Results 1 to 35 of 35
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Middleburn Fatty Crank !
    Looks like it has arrived (?).
    Was looking on the Sideways Cycles blog and found this :-
    Middleburn Fatty Crank « Sideways Cycles
    Disclaimer :- no relationship with SWC other than bought a Nate off them once.
    A Fatback'd Lefty for who life IS a Beach
    Reputation: Velobike's Avatar
    Then this will interest you
    Forward Components eccentric BB
    Latitude: 57º36' Highlands, Scotland
    arghhhhh my heads gonna explode with all this great new componentry for fatties
    ive got a phil wood bb and middleburn crank at the mo
    Quote Originally Posted by cozz View Post
    ...ive got a phil wood bb and middleburn crank at the mo
    I've got that set up on my 907, but with the x type crank I can use the eccentrics and adjust my chain, so the Pug is going to get an upgrade too.
    How much does it weigh?
    Reputation: Borgschulze's Avatar
    Nov 2007
    I just wish they weren't $400....
    That's just too expensive for adding a spindle in my opinion.
    I mean.. I just bought e.Thirteen cranks for $200... and CRC has the RS8 X-Type for 68mm shell at $215...
    Quote Originally Posted by Borgschulze View Post
    That's for the arms and spindle only. By the time you add a spider, bolts, and rings, you come close to the $400 mark.
    mtbtandems.com is the US distributor for Middleburn. In my experience their prices have been a little better than CRC's.
    Dirt Huffer
    Reputation: AC/BC's Avatar
    $400 = FAIL. They should be carbon fiber for that much
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    Quote Originally Posted by AC/BC View Post
    agreed
    Nov 2007
    Quote Originally Posted by Andy FitzGibbon View Post
    Still $125 for Square Taper arms, or $215 for X-Type...
    $280~ for what I want... X-Type arms + Uno ring. I refuse to put front derailleurs on my bikes.
    With that $120 I can buy a King BB...
    I get too many pedal strikes to want carbon fibre for my cranks. I'd happily use it for my road cranks though.
    Bicycle Obsessed
    Reputation: jpettit's Avatar
    Dec 2011
    I paid $210 for a Middleburn RS7 UNO, spider, lock ring and crank bolts from CRC.
    Quote Originally Posted by jpettit View Post
    We are talking about X-Type arms, which are thru-axle and are much more expensive. The RS7 arms are square taper or ISIS only.
    Middleburns are darn expensive no matter what, and there is a big jump in price from the square or ISIS arms to the X-Type.
    My point was that they aren't that much more expensive than a standard set of Middleburn X-Type arms, going by what the blog says. If you put together an X-Type crank with three rings and a triple spider, you end up over $400 from either CRC or mtbtandems.com.
    I was hoping for news of something like a DUO chainring with a 20t inner with a 30t +
    outer...or a spider for the same result...someday? Something to keep from increasing
    the Q factor...not that I am too concerned about that, but moving the rings over is a
    better way IMO.
    Note they won't fit a Moonlander - I know all to well......
    aka DummyDiva
    Reputation: cowboygrrl's Avatar
    Jan 2011
    Middleburn crank and chainring on my Pugs with an IGH.
    Attached Thumbnails Attached Thumbnails Middleburn Fatty Crank !-puglsey01_web.jpg
    Reputation: modifier's Avatar
    Cool looking but unfortunately pretty heavy too.
    I think Middelburn's reputation for being light weight is from many years ago.
    Quote Originally Posted by modifier View Post
    Advertised weights for the Middleburn standard (not fat) X-Type cranks are only 40 grams over e*thirteen's standard crank. I would expect that the fat versions would have about the same weight gap. Should be the two lightest options for fat bikes.
    Hmm, well I didn't look anything up but from memory I thought E13 100mm full cranksets with 3 rings were only around 850g. What's on the scale above is already over that. 931g and there is still a lot left to go.
    The FC EBB in the pic above is a lot heavier than a "normal" BB so I guess you can subtract around 175 grams from the 931 grams…
    Reputation: BurkeVT's Avatar
    Jul 2003
    My question: Will Middleburn make the equivalent of the MWOD spider for its cranks? I've an older square taper/phil setup, which will last forever, as you all know. I'd love to future-proof it with some wider clearance in the future.
    Those are beautiful spinners, Velobike!
    -Chris
    The BB that velo pictured above is a Forward Components EBB. Weighs about 200 grams more than a standard Shimano Hollowtech II. The cups and eccentrics are stainless.
    A lot of advertised weights for thru-axle cranks don't include the weight of the bottom bracket.
    e*thirteen triple crankset (standard width): 730 grams
    Middleburn RS8 X-Type triple crankset (standard length): 778 grams
    Add around 100 grams to either one for the bottom bracket.
    The e*thirteen wide triple cranks are 796 grams, or 66 grams more than the standard. I would expect the Middleburn wide setup to gain about the same amount of weight.
    @adelorenzo
    Reputation: anthony.delorenzo's Avatar
    Those are so sweet. I wish that Middleburn made 180mm length in their X-type cranks.
    I am curious as to the Q factor reference when discussing cranks. I hate to be left in the dark, please
    enlighten me. Thanks
    RailnTrail
    A Surly Maverick
    Thanks Doc !
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Does anyone have these yet?
    "Keep your burgers lean and your tires fat." -h.d. | ssoft | flickr
    Quote Originally Posted by Drevil View Post
    I got mine 4 weeks ago. They're going on my new Pugsley when the fork and wheels arrive…
    Reputation: HDTVdevil's Avatar
    Just delivered with a DUO spider...
    Sent from my GT-I9100 using Tapatalk 2
    Rasse and HDTV, where did you buy yours from?Can you adjust the sideways position of the crank, i.e., move it out further on the drive side or vice versa?
    Got it from the benelux distributor (BikeBoutique).
    I didn't have time yet to install them
    I got mine from Sideways Cycles in UK but haven't installed them yet. It looks you can move them 2-3 mm sideways if you play around with some spacers behind the BB cups.
    Don't you have Middleburn cranks on your Vertigo already...?
    Yes, I do have Middleburn cranks on the bike now, but they were stolen from one of my other bikes, which I want to ride again. I ordered a replacement from the american distributor, but for months he couldn't get the size, color, and BCD I wanted, (165mm silver 58/94 BCD) so I gave up.
    Another reason I was exploring this option is because I prefer the simplicity and ease of removal of external bearing BB cranksets, plus the ability to run a King BB. I also need to be able to slide it laterally outward more on the drive side. Are there any other external BB cranks that will do ALL of the following?
    1. External BB
    2. Silver arms
    3. 58/94 BCD
    4. 165-170mm length
    5. Able to make lateral adjustments
    Frt Range, CO
    Reputation: pursuiter's Avatar
    ...Are there any other external BB cranks that will do ALL of the following?...
    Surly Mr Whirly is close. You can have either the MDOW chainring set or the 58mm/94mm spider to make "lateral adjustments" to the position of the chainline(s) along with the usual 2.5mm bb spacers.
    @adelorenzo
    1. External BB
    2. Silver arms
    3. 58/94 BCD
    4. 165-170mm length
    Profile Racing cranks will do all of those things.
