Manitou takes on fat bike forks with the Mastodon - BikeRadar
Mastodon features
Cold weather tested at -15C / 0F and colder temperatures
34mm stanchions
80, 100, 120, 140, 150mm travel options
Fits 26 x 5.15in and 27.5 x 4.5in tires
Two ride heights: standard as direct replacement and extended for increased tire room
Pro weight for 26in / 100mm travel: 2,210g
Comp weight for 26in / 100mm travel: 2,430g
So wide
Even off of a bike it was clear from the giant crown and prairie-wide stance that the Mastodon was designed to fit even the widest-of-the-wide fat bike rubber.
The chassis can easily surround the largest tires available; everything from Vee Rubber's 26 x 5.05in 2XL Snowshoes to Bontrager's Hodag 27.5 x 4.5in. There's also plenty of room for 29 x 3.0in plus tires.
Dialed damping
The Mastodon uses damping technology derived from its well-received Mattoc and Dorado forks.
The forks are upgradable as well, accepting Manitou's Infinite Tuning Rate kit for additional mid-stroke control, and all of the seals, oils and internals are built to work in freezing temperatures thanks to Manitou's expertise in snowmobile racing.
Stiffness claims
Through the use of large 34mm stanchions and Manitou's classic reverse arch, both front and back and torsional stiffness is claimed to be improved over the Bluto. Manitou's testing puts these numbers at 26 percent and 25 percent respectively.
Mastodon pricing and availability
Mastodon Comp: $649.99 with availability now
Mastodon Pro: $849.99 with availability now
