Results 1 to 13 of 13
    Sep 2004
    Moonlander fork on a Pugsley???
    Will a moonlander fork work on a Pugsley frame. My fork has a slight bend in it and I might be replacing it. Just wanted to know if the handling be the same? thanks
    Reputation: BoogieMang's Avatar
    Mar 2011
    Considering that the Neck Romancer Pugs comes with a Moonlander fork on it, no, I don't think that it will work.
    Human Test Subject
    Reputation: Volsung's Avatar
    causes genital fires. don't do it.
    Feb 2012
    my necro pug has a non offset moonie fork, there may be some difference in wheel dishing?
    Reputation: Weinerts's Avatar
    hmmm chestnuts roasting smell...
    My bike is heavier than yours - it does not have Carbon or Titanium parts - I love it!
    I have moonie fork on my black ops necro neck romancing pugs - works.
    Fork works fine with the frame, but you'll need a new, non-offset front wheel. It'd be better just to buy another offset Pugsley fork.
    Also what do you mean your fork is bent?
    Dec 2012
    They sell an off-set version of the Moonlander fork now as well, standard 135mm offset rims work fine.
    I have the non-offset moon lander for on my black pug with a daryl up front and a marge in the rear. You can run what ever rim you want in the moon lander fork, I got it simply because I loved the cage bolt options from my time using a Salsa Enabler fork on my 29'er.
    either moon lander fork works fine on a pug.
    Re: Moonlander fork on a Pugsley???
    The offset Moonlander fork is a different offset then the pugsley fork.
    0 offset
    bikeboatbrewski
    Reputation: scottybinwv's Avatar
    Jun 2010
    kids these dayz
    Sep 2004
    I bought the bike used and the fork is bent a little just below the crown on both sides. The bike was jumped a little before me. I'll ride it like it is for now, I'm not hard on the bike so not really worried about it getting worse but I do plan to replace it with the stock fork when I can find one at a good price. Seems there was a recall for a problem but not the same thing as my fork.
    Dec 2005
    Quote Originally Posted by cottonball View Post
    Just so no one else makes this mistake. The fork bend is by design. It matches a similar bend in the frame so the the wheels are interchangeable. Moonlander offset forks will have a similar but greater bend putting the hub 28mm offset to the right instead of 17.5mm so that is matches the Moonlander frame. Non-offset forks for either will be symmetric. All 3 require different wheel builds.
  1. Moonlander vs. Pugsley
    By Larry Endomorph in forum Fat bikes
    Last Post: 06-10-2013, 09:19 AM
  2. Replies: 79
    Last Post: 01-15-2013, 01:10 PM
  3. Moonlander Paint Job on a Pugsley...kind of
    By SwillyBear in forum Fat bikes
    Last Post: 01-10-2013, 05:57 PM
  4. moonlander, pugsley awesomeness
    By AJT in forum Fat bikes
    Last Post: 02-08-2012, 08:37 AM
  5. Pugsley to Moonlander wheel compatibility
    By western high plains in forum Fat bikes
    Last Post: 08-19-2011, 08:40 PM
