Results 1 to 31 of 31
Thread: Lauf vs. Bluto
    Reputation: Coach529's Avatar
    Mar 2006
    Lauf vs. Bluto
    Newbie to fat biking. Looking to pick one up shortly. Probably 50/50 winter/ summer use.
    Was wondering about feedback from guys who have used the Lauf fork and the Bluto.
    Pro's and Con's for each?
    Thanks!!
    frl
    frl is offline
    Jul 2014
    +1. I have used bluto. Really want to try lauf.
    Jun 2016
    First, make sure the geometry of your new bike can fit a Lauf or Bluto.
    Even some bikes with the proper tapered head tube, can't take the 120mm travel Bluto without the possibility of the fork hitting the frame.
    So even if the bike says "Bluto Ready", make sure that it actually is "120mm Bluto Ready", and make sure that the front wheel has a 150mm hub that can accept a 15mm through axle - or it's going to cost you a bunch of cash for a new wheel or new hub and rebuild.
    Jan 2016
    Quote Originally Posted by Coach529 View Post
    Lauf
    Pros:
    Maintenance free
    Works the same in all weather conditions
    Progressive (no need for lookout)
    Manages vee 2xl on 90mm rims
    Light
    Cons:
    Insanely expensive
    Only 60mm travel
    No rebound dampening
    Bluto
    Pros:
    Cheaper than lauf
    Real dampening effect
    Up to 120mm travel
    Rebound dampening
    Cons:
    Heavy
    Slugish
    Needs maintenance
    Weather dependent (struggles in real cold weather)
    The lauf is often seen as something between rigid and suspension. Better for people who "just want to take the edge off" without a weight penalty and need for maintenance, whereas the bluto is better if you need real suspension (trial/DH riding) and have a smaller wallet ☺️
    Reputation: schnee's Avatar
    https://fat-bike.com/2015/07/lauf-carbonara-tested/
    Good review that compares the two.
    Yamaguchi Cross YT Jeffsy Salsa Mukluk & Vaya Canyon Commuter
    Mar 2006
    The main reason I am asking is because I am looking at a custom Framed Alaskan from The House. The cost of a build with a Pluto vs Lauf is $300.00.
    Since I have never ridden a fat bike.......I am not really sure what I am after.
    Jun 2016
    I always liked the cool colors of the Framed wheels
    Mar 2006
    Quote Originally Posted by GiantTurd View Post
    Get a Wren or Lauf, skip the Bluto.
    They have 2015 versions, 150mm hub with 100mm travel on sale for $699.00
    Feb 2012
    There is a pretty big difference between the 2015 version and the new style. The old style has only 1 air chamber the new has 2 air chambers. The only downside to the wren is they are heavy about a pound more the a bluto. But if you want a real suspension fork wren is the way to go.
    Mar 2006
    What I really need is a good question. This will not be my primary bike. This will be a back up summer bike/ part time training bike to my Spearfish.
    Originally was planning on going all rigid but everybody keeps telling me I need some front suspension......
    Jan 2015
    The lauf is a real nice fork for 75 percent of the conditions. Here in New England I love it for snow riding as it really takes away the chatter of rigid. It's also the bike I reach for if I'm going to places that have fast single track. Not my favorite to take to the heavy roots and rocks but it's very doable just not the best tool at my disposal
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by vid1900 View Post
    Kinda off topic but why does it need to 120mm Bluto ready? Where did that even come from?
    Here's a 'radio' interview with Kevin Wren about his fork.
    https://fat-bike.com/2016/09/weekly-...pension-forks/
    Sep 2015
    Quote Originally Posted by bdundee View Post
    The size bluto a frame can take only has to do with the geometry. It has nothing to do with it hitting the frame. Most frames are designed around the 100mm bluto and you use the 120mm bluto, it will raise your front end, bottom bracket, and slack out the front end. If the frame was designed around a rigid non suspension corrected fork, then you will want an 80mm bluto, or the lauf.
    aka bOb
    Quote Originally Posted by johnny5jz View Post
    I know geometry and how a forks a2c affects it. I was just wondering why you brought up 120mm travel in the first place when the op said nothing about wanting a fork that long.
    Rippin da fAt
    While a long a s s fork can throw the caster angle into oblivion, a Lauf, being an undampened spring, drop your tire pressure and you have an undampened spring without coughing a grand... And your rigid fork prolly doesn't look like some kind of diabolical medical device from WW2 death camps.
    +1 for a Wren.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    fat guy on a little bike
    andy81 nailed it. i would lauf is you are slow and just want to take the edge off, or wren if you are fast and need damping for multiple hits/drops. bluto seems to suck everywhere...
    Aug 2010
    If you're buying a bike, get one with a Bluto already installed (and don't pay MSRP for the bike). They are overpriced to buy aftermarket. A lot of Bluto hate on this forum. All I can say is I ride mine pretty hard and have had no problems. Don't expect it to be a enduro/DH fork, especially if you are big. Wren might be very good, not aware of it being specked on any production bikes though, so you might have to pay retail for it. There is a very long Wren adjustment advice thread be sure to check that out, especially if tinkering is not your thing.
    A friend of mine is running a Fox plus-tire fork on his fat bike. Plenty of clearance for the 4" tires he is running, but certainly no room for the truly wide tires out there. Just saying, if you are happy with 4" tires then "the Fox fork will really transform your bike" (his words).
    Fred
    Reputation: burtjason's Avatar
    Oct 2015
    I have both....and I like both. The bluto is better on the rougher stuff. But for what I mostly ride here in FL, I favor the Lauf as it fits my favorite 27.5 4.5" tire and leaves my front end so much lighter. Enjoy climbing with it.
    MN/WI
    Reputation: theGliberal's Avatar
    On my Farley 9.8, given my current a2c, tire radius, and using the formula provided by Wren to calculate the max travel, the Lauf and Wren had the same amount of travel. So it became an issue of weight and how I like to ride. Also, QBP distributes the Lauf, so my LBS could order and install it. Finally, Lauf has a five year warranty.
    I found both Wren and Lauf to be very responsive to my emails, which is very positive.
    Forgot to mention that I had to go to a 180mm rotor.
    Remember, nobody knows. So let's find out...
    Jan 2016
    Quote Originally Posted by theGliberal View Post
    That sounds a little strange the lauf only has 60mm travel and the Farley should be "bluto compatible" for 100mm travel without influencing the geo. I know wren isn't bluto (perhaps it's longer?), but you should be able to fit a wren and get more than 60mm travel.. 60mm is very short.
    Basically any front damper would and should provide at least 80-100mm travel on most bikes while maintaining the same angles and length.
    In general:
    That's the reason why lauf "looses" out when people ride hard trails and need real dampening since 100mm+ will provide a lot more cush.
    It "wins" on weight, maintenance and simplicity for those of us who aren't bombing down the hardest trails.
    Lauf isn't really a damper, but something to "take the edge off" the riding. 60mm and no dampening on the rebound is night and day compared to a wren fork.
    I'm a huge lauf fan though, and hoping to purchase one eventually.
    MN/WI
    Got this formula from the good folks at Wren:
    Potential travel = a2c - crown height - tire radius - safety
    So for me it was
    490 - 28 (per Wren) - 391 (27.5x4.5) - 10 (per Wren) = 61
    Jul 2014
    So for me it was
    I think you are forgetting about sag. Your Farley is designed around a 100mm suspension fork which is 511mm ac, which with 20% sag would be 490. You could run a Wren at 100mm travel @25% sag and have a similar ac, or if you needed additional clearance for the tires worst case keep the fork length the same but limit the travel to 90mm.
    I'm guessing the Lauf sags as well, so if it was a 490mm fork you would sag somewhere in the 475-480mm ac range which would quicken your handling a bit.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    I love my Lauf. As mentioned, it does a great job of taking the edge off, is very lightweight and zero maintenance, which is a bonus for the cold winters where I live. My fat bike is largely just for winter riding and the occasional bikepacking trip, though.
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Reputation: blekenbleu's Avatar
    Aug 2016
    re: coughing
    Quote Originally Posted by BansheeRune View Post
    Before Lauf installation, dropping pressure enough to approximate that compliance made issues of rolling resistance and self-steering. With an innertube, that underinflated tire arguably had more damping, tho...
    How do you like the Lauf on the Farley 9.8? I have a Farley 9.8 with 100mm bluto and thinking about getting a Lauf. Did the Lauf slacken the front end of the Farley at all? Did you go from bluto to Lauf or rigid to Lauf? Is it worth the swamp for someone with a bluto already?
    Reputation: baltobrewer's Avatar
    Apr 2015
    Quote Originally Posted by Negotiator50 View Post
    This depends heavily on how you plan to ride. A Lauf (and I have one) and a Bluto are different tools for different jobs. Bluto vs. Wren? More of a direct comparison. My feeling on the Lauf is if you'd prefer rigid but can't take the beating that it serves up, a Lauf will do you well. If you ride aggressively and need the travel/damping for bigger hits, it's not for you. For me, and the kind of riding I do, it works great. Horses for courses.
    MN/WI
    It turned out that the ATC remained the same, given the sag. That was good. I went rigid to Lauf -- and sold the rigid. I did have to get a bigger rotor.
    I was able to do more no snow (Battle Creek) riding and noticed more (coming from a FS) the backend difference than the front. The true test is still going to be the CAMBA trails. But so far, it's doing exactly what I asked it to do.
    Check out this viddy...
    Reputation: solarplex's Avatar
    Apr 2014
    Farley fork is 490mm and lauf is 493mm.
    Fatbike, XC bike, Gravel Bike....
    Oct 2015
    Quote Originally Posted by burtjason View Post
    Kind of changed my mind after 8 months more of riding. I like both but I am favoring the Bluto these days. Had been going back and forth between the 2 on my Farley 9.6.
  1. Lauf' Carbonara Fork?
    By DBLUNG in forum Fat bikes
    Last Post: 3 Weeks Ago, 01:22 PM
  2. Lauf Fork
    By Ailuropoda in forum Shocks and Suspension
    Last Post: 11-17-2017, 08:53 AM
  3. Need Fat bike advise Bluto or no Bluto
    By brianbmw in forum Fat bikes
    Last Post: 07-12-2016, 03:23 PM
  4. Borealis/Lauf
    By b2b2 in forum Fat bikes
    Last Post: 06-19-2015, 05:27 PM
  5. Lauf TR29 fork
    By Testmule in forum Fat bikes
    Last Post: 09-05-2013, 10:41 PM
Members who have read this thread: 65
