Results 1 to 48 of 48
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    Marge lite tubeless issues?
    I'm getting sick of thorns etc with my "flat bike"
    I read thru a mess of write ups etc and decided to go with the gorilla tape and foam method
    all went well, my beads snapped into place and the tires held air without sealant (not on the bike or ridden of course)
    so I put 3 caps of stans in each tire, aired them up, did the stans dance, put them on the bike, gave them a good spin and then went to inflate them to around 20psi
    goo all out the edges, not mass quantities but some bubbling so I thought I'd let them rest overnight and maybe it would seal up
    no such luck, they hold 20-30 psi before they start to bubble (more than enough for a fat bike) but at 15psi plus my 250# of meat they are flat before I make it around the block
    here's a sketch of my setup, black being the rim, green the tire bead, red is my tape and grey being the foam
    the marge lite rims have holes on the bead shelf noted by the arrow, is this part of the problem?
    should I apply another layer of tape over the top of the little lip that catches the tire bead to make it tighter and cover these holes?
    Name:  4-22-2013 9-20-02 AM.png
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    I always run my tape all the way over to the outside of the rim and then trim it flush with the outside of the rim. When the tire seats, it will pull the tape back in a little and it looks and seals well. I also spread some of the stans up around the tape before trying to air up the tire.
    Mar 2013
    Re: Marge lite tubeless issues?
    tried tubless with no success didnt fancy going downhill and tyre pop off and ruin my rims. so got a thorn puncture again but this time got a shringe with needle put it in thorn hole and filled tube with 80mm stans ok so far might not work as good as tubeless but worth a try people say it works for thorn holes etc
    Sent from my GT-N7100 using Tapatalk 2
    Reputation: sickmtbnutcase's Avatar
    Nov 2012
    Like alphazz said, run the tape right up to the rim edge. Tire bead needs a bit more material to seal against. The tape on that bead shelf does it.
    Lord Thunderbottom
    is 1 layer up there usually good enough or is 2 any better in this case?
    I assume it would just be extra tight if I put on an extra?
    Mar 2013
    Quote Originally Posted by sickmtbnutcase View Post
    tried that and more cant seem to get this right with the on one fatty rims
    Dec 2008
    I'll take a picture of my profile sometime soon- You don't need that indentation for the bead to sit in, just a gradual tightening as it sets. I'm making rims with that profile in near future fwiw.
    Laramie, Wyoming
    Oct 2012
    I've used a single layer and I've used a double layer. I've even tried three layers. These tires are not all the same in how they fit. I had a Lou recently that was so tight that it almost took two people to get the tire on. If you are covering the small holes with it as well, I would like two layers. I like using the thick clear packing tape on the inside (over the foam or rim strip and over the little holes before putting on the gorilla tape).
    Laramie, Wyoming
    Oct 2012
    stesteste, are your tires falling down off of the small shelf to the inside of the rim?
    Lord Thunderbottom
    This will be my new plan of attack
    again - black being the rim, green the tire bead, red is my tape and grey being the foam
    Mar 2013
    yes mate they are
    nvphatty
    Guest
    ah ok
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    I run my tape all the way to the outer edge, as mentioned above. I also do 2 layers of tape. (this is on RD's, but the ML looks like it should be similar, getting ready to mount up a new HUDU on a ML this week).
    Laramie, Wyoming
    Oct 2012
    Quote Originally Posted by TitanofChaos View Post
    TitanofChaos, I would strongly suggest the following change to your new plan of attack.
    Feb 2012
    i only tape to the inner bed lip..........one big tip i can give.......after taping, but before going full tubeless with sealant, put the tube back in and inflate to 20-25 pounds for a day or 2.........it seems to seal the tape to the rim better.......then you can pull on bead off, pull the tube, put in the stem and sealant and reinflate........
    Laramie, Wyoming
    Oct 2012
    Quote Originally Posted by killarbb View Post
    Why mess around with that? It's easy to just run the tape wild to the outside of the rim and trim it. No taking the tire off and putting it back on multiple times.
    Lord Thunderbottom
    UPDATE -
    I added another layer of foam to the center of the rim and I bought a roll of the fat (something like 4" wide) gorilla tape, it was wide enough to cover the entire width of the rim and go up the sides with one strip
    I aired it up the front tire that was completely flat and it snapped into place with a lot more force but it still bubbled a little again at the bead
    I got frustrated and just let it sit in the garage
    went to check it out last night and it's holding about 20PSI so I guess the stans did it's thing and I'm good to go
    guess I'll do the same with the rear if it actually goes flat, it's holding 15ish PSI just fine as is
    Plan #123-D
    Reputation: The_Aaron's Avatar
    Thanks for the update, I'm looking forward to trying it.
    C'mon lets go for a whirl.
    Jan 2013
    UPDATE -
    Did you find that is took a great deal of pressure to ride the bead up the inside of the rim and into the grove of the bead seating area? My Larry front tire is so tight on the Marge lite rim that I have to soap it up just to get it to seat WITH A TUBE using an air compressor.
    I finally said screw it and put 3 scoops of stans in my tube. Hopefully it keeps the thorn flats at bay.
    Thanks for the update. I've been following this thread after failing to get my marge lites to work tubeless. Let us know how it holds up after the first couple of rides.
    Fat & Single
    Reputation: ozzybmx's Avatar
    The problem with gorilla tape is it moves, the glue on it does not stick and hold, when the foam compresses in the middle of the wheel under air pressure the tape creeps inwards and eventually air with the help of stans gets under it.
    Apart from leaving a mess that takes over an hour to clean off the rim, 1 wrap of "Tough & Wide" 75mm Gorilla tape weights over 50g on its own.
    Get some 3M 8898 strapping tape, I'm about 3 months in now on 2 sets of wheels and have zero issues.... after about 5 failed attempts using Gorilla crap.
    Evil Following
    Trek 9.9 Superfly SL
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Laramie, Wyoming
    Oct 2012
    ozzybmx, don't be offended, but I've had zero issues with using gorilla tape. Is it possible that your tape didn't overlap enough or wasn't wide enough?
    Vagician
    Reputation: EPcycles's Avatar
    Dec 2009
    Quote Originally Posted by ozzybmx View Post
    Agreed.
    Fat & Single
    Alphazz im not offended in any way, that's what forums are for, everyone has an opinion and my thoughts on Gorilla tape is just going on my experiences.
    There's plenty of my pictures on tubeless threads here on the fatbike forum documenting the way I did it. Ive been using Gorilla for over 2 years now as it initially came with my ENVE wheels and its the same with them. I now use the 8898 tape on all my MTB and fatbike wheels and its loads better IMO.
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Oct 2012
    I have used 3M products for many years, including duct tape. I haven't found any other products that can match their quality. Last time I asked someone to get me duct tape, they got me Gorilla tape instead. It is a lot better than Duck, or some of the generic ones in strength, but it is too thick for most things I use it for, and doesn't adhere that well. I will look for that 8898. Where did you find it in a wider roll, Ozzy?
    Fat & Single
    Evil Following
    IndyFab Deluxe 29
    FM190 Fatty
    Pivot Vault CX
    Cervelo R3 Disc
    Oct 2012
    thanks.
    Taking a look at the website, are you using the 72mm blue tape? I want to make sure I order the right width.
    Dec 2011
    You may want to take a look at this thread. This method has worked great for me.
    Tubeless: Marge lite rims + Clownshoe rim strips. does it work?
    Nov 2008
    I have used foam and split tube (works great) but after watching THIS VIDEO I have changed my Marge Lites and my wife's Rolling Daryls into Gorilla Tape Tubeless:
    Video: Fat Bike Tubeless Set Up The Right Way | Singletracks Mountain Bike News
    NO FOAM, NO MESS, NO PROBLEMS! (my foam and tape hack plus split tube was actually pretty heavy).
    My wheels: Marge Lites with Surly rim strip, 1 wrap Gorilla Tape, Dillinger Front and Knard rear (120 folding tires). 3 oz Stans valves and solution (rear needed 1 more shot to keep a slow leak at bay). Note I did not trim my rim strips.
    Wife's: Holy Rolling Ds with Surly rim strips TRIMMED thinner, 1 wrap Gorilla Tape, Vee Snowshoe (120 folding) and 4 oz Stans each with Stan's valves.
    The key--after cleaning, trimming and taping your wheel, put a tube in and pump the tire up to 20 PSI. I even drop a bead of Stan's onto one side (the side you're NOT going to open with a lever) AND LET IT SIT OVERNIGHT. This will stick the bead on super-mega-wonderfully and compress the gorilla tape.
    Thanks bobkorn, I am going to try that first. Just ordered the Clown Shoe rim strips from Jenson USA for $5 each.
    Did you use the Marge Lite rim strips with the Clown Shoe, or just the Clown Shoe ones by themselves?
    Jun 2010
    Quote Originally Posted by crank-87 View Post
    You can run the CS strips by themselves. They'll bulge a bit more, but they work just fine.
    Jan 2016
    I did a search and found this thread today, after I got an email reply from an employee at Surly who wrote that Marge Lites and my Nate tires are not designed to be run tubeless, and he would not recommend it.
    Reputation: mr_manny's Avatar
    May 2016
    Quote Originally Posted by Staktup View Post
    I switched the Pugs to tubeless this year.
    Was not easy, as both the new Minions and original Nates fit rather loose in the MLs.
    Finally went tubeless on my Pugsley on ML65 rims.
    Still running tubeless without any issues.
    Jun 2010
    I've recently discovered that the Clownshoe rim strip has changed from 75mm PVC to 65mm nylon. I'm now searching for a pair of the original 75mm wide strips at a good price in desirable colors...
    I tried the blue tape, Gorilla tape, stretch wrap plus some other things, and none were successful to the point of full confidence riding them. I recently went with the split tube method over the standard Surly rim strip for my ML and Nates, added 4 oz. of Orange Seal and it works perfectly. The best part is in the event of a disaster, putting a spare tube in would be quick and reliable.
    "Wait- I am confused" - SDMTB'er
    turtles make me hot
    Reputation: NYrr496's Avatar
    Yep. Split tube is the way to do it. 24" Q Tube.
    I like turtles
    Reputation: BlueCheesehead's Avatar
    Quote Originally Posted by NYrr496 View Post
    These work great on rims that are hard to set up tubeless. I have 6-8 24" Q tubes (new) that I bought for a previous wheelset. If anyone is interested I will ship a pair for $16. Shoot me a PM if interested.
    May 2016
    Got the idea for using scotch transparent duct tape from google...
    Here is one example:
    Tubeless Fatbike Conversion Update | Cycles In Life
    Reputation: watermonkey's Avatar
    Quote Originally Posted by slabber View Post
    Good luck - I haven't seen any of the old clownshoe strips available in well over a year, had to go back to split tube.
    I would advise not taking my advice.
    Reputation: Wombat's Avatar
    Surly indicate that they still make both the 65mm and 75mm strips https://surlybikes.com/parts/wheels/rim_strip), so it's probably worth asking them if anyone stocks the 75mm ones.
    There are still a few places outside the US that seem to have old stock, although prices vary a lot:
    https://www.bicyclestore.com.au/surl...trip-75mm.html
    https://www.tritoncycles.co.uk/compo...rim-tape-p1492
    You can find a few more places that stock it through a google search.
    There's also the Origin 8 75mm strip that appears very similar: https://www.ebay.com/itm/Origin8-26-...r=590923353755 it's available form a number of places.
    Tim
    Jan 2016
    Quote Originally Posted by deuxdiesel View Post
    Think I'll bite the pillow and try the split tube method. Once the Nates are toast, I'l try some different tires that might fit better. Does anyone know if the 45NRTH Van Helga or Dillinger 5 tires fit tighter on MLs than Nates?
    May 2016
    Scotch Transparent Duct Tape is Marge Lite's Friend
    Jan 2016
    Well, I was able to use the fattystrippers
    to mount up my Nates with Stanís. The only thing different I did was to tape the foam backer rod in place before over wrapping the rim w/ the latex strip as the bead kept folding inwards and pushing the rods to the middle. Now I just have to test ride them in 8-10 psi and see how it works.
    Feb 2010
    Quote Originally Posted by BlueCheesehead View Post
    I agree that split tube is the easiest most reliable way to set up tubless for rims not intended to be tubless. I gave up on other methods for my marge lites because it was not worth the effort. Recently I have switched to saran wrap because it is cheaper, lighter and you can trim to the edge of the rim without having to worry about reusing the tube. The only downside I have found is that it takes a few rides for the tire bead to seal completely compared to using a split tube.
    Sent from my SM-G920V using Tapatalk
    May 2010
    Yes, I have Nate rear and VH front. VH seems to fit a bit tighter and seal better. Iíve set both up on Fattystripper.
    Nov 2014
    I have been using the fattystrippers with sill foam and tubeless bead tires like JJ/45nrth and it works with a floor pump and the beads audibly snap into place. Since the bead snaps into place I can refresh sealant. To swap tires requires new foam and new stripper. Just did my first mulefuts last night with JJ 4.8, Sun tape and those also inflated with a floor pump. The key here is having the tire bead snug enough against the wheel to build pressure and snap into the bead eventually. I'm tempted to try tape again with my marge lights with the sill foam to make the bead snug.
    Jan 2011
    I can confirm that certain versions/years of the marge lite rims will not go tubeless with the Gorilla Tape method and I have serious doubts if the clown shoe rim strip method will work.
    What I did was the split tube method with no foam silliness and regular MTB Floor Pump.
    My Marge Lites have these breather holes right up to the side wall. Most tape methods simply will not seal these holes nicely, you can go up and over the side wall but then I was not getting the tire beed in when pumping. In the end a 24" mtb is less weight than a whole strip of Gorilla tape and it was my only option left.
    Things that I learned while doing the Ghetto/Split Tube.
    - Install tire first with nomal tube and let it sit hour+
    - The tire out of the box is crumpled up
    - Installing the tire with tube should stretch out the tire a bit and make it less crumpled
    - pump the tire to 30psi/untill you hear two pops at least
    - the pops are the tire seeding into the rim
    - Remove tire
    - 24" MTB inner tube Michelin (no dust, more rubbery)
    - make sure to get a wide one 2.5"+
    - the un-inflated width of the split tube when doubled needs to span the rim or more
    - install 24" tube, stretch and inflate slightly on the wheel first
    - cut down the middle slowly and carefully
    - Remove the valve stem complete with pliers, cutters, etc.
    - Use your presta-tubeless valve stems and re-stretch the tube back over
    - remove valve for faster air delivery
    - Re-Install tire
    - Reach inside and flare out the flaps of the split tube
    - Use soapy water to soap up the split tube and tire
    - knock around the tire to get a loose seal with the soapy water going
    - connect your pump and BLOW!!!!
    - Go again to around 30psi till again you hear at least a few pops
    - Let sit for a few hours to ensure it is working.
    - deflate
    - pour in about 5oz of sealant
    - re-inflate
    - ride!
  1. Ghetto Tubeless w Marge Lite and Husker 120tpi tips?
    By easterntide in forum Fat bikes
    Last Post: 06-07-2014, 09:33 PM
  2. Marge lite or Marge DH for some loaded touring.
    By lostraveller in forum Fat bikes
    Last Post: 06-10-2013, 04:49 PM
  3. Marge Lite on a Krampus???
    By Clobber in forum Fat bikes
    Last Post: 10-02-2012, 12:47 PM
  4. Marge Lite
    By jfkbike2 in forum Fat bikes
    Last Post: 05-26-2012, 11:19 AM
  5. marge lite build
    By cozz in forum Fat bikes
    Last Post: 02-13-2012, 12:54 AM
Members who have read this thread: 97
