Page 1 of 12 1234511 ... LastLast
Results 1 to 100 of 1102
    Reputation: Larry Endomorph's Avatar
    Jan 2011
    Mongoose Beast modifications
    I started another thread ( Walmart Mongoose Beast sucks! ) hoping that it would be about the bike itself and modifying the bike. It didn't work. I'm going to try again.
    I knew what I was getting into, and I'm glad I bought my Beast. I'm not saying it is an awful bike. My premise is that the bike is close to unrideable in its stock form. It's way too heavy and the gearing is way too hard. The bike will be modified! This ought to be fun!
    Let's keep this thread to discussions about the bike!
    How have you modified your Beast? What parts did you use? How much weight did you save? Got any pictures?
    Out to ride
    Dirt Huffer
    Reputation: AC/BC's Avatar
    Quote Originally Posted by Larry Endomorph View Post
    Thanks for starting this again!
    I might drill out my wheels later this afternoon.
    Reputation: jvm051's Avatar
    So does the rear take a special cog to change the gearing or just a standard cog?
    Mar 2011
    Quote Originally Posted by AC/BC View Post
    Would you please weigh your wheels before and after. Especially the front. Maybe we can make some deductions to arrive at the approximate weight of the rim itself.
    Mine doesn't arrive until next week ... But if no one has done so by then, I'll throw up any and every number I can think of as they relate to sizes, geometry, and weight (to the limits of my scale).
    Tires = Already have a set of Origin8 Devist8er's on the way, and I'll give an impression of them, also ... But must admit that I can only compare them a standard width MTB tires that I have ridden, so it won't be a proper comparison.
    My intention is to ride it for a bit, and sort things out, but am thinking along the lines of widening a set of disc capable hubs Al La Sryanak's method - Widening a hub ?
    Then coming up with appropriate mounts for the calipers, and investigating at the same time, what a triple chainring might do for things.
    The basic idea being that as many components as possible be taken from the junk box, or salvaged off an as yet to be found donor bike.
    It will never be ultra-high-tech and modern, but what I buy today is usually soon outdated, anyway.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Can you post pics of the bottom bracket?
    gran jefe
    az, it's a cup and cone square taper bb. 68mm diameter, and really long. i saw a picture somewhere. i think it was the blogger with the "90 of the fun at 10 percent of the cost" post. not that post, but one of the followups. edit: nope, not that one.
    Bikeabuser posted it below. Thank you, BA.
    AZ
    AZ is offline
    Thanks Gents.
    Dirt Huffer
    Weights
    Tire 1........2821g
    Tire 2........2785g
    F.Wheel.....1846g
    R.Wheel.....2713g
    Tube 1.......743g
    Tube 2.......750g
    Rim Strips...95g/ea
    Bar+Grips...671g
    Post.........449g
    Seat... who cares
    Crank.....1180g
    Pedals......379g
    Mar 2011
    Hmmm, this is interesting.
    Sounds like the rim weighs less than 1300 grams and maybe somewhere as low as 1250 grams before drilling. Not too bad considering the very thin walled Flattop 100s were about 1130 before drilling and heck even the Uma 90s are about 1080 grams even with the lightening holes.
    That WAG is based on the assumption that 36 spokes (14 gauge straight) weigh about 240 grams for typical fat wheel lengths of about 260 mm and cheap brass nipples weigh about a gram a piece, and an aluminum 135 front hub weighs in the 240ish gram range but this relies on solid steel axles so add another 50 grams. Total 566 grams.
    Nov 2012
    750 gram tubes!!!
    And I thought that my OEM On-One Fatty tubes were made of lead at 600 grams each!
    It will be an easy and cheap upgrade to go to Q-tubes at about 300 grams each.
    Mar 2011
    With a tube like that i say you just glue the tube to the rim like a sew up and run it sans tire.
    Could be the new trend. Forget tubeless, I'm biking tireless-ly.
    Reputation: duggus's Avatar
    Quote Originally Posted by bikeabuser View Post
    Here ya go:
    Product Preview Origin8 Devist8er Fat-Bike Tire | FAT-BIKE.COM
    Origin8 OR8 Devist8er 4.0 tire
    Reputation: Houndog45's Avatar
    Oct 2010
    Not really an upgrade...
    Attached Thumbnails Attached Thumbnails Mongoose Beast modifications-dsc01246.jpg
    Oct 2010
    Neither is this...
    Attached Thumbnails Attached Thumbnails Mongoose Beast modifications-dsc01241.jpg
    Oct 2010
    I plan on ordering some Devistater tires as well...
    Also gotta get a smaller chainring...
    Ordered a threaded to threadless adapter..
    I also have access to a tig welder.
    Just might slacken up the front and shorten the rear...
    WTF it's a $200 bike....
    gran jefe
    Son, all your paint is gone!
    Quote Originally Posted by Houndog45 View Post
    Oct 2010
    Quote Originally Posted by Bill in Houston View Post
    Because stock sucks.......
    Oct 2010
    I'm not new to upgrading Walgooses hahahahha ...
    I must add that it now sports some Racing Ralphs
    and a brooks saddle...and bb7s.....
    Attached Thumbnails Attached Thumbnails Mongoose Beast modifications-finished-mongoose-009.jpg
    gran jefe
    whatcha gonna put on in its place?
    I read that, and they're obviously better than what comes on the bike.
    A pair should be arriving Tuesday.
    I've had the same thought ... Gotta get it and ride it first.
    ETA,
    I've got access to CAD software and the ability to perform analysis, so it might be possible to get decent response via fork modification ... Just doing an overlay, it appears that the head angle is 74 degrees.
    Angles will be the first thing I measure.
    Oct 2010
    ETA,
    Please keep us updated...
    Oct 2010
    Clear coat.....
    Dirt Huffer
    Wally Drilliums
    1.5" hole cuts, left two spaces near valve uncut
    Front wheel: 1549g
    Rear wheel: 2490g
    Shed 524g
    The drilling felt much the same as the Daryls - good cutting resistance, similar thickness.
    gran jefe
    Clear coat.....
    very nice.
    Absolutely ... But the bike might not get here until Friday.
    Kind of strange, in the cart Thursday, with an actual delivery date ... Waited till Friday, and it became a 2nd thru 5th estimate.
    Front wheel: 1549g
    Rear wheel: 2490g
    Shed 524g
    Sweet ... Are you gonna paint them ?
    Dirt Huffer
    I think i'm going to leave them alone. My goal is to get this bike to 32lbs and spend less then $120 doing so.
    Reputation: jackbombay's Avatar
    Front wheel: 1549g
    Rear wheel: 2490g
    Shed 524g
    It looks like you used a handheld drill for that, yea? Nice work, did you just use a half round file to break the edge of all the holes?
    Oct 2010
    What does 524 grams work out to in lbs??
    Oct 2010
    I don't understand why the mixture of measurements on bikes..
    Tire size is in inches,,etc,,,other stuff in metric..
    I'm old and stubborn ..metric makes no sense to me whatsoever..
    Oct 2010
    Ok I googled. just a little over a LB...
    Based on what's been posted, 32 seems attainable.
    turtles make me hot
    Reputation: NYrr496's Avatar
    Metric is all based on ten. It's actually pretty easy. I'm 47 and I completely understand what you're sayin', but try it. It's easy.
    I like turtles
    Dirt Huffer
    Quote Originally Posted by jackbombay View Post
    I use a Dremel with a deburring bit but a file would probably work just as well.
    Two Headed Boy
    Reputation: Trower's Avatar
    1.155
    tSETFREEBYLOVEt
    gran jefe
    454 grams per pound.
    Dirt Huffer
    Can't wait to get the wheels and tires back on the bike and test it out.
    Just crunched the numbers. I'm looking at 10.62lbs of weight savings just doing the drilling, new tubes, and some "newish" used rubber. And thats all rotating mass, where it counts.
    Oct 2010
    Looks like a set of triple trees fixes front end flop..
    The adventures of bighit and his $200 Walmart fatbike | The UNDERGROUND!
    Didn't bighit say his forks were screwed up ?
    A guy on bighit's (I think) forum said he can ride no-handed with stock everything ... Just say'n.
    The problem might not even exist.
    ETA;
    Not trying to turn this thread into an argument, but wheel flop is highly subjective, and because such a change absolutely affects the geometry of the entire bike, there will be an obvious perceived difference in handling.
    The trail doesn't look to be excessive, and once I take delivery, I'll have more factual information to share about this subject.
    Tires also come into play, and he did change his tires ... Maybe they weren't a good choice for this geometry and aggravated a situation.
    The jury's still out ... But if it worked for him ... Good deal !!!
    Dirt Huffer
    ^ The fork didn't bother me that much but I do get where he's coming from. Perhaps once I get this bike traveling faster i'll find the problem more bothersome.
    Nice. I'm hoping that drilling the rims and swapping the tubes is enough for me to not have to gear down. I think BigHit is still running stock tubes and non-drillium wheels.
    Oct 2010
    Nevermind on the triple tree,I just noticed that wasn't the stock wheel...
    Nemophilist
    Reputation: TrailMaker's Avatar
    Geeeez....
    You guys are all bonkers. I kinda like that... personally.
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Interesting setup
    That (underground) thread is formated nicely for mobile use, why can't MTBR follow suit. Their mobile version sucks on an Iphone
    Quote Originally Posted by TrailMaker View Post
    Geeeez....
    That's why I love that cruiser frame you built
    Everything done to this bike, will be done with the intention of transferring most of it to another frame, someday.
    Nemophilist
    Your own frame, one might surmise? Hope, even?
    Someday ... Been practicing my brazing
    Might even make it a retirement plan.
    Reputation: bighit's Avatar
    Yep my forks bent. That's the reason why I was having a hard time getting the wheel in. One leg looked off and sure enough it is. I got to bend it back now.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    Dirt Huffer
    Reputation: Siddhartha Valmont's Avatar
    Feb 2013
    These wheels looks great with HuDu and drilled rims
    Sorry for the already covered questions, but the threads about the Walgoose Beast keep on multiplying and it is difficult to find technical details among arguments (no offense meant):
    Are the wheels built symmetrically ? Or if the front/rear is built with an offset, is it because of the frame/fork or tech constrain (chain-line...) ?
    Is the front and rear hub 135mm ? Or is it a 100mm front / 135mm rear ? Or 135mm front / 170mm rear ?
    Dirt Huffer
    Quote Originally Posted by Siddhartha Valmont View Post
    Symmetrical build. 135/170 hub sizes.
    If you get one of these bikes, check your spoke tension. Mine needed to be brought up and another guy on here reported his spoke holes had "volcanoed" - YIKES!
    Feb 2013
    That's great news !!!
    It means having a summer wheelset (29er or 26) won't be as much a nightmare as with the original Pugs offset frame.
    This Walgoose might not be a great finished product as-is, but seems to have a lot of potential as a customization project starting point
    Who reported that ?
    I've only heard that from duggus, and I don't think he owns a Beast.
    That doesn't mean it's not true ... But until I see pictures, or read it from the source, I'm not gonna be repeating the claim.
    Dirt Huffer
    IDK, hard to sift through all the BS.
    Generally speaking the whole bike should be looked over due to lack of QC.
    It's a gamble. There will be winners and there will be losers. And sometimes BIG losers. That's the game. If you don't like the rules, don't play. Overall I think I ended up winning out with my purchase.
    For $200, I've got nothing to complain about.
    And totally with ya on the QC thing ... I'm going through the whole bike before I even ride it.
    Dirt Huffer
    Hope
    Ok, ive pretty much maxed out the rotational weight savings on this bike without doing anything too extreme. I can now happily report that i'm able to cruise at low intensity at 10-12mph flat land. At moderate intensity flat land I can avg around 12-15mph, and at full sprint i can max out the gearing.
    The bad news is this thing is still a beast up hills. I have yet to weight it. Maybe ill do that in a few days. Also note that the speeds I give were all on paved surfaces. I haven't taken the bike off road yet.
    Mods:
    300g Saddle
    250g XLC post
    2.2 "lite" tubes
    Black Duck Tape rim tape
    Hudu's
    I don't know what city that is, but I see you stopped at the "dream girls" for a pic ;-)
    29er
    and the bike also marked its territory
    Dec 2008
    Minneapolis
    Nov 2012
    i don't know what city that is, but i see you stopped at the "dream girls" for a pic ;-)
    lol
    Quote Originally Posted by Dan GSR View Post
    Beast
    Human Test Subject
    Reputation: Volsung's Avatar
    AC/BC, please don't ever park that next to my moonlander.
    Reputation: Velobike's Avatar
    Quote Originally Posted by Volsung View Post
    Worried about them mating?
    Latitude: 5736' Highlands, Scotland
    Feb 2013
    Quote Originally Posted by Velobike View Post
    (off-topic)
    He is maybe worried that he will unconsciously take this other fatbike home instead of his Moonlander
    (/off-topic)
  67. #67
    Mods:
    300g Saddle
    250g XLC post
    2.2 "lite" tubes
    Hudu's
    You need to do a gear change ... Right now you're riding a fixie, and it's geared wrong.
  68. #68
    Reputation: kbollox's Avatar
    AC/BC - I'm sure I'll see you out and about in the 612. I'll be on the red beast.. though probably not over the weekend as someone bent my seatpost last night. Got one on order at OoOBs.
    Auto-setback.
  69. #69
    Reputation: farleybob's Avatar
    May 2012
    Oh My!! :0)
    Gettin' Fat!...That's Where It's At!
  70. #70
    Reputation: Flat Again???'s Avatar
    Dec 2012
    Minneapolis looks like a very nice city. I appreciate the pics!
  71. #71
    AZ
    AZ is offline
    Back in stock, get em while you can.
  72. #72
    Dirt Huffer
    That sounds like a dare.
    This Beast actually could use a bigger gear except the start and go would require so much work. And with the current gear, my legs start to red line past 95. My new fear is that im going to burn up the rear hub braking.
    Quote Originally Posted by kbollox View Post
    Auto-setback.
    :rock:
  73. #73
    :rock:
    Mine grinds something terrible, and the (internal) lock tab looks very weak.
  74. #74
    nvphatty
    Guest
    thats ok for another 200 clams you too can have a pr.
  75. #75
    Dirt Huffer
    I took my bike out in the rain and rode down a few stair cases and off a few 1-2.5ft ledges. The rims are holding up good. I did hit some off road stuff too. But the gearing is really better for cruising. I think if i was going to regularly use this bike off road i'd want to put a smaller cog on it like bighit has done.
    That sucks you got a dud. I bet if you call Walmart and explain that the hub is defective, they'll send you another one. Also, you'll want to grease the BB and headset. Everything is dry on these bikes.
  76. #76
    Quote Originally Posted by nvphatty View Post
    When it dies, or gets replaced, the new back hub will ultimately end up on another frame ... Now who makes frames with 170mm spacing on the back
    Ehh, might have to make one ... Someday.
  77. #77
    Not that worried about replacing it ... Ride it till it dies ... I sure didn't buy it for the hubs.
    And everything on mine had grease.
  78. #78
    Quote Originally Posted by MiniTrail View Post
    of course it did sponsorboi
    Sorry that your's wasn't ... But I'm sure you remedied that
  79. #79
    Oct 2010
    Truativ 32 T Crankset,23 T Cog...Heat Bueing effect with propane torch,light glitter dust on frame,heavy glitter on forks...Waiting on more stickers to arrive for stickerbomb...
    Attached Thumbnails Attached Thumbnails Mongoose Beast modifications-dsc01264.jpg
  80. #80
    Turns out it's an annoying brake drag thing ... Just keep pedaling, and it's quiet.
  81. #81
    Rides like wrecking ball
    Reputation: Bulldog's Avatar
    Anybody in the 6' range riding a Beast? I'm willing to buy a new seatpost and even a longer reach stem. This isn't for typical/traditional high-end fatbiking (obviously). Just for riding around having a smile with the boy, as a replacement for the 80's cruiser I gave away last year that filled that role.
    Quote Originally Posted by Hesh to Steel
    With people liking mongoose and trek bikes now, what's next in this crazy world? People disliking the bottlerocket?!
  82. #82
    I was, had a 400mm seatpost and a 90mm stem with some riser bars, but since all the bearings in the wheels and headset were dry as a bone, I decided to remove the bottom bracket....they were dry as well, but as some others have reported the bottom bracket was cross threaded. Walmart now owns my beast again. Rip walgoose. How I hardly knew the....
    Quote Originally Posted by Bulldog View Post
  83. #83
    Cross thread ... Mine started to do that when I put it back together, but I noticed it, and didn't keep wrenching.
    Tight-ass thread, though ... Easy to cross-thread the thing if you're not careful.
  84. #84
    Dirt Huffer
    Road down more stair cases today. One had super long treads that were about as long as the wheelbase of the bike. The bike would drop front and rear at the same time. It was awesome. Still no issues with the rims.
  85. #85
    Quote Originally Posted by jvm051 View Post
    Thanks. I ordered a green one. You getting another?
  86. #86
    Impossible ... That thing is a piece, and you're an idiot who has wasted their money
  87. #87
    No I just returned it. I am going to wait for a company like Nashbar or performance to come out with one. Its too bad about the Walgoose because it was fun. Funny to see the reactions from people too.
  88. #88
    Nice old school look.
    2012 Moonlander.
  89. #89
    gran jefe
    deorman on this page is 6'2" and comments on how it fits him.
  90. #90
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    My inlaws live on the coast and walk the beach all the time. They saw pix of the "Beast" at their local Walmart and a guy told them it was designed to cruise the sandy beach. They called me before ordering them and I told them I'd find out some info.
    Are these bikes very ridable on compact sand in stock form, it will it be too hard for casual riders to pedal? They arent looking to mod them or really do anything other than ride them.
    14 Aurum, 16 Fuse, 17 T130
  91. #91
    gran jefe
    even after you fix the gearing, you'll have to convince your dad to run the tires at 8 psi, which could be a challenge all by itself.
  92. #92
    Quote Originally Posted by Mr. Lynch View Post
    Ask bikeabuser... he is the resident expert on them
    They are a fantastic deal for your typical Wal-mart shopper and they should have no need to ever maintain it (because *typical* walmart bike buyers have no knowledge of bike maintenance). They should have no problems hammering it on the beach or any other terrain... after all, it IS an "all terrain" bike according to the straight-shooters over at Wallyworld of wonders!
    OOFTA. I just had to, I'm sorry. It's a slow day, Friday, and I'm bored.
  93. #93
    ^^^ You remind me of a moth LOL
  94. #94
    ^^^ you remind me of a moth lol
    DITTO!!!!
  95. #95
    I guess I should cry, because you once again bumped this thread LOL
    Soon, very soon ... Vee Rubber will be selling their line of tires ... IN WALMART & your LBS.
    Your choices in Fat Tires will increase ... And you can thank the bike this thread is about, for bringing you lower prices.
    Experience the POWER of MASS MARKETING
  96. #96
    well we had yesterday off from this bullsh!t
    be thankful for that I guess
    Don't worry, next round of Beasts will be delivered very soon.
  97. #97
    Dr Gadget is IN
    Reputation: wadester's Avatar
    Assembly quality is a bit of a crap shoot, but if you buy in the store you can pick&choose. The fat tires do cruise sand well - once aired down to 8-10 psi. The gearing is ok for hard surface, but needs to be changed for sand, especially to get across the soft/loose to get to the wet stuff. You've got 36x18 stock. You can get as low as a 23t cog - but you'll have to get a new chain to add more than 2 teeth. I run 34x20 on my 29er, a 49" gear. Low enough to climb/do hard stuff if standing, but still plenty high enough to cruise. 36x18 is 58", 36x21 is 50", 36x22 is 47", 36x23 is 45". My Moonlander has a 3spd hub, low is 41". I went up a very soft arroyo last week, and it was hard work - I could stay seated for a bit, but would have to stand for "rough" sections and to regain momentum. If you swap out the stock square taper cranks you could keep the same chain (total number of teeth on both cogs) and go 34x20 or 32x22 (42") depending on what rings came on the cranks.
    This isn't a "you're doing it wrong" topic.
    WSS/OSS: Open Source Sealant
  98. #98
    Mar 2011
    Quote Originally Posted by wadester View Post
    pick&choose...8-10 psi...If you swap out the stock square taper cranks you could keep the same chain (total number of teeth on both cogs) and go 34x20 or 32x22 (42") depending on what rings came on the cranks.
    Brilliant information. That's what this thread is about; how to make the beast better.
  99. #99
    I'm running 32/22 on mine and it's ok for off road. On the road with black Floyd's I spun it out very easy.
    I also think there is enough room in the drop outs to swap rear cogs depending on where your going without breaking the chain.
    2012 Moonlander.
  100. #100
    Nemophilist
    Hey;
    I asked the bike guy once and he said "Sure... we can sell it to you still in the box." Taking it home that way would most likely be of benefit to any buyers here reading this, and to the bike as well. This assuming that anyone reading this is a better assembly person than the Walmart dood.
  1. Bighits 37lb Mongoose Beast
    By bighit in forum Fat bikes
    Last Post: 12-02-2016, 12:20 PM
  2. Mongoose Beast review etc.... Walmart Fatty!
    By 2silent in forum Fat bikes
    Last Post: 10-05-2014, 05:41 AM
  3. Walmart Mongoose Beast sucks!
    By Larry Endomorph in forum Fat bikes
    Last Post: 02-24-2014, 01:06 PM
  4. Mongoose Beast... cannot wait
    Last Post: 11-09-2013, 08:59 AM
  5. Mongoose Beast Fatbike - Specs + Pics!
    By theboss in forum Fat bikes
    Last Post: 05-13-2013, 09:12 AM
Members who have read this thread: 27
