Page 8 of 8 FirstFirst ... 45678
Results 701 to 778 of 778
  1. #701
    Mar 2012
    Thanks rvercoe for your detailed answer, I appreciate and specially now while waiting for the bike since I am thinking about an extra wheelset for drier conditions! 2.6 29er or 650b+ is the question, I will not be able to afford both. I am slightly leaning towards 29" wheels since the geometry is spot on for an aggressive hardtail 29er once the head angle has been slacken.
    I used this page to calculate the changes in geometry https://bikegeo.muha.cc
  2. #702
    strider
    Suggestions
    Quote Originally Posted by Nurse Ben View Post
    Instead of 2.6 "skinnies", how about some 3" Chupas? Fast and light, not mud tires, but definitely a fun fast tire.
    For really ripping on 29+, the Minion 3" is killer.
    NB, I am open to considering that as an option. After running 27.5x3.0s for a season (Nobby Nics) I was less impressed with plus performance than I thought I would be for the increased rolling resistance and agility. I also didn't appreciate the extra drop in BB height.
    My favorite set-up so far though are the Minions 27.5x3.8 (FBF/FBR) on 45mmID rims for 3-season all conditions bomber radness. I can conquer anything on those and the 325mm bb height feels just right (yes, I'm still on 175mm cranks). I feel like the Wozo would thrive with 29ers and that 30mmID rims and 2.6s would give enough plush and traction without too much compromise in speed and agility.
    I'll take yours and others thoughts on what an ideal 29er set-up might be for summer/race wheels.
    On a related note, I'm heading to Grand Junction this weekend to ride the "Lunch Loops" trails. I can't decide on whether to leave the Minion 3.8s on for no-doubts performance or swap over to the NN 3.0s for a lighter and more agility.
    Has anyone ridden Lunch Loops and want to offer their 2 cents on tire preference for the Wozo?
  3. #703
    DLd
    DLd is offline
    Feb 2005
    Quote Originally Posted by rvercoe View Post
    Trails in GJ are hero dirt right now after some recent moisture. Either choice would work well. I could ride Ikons there right now and not be traction limited. BB height might be the deciding factor depending on how aware of your pedal position you tend to be.
    Fall is here. Woo-hoo!
  4. #704
    Have any of you guys tried the Mastodon at 150mm?
    I have my flat bar slammed down with a negative rise stem already. I have a feeling raising it up from the 140mm setting will make the front end too light for steep climbs. I question whether I will really benefit from the additional travel too.
    I right now I find I get about 135mm if I land a decent drop. Any of you guys getting closer to the full 140mm travel?
  5. #705
    Reputation: david.p's Avatar
    I don't believe I've used all 140mm of travel, but I'm also running the IVA at the 120mm setting for a more progressive spring rate than stock - though I have a feeling most people don't bother to adjust the IVA when going from 120mm to 140mm.
  6. #706
    strider
    Thanks DLd! That helps. I'll keep an eye on how much precip happens out there tomorrow.
  7. #707
    strider
    Wozo Review from Fat-Bike.com for those interested: https://fat-bike.com/2018/02/2018-ko...stotle-peters/
  8. #708
    DLd
    DLd is offline
    Feb 2005
    We got some during the day, but word is they were already good to go yesterday evening.
  9. #709
    Te mortuo heres tibi sim?
    Quote Originally Posted by GspotRider View Post
    No Mastodon, but a Bluto @ 120 and still wanted my bars lower.
    Syntace Flatforce stem. Looks a bit odd, but gets that bar back down where it sounds you want it.
  10. #710
    150mm on my Fatillac and use it all, 140mm on my Wozo and use it all.
    If you run a big front end, donít expect it to feel like a road bike.
    Nothing wrong with a tall front end, makes it easier to get back and resist gravity, also easier on your back.
    Youíll get used to it.
    If your front end is lifting youíve a couple options:
    Run a longer stem, slide your seat forward, or adjust your riding style; or all of the above.
    Bar height is not the problem.
  11. #711
    Jan 2018
    Just wanted to reiterate how versatile the Wozo is as I continue to be impressed by this bike. Just finished my 3rd ride with the 29+ and all I can say is WOW! This bike excels with that platform. I call it the Big MF Honzo as it just rips on descents and accelerates on the climbs. Crazy, crazy fun! 2 wheelsets are highly recommended!
  12. #712
    How are you guys making your 29+ wheels? Custom jobs or are there some off the shelf stuff available?
    If custom, could you give me some ideas on what to get that is not too expensive.
  13. #713
    Jan 2018
    I had mikesee build me up a set. lacemine29.com He's super easy to work with and delivers great customer service. Prices seem fair.
  14. #714
    Reputation: Waxtrax84's Avatar
    May 2010
    I just received a 2018 warranty replacement Wozo frame (cracked welds @seatstay to seat tube on the '17). The bike feels much different now, both are size Medium but after reviewing the geometries between the two years the major difference looks to be fork length (at 1cm longer on the 2018). With both bikes running a 100mm Bluto how can the fork length be any different?
    I am noticing that the new bike doesn't want to manual as easy as its 2017 brother and I'm guessing this must be the reason? Maybe putting a 120mm airshaft into the bluto would make the bike feel a bit better.
  15. #715
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by Waxtrax84 View Post
    I'm pretty sure Kona said the frame is exactly the same and that they just corrected the geometry chart.
  16. #716
    May 2010
    Thanks bdundee!
    I also contacted Kona's tech support and they mirrored what you said. It was a typo on their end for the fork length and said they would fix it.
  17. #717
    Same frames, no changes other than colors.
    I prefer the green, but apparently somebody in the Kona chain of command had a baby boy and decided powder blue was the new black, go figure.
    What boggles my mind is Kona has had two years to get on board with 27.5 BFat and long travel forks like the Mastodon, and yet they're still equipping the Wozo with 26" wheels and a Bluto.
  18. #718
    I got one set from Mike Curiak at Lacemine29, the other set I built with parts Mike sent me.
    Mike builds a great wheel, but I usually build my own.
    Quote Originally Posted by Bikemusher View Post
  19. #719
    New Build
    Well - I like the blue....the good thing is that kona sells as frame only - so bfat or whatever is an option...
    New bike build in progress. Ignore stem, waiting on a short stack dmr 50 (hoping will work with my short steerer).
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6009.jpg
    Building as lighter bfat with hugo wheels, hodags, and manitou magnum comp. waiting on more parts....
  20. #720
    Reputation: Stopbreakindown's Avatar
    Nice! Where did you source the frame? My local Kona dealer said they were sold out.
  21. #721
    I like the brown accents, it mutes the baby powder blue 😏
    Quote Originally Posted by telejefe View Post
  22. #722
    Bikeman.com
  23. #723
    [QUOTE=Nurse Ben
    What boggles my mind is Kona has had two years to get on board with 27.5 BFat and long travel forks like the Mastodon, and yet they're still equipping the Wozo with 26" wheels and a Bluto.[/QUOTE]
    I was in Bellingham with my wozo with Mastodon and one of the Kona development team employees stopped to chat with me about the Mastodon and set up. He was saying Kona was definitely considering specíing the Wozo with the Mastodon. I was surprised they have not made the move yet. Perhaps in the end, the question is how many fat tire riders are looking for even more travel and slacker geo.
  24. #724
    Mar 2006
    Finished my build! Already realize I should have gone with 29+ rather than 27.5+ so that will be changing soon. Also have 26x4.3 for snow.
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-mvimg_20180324_142049.jpg
  25. #725
    Sep 2016
    Quote Originally Posted by captainmorgan View Post
    How do you like it as a single speed? What's your gearing?
  26. #726
    Or get shorter cranks.
  27. #727
    Aug 2017
    So, when will Kona update this frame with even more aggressive geo, a steel frame (ŗ la Honzo), and a threaded BB? :)
  28. #728
    Mar 2006
    For the trails here, single speed is perfect. Nothing too hard to climb. I was riding single speed DJ on trails before. It's spring thaw so only pavement riding right now, but so far it seems good.
    I have it set up 32/20 right now and that feels pretty good. I had 34/16 on the DJ with 26" wheels and this feels just about the same.
    I have looked at different crank Arms, but there aren't many options for 165 for dm or ss. Seems sram and RaceFace only come in 170 or 175. won't get me a ton of clearance compared to going up a wheel size or tire size.
    I do need to dick around with the fork and change the travel.
  29. #729
    My Wozo
    Stoked to share my Wozo.
    XL frame with awesome tt length and reach. Built up for $1600...
    Bike fits great and is super fun. This is my 3rd fat bike and blows the previous two out of the water for fun!!!
    Built myself to go 27.5 fat and like that choice. Quite fond of the skinnier fat bike. Personally, I do not enjoy soft snow that much, and this will be perfect for the packed trail conditions I normally ride....
    Fun fact for this build was my first wheel re-build. Rebuilt the stands hugo v2 wheel with a BHS hub. So far so good.....No scale, but much lighter than my Fuel Ex set up with durocs and 29x2.8's....
    Oh...I am also drinking the short chainstay cool aid. Manualled through more terrain than any other bike I have owned including all my full suspensions.....Can't believe 420 vs 435 on my fuel makes such a big difference, but sum of the geometry I guess....
    Still working on pressure with the hugos and hodags...11 psi in rear was not enough for jumps (225 #)....
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6200.jpg
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6197.jpg
  30. #730
    SRAM GX Eagle 165mm, 2017 non DUB, 2018 DUB
    SRAM Descendent 165mm, 24mm and DUB
  31. #731
    That's exactly the thing, people just don't seem to understand how much short chainstays change the ride. Literally, it makes average riders into superstars!
    Not saying you're average or anything
    I love being able to manual on command, esp when I need to manual suddenly; like right before I eat a big rock!
  32. #732
    Duroc 50s? You could keep the wheels and go with 27.5x3.8-4" tires. I've been loving my Wozo with this setup - 29+ is fine but B-lowfat shines on our singletrack.
  33. #733
    Fun!
    Seriously fun bike. Need a dropper ASAP!
    Just as fast as my Fuel Ex both up and down my xc/trail trails. Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6228.jpg
  34. #734
    WNC Native
    Reputation: nitrousjunky's Avatar
    Nice looking ride there and very similar to the build I'll have on mine (except less gears).
    I have a used frame inbound to give a go. Thanks Shinkers!
    I know I've bashed on the geometry a little in the past and no way I'd ever ran one with a 120mm Bluto fork, however we have better fork options now and angleset options.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  35. #735
    Aug 2015
    I put a 125 mm Bikeyoke Revive on mine. Excellent dropper, and well worth the money.
  36. #736
    Still trying to find a frame weight on the Wozo. Does anyone have this?
    "Wait- I am confused" - SDMTB'er
  37. #737
    WNC Native
    Quote Originally Posted by deuxdiesel View Post
    From post #485 -
    Quote Originally Posted by Carl Mega View Post
    Size Large - weight w/ headset cups, sliders, axle and QR seatpost clamp - 5.6lbs.
  38. #738
    Awesome- thanks!
  39. #739
    My Kona Wozo size medium will be going up for sale soon. Just a heads up in case anyone is looking. I'll post a sale build in the next week or so. Not willing to part it out, that's too much trouble, just buy it the way it is, pretty much perfect bike as it rolls
    29+ DT Swiss 350/Duroc 40/Chupas 3" (no fat wheels available)
    GX 11sp drivertrain, Sunrace 11-46, SRAM GX 165mm cranks
    Mastodon Pro 140mm, CC Forty.
    RF 150mm Dropper with sidepaw remote
    XT 8000 brakes
    Stem choices, flat bar
    A seat
    No pedals
    Not sure on the final outfitting as I'm doing other builds concurrently.
    The Wozo is great bike, but I no longer need a fat bike, so I'm going to 29+, likely a Stache.
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-1bc92a63-b197-436e-aa51-e28ec19cf8e1.jpg
  40. #740
    Aug 2016
    I tried to make my Wo into a Wozo for summer, it didn't work... lol
    I'm hoping Kona will send me a Wozo frame (and i'll cover the difference) instead.
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-20180417_201650.jpg
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-20180501_200230.jpg
  41. #741
    My Large Wozo frame with seat collar (no axle or headset) is 2387 grams (5.26 pounds)
  42. #742
    Here's the state of my Wozo - this spring has mostly seen time on the B-lowfat wheels (Cake Eaters on Kore Realm P45 rims):
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-wozo-18-05-15.jpg
    A little while ago I started noticing a creaking in the crank area and figured it was the BB, so I recently ordered the Wheels Manufacturing thread together BB86-FAT to replace the Raceface BB86/92 I used in the original buld.
    While removing the crank to install the new BB I found the spider was loose, so this was the actual source of the creak. I'm guessing the repeated knocks on the spider mounted bash ring eventually worked the Cinch lock nut loose. I added blue loctite and retorqued this so hopefully it'll hold.
    One of the Raceface BB bearings turned smoothly but the other was pretty gritty so I went ahead and replaced it as planned. I got a little over 200 miles on this bottom bracket, hopefully the thread together BB improves on this.
    The Wheels Manufacturing BB installed nicely. I was suprised when the drive side cup slid in without a press and was concerned that the cup would spin while tightening the NDS side, requiring a 2nd BB wrench to install it, but it didn't move and a single wrench did the job.
    With the Aeffect cranks I needed 2mm worth of spacers (WM supplies 2x 1mm and 2x .5mm spacers with the BB) on the spindle to eliminate any side-to-side play.
    This morning's ride was creak free.
  43. #743
    Your bike sucks
    Reputation: Carl Mega's Avatar
    Quote Originally Posted by david.p View Post
    Timely post. I, too, just replaced my RF BB on my Affect cranks. Was getting some creaking. I sort of hedged that it was the BB. Things spun freely. I got a lot more mileage than you tho - more like 200+ rides before the creaking started.
    Did the wheels mfging angular bearing BB92 FAT thread ins - 24mm. Nifty product. Like you -now I have no noise. I think I only installed 2 .5mm spacers and I don't have play. You need the 48.5mm notched wrench for install - FYI for others. If this product performs as billed, I think it'd be a good choice in the long term. Cross fingers - 20ish rides and alls well.
  44. #744
    WNC Native
    Here's the initial build on my WoZo. Hopefully I'll get the first ride on it soon, as the forecast looks good for our trail systems to be reopened this week.
    27.5 x 3.8 Hodags on 50mm Mulefut rims with a 120mm Magnum Pro 27.5+ fork. Angleset is sitting waiting to be installed, but I figured I'd give it a few rides in stock form before swapping over.
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6073.jpg
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6077.jpg
  45. #745
    Increase the travel to 140mm, then you won't need the angleset
    Quote Originally Posted by nitrousjunky View Post
    Lrg GG Pedalhead 29
    XMed GG Smash 29
    Lrg Devinci Hendrix 27+
    Med Specialize Levo FSR 27+ (wife)
  46. #746
    WNC Native
    Do have that option as well. However I'm thinking I'd rather keep the fork at 120 and run the CC -.5 or -1.0 cups instead (can get it slacker while increasing standover 10mm less).
  47. #747
    aka bOb
    That's what I do, I like the little extra standover.
  48. #748
    Reputation: MMcG's Avatar
    Jul 2003
    Nice Stem!
  49. #749
    aka bOb
    A little Wozo action
    https://youtu.be/IOHEOjSz4Pw
  50. #750
    Sep 2013
    Quote Originally Posted by bdundee View Post
    Nice! What wheel and tire combo were you using for your run? Sounded like an I9 rear hub...
  51. #751
    aka bOb
    Quote Originally Posted by mohrgan View Post
    Nextie 90mm hoops with Hope pro 4's and some ole Ground Controls I had laying around. The wheelset is really just my winter set but I couldn't resist taking it for a spin.
  52. #752
    Sep 2013
    Very cool video and great riding! I have been thinking about a Wozo for a while and it would be an addition to my ICT. What size frame do you have and what's your height? I am usually a medium in everything at 5'9" but it appears the reach on the Wozo runs long. I am torn between a medium and a small...
  53. #753
    aka bOb
    Thanks, the bike is a real hoot for sure. I am 5'9 on a medium with a 45mm stem. I prolly could run a 35mm stem as well but it's what I had in the bin. The fit is great except for the standover for winter riding is a little tight (I have a 32.5' inseam) Here it is with the winter rubber.
    Attached Thumbnails Attached Thumbnails Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-23732549_2135603249798516_971897404_o.jpg
  54. #754
    Sep 2013
    Thanks Bob!
  55. #755
    The reach on the Wozo does run long. At ~6', I'm usually on a L frame but went with M on the Wozo based on the ETT/Reach, and this is still the longest bike I've ever had. I like the standover for running b-fat and a 140mm fork and fit is great - very comfortable for long stretches of seated pedaling and lots of fun on the twisty, techy NE trails. I'd go with the ETT/Reach that is closest to slightly longer than what you are used to.
  56. #756
    strider
    WM Threaded BB?
    Hi Carla Mega and David P,
    It is time to replace the stock Raceface BB on my Wozo with the Affect cranks. Is this the correct Wheels Manufacturing bottom bracket (BB86/92 for Shimano)?
    https://wheelsmfg.com/bottom-bracket...nks-black.html
    Thanks for your help.
  57. #757
    Your bike sucks
    You want the fat versions.
    Regular bearings:
    Or Angular like I got:
    Worldwide Cyclery w/ coupon is way to go:
    https://www.worldwidecyclery.com/pro...iABEgI0pfD_BwE
    See if you can dig up a coupon code - a 20% and 15% just expired but they come around.
    "Wheels Manufacturing PF41 Angular Contact Fat Bike Bottom Bracket 24mm Cranks"
  58. #758
    strider
    [QUOTE=Carl Mega;13731528]You want the fat versions.
    Awesome, Thanks Carl Mega! That was the deets I needed.
    Cheers!
  59. #759
    strider
    Cracked seatstay welds.
    Greetings,
    I just wanted to let fellow WOZO riders know that I had a similar situation as WaxTrax84 with cracked welds where the seatstays join the seattube. Kona was ofcourse really good about warrantying it. They didn't have any WOZO frames available, so they unbuilt a complete bike in order to get me a frame ASAP. Cheers to them for awesome warranty and customer care. I just thought I'd send this FYI out to keep an eye on that area as it may be a vulnerable point (probably the only one if any) on this frame.
    This also means that all my matchy-matchy purple bits are gonna look a bit odd going from the Hulk green to Beast blue. But atleast I still get the rad ride and geo of the WOZO.
    Cheers, R-
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_2441.jpg
  60. #760
    Jan 2018
    rvercoe,
    Thanks for the post! Got me thinking... Took a look at my Wozo and was bummed to see that I had the same cracks, only more significantly cracked, at the weld. Called my "local" Kona dealer (3 hours away) and started the warranty process. Unfortunately, it doesn't look like I'll be getting a replacement frame anytime soon. Totally sucks as I had 2 sweet bikepacking trips planned for it this month. Pretty bummed.... This after having my crankshaft literally sheer apart and took that 3 weeks to get figured out.
    Anyone have any idea when the 2019s will be available? Feeling at a loss as I had just whittled down my quiver to 1 bike w/ 3 wheelsets. Doh!
  61. #761
    strider
    Dang Bikemusher, Sorry to hear that. That timing is a huge bummer considering the plans you have.
    I had done the same and reduced my stable to just the WOZO as my one-bike quiver-killer with two wheelsets. I will say that I still rode the frame hard while I was waiting for the replacement to arrive. In addition to a couple rides per week, I also raced to X-C races and two short Enduros and the frame held up.
    I don't know how bad your cracks are, but you might still be able to ride it until your new frame arrives. Do you notice any creaking sounds or additional flex when riding? Just a thought.
    Best of luck.
  62. #762
    Jan 2018
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-20180729_121708.jpgKona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-20180729_121725.jpg
    Thanks, rvercoe! I'll probably end up doing that. Kinda hesitant to go on any backcountry, epics as it is the season but it could be a long walk out.
    Least I will try it on the local town trails.
  63. #763
    WNC Native
    Thanks for sharing this guys, something to keep a periodic check on.
    Otherwise, I'm loving mine!
  64. #764
    Jan 2014
    Ran across these and thought I'd check to see if I'm missing anything. I have the 2017 stock WOZO with 100mm Bluto. I believe it should all fit, or am I missing anything?
    Sunringle Mule Fut 27.5 fat bike rims 80mm with Maxxis Minions FBR/FBF 27.5 X 3.8 120 tpi tires.
    This wheel set was used one winter and are taken off a 2018 Salsa Beargrease. Wheels are in great shape, presently set up tubeless.
    Hub spacing is 150mm Thru Axle front and 177mm Thru Axle rear.
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
  65. #765
    strider
    Quote Originally Posted by Bumpyride View Post
    That set-up should make for a rad ride on the Wozo. I love the 27.5 x 3.8 set-up on the Wozo as an all season shredder. If you can, I recommend bumping that Bluto upto 120mm travel or getting a Manitou Mastodon with 120-140mm travel. That brings out the capabilities of the those wheels and that bike even more.
  66. #766
    Jan 2014
    Picked up the wheelset and minios the other day. Looked like they just came off the showroom floor. Guy was very reasonable $325 and accommodating. Just have to get them back to the West Coast where the bike is. I'm a light weight and no jumping, so I'm actually considering getting an additional carbon fork to lighten the load. Still haven't buried the bluto with a 30% sag, so I'll live with that for the time being, but will hold the idea of more suspension for a later date.
  67. #767
    Jul 2013
    2019 pics spotted
    On the Kona Cog... 2019 spotted... Purple! Mastadon! 27.5 fat by the look of it.
    http://cog.konaworld.com/wp-content/...0-PJK-1176.jpg
  68. #768
    Quote Originally Posted by GusM View Post
    And complete bike only from what I hear.
  69. #769
    WNC Native
    Yep, that's definitely 27.5s on it. Yay for Purple, boo for complete only though. Good to see them moving to a better fork too.
    Mine is hands down, my favorite fat bike to date. I've got over 100 miles on it in stock geometry form (well with 120mm fork) and am slinging the CC Angleset in it tomorrow.
  70. #770
    Mar 2011
    Hope not,as I would drive to dealer this afternoon and pay full price for a frameset and just wait until it shows,but want to build it my way. But I don't really expect any different of Kona. Colors a 59 year old guy wouldn't really want first 2 years production,then good color but won't sell it to me the way I want. Maybe I will go get $700 out of bank and wave it in front of my dealers nose. Kinda want to build it as a 29+ with a boost fork.
  71. #771
    fat guy on a little bike
    ooh, me likey...
    *the bike, not the hipster tied shirt...*
  72. #772
    WNC Native
    Ready to try out the slacker HT angle.
    Kona Wozo Review: 420mm chainstay, runs 29+ to 26 x 4.8!-img_6352.jpg
  73. #773
    A bit of extra stack. Look forward to the ride report. I think I am going to bump my 120 to 140. Really to increase stack - I am out of fork steerer and 6'5" could use the extra....
  74. #774
    WNC Native
    Yep, the change adds around 10-11mm lower cup stack height.
    Uh oh, yeah bumping up the travel or bars with more rise sound like your only options (to stay with that fork anyway).
  75. #775
    May 2014
    Do you think they updated the geo for 2019 or just color, fork, wheels, etc?
  76. #776
    Jan 2018
    Warrantied Frame
    Kona sent me one of the demos they had. Tons of appreciation as I was gonna have to wait another month to receive my warrantied frame!!
    Super excited that today I had the frames swapped out and now I'm ready to roll. Bike looks sweet!
    Not sure why I can't upload photo on my phone. Will add some pics later.
    Colors are inverted from the original green, purple.
    Have 29+ on it now. I have BFats as well. Excited to try Bfats 27.5x4.5. Hopeful!....
  77. #777
    May 2014
    Well, you can add my name to you "Wozos". I bought one of the last(maybe the last)2018 XL frames as my first ground up build. I just have to see what the hype is all about. Going to build it pretty close to factory spec with the exception of a 120 ext mastodon and possibly an angleset. super short stem and 780-800 bars. Pretty excited.
  78. #778
    Jan 2014
    Quote Originally Posted by kelbo View Post
    Hypes worth it. Have fun.
  1. I got my Kona Wozo
    By OfficiallyColin in forum Fat bikes
    Last Post: 12-26-2017, 11:07 AM
  2. Kona Wozo
    By nitrousjunky in forum Fat bikes
    Last Post: 12-30-2016, 05:46 AM
  3. Kona Wozo frame only option?
    By Nurse Ben in forum Fat bikes
    Last Post: 11-30-2016, 04:41 PM
  4. Help with my first bike - KONA WOZO or KONA BIG HONZO DL??
    By stew1818 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 08-19-2016, 02:43 PM
  5. Kona wozo
    By stew1818 in forum Fat bikes
    Last Post: 08-15-2016, 02:43 PM
Members who have read this thread: 302
