Results 1 to 14 of 14
    Feb 2012
    Middleburn RS8 X-Type 100mmBB
    Home - activesport.co.uk 01298 22002 / 01298 22006 email sales@activesport.co.uk
    Middleburn-RS8-X-Type-Chainset-with-rings-Hardcoat-SlickShift-100mm-BB
    Middleburn RS8 X-Type 4 Arm Duo Chainset with rings Hardcoat SlickShift 100mm BB
    Any thoughts on these! I was looking at the RS7 sq taper with Phil BB.
    Reputation: HDTVdevil's Avatar
    Quote Originally Posted by lostraveller View Post
    I am using that crank but not the chainrings. So far I am very happy with them.
    Sent from my GT-N7100 using Tapatalk 2
    ohh they are nice, wonder what the weight is
    Feb 2012
    Set up
    Quote Originally Posted by HDTVdevil View Post
    How have you got them set up? Clearance issues? What chainline? Would appreciate your advice or hints with set up.
    Reputation: tracerprix's Avatar
    Dec 2009
    That's the setup I have. I really like it.
    Attached Thumbnails Attached Thumbnails Middleburn RS8 X-Type 100mmBB-fattycrank.jpg
    Feb 2012
    tracerprix, can u give me some detail? What chainrings? Chainline? Ok with BFL? cheers
    I got Carbon-Ti 38/26 chainrings setup. Clearance with HuskurDu on 80mm rims is about 8mm.Bud/Lou should clear too I think.
    Dec 2009
    Those are middleburn 39/26 rings coated. I don't have bfl to try. With the Floyd's I had 5mm and with the Nates about 4mm. That's on a 9:zero:7 135mm offset frame.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Anyone know if this crank will fit just fine with the extra small 907 170mm 1 1/8" frame? I probably wouldn't use tires fatter than the Nate. I also have a fat (100mm) Chris King bottom bracket already. Thanks!
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Quote Originally Posted by Drevil View Post
    Only know about installing on a mukluk and there this comvo works fine.
    Dec 2009
    Yes they should work fine. I have them on a medium 170mm frame now with nates.
    Order them from Alex at MTBTandems.com Home Page you probably have to call him at (678) 445-0711. He is great! They are in GA in the states.
    I have purchased my crankset from him. Very fast shipping and I'm a pleased customer.
    Quote Originally Posted by tracerprix View Post
    Yeah, I always deal with him. He's cool.
    Which spider did you go with? I'm thinking 3 chainring, 4-bolt.
    Dec 2009
    I got the duo (2 chainring). Works well. If you need more chain line clean ace I wonder if you could use the triple and only use the 2 outer ones.
    Reputation: Surlynot's Avatar
    Currently running a set of triple ring Middleburns, 9 speed sram, Hope external BB, on my 18" pugsley, nate on the rear.
    Working fine for me so far.
    Leave nothing but footprints & take nothing but photographs.
