Page 1 of 3 123 LastLast
Results 1 to 100 of 209
    Dec 2012
    Less 'Beast'ly Fat Bike
    So I'm new here, and I hope members dont get the wrong idea - that the Walgoose bike has brought the riff raff out of the woodwork. I've been researching fat bikes for about a year now and have been lurking and learning. My problem is - I was reluctant to drop $2k on a bike without the ability to test ride one. The cheapo Walmart bike is my solution. Allows me to start fat biking with a reasonable investment.
    I've read it all and others are doing similar things, but here we go. Ultimate goal is a sub-35lb. fat bike with gears and disc brakes. Things move kind of slowly here on the Big Island of Hawaii. Everything takes longer to ship in - although most everything I will be doing will be used/donated parts from friends and the LBS.
    First one didn't make it here in one piece -
    Second try went much better -
    Weighed it on the digital bathroom scale. Stripped of reflectors and decals it weighed in at 48.8lbs!
    Got a plan and started collecting parts:
    nvphatty
    Guest
    happy gooseing
    Puro Vida!
    Reputation: Nelson34's Avatar
    How is the bike? Maybe a good bike for my mrs?
    Dec 2012
    I'm happy with it... but I am looking for a project starting point. It is way to heavy, needs gearing and needs brakes terribly. So basically unless you are looking for a project, I probably wouldn't go this direction.
    It only needs gearing if you aren't into singlespeeds. Definitely not a must. Here's mine. Good luck on your build.
    Human Test Subject
    Reputation: Volsung's Avatar
    Thank you for starting another mongoose thread. The other 9 weren't quite enough.
    Dec 2012
    I'm involved in many forums and in every case, my posts are highly technical and enjoyed by all.
    This would be an example:
    Next Briggs powered chop - Club Chopper Forums
    Hopefully, you can give it a chance and keep postive.
    -Greg
    Dec 2012
    Hub sits at 100mm wide- I'm going to add 30mm to it and build a solid titanium axle.
    Feb 2012
    WOW, I took the time to read all pages of the Briggs build, As a powder coater and custom fabricator I can really appreciate the finish and details.
    I really like the effort put into the many photos documenting the build.
    Dec 2012
    Thanks- hopefully this will turn out just as intriguing.
    Dec 2012
    Every spoke nipple looked like a drill bit was used on them
    Reputation: thing's Avatar
    Oct 2007
    damn thats a cool bike
    looking forward to seeing how this one turns out
    Rogue Exterminator
    Reputation: kjlued's Avatar
    I dunno but to me it seems in your attempt to try affordable fatbiking you, if you carry out your plans to upgrade, you will end up spending just as much money.
    Oh well, should still be interesting.
    Just stick it in granny and start grinding.
    Reputation: vaultbrad's Avatar
    Oct 2007
    Quote Originally Posted by kjlued View Post
    It looks like our new friend likes projects, which is awesome. This little cheapy is easier to justify cutting and modifying than a more expensive bike.
    I'll be watching this thread closely.
    Moderator Moderator
    Please document as fully as possible since what you do might translate into other projects, not that the Walbeast isn't a fun challenge.
    Reputation: Siddhartha Valmont's Avatar
    Feb 2013
    If he keeps reasonable, it is possible to push the Walgoose to a setup with disk brakes and realistic tires & tubes for $350 (meaning a total of $550). All the rest (drilling, wheel rebuilding, paint or whatever else...) is just time so it is cheaper and nicer if tinkering is a hobby
    Nemophilist
    Reputation: TrailMaker's Avatar
    Hey;
    Buying a turn key bike is not always the goal. Anyone can do that if they have the funds. Some of us even make the entire thing!
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Dec 2012
    ^^ exactly how I think.
    Cut the front hub in half this morning...
    Mar 2011
    Quote Originally Posted by chopsmitty View Post
    Could you please throw that unlaced rim on a scale? The best feature of this bike may be the rims. I'd love to know how many grams they weigh prior to drilling.
    Rogue Exterminator
    Quote Originally Posted by TrailMaker View Post
    Hey;
    Hey, I get that totally.
    Not my thing but still cool if it makes him smile.
    Dec 2012
    Bare rim weight - 1234 g
    Moderator Moderator
    Individuals have "drilled" about 300 grams from each rim, but I'll bet you can do better.
    Dec 2012
    I am tempted to cut them on the cnc, but I'd have to swing the head... We'll cross that bridge when we get there.
    Dec 2012
    Stock hub with bearings, axle, nuts etc - 326 grams
    New hub complete minus disc brake - 388 grams
    Reputation: Velobike's Avatar
    Keep it coming.
    Looks like you're aiming for being the Manuel Beastly of bike modification...
    Latitude: 5736' Highlands, Scotland
    Dec 2010
    subscribed! this thread looks promising
    gran jefe
    wow. nice work so far. subscribed.
    Dec 2012
    Next project is to reinforce the rim at it's 'weld'. I am able to see light through the joint - it appears to be only joined at the outer rim edges... Then we are going to drill them.
    Dec 2012
    Walked in to work and on my desk were more used goodies from the resident mountain biker. Between Grant and Matt at Mountain Road Cycles - this thing is coming along...
    Dec 2012
    Forgot to mention - total weight of the RaceFace parts - 691g
    gran jefe
    i think that crank would survive a nuclear war! wow...
    Reputation: dudeist's Avatar
    Apr 2013
    Someone on I think Rat Rod Bikes stripped and polished the rims and they look very cool.
    Dec 2012
    I was thinking of doing just that - because I have to strip the joint to be welded.
    Dec 2012
    Finished product weighs 1014g.
    Apr 2013
    Reputation: gmats's Avatar
    Apr 2005
    *****in'. That's like 1/2 lb right there. Nice!!
    Dec 2012
    I made a quick model of the wheel in Solidworks and did a stress analysis with a couple different hole designs. This one proved to be the strongest with the most weight removal.
    Reputation: Greenfin's Avatar
    Great Work keep it up!
    Still cleaning my Fatback.
    It's a life style.
    Dec 2012
    Going to have to fix the chain line while adding new gearing... But we'll tackle that when the rear wheel gets built and we can see what works on the rear hub.
    That's interesting. I got the same pattern when I worked out how I wanted to lighten my rims.
    My method was more low tech using my man-in-a-shed with hand tools ethos - I used masking tape and joined up the spoke holes because I figured the metal was only needed between them. Then I outlined the edges of the masking tape and ended up with your pattern.
    BTW why leave the valve hole area untouched? Do we actually need a valve hole - surely it can simply be in one of the open areas? It's a bit more weight to save.
    Are we there yet?
    Reputation: AlmostQuick's Avatar
    Chopsmitty, you obviously are a very skilled craftsman, and we all love seeing your work.
    I can see you are a perfectionist. Doesn't it bother you starting off a project with junk like this bike? There are so many issues going on here that you might as well start from scratch. I wouldn't be surprised to find frames out of line too. (we've already seen forks)
    I drilled my front wheel, (turned out nice) and moved on to the rear. Had everything marked off and drill in hand. Then upon closer inspection, I could see the wheel had been over tightened, and the cheap rims were slightly deformed at the spoke holes.
    Since the rear wheel supports more weight, and is subject to the stress of driving and braking, I couldn't do it. Junky parts, crappy quality control.
    (my rims aren't even the same color. Front is white(ish) silver, and the rear is greyish silver)
    Quote Originally Posted by AlmostQuick View Post
    ...I could see the wheel had been over tightened, and the cheap rims were slightly deformed at the spoke holes...
    Easily fixed - use spoke washers to spread the load. The wheel won't collapse.
    Reputation: vikb's Avatar
    I'm hoping that the last step in this project will be to weld up a new Ti frame!
    Safe riding,
    Vik
    www.vikapproved.com
    Dec 2012
    Velobike, i can't imagine doing that by hand - the CNC did it for me and the whole job took just over an hour.
    bigger than you.
    Reputation: Gigantic's Avatar
    wow. you can spitshine a turd!
    Dec 2012
    Quote Originally Posted by vikb View Post
    That is exactly what I was thinking- but it's going to take a while. I have too many projects in the works now!
    Quote Originally Posted by Gigantic View Post
    Carefull....that almost sounded like a compliment
    I sure wish I had your setup... that must have nice edges.
    Rim's only Al. Maybe it's time to build a micro CNC setup.
    Any chance of posting:
    - a jpg of the cutout template with dimensions?
    - comparative strength against no cutouts, and against 1.5" circle cutouts?
    If one were to cutout such a shape with drill bits, and an appropriate saw for the straight edges, how critical is it to keep the edge square and the straight into the corners smooth to avoid stress risers?
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Great job so far !
    LOVE what you did with the wheel cutouts
    Life IS a Beach and then you Corrode
    gran jefe
    chopsmitty, pretty amazing. nice work!
    Mtn Biker Machinist
    Reputation: 1 cog frog's Avatar
    Dec 2004
    I love watching these types of builds in process. Way to use what you have access to. So many times my students ask my why I am making a particular part in the shop. My answer is usually "because I can". Enough said, excited to see how this turns out.
    May 2013
    Super post I am a newbie and was hoping for a post just like this. The bonus is I work at a prototype shop so I have access to all the machinery I need
    Dec 2012
    NMBP
    Reputation: crashtestdummy's Avatar
    Jun 2005
    You need to replace that kickstand spring with a titanium one. Seriously though, nice work.
    Jan 2013
    WOW. never thought I'd see this. I mean I kinda did, but not really. Follow me?
    May 2013
    Any updates chopsmitty?
    Dec 2012
    Not really.. My co-worker Grant did bring me some more parts. A cog set for the rear hub and a 24 tooth front sprocket! Getting closer!
    Matt Bisaro at Mountain Road Cycles has the front wheel/hub and is going to lace it up with new quality parts. Will post pics when we get that back.
    May 2013
    I bought an archer 3 speed for my rear any tips on lacing it up? What size spokes ect...
    Dec 2012
    I've only laced/trued motorcycle wheels. Matt Bisaro was excited to work on the wheel, he has all the spokes right there - and tons of specific experience - so he is doing the work for me.
    Question for anyone who reads this - I'm a really a motorcycle guy. I can make anything work, but what would be the best derailleur to start with??? I know I need something for the 7 speed cassette but what about the specific mount styles?
    I see this on ebay:
    SRAM X.3 7/8 speed Rear Long Cage Derailleur Black Mountain MTB
    SRAM X.3 Rear Derailleurs.
    Will work with 7, 8 or 9 speed cassettes, depending on the shifter used
    Item Specifications
    Color Black
    Weight 272g
    Intended Use Mountain
    Cassette Spacing Shimano/SRAM 9,Shimano/SRAM 7,Shimano/SRAM 8
    Shifter/Derailleur Compatibility SRAM 1:1
    Largest Cog 34teeth
    Chain Wrap Capacity 45teeth
    Derailleur Action Top-Normal (Traditional)
    Cage Length Long
    Will this work ok?
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Should be fine, but an x7 is only a little more expensive and should be a little lighter and offer better shifting. Main thing is any 9 speed should work and long cage will be required if you want to have a triple in front. Otherwise a medium cage (for a double) or short cage (for a single or compact ratio double) should be fine. Good luck, great build so far.
    --Peace
    I haven't actually used one of these but from what I understand about how they work I think an old Saint Rear Derraileur might be the easiest way to go because they bolt right to the rear axle requiring no hanger. Would seem to be just what the doctor ordered for this bike.
    Like this New Shimano Saint RD M805 SGS 9 Speed Rear Derailleur Low Normal Long Cage | eBay
    Also why 7 speed? That's pretty old school, anything 7 speed you find new is going to be very low end and heavy.
    May 2013
    your setup is pretty mean. i signed up just to follow this build and see what else you make.
    aloha \m/
    Dec 2012
    Screwed up when welding the hub together and aligned the spoke holes side to side. Had to fix that today and clearanced Matt's derailleur hanger alignment tool to make up for my mistake..
    Amazing and bemusing in equal measures !!!!
    Apr 2005
    Bummer on the hub. Sorry I didn't catch that when I looked at it earlier. Whoops.
    Dec 2012
    No prob. Just make sure you guys get over to our place before the airport!
  67. #67
    Dec 2012
    This showed up today. Huge box!
    Only thing in it was two significantly lighter tires!
    I've got a Thompson seat post, tubes, steering stem... I gotta put some pressure on my wheel builder!!
  68. #68
    May 2013
    lmk how you like those tires. i got a set on the way but my builds gonna be awhile before i finish. hopefully get to ride it out in hilo tail end of summer when i go up to visit a buddy for a fishing trip.
  69. #69
    May 2013
    Quote Originally Posted by Justin Wood View Post
    pretty good calc can be found here Freespoke and heres a pretty understandable wheel build guide Wheel Building
  70. #70
    Feb 2012
    Quote Originally Posted by cujo_mia_chew_toy View Post
    Just got a Floater a week ago and am loving it so far. Haven't done much off roading, but they roll great on hard surface. The little off roading I have done it seems to hook up well. Seeing it in pics doesn't do it justice- it's a great looking tire in person- I think this is going to be my all around go to tire as it rolls well, fairly lightweight and gives plenty of traction.
    Great job by On One.
  71. #71
    Dec 2012
    Stock tires - 2840g each
    Floaters - 1460g each
  72. #72
    gran jefe
    wow, 6 lbs of lost weight just from tires. should feel a lot better.
  73. #73
    Dec 2012
    Stock Mongoose tubes - 727grams
    Q-tubes superlight 2.4"-2.75" - 240grams
    That's 2.14 lbs just in the tubes!
  74. #74
    Reputation: mochunk's Avatar
    I was trying to put my stock mongoose tires on my marge lites with the Q's for the hell of it. I couldn't get the bead set evenly at pressures I felt comfortable going to while stretching out those tubes. I have read several times they fit BFL/CS but I didn't want to risk it without spares handy. By the bulging (or lack there) of the rim strip through the cutouts, it was only stretching to size in half the tire. Shrug.
    Fatbike Chicago on Facebook
  75. #75
    Anchorage, AK
    Quote Originally Posted by mochunk View Post
    Use soapy water.
    --Peace
  76. #76
    Quote Originally Posted by Lars_D View Post
    Use soapy water.
    I was. But that wasn't the thing holding me back. As I stated, the smaller 2.7" tubes filling the larger tire evenly at sane pressures was the limiting factor. It's one thing to crank up to 30 psi in a Larry vs, say, a BFL with the smaller tube. I didn't want to risk it. If I had a Surly toob handy I would have used that for that application.
    It was more of an experiment as to how heavy the stock Beast tires would have felt on my Pugs, and how well it rolled on pavement as I had a long paved ride this weekend.
  77. #77
    Dec 2012
    Front wheel is done! Here's the detail shot of the weld reinforcement done at the seam.
    Going to try to get the caliper mounted tomorrow..
  78. #78
    Apr 2005
    Sweet! Can't wait to see it in real life!!
  79. #79
    Dec 2012
    Cut a bracket on the CNC
    After a little TIG welding, Disc brakes in the front...
  80. #80
    HOV
    HOV is offline
    Reputation: HOV's Avatar
    Re: Less 'Beast'ly Fat Bike
    Awesome job!
    (FYI, a bicycle front brake lever goes on the left)
    Sent from my HTC One X using Tapatalk 2
  81. #81
    Reputation: davesauvageau's Avatar
    Quote Originally Posted by HOV View Post
    Awesome job!
    In America! I have a few buddies that run their front brake opposite. Some BMX guys in town run their rear brake on the left just for something different. Some motorcycle dudes run their front brake on the right because it is more familiar. Either way, you can do whatever you prefer!
    My motorcycle runs on infant blood
  82. #82
    ...(FYI, a bicycle front brake lever goes on the left)...
    No it doesn't. It goes on the right for a large part of the world's population.
  83. #83
    Awesome job!
    Where's the rulebook for that?
    Tallboy 3
    OG Ripley v2
    Carver 420 TI
  84. #84
    gran jefe
    No arguing about religion, please.
    chopsmitty, that really looks good. nice work.
  85. #85
    Dec 2012
    Remember everybody, I'm a motorcycle guy. Clutch on the left, front brake on the right.
  86. #86
    So am I, and I never had a problem with going back and forth. Shrug. I prefer the 'standard' bike setup as it's what I've ridden for longer than I've ridden motorcycles I guess. And I rarely use the rear on a motorcycle. I also tend to cover the rear on the bicycle more.
  87. #87
    Dec 2012
    Sorry, took a long break in the action. Have too may projects! I'll get the rear rim delaced, welded and cut this weekend.
    Picked up some more craigslist stuff... It's very difficult to find this stuff in Hawaii and shipping kills the deal. Trying to keep this as 'cheap' as possible...
  88. #88
    Dec 2012
    Wheel is done and the hub is widened by 40mm. Have to turn the axle and off for relacing...
  89. #89
    Dec 2012
    Axle done, 7 speed cassette installed ...
  90. #90
    Apr 2005
    Sweet!! I was lucky enough to see the hub being split on the lathe. Awesome stuff!!
  91. #91
    Dec 2012
  92. #92
    Anchorage, AK
    Looking very good.
    --Peace
  93. #93
    Dec 2012
    Have all the parts. Just might get riding this weekend...
  94. #94
    Dec 2012
    Bike sits at 36.4 lbs right now. Still need to add the rear caliper, brake line and master cylinder/handle. The gearing is pretty darn good! The bike is light enough (for now) and works very well!
  95. #95
    Great job, Chopsmitty!
    Fun to watch this come together, and glad to hear the results are working well!
  96. #96
    has a bad
    Wow, you make these mods look really easy. Well done!
    In that last picture, is the chain touching the tire?
  97. #97
    Dec 2010
    Awesome color combination! That thing looks great
  98. #98
    Dec 2012
    Quote Originally Posted by xobloof View Post
    Not even close. It's just a seven speed cassette, but I'm thinking there was room for more....
  99. #99
    I think you need to get in touch with Manuel Beastly for a job in his pit crew.
  100. #100
    Reputation: buckfiddious's Avatar
    Fan-freaking-tastic!
  1. Replies: 61
    Last Post: 10-25-2013, 08:35 PM
  2. Replies: 57
    Last Post: 07-09-2013, 02:22 PM
  3. Replies: 9
    Last Post: 05-30-2013, 11:52 AM
  4. mountain bike comfort, road bike speed,which bike?
    By traumamagnit in forum Bike and Frame discussion
    Last Post: 07-23-2011, 07:25 PM
