I've heard that Treks are being spec'd with this new fork from Manitou. Has anyone heard any details?
I haven't taken it apart yet, but the longer stancions( there is 2 different part numbers but niether say std or ext) and longer air spring in the extended is the reason. That extra inch is to keep a tall tire from hitting the crown.Has anyone opened one of these up yet to adjust travel?
My Pro Ext set at 100mm still has 1" of extra stanchion above at max travel. Per Mantitou's service manual, my fork should only be adjusted downward towards 80mm. But I'm trying to figure out why spacers couldn't be removed to give 120mm without increasing the ride height at all.
Bluto could come with a ham sandwich and a pallet of cupcakes and it still wouldn't be worth riding.The Bluto *comes* with a shock pump if you buy it aftermarket.
Manitou is robbing you guys.
:nono:
You're not you when you're hungry.Edit: Deleted. This is stupid and not worth my time.
Stop using my name on a public forum Ben, no one knows who you're talking about. Don't patronize me. I'm a grown ass man that can afford to buy any fork that I want.
You don't know me, so don't pretend that you do.
Your axle issues have been solved with a new bolt on rather than QR style. As you know the older problems were already corrected. The damper has also seen small changes that most people will never even realize.Okay, I'm gonna post a little review, mostly cuz I'm bored with nothing worthwhile to do ... van is getting serviced.
Wren: Three forks, 150, 150, 110, used on a Mutz and a tandem fatty. First fork blew a damper, I replaced it , then later the steerer tube came loose in the crown, replacement fork worked fine. The Wren is a good idea that suffers from poor tolerances, lackluster damper design, and in my opinion it needs improved axle/dropout design to prevent torsion and asymmetrical leg movement. The Wren is burly, and though it's a bit "loose", it takes a beating and until recently it was the only choice for hard charging, long travel, and Clydes.
