Page 2 of 2 FirstFirst 12
Results 101 to 185 of 185
  1. #101
    You're asking the wrong question...why do you need 203mm rotors on a rigid fat bike?
    Quote Originally Posted by dirt-nerd View Post
    Will xt brakes with 203 rotors/ adapter from Bluto work with Lauf?
    Reputation: jpfurn's Avatar
    Oct 2014
    Quote Originally Posted by Nurse Ben View Post
    I checked sag and looked at how it was responding to input, and I would not say that the light springs were too light, though I did bottom it off a jump. If I bought one, I'd go with heavy springs.
    The biggest thing that stands out in my mind is that the Lauf is not a a suspension fork, so if you're expecting suspension, then the Lauf is not for you. It does provide some give, but it's not even as signfincat as riding a Bluto 80mm fork.
    I hear what you're saying about being used to one system, then moving to another, but the reality is that if I want to ride hard, real suspension is the only answer or I will get beat up.
    After spending recent time on all three as well(Bluto, Rigid, and Lauf) I have to agree with you about the Lauf no being the best choice for riding hard.
    I have found the Lauf to be great when riding under 75% effort. Once I tried pushing it in the corners and rough I lost confidence quickly. It is defiantly smoother then full rigid but a lot less predictable. I'm going to take my advice and ride it all winter, but will definitely be going with the Fox plus unless Fox enters the full fat game.
    After riding the Bluto all summer it was a fresh breathe of air going back to rigid. I was really hoping the Lauf would be exactly what I was looking for so I'm really going to give it a chance before selling or throwing it in my wife's Farley!
  3. #103
    Reputation: schnee's Avatar
    Speaking for myself: 265 pounds, plus gear, on long long swoopy downhills = no fade for once
    Yamaguchi Cross • YT Jeffsy • Salsa Mukluk & Vaya • Canyon Commuter
  4. #104
    Quote Originally Posted by schnee View Post
    Good calipers are far more important than rotor size, my wife and I are #350 plus kit, tandem fatbike, and 180's are plenty with Guides. Before we got decent calipers we tried lesser calipers and large rotors...not as good.
    ...and it's a big no way on a 203mm rotor for a Lauf.
  5. #105
    Reputation: baltobrewer's Avatar
    Apr 2015
    Curious as to why you say this. I ask because I'm running BB7s with my Lauf and had to add a couple of washers to the post to clear the caliper body, so I will need to either 1) get hydros to replace the mechs (Guides are the likely choice here) and keep my 180 rotors, or 2) keep the BB7s, get a 20mm post spacer and go to 200s/203s. New rotors are by far the cheaper route, and as I'm not displeased with the performance of the BB7s, I'll likely go this route. They are more fiddly, but fine once they're dialed. Thoughts?
  6. #106
    Reputation: Läskimasa's Avatar
    Jul 2015
    ^ That's right. 20 mm spacer and it's ok for Ø 200 or 203 mm disc and BB7.
    Quote Originally Posted by Läskimasa View Post
    I have. Works fine with Ø200 mm disc, maybe not possible with Ø180 mm.
    Fatter is better
  7. #107
    Quote Originally Posted by baltobrewer View Post
    Because the mfg says so, which means it voids your warranty if you break the post mounts. That is a huge lever you've creating with those long mounts, on a front brake, mounted to a carbon fork, with an enormous contact patch. Good luck.
  8. #108
    Jul 2015
    Mfg said to me when I asked about spacer for Ø 200 mm disc, "just standard 160 to 180 mm PM spacer bridge or equivalent amount of spacer shims."
    Fatter is better
  9. #109
    Your hills aren't as steep as mine I guess
  10. #110
    Apr 2015
    Ok, so:
    Nurse Ben says no.
    Laskimasa says yes.
    What sayeth Lauf? Straight from the horse's mouth:
  11. #111
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    you must spread some reputation around before giving it to baltobrewer again.
    thx4ß
    ptarmigan hardcore
  12. #112
    Reputation: blekenbleu's Avatar
    Aug 2016
    bearing race?
    What bearing race fits well?
    That included with Cane Creek's ECC44/40 seems too tight;
    the seal seems nice, though..
  13. #113
    Sep 2013
    Quote Originally Posted by blekenbleu View Post
    I used the Cane Creek crown race and it was an extremely tight fit! Use lots of grease and hit it hard!
  14. #114
    Wahahaha!
    North Cascades dude, moto trails, not a lot of stuff steeper or more sustained in NA.
    I ran 180mm rotors on a tandem...you dont need unless you're a pro downhiller; do those guys even run 200mm rotors these days?
    The issue with big rotors is warpage anf flex under load. The Lauf twists noticeably under load, a big rotor is more likely to rub.
    The Lauf needs damping, something like a steering damper from a moto, doesnt needto be much.
    The travel is kinda harsh, I much prefer a rigid or a suspension fork.
  15. #115
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by mohrgan View Post
    Or stick the fork in your chest freezer for ~3 or 4 hours (or, um, outside in most of North America right now...) then immediately bang the race on.
  16. #116
    Sep 2013
    Quote Originally Posted by mikesee View Post
    Thanks Mike! I will have to remember that for the future!
  17. #117
    Aug 2016
    re: crown bearing race
    Doh! no chest freezer since Matthew..
    Further research reveals Cane Creek offering 3 different crown races:
    10 series - polymer
    40 series - steel with seal
    110 series - alloy with (double?) seal
    Polymer or alloy likely would be better for carbon fiber crown.
  18. #118
    +1
    tight fit cane creak race on Carbonara fork, put it on my Beargrease a few rides ago. I found even working on the Thomson stem on to steerer tube to be more snug than normal but no issues...
  19. #119
    Aug 2016
    re: crown race
    OK, crown race setter upgraded from plastic to aluminum
    (1.75" OD 0.065" wall tube fits well, avoiding seal contact)
    seated crown race, but not fully.
    Aligning with sun illuminated a small gap on one side.
    Race does not appear to be crooked;
    is Carbonara crown imperfectly square to steerer tube?
  20. #120
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I've always just used PVC pipe to set the race. In these temps, I could just put the fork outside and it'd end up a lot colder than most freezers
  21. #121
    Aug 2016
    With PVC, mine seemed to stop about 2mm from seated,
    and damaging Cane Creek's integrated seal was a concern.
    It was warm enough here today for shorts and tee.
  22. #122
    Reputation: solarplex's Avatar
    Apr 2014
    Ok, so:
    Nurse Ben says no.
    Laskimasa says yes.
Name:	Screen Shot 2016-12-09 at 2.27.21 PM.jpg
    Ditch the bb7 for a trp spyke. Its narrower than shimano hydro, dual piston movement.
    Fatbike, XC bike, Gravel Bike....
  23. #123
    May 2015
    I've got 2 Lauf forks, a TR29 on my gravel whip and the Carbonara on a Framed Alaska Carbon. My opinion only, it beats the heck out of rigid for small bump compliance (especially on the gravel bike) and takes the sting out of hard to coordinate drops on the fattie.
    Compared to my Spec Fuse plus-bike with Manitou Magnum- the Lauf will never be truly plush in the big hits. It is plush for the smaller stuff, super compliant. It doesn't pump like an old 4" fork without lockout. First, it doesn't have that range. Second, the resistance is progressive. It won't be a Bluto, it shouldn't have to be.
    It is worth noting that it doesn't seem to care about temperature as compared to elastomers and hydraulics. The maintenance kit is a soft cloth.
    It's simple, and it does it's thing. For serious questions, as about, contact Lauf directly. They're more than happy to reply.
  24. #124
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    First little test ride on the Carbonara today. We've been in and out of freeze/thaw cycles all week, so things are a lumpy, crusty mess right now - perfect testing grounds.
    The amount of squish is more noticeable than I thought it would be, but in a good way, and smoother than I was expecting. For this type of chunky, uneven surface riding, it didn't feel bouncy at all, just felt like it was doing what it was supposed to.
    The Blackborow isn't my year-round primary trail bike - it's my winter ride and occasional bikepacking rig, and for these uses, I think the Lauf is going to be exactly what I was looking for.
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
  25. #125
    Reputation: Kirkerik's Avatar
    Apr 2016
    I'm looking at the Carbonara. I only weigh ~150 lbs so i'd be getting the light spring version.
    It appears as though axle wrap could be a concern in hard braking. Does it dive when braking?
    Also some here say it is NOT torsionally rigid and others say it is precise. If not as precise as a rigid fork, is it MORE precise than a bluto?
    Studded Dillinger 4/5 For Sale
    The tires are the things on your bike that make contact w the trail
  26. #126
    Sep 2013
    I've got a Regular Spring Carbonara now but had a Bluto. I find the Carbonara to be more predictable than the Bluto under compression while cornering. For me, the Bluto would encounter stiction because of torsional flexing and then suddenly compress. That was a little unnerving and made me more cautious because I didn't always know what the fork would do. The Lauf is very consistent in tracking(however not quite as precise as a rigid fork) through the corner yet is not quite as plush as the Bluto. I would gladly trade that for consistency.
    PS...I weigh around 170 lbs. and am on the border between Light and Regular Springs according to Lauf. I am most likely not flexing the fork as much as someone that weighs more than I do so that probably plays a role in people's opinion of the fork.
  27. #127
    Apr 2015
    Quote Originally Posted by Kirkerik View Post
    I would not think that, even given an exceptionally heavy person, that axle wrap would be a concern. IMO, the springs are far too stiff to do so, and given that there are two sets of springs tied together by the axle stanchion, I would think this almost physically impossible. Typically axle wrap on 4X4 vehicles occurs when there is only one set of springs and the axle literally twists itself up.
    I have not experienced lateral flex, but have heard reports of it occurring during very heavy braking combined with hard cornering forces. Personally, if you're riding this hard, then the Lauf probably isn't the fork for you anyway. Go with a Mastodon and call it a day.
  28. #128
    Aug 2016
    lateral flex
    My route to the beach requires moderate braking on a narrow paved downhill curved path, and that braking provokes bothersome directional change appreciably more than occurred with a rigid fork. No experience with Bluto or other telescoping fork and disk brake.
  29. #129
    Apr 2016
    Thanks all!
    Very interesting! Hmm
  30. #130
    Reputation: Swerny's Avatar
    bumping this, i'm thinking of picking up a Lauf for my newly acquired Farley 9.6.
    Any other reviews?
    I'm looking to get the regular version and I weigh 215 and ride mostly smooth XC/trail. I'm 43 if that matters.
    I will run my Farley 29 x 3 in summer and 27.5 x 4.5 winter.
    I've had 2 Bluto's and didn't love either of them, I don't really want to add the weight of the Wren or Mastodon for my typical riding.....and not sure the Mastodon will clear the downtube.
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6 with Lauf
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
  31. #131
    Sep 2014
    I have one on my Framed Alaska Carbon. I rode a Bluto before on my Specialized Fatboy Pro. I weigh 210 lbs. and would consider my rides average, with no large obstacles, hard corners, or jumping. I find the weight savings and simplicity to outweigh the additional plushness of the Bluto. I haven't experienced any of the negative handling characteristics mentioned in this thread.
  32. #132
    Apr 2015
    Have had mine since November and have been riding in mainly rooty, rocky, chunky stuff. Certainly less plush than my old Lefty, and probably less so than a Bluto or Mastodon, but then again, I don't tend to ride as aggressively as I once did (47 yo here). Bottom line, for me, is that there seems to be an inverse relationship between the aggressiveness of your riding and the appropriateness of a Lauf.
  33. #133
    Lauf' Carbonara Fork?
    Swerny
    I had a Lauf for the last 6 months & I weigh a little more than u and it didn't last through the rooty, rocky XC single track I was doing (4x a week) They do stand behind their fork and warrantied it asap. It definitely splits the difference between a bluto & rigid fork but not for real trail riding. Snow & smooth trails it would be great.
    Sent from my iPhone using Tapatalk Pro
  34. #134
    Nov 2015
    Swerny
    Wow, mines been pretty bomb proof on rocky Colorado singletrack. What was the failure mode?
    MiTT
    Denver Metro (Front Range), Colorado
    '17 Otso Voytek (B+ & Fat)
    '00 Yeti ARC
    '12 Novara Buzz
  35. #135
    It wasn't a failure yet but the small parts of carbon on leaf springs started to come peal. Then the fork was hitting the stoppers on smaller bumps that they never hit before. I ride a lot of the same trails so it was easy to notice. It did not feel good. I sent a picture to rep and asked what they thought .... After a few emails they sent me new forks & I sent mine back.
  36. #136
    Ambassador of Chub
    Jul 2015
    It's been a while since I've performed the annual maintenance on my Lauf, so with the impending winter, I figured it was time.
    I took a warm, wet rag and wiped it down, which removed most of the dust/dirt. And then I took the extra step of cleaning and greasing the thru-axle.
    And then I poured a pint, kicked back, and admired my handiwork.
  37. #137
    May 2015
    The provided toolkit is handy, but my last ride got a little muddy. Used a roto-brush hose attachment, gently scouring away the muck. Also replaced fork seals, on my 1998 Judy XL. That was more work.
  38. #138
    Aug 2003
    Quote Originally Posted by Smithhammer View Post
    Strong work.
  39. #139
    Ambassador of Chub
    Jul 2015
    Strong work.
    Thanks. As you know, it's better to keep ahead of it rather than wait until it seizes up in the middle of a ride.
    One of these days, I'm going to put together a video of the step-by-step service process...
  40. #140
    Aug 2003
    One of these days, I'm going to put together a video of the step by step process...
    You'll need a super-slow-mo camera to catch the fine details. Might not be worth bothering with anything less.
  41. #141
    Sep 2017
    Crazy design hard on the eyes. But definitely an original design
  42. #142
    MN/WI
    Reputation: theGliberal's Avatar
    Quote Originally Posted by STAGER1 View Post
    Not that hard.
    Remember, nobody knows. So let's find out...
  43. #143
    fat guy on a little bike
    local fast rider f'd up a Lauf. It went limp on him. Lauf sent him another with no issue.
    I am considering one, but only if i can get a deal on it.
  44. #144
    Apr 2016
    It sure is nice when a job comes easy. Sweet!
    I almost bought one but got a deal on a bluto. How does it track on the curves compared to a bluto or rigid fork?
  45. #145
    Nov 2015
    Quote Originally Posted by theGliberal View Post
    Not that hard.
Name:	20171102 by the River.JPG
    I’m with you, I rather find it attractive...
    Attached Thumbnails Attached Thumbnails Lauf' Carbonara Fork?-1ed97051-afe0-43ad-860a-f11625e9a32c.jpg
    MiTT
    '00 Yeti ARC
    '12 Novara Buzz
  46. #146
    Ambassador of Chub
    Jul 2015
    I'd preface it by saying that my fat bike is largely for winter riding, and the occasional bikepacking trip. For summer trail riding, I have a totally different, plus bike. So for what I use it for, I think the Lauf is great. It offers 60mm of travel which, combined with a 4-5" tire, is plenty to smooth out chundery snow, etc. I honestly don't notice much flex in the curves, but then again like I said, I'm not using this for serious dirt trail riding and hitting curves at high speeds.
    And like I joked above, I love that it maintenance free. I already have plenty of sus maintenance to attend to on several other bikes - the fact that I don't have to even think about this one is a big bonus for me as well.
    And yeah, I actually think it looks pretty cool. But it seems to be a love or hate thing, much like IPAs or cilantro....
  47. #147
    Dec 2005
    I have one coming for my new suzi q. I also have a bluto sitting here. I’m going to try the lauf first though. I have no serious trails to ride on, mainly just winter wet and cold paths. So I’m hoping the lauf will be good enough.
  48. #148
    I'm happy with mine so far, but I've only run it 29+
    Mike
    Toronto, Canada
  49. #149
    What spring rate are people running? 185# person here
    SalsaTiMukluk
    Salsa Fargo
    Salsa Cutthroat
    Salsa Blackborow DS
    Pivot Switchblade
  50. #150
    Considering a Lauf... Everyone still happy with theirs?
  51. #151
    Ambassador of Chub
    Jul 2015
    Quote Originally Posted by demondan View Post
    I'm 175# and running the 'Light' spring rate. Can't say I would want it any stiffer.
    Quote Originally Posted by Rodney View Post
    Yup - no complaints!
    Anyone found an inexpensive plastic fender (preferably the kind that zip ties on) for the Carbonara?
  52. #152
    Nov 2015
    Yep, still very happy with mine. Happy enough that I just got one for my wife’s bike as well.
    MiTT
    '00 Yeti ARC
    '12 Novara Buzz
  53. #153
    Aug 2003
    Yes, but I do not think this is your bowl of oatmeal...
  54. #154
    I'm still happy with mine, winter wheels going on shortly. I've only run it 29+ so far
    Mike
    Toronto, Canada
  55. #155
    Oct 2013
    I am still happy with mine. it works the trails pretty good, even has taken some good old Clyde abuse.
  56. #156
    MN/WI
    Yes. Did the Chequamegon 40 with no issues. Can't wait for winter.
  57. #157
    darn, i like oatmeal too.
  58. #158
    Dude, I like oatmeal too, but sometimes you just need a friggin omelette!!
    I rode a Lauf for a bit on a Beargrease. It's a nice fork, waay better riding than rigid, BUT, it's not for hard charging, certainly not a fork I enjoyed jumping or pushing hard into corners. If I was riding a full on fatty for snow and wanted lightweight and no maintenance, I'd get a Lauf.
  59. #159
    Ambassador of Chub
    Jul 2015
    ....If I was riding a full on fatty for snow and wanted lightweight and no maintenance, I'd get a Lauf.
    This.
  60. #160
    Jul 2016
    OK, first post here (hooray?)... and new fat biker after finally moving back home to Iowa! Buying a Beargrease NX1 and swapping out many parts to lighten it up a bit. Really want a Carbonara but just need to know... is there any chance the Tangerine Matte matches the NX1? Seems like it might... then again, seems like it might just be close enough to be aweful!
  61. #161
    Nov 2015
    Quote Originally Posted by masini View Post
    I'd be asking Lauf and Salsa. They can probably both tell you the RAL number and then you would know for sure.
    MiTT
    '00 Yeti ARC
    '12 Novara Buzz
  62. #162
    Dec 2005
    The funny thing is, I just sent my Lauf back to Jenson because of a color thing. My bike, I thought, was white. So I ordered the white Lauf. It sat in the garage for a month, and when I finally got around to installing it, realized the colors are off enough to look bad. The Lauf is really pure white, and my Suzi Q is more like a light cream white. Visually they looked horrible together...like the fork had too much teeth whitening done, face to face with a chain smoker. So I just threw a Bluto on there in black and moved on.
  63. #163
    #ifixedit
  64. #164
    Dec 2005
    OMG. You did not really use spray foam on a $900 fork? Did you? EEEEEK!
  65. #165
    Ambassador of Chub
    Jul 2015
    Wert da ferk?!?
  66. #166
    Quote Originally Posted by curtlo-dork View Post
    no, that would be crazy. I used spray foam on a $700 fork (street price).
    I upped the cool factor with some Batman duct tape.
  67. #167
    Aug 2003
    And the end goal was...?
  68. #168
    to piss of BookFace users on the Fat Bike list. So far, so good.
  69. #169
    Aug 2003
    Ah.
  70. #170
    Ambassador of Chub
    Jul 2015
    In that case, I yearn for the day I have your disposable income.
  71. #171
    Can you afford nothing? Cause that is what is cost.
  72. #172
    Ambassador of Chub
    Jul 2015
    Well then good on ya. But was there actually a functional reason besides pissing off BookFace users?
  73. #173
    yeah, fork was trash. f'ing around with it, actually brought life back into it. I don't expect it to last, but it made quite a difference from what it was.
  74. #174
    Ambassador of Chub
    Jul 2015
    Interesting. Curious to see how the mod fares after more usage. Was it the "light" version and you're trying to stiffen it up a bit?
  75. #175
    installed the HAHAHA and have about 30 min on it. so far, so good. it is a definite improvement on what was there before. #expandingfoamforworldpeace
  76. #176
    NEVERMIND. HAHAHA failed again, and is now in the trash. I tried. Meh.
  77. #177
    Jul 2016
    what about some tight wound rubber strips on the outside of the forks?
  78. #178
    Ambassador of Chub
    Jul 2015
    Leaf springs deteriorated?
  79. #179
    Stubby-legged
    I would love to trade my mastadon for a carbonara.....just sayin"
  80. #180
    Sep 2013
    Warranty?!
  81. #181
    Aug 2003
    Ditto. I’ve had my Mastodon available for sale or (ideally) trade for a few weeks now. Wrong time of year I think...
  82. #182
    i would have bought yours, but i needed a standard mastodon...
  83. #183
    Stubby-legged
    I have removed my Mastadon from my fat boy and would like to trade (or sell it) for a lauf if anyone is interested.
  84. #184
    Apr 2018
    Hi Guys, new owner of Carbonara, Pretty sweet, didn't take it to trail yet as there is snow in some places, hopefully by the weekend.
    I got a question about how do you set up the stem.
    Because I'm using a tapered headset adapter, that has elongated the requirement for the steerer length.
    I got a pretty standard steerer length about 7 3/8s".
    so basically I got 1 good expander cap https://goo.gl/images/RUw7Ge
    if I put the steerer with no spacers directly on the FSA dust cap, i get maybe 2mm of steerer showing up on top of the fork. but the suggestion from the manufacturer is atleast a 5mm Spacer on top.
    So to make a snug fit from the TOP it takes basically 2x5mm spacers from bottom so that I can properly fit the top cap to hold it in place, and the bottom bolt of the stem has a solid grip in the middle of the expander plug, however the top Bolt has very little carbon steerer+ the inside of the aluminum expander plug.
    any suggestions? comments?
  85. #185
    May 2015
    Quote Originally Posted by madmitry View Post
    If you have 2mm of steer tube above the stem, a 5mm spacer on top should suffice. If that doesn't work, perhaps one above and one below?
  1. Lauf fork reviews?
    By MAX LLOYD in forum Shocks and Suspension
    Last Post: 08-23-2016, 06:57 PM
  2. Lauf Trail Racer Fork. The lightest 29er suspension fork ever?
    By Shalom in forum Shocks and Suspension
    Last Post: 06-11-2015, 05:45 AM
  3. Fat Lauf leaf spring suspension fork
    By Drew Diller in forum Fat bikes
    Last Post: 02-06-2015, 12:58 PM
  4. Lauf TR29 fork
    By Testmule in forum Fat bikes
    Last Post: 09-05-2013, 10:41 PM
  5. Lauf trail racer 980 gram fork
    By Hogdog in forum Shocks and Suspension
    Last Post: 07-12-2013, 08:15 AM
Members who have read this thread: 56
