Page 8 of 8 FirstFirst ... 45678
Results 351 to 361 of 361
  1. #351
    Reputation: Zinzinnati's Avatar
    Jan 2011
    Quote Originally Posted by prj71 View Post
    Small pinholes that I tracked down with soapy water. 3 in the original tube and 2 in the replacement tube.
    That is odd. I would not expect a pinhole puncture through the casing of the tire. What kind of tubes were you using?
  2. #352
    May 2015
    went to install my new pro 4.5's today. mounted both tires backwards. twice. I hate getting old.
    so maybe instead of having to pump them up yet again, maybe I can just ride backwards....
  3. #353
    Dec 2015
    I am 146 lbs and have them on a 20 lb bike. I am running 6 psi front and back. Here is a link to yesterdays race with them. I had to drop to 6 psi to get the corner traction I want. The beginning is the warm up. The wooded section is the best part to watch.
    https://www.youtube.com/watch?v=zsB0jlVt-bA
  4. #354
    Oct 2012
    Has anyone studded these?
  5. #355
    Reputation: blekenbleu's Avatar
    Aug 2016
    tube pinhole leaks
    Quote Originally Posted by Zinzinnati View Post
    prj71
    did not indicate a casing puncture. The Kenda tube in my 4.5 Pro recently developed a pinhole leak, successfully patched, along a sidewall well away from the valve stem with no corresponding tire puncture. A manufacturing defect in the tube, exacerbated by stretching to fill a larger (than 4.0) tire casing, is suspected
  6. #356
    Nov 2016
    Quote Originally Posted by Rumblefish29er View Post
    I'd like to hear about that as well.
    I'm using the 4.5 pro and so far they are awesome in the snow!
  7. #357
    Dec 2014
    Quote Originally Posted by blekenbleu View Post
    prj71
    The casing was punctured. Tube punctured same exact spot as the casing.
    All I did with the tires is ride them on gravel.
    Never again will I own Kenda Juggernaut Pro tires.
    Sent from my SM-G900V using Tapatalk
  8. #358
    I'm having a hard time setting the bead on 4.5 Pros tubeless. Any suggestions? I'm using a compressor and the bead isn't moving at all.
  9. #359
    Jan 2015
    I set up my 4.0 pros and D5's very easily with a hand pump and generous supply of windex
  10. #360
    Music & Bikes
    Reputation: fokof's Avatar
    Quote Originally Posted by grizwold View Post
    What I do:
    I first mount it with a tube , making sure one side is well seated.
    I remove the tube on the non seated side
    Put the valve and sealant before putting the tire back on
    Then , here's what might help you , I put the wheel horizontal , the unseated side down , while putting air , I "push" the tire so that the seating gets closer to the side of the rim.
    I do it alone but a third or fourth hand might be helpful for the first time.
    Hope that helps
    "There is a big difference between kneeling down and bending over" -FZ
  11. #361
    Oct 2012
    Kenda Juggernaut 26x4.0 (and 4.5)
    Since I know there is a little of negative sentiment on these....Just wanted to say that I've been impressed with my 4.5 sports in up to 5 inches of wetter snow. 3psi up front and 5 in the rear ( I weigh 200) and I've never needed more grip, even over snow covered, wet roots. At those presssures, pavement is torture. Pump them up to 15 or so and they actually roll along pretty well. Have had them set up tubeless on non-tubeless rims for over 3 months with no issues.
  1. Kenda Juggernaut...sub-800g tires???
    By OnThaCouch in forum Fat bikes
    Last Post: 12-27-2014, 08:07 PM
  2. Kenda Juggernaut tires?
    By Jisch in forum Fat bikes
    Last Post: 07-20-2014, 02:56 PM
  3. On-One Midge bars = rad. [x-post 29" juggernaut forum]
    By flexiflyer in forum Singlespeed
    Last Post: 11-10-2013, 09:43 PM
  4. 26x4 v. 29x3.0?
    By green mt. boy in forum Fat bikes
    Last Post: 08-14-2012, 09:45 AM
  5. Replies: 34
    Last Post: 02-21-2012, 09:47 PM
