Surly before you add any rear racks to the Moonlander.The official word from Surly is NO rear racks on the Moonlander because you have to space the racks so far that there is too much stress on the frame bosses.Surly say Moonlander is frame bags ONLY! Do check with Surly BEFORE fitting any rear racks to avoid invalidating the guarantee and possible injury or DEATH through possible failure..
    Quote Originally Posted by OlafSeelhorst View Post
    Interesting! I talked at length with one of the guys at Surly and he did not mention this regarding the rear rack. In fact he actually said if I find something that works to let them know because he was getting calls about it. I will give Surly another call regarding the rear rack. Thanks for the heads up.
    aka RossC
    The other option is just to bend the crap out of the rack so that it fits the rear end with zero stress points or spacing adapters. If it wasn't designed to have a rear rack, why has it got the braze on's? Seems a bit strange?
    @ Jeepgear - The minimalist failed after taking an absolute beating on a rock strewn 30km section of trail. It uses a single piece of16mm wide x 2.5mm thick (?) steel to brace between the rack and the fork crown. That bit of steel has a tight radius 90 degree bend in it when sheared under the repeated loads. I've since ordered some 20mm wide by 5mm thick stainless steel to fabricate a replacement.
    The bag on the front is actually a tent. The tent weight is 1.7kg and the rack has a 5kg limit so I wasn't stressing the rack too greatly but I don't think Salsa were thinking of that weird harmonic resonance fore-aft rocking that the moonlander develops when they were designing the rack. It nearly broke the rider too
    giddy up!
    Reputation: donkey's Avatar
    Quote Originally Posted by ocean breathes salty View Post
    Why not just bolt the rectangular block directly to your fork crown via the holes that are drilled through the crown?
    That's how I've always installed these racks and it's been super easy everytime.
    B
    www.thepathbikeshop.com
    Human Test Subject
    Reputation: Volsung's Avatar
    I've got a OMM cold springs on my ML. They custom made some of the connecting bits at no extra charge.
    My LBS had previously talked to QBP about racks and they made no mention of possible death/dismemberment/involuntary virginity loss. In fact, Surly's own description of the Moonlander on their website says "Mid-blade thru-eyelets and lower rack barrels are included for installing fenders and racks"
    aka RossC
    Quote Originally Posted by donkey View Post
    B
    Mostly because:
    a. I didn't really think of it and was rushing the job
    b. The extra stand off distance away from the cables made the tent fit a little better.
    OBS - Thanks for the information on the Salsa Minimalist Rack. Please post up some photographs of the rack once you make the changes.
    Volsung - It is good to know that OMM is working on the Moonlander. I would like to see some photographs if you get a chance.
    I left a message with Surly regarding the rear rack warranty issue. I will post up my findings.
    Justin
    Reputation: JRWPIX's Avatar
    The Topeak Explorer Disk rear racks fit the Moonlander both front and back...I added a couple of presta nuts and a longer screw to space out the left rear....the front just dropped right on....I added the slide and click wire Topeak basket onto the front, as I need it for commuting and utility. Great price-beefy black build! click on my avatar for a larger view <-
    Quote Originally Posted by JRWPIX View Post
    The Topeak Explorer Disk racks fit the Moonlander both front and back...I added a couple of presta nuts and a longer screw to space out the left rear....the front just dropped right on....I added the slide and click wire Topeak basket onto the front, as I need it for commuting and utility. Great price-beefy black build! click on my avatar for a larger view <-
    Thanks for the information on the Topeak rack. I am pretty sure I can find one locally to look at. Lately all of my extra time has been spent riding the bike. Hopefully soon, I will make it down to the LBS to check out the options in person.
    Finally made it down to the LBS and ended up picking up a Surly Nice Rack(rear) for the front of my Moonlander.
    Side profile - The one modification that I made was a simple bend to the upper bar closest to the stem. I put it in a vise and gave it a more vertical stance. This increase the clearance between the rack and the front of the frame. On closer inspection you can see where the powder coat has chipped off. In the future I will touch this up.
    The attachment points turned out to be really simple and solid.
    Credit - I got the idea for this from this thread. Post #7
    its a Pug's life
    Thanks Devian your threads have been a big inspiration.
    I have yet to make the changes to the Surly rack. I am going to run it like it is for a while.
    Human Test Subject
    I'd put a pic of my OMM rack but I don't have 10 posts.
    Lovin the nice rack on the front though.
    Quote Originally Posted by Volsung View Post
    Well you have 7 more to go. Then I would like to see some photographs.
    Moon Child
    Both racks are rear Surly Nice Racks. The install of the front mod is per jeep gear's install.
    The rear install is stock with one mod. The rack sat offset due to the offset of the rear tire. The left side was very close to the tire. Of course, you can bend the left side out as the rack is steel. But, I noticed you can bolt the stay on the inboard side of the mount. Perfect alignment and no bending.
    Reputation: TX K@@TER RED's Avatar
    Feb 2012
    Quote Originally Posted by Fresno View Post
    Very nice!
    Geordie biker
    Reputation: saltyman's Avatar
    I wasn't going to get racks for mine but looking at these examples it's pretty tough to resist!
    2014 milage so far - 2,485
    www.ukfatbikes.co.uk
    Thanks for the explanation. Next time I am at the local bike store I am going to have another look at the rear rack. Now all you need is a seat on the rear rack so you can bike that perpetrator out of the woods.
    Reputation: t0pcat's Avatar
    May 2012
    bump so i can find this again
    Saw
    Saw is offline
    Mar 2012
    Quote Originally Posted by t0pcat View Post
    Thanks, T0pcat. I love reading older threads that contain useful or cool information.
    @Fresno
    That bike is Sick! I love it. That is amazing that you can go Code 3 on that thing.
    Any chance we might get to see an action shot with you actually using your bike in the field? How about one with your long gun(s) strapped to it?
    That would make my week.
    Stock rack on moonlander
    Here's a standard MTB rack (albeit one designed to fit a battery as well as panniers) that I mounted to my moonlander. It took a little bit of work, but wasn't too bad.
    In addition to the standard mounting hardware, I needed:
    2x 1/4" aluminum spacers (from a leftover planet bike fender kit)
    2x 1/2" aluminum spacers (from the small parts section of my local hardware store
    3x extra-long mounting bolts w allen heads (not sure of the length, but they needed to accommodate the spacers.)
    1x extra-long mounting bolt w a hex head (I found it easier to tighten the drive-side bolt with a socket wrench than an allen key, hence the different head.
    The top rack struts hit the frame at the seat-stay braze-ons, so I just added the 1/4" spacers to move both sides outboard, and problem solved.
    The lower seat-stay braze-ons each required a 1/2" spacer, each towards the non-drive side of the braze-on, to approximately center the rack on the wheel.
    It's been fine, requiring only minor tightening and and surviving a pretty good hit during an over-the handlebars high-speed encounter with a posthole. I need to take it on and off fairly regularly, but f I were going to mount it longer-term I'd use some blue loctite to keep everything nice and snug.
    Attached Thumbnails Attached Thumbnails Moonlander Racks - Show and Tell-dsc04432.jpg
    Very cool. I had two rear racks on my Pugs (ala Devian) and now will get two rears for my ML.
    Thanks to jeepgear for paving the Moonlander way!
    Reputation: GnarBrahWyo's Avatar
    Jun 2012
    What I love about these bikes is no one cars about the weight. Mine will be north of 40 lbs once I get what I want on it. lol
    Reputation: bighit's Avatar
    Quote Originally Posted by GnarBrahWyo View Post
    Isn't that the best part of owning a moonlander, throwing your hands in the air and saying I'm in it for the fun of it.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Jan 2015
    check with Surly before you add any rear racks to the Moonlander.The official word from Surly is NO rear racks on the Moonlander ...
    I know this is an old thread, but it was the first that came up on my search for "rear rack moonlander" so I thought I'd update it.
    Here's the Surly link about their rear rack....
    FAQs | The Information Hole | Surly Bikes
    After seeing this thread I decided to take a look at my rear rack while cleaning the drive train. The bolt on one side had a bend in it. I recall thinking having to use a 12mm spacer to make my rear rack fit seemed a little dodgy. I'll swap the stainless bolt with a grade 8 one and see if it holds up better.
    Reputation: surlybugger's Avatar
    Jan 2013
    ... and if we just ... Just Brazed a Rig-Rack
    Purchased some 3/8" steel brake lines, Mapp gas, silver brazing wire, and the associated flux. Then I made up this hyar rack & bag combo, for some cool adventures this summer. Camping gear can now be carried with me; or other fun toys, such as pictured below.
    The bags are are clone molle gear, that can found at just about every surplus or Airsoft retailer.
    Got the scale crawler & film gear in back this weekend. Fun times.
    Simple 1/4" birch plywood for the floor.
    Hope I inspire y'all to make some cool parts for your bike.
    That is beyond cool! Wish I had the skills/time/knowledge/space/tools/etc to pull off something like that.
    What photo shoots are you planning on using the scale crawler for?
    Jan 2013
    Don't wish, brazing is easy. I learned from you-tube for the scale crawler cage work. The only hard part is the manual shaping of the steel to fit. Arthritus sucks!
    The hobby is to make a cool turk (or jerp if you like them), as much scratch built as you can (for awesome-ness), then make some cool videos, or even short films if your creative enough. Search you-tube for Headquake. Amongst many, he is one of the most creative.
    Aug 2015
    How have those racks worked out? Its been years since this post
    If anyone with the same racks on their bike, I need something for my mountain bike I'm turning into a tour bike.
    Apr 2014
    Quote Originally Posted by surlybugger View Post
    OMG DUDE THAT IS SO COOL. I really want to make something like that now!! How did you get started with the welding if I may ask?
    Quote Originally Posted by edenflux View Post
    Mine are still going strong! From this winter:
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Pelago Commuter front rack on my Moonlander.
    Straight bolt-on fit. No spacers, no modifications, no bending.
    It's designed for a regular bike, so I installed the bottom plates to the insides of the barrel bosses on the fork. No biggie. Clearance is good, about the same as the fork itself.
Members who have read this thread: 11
