Results 1 to 6 of 6
    Jul 2013
    Krampus Tubeless Tire Pressure
    Anyone else running a tubeless Krampus setup? I recently converted mine to tubeless using gorilla tape and it's holding air really well. However I took it out today and even though I was running the same psi I normally do my tires were spreading out quite a bit and I had a lot of chain rub - I even hit my front run on a log. I added air and I still had a lot more chain rub than usual. I weigh 250 and I usually run 10 front/12 rear with tubes, but I ended up running 13 front/15 rear tubeless and it still felt low. I am wondering if i just have to run a lot more pressure, but i feel that if I run too high of a pressure I'm negating the benefit of running the Knards. Will the tires feel the same at a higher psi tubeless than they do at a lower psi tubed, or am i going to have to go back to tubes to get the ride I want? Is the sidewall just too think for tubeless?
    I weigh 160 and I'm running 14-15 with my tubeless setup. I'd say go a bit higher.
    Jul 2013
    Quote Originally Posted by sanjuanswan View Post
    Were you running tubes before? If so what pressure were you running then?
    With tubes I think I was running 13. I know I got pinch flats at 11 so I increased it.
    Reputation: mbeardsl's Avatar
    It'd be a lot quicker to just put some more air in the tires and see for yourself if you like how it rides ?!
    Jul 2013
    Quote Originally Posted by mbeardsl View Post
    I wanted to see if anyone else had success with tubeless Knards, or if they were somehow unsuitable for tubeless. I thought one of the biggest advantages to going tubeless was the ability to run low PSI, but when I tried running the same PSI I was running with tubes the ride was pretty bad.
  1. Replies: 48
    Last Post: 05-08-2016, 10:33 PM
  2. tubeless tire pressure
    By Phinox in forum Wheels and Tires
    Last Post: 07-28-2013, 06:10 AM
  3. Tubeless tire pressure for 250 ibs rider
    By Iceman30 in forum Clydesdales/Tall Riders
    Last Post: 09-10-2011, 07:56 PM
  4. Tubeless tire pressure
    By tommyturbo in forum Specialized
    Last Post: 08-23-2011, 01:49 PM
  5. Tubeless tire pressure question
    By RBowles in forum Beginner's Corner
    Last Post: 01-19-2011, 02:10 PM
