Page 2 of 4 FirstFirst 1234 LastLast
Results 101 to 200 of 362
  1. #101
    Quote Originally Posted by PlutonicPlague View Post
    Thanks Welnic. Sounds like they are a lighter and less bulky spare to haul around. I should give the Q-tubes a try. I've also heard that the Specialized tubes in the same 2.4" - 2.75" size are worth a try. I ride mainly on the beach, and thorns aren't a problem on the trails I ride. I might stay lucky and continue to avoid flats!
    I have been running the Q tubes in both our fat bikes with very good results. The Bontragers are good too. The Surly light tubes are a bit heavier than the Q version even though they are technically the same parent company.
  2. #102
    Feb 2012
    I rode my wirebead Juggernauts this weekend for the first time. They rolled very fast and hooked up well in soft moondust and dirt in Fruita, CO. Overall, I was very pleased. Pressures ranged from 7.0 on day 1 to 6.3 on day 2, at the lower pressure there was a hint of self-steer. The sidewalls are quite stiff, I suspect I could run them below 5 in these conditions. I ran them tubeless on Hed carbon rims, they were a bit of a fight to seat, but once it was done, no issues. At these pressures, they did not seem to dribble too much in rocky sections, although I did have one big rebound that reminded me of the Scott Unishock.
    Basically, the heavier, wirebead version is pretty good, and at about $60 retail, priced well to be trashed over a summer season. If I can get the Kevlar versions to replace these, I will, and I suspect I have several good months of riding before this pair is done. If I recall correctly, weight was 1100-something grams. The bike is 27.1 with them if I take my KingCage MudFlask off (to refill it, of course, with 12oz of Boathouse Bourbon goodness. For safety).
  3. #103
    Feb 2015
    Quote Originally Posted by Stockli Boy View Post
    Were they the 4.5 or 4.0 juggernauts?
  4. #104
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    Quote Originally Posted by CraigH View Post
    If anyone is looking for the 4.5" Sport (Wire bead) AEbike has them in stock here for the best prices I've seen:
    Kenda Juggernaut Tire 26 x 4.5" Steel Bead Black - AEBike.com
    I picked them up yesterday but haven't mounted, ridden or weighed them yet.
    The knobs are taller than I expected based on the photos I've seen.
    Likely be cutting the center knobs off anyway turning them into a budget Endo/BFL sand tire ala Ward.
  5. #105
    Is there anyone who can tell us how the juggernauts ride in the real world ?
  6. #106
    Feb 2015
    I just got a set of 4.5 juggernauts yesterday. They have great grip and braking performance, however, the rolling resistance is relatively bad. The tires exhibit virtually no self steer although I have only run them on higher pressures.
  7. #107
    Reputation: Swerny's Avatar
    Quote Originally Posted by WalrusWrangler View Post
    I just got a set of 4.5 juggernauts yesterday. They have great grip and braking perfirmance, however the rolling resistance is relatively bad. The tires exhibit virtually no rolling resistance although I have only run them on higher pressures.
    That totally contradicts itself
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6 with Lauf
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
  8. #108
    Feb 2015
    Quote Originally Posted by Swerny View Post
    Sorry accidently said rolling resistance twice. Thanks for catching that.
  9. #109
    I would think no rolling resistance to be a good thing . Amazing quite actually
  10. #110
    Feb 2012
    4.0. I like them in the dirt, wouldn't even bother in snow.
    4/11/15 Update: I've tested several pressures, and they seem to self steer pretty badly below 6.5PSI on dirt, but are pretty happy at 7.1-6.9PSI without self steer or dribbling. They did well in loose dirt, moondust, and platy rocks in western Colorado. A bit of tearout when out of the saddle on steep climbs, not much grip on steep off-camber stuff, but overall, for the price, a good pair to chew up until the now flies. These are wirebead 4.0.
  11. #111
    Reputation: IvanMTB's Avatar
    Hi,
    Any word when 4.0 Pro version will be available for average peddal pusher?
    Cheers!
    I.
    LoMF syndrome...
  12. #112
    Aug 2014
    Just put the 4.5 juggernauts on the front last night (bought one for now as I have to test fitment on the rear). Rode to the bus stop this morning, and agree with your assessment! No self steer, as good as my husker dus, but definitely more rolling resistance, which is to be expected. Measured just shy of 110mm on an 80mm rim. Also agree the knobs are quite pronounced.
    Oh yeah tried my best to weigh, kinda hard being a write bread tire, but came in right around 1500g, not a lightweight.
  13. #113
    So anybody? Anything?
    No word about when Pro wersion will go public?
    Cheers!
    I.
    LoMF syndrome...
  14. #114
    Used the 4.5 for a trail ride (loaded with a heavy pack), 2 flats due to thorns (one front, one back). I think the knobs are spaced too far apart so that the tire casing is actually in contact with the ground. Changed to 4.7" Bulldozers for the next day with no flats on the same trail.
    I bought the 4.5 Juggernaut tires to use for beach & sand, they just can't be used for trails.
  15. #115
    Slow is good
    Reputation: Drillbit's Avatar
    Oct 2007
    I bought a pair of the 4.5's for my Fatboy before I went on vacation to Florida. I anticipated doing a bit of pavement riding and didn't want to wear out my Ground Controls. They performed well on the beach until the pressure got really low, then there was noticeable self steer. They were fine for pavement. When I got home and hit the trails is when the performance fell off sharply. The first trail I rode was one I hadn't ridden for a couple of years. The tires were very bouncy during a large portion the the ride. I stopped ant let some air out of them and the bounce decreased, but the rolling resistance increased. When I get back to my car I checked the pressures, 3.5 front and 5 rear. Much lower than I had been running on dry trails.
    The second trail was a very familiar trail which I had ridden not too long ago. I increased pressure to 5 front and 10 rear because I know this was a smoother trail. The tires seemed slow to me, even the downhill sections where I knew what to expect the didn't carry the speed as well as the Ground Controls. Felt like I was working much harder to ride at my normal pace. I can only attribute this to greater rolling resistance. I re-mountd the Ground Controls when I returned from the ride.
    I liked the price ($120 for the pair), but I guess $55 tires can't compete with $160 tires.
    I am by no means an expert, just an average rider. But I did notice a huge difference between tires. That's my take, YMMV.
  16. #116
    Jan 2014
    They are OEM on my scott big ed, loads of grip, but loads of drag. Mounted a set of maxxis mammoth for summer, and the jumbo jim for winter driving.
    Weight them at 1590 and 1610 grams, 4.5 60tpi sport version
    Scott Scale 710 plus, with mt7 danny mcaskill, eagle nextie and some fun bits
  17. #117
    Has any one run the kenda juggernaut 4.0 folding Pro ?
    Is it available Now?
  18. #118
    Reputation: jeffreyjhsu's Avatar
    I rode a test bike equipped the the 120 tpi 4.0 version. The knobs are very small and the tires are very fast. I don't know their weight as they were already on a test bike.
  19. #119
    Juggernaut Pro
    Quote Originally Posted by Big Foot View Post
    I gave up trying to find Jumbo Jims and went on a search for the Juggernaut Pro 4.0 120tpi. Finally tracked down a pair. Here are the weights:
    868gr and 867gr
    Kenda Juggernaut 26x4.0 (and 4.5)-img_3369.jpgKenda Juggernaut 26x4.0 (and 4.5)-img_3368.jpg
  20. #120
    Quote Originally Posted by tjdog800 View Post
    868gr and 867gr
ID:	1021594Click image for larger version.
    It is my firm belief that unicorns are sacrificed to make these tyres.
    Where oh where did you pur-chase these most elusive of items sir ?
    I have in my extended search , managed to acquire 4 goose eggs (gold) , rocking horse poop (3 sacks) and dentures - hen (7 sets) . Some of which I am willing to exchange for information leading to the actual procurement a pair of these far more scarce fictional pneumatic wonders .
    TIA
    Fat Biker
  21. #121
    Apr 2014
    Quote Originally Posted by Fat Biker View Post
    TIA
    Fat Biker
    Monfat.fr bought a pair from them came in at 820/830 grams
  22. #122
    Quote Originally Posted by mortenste View Post
    Thanks bud will check them out ASAP
    Fat Biker
    Edit: Well . Not an entirely fruitless exercise . NO Juggernaut Pro's
    Well not much of anything as far as "parts for fat bikes" goes . 1 inner tube and 3 Tyre options and THAT's it
    The good news is though that they DID have my second choice of tyre the Jumbo Jim Liteskin 4.0
    2 ordered and 161 Euros relieved from my bank account
    very happy .
    Double thanks
    Fat Biker
  23. #123
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    My Bud and Lou are getting winterized with a fresh set of teef soon, and will become my dedicated winter tires from then on.
    For summer use, I'd like something a little narrower (and a lot lighter), but that will still run fine on my Clownshoes, without having to build up a whole different wheelset. A pair of Jugs have risen to the top of my list for next spring. But I'd love to see a few more offerings in this "mid" size range - kind of like Surly bringing back the ET as a great in-between 2" and 3" option, the 4.5" tire seems ripe for development, particularly with dirt-specific tread designs. But I'm also a horrible businessman, and I realize I probably represent a tiny niche of an already small niche...
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
  24. #124
    Jan 2014
    Better option is the jumbo jim, juggernaut 4.5 is an anchor and same weight as the bud/lou
  25. #125
    Ambassador of Chub
    Jul 2015
    Quote Originally Posted by Novaterra View Post
    Yeah, you're right - I was getting my 4.0 and 4.5 weights mixed up, which I'll blame entirely on the painkillers I'm taking right now.
    Well, maybe I'll go back to the Bulldozers for summer use. I'd really like to run something a little skinnier than the Lou/Bud in the summer..
  26. #126
    Still searching for a reliable source for the 4.0 pro's.
    After purchasing a set of my second choice Jumbo Jim's 4.0 liteskin all I can say is I'm disappointed with the weights of the JJ's. Both marked up as liteskins and both over 1100g (1108g and 1137g) !!!
    I must say though that the mould quality is not what I have come to expect from Schwalbé and the printing on the sides looks second rate too. If I didn't know any better I would say they're fakes, but I've neither heard or seen such a thing with tyres ????
    So, top and bottom of it is . . . . . . Any news on the public pro 4.0 120tpi Juggernauts availability ? Before Christmas, before spring ? Hell before NEXT winter ?
    Fat Biker
  27. #127
    Fat Biker
    I talked to a Kenda Dir of Sales and Marketing at their booth during the ICEMAN Expo... says the J-Pros are just now in production and due in the USA in 3 weeks. Also, after inspection, said that the the ones I found were pre-production/engineering versions and I should not have been able to get them... will be replacing them with the real McCoy's (minus the nasty self steer I hope!).
  28. #128
    Sweeeeet! 3 weeks is only like 6 months in fat bike land!
  29. #129
    That's good to hear , thanks.
    I do hope it's true and they're pretty close to the 880g-900g we've been seeing lately .
    I believe the first pre-production one were coming in under 800g .
    Probably means that we'll be lucky to get them for spring in the UK
    I do wish companies would't reveal or pre-release stuff so far off being production ready though .
    This thread's a year old come next week .
    Fat Biker
  30. #130
    Fat Biker
    Kenda rep said the production versions were coming in at about 850gr. Not the 750gr pre-pro weights like the ones I got.
  31. #131
    Oslo, Norway
    Feb 2012
    Yep, just got six more of these. Lightest was 815g, the rest right around 860g.
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
  32. #132
    Nov 2007
    Starting to see the Juggernaut Pro 4" version showing up for sale. At 835g, they're a little heavier than the ill-fated v1 that popped up and disappeared quickly. That's still ridiculously light for a 4" tire. Anyone try these yet?
  33. #133
    RAKC
    Reputation: tigris99's Avatar
    I can find the 4.0, not the 4.5
  34. #134
    Jan 2014
    where are people finding the 4.0 pro? I have a race next weekend and would like to set these up tubeless on my Farley 7 for the early no-snow fatbike races.
  35. #135
    RAKC
    use google, ive seen a couple places with it. Bikeman was one of them, forget the other one.
  36. #136
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by SmooveP View Post
    Yep, been riding them since May or so. Just got to test them on some snow as well. Works fine, but they are not the best on powder, of course.
    They will be way fast on packed snow.
    Espen Wethe
    www.kindernay.com
  37. #137
    Nov 2007
    Quote Originally Posted by slowride454 View Post
    eBay
  38. #138
    Nov 2007
    Quote Originally Posted by Espen W View Post
    What kind of (non-snow) terrain did you test them on? I'd have to think these are way fragile. Maybe a good beach tire, as long as there's no seashells .
  39. #139
    Oslo, Norway
    Feb 2012
    Hardpack with a multitude of sharp rocks.
    They are more fragile than more standard type fat tires, but held up surprisingly well.
    Espen Wethe
    www.kindernay.com
  40. #140
    blood in / blood out
    Reputation: majack's Avatar
    I just picked up a set of the Jugger Pro 4.0's. But I will have to wait till I use them. We are heading into the early part of winter here in MN, so snow is coming. I like my VanHelgas for the snow and that is what I have mounted on the bike now. But after reading what Espen wrote about the tire, he has me thinking if I should give the JP's a try in the snow.
    Espen, did you reverse the tread pattern on the rear when you had it in the snow?
    RICOH for LIFE
    Pain is Weakness
  41. #141
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by majack View Post
    Yep, run it reversed on the rear.
    (Tioga Farmer John style)
    Espen Wethe
    www.kindernay.com
  42. #142
    The prices for the 4.0 Pro are crazy low. I'm suspicious. Unless these tires are significantly inferior to everything else on the market, we've been played the fool for years.
    The Fat-B-Nimble has it's own shortcomings, sure, but this proves that its pricing is not an anomaly for decent tires.
    Weights and bead-bead measurements when these start arriving please.
  43. #143
    Reputation: thickfog's Avatar
    Oct 2010
    Quote Originally Posted by bme107 View Post
    Yeah, but got mine for 60 bucks at treefort. Kinda scares me like you said. We'll see. Hopefully we've simply been suckers for years.
    CRAMBA Chairman
  44. #144
    Thanks for the reply Espen. I was going to run it in reverse but wanted first hand feed back before I mounted it up.
    RICOH for LIFE
    Pain is Weakness
  45. #145
    Oslo, Norway
    Feb 2012
    Out of many:
    Lightest that I have seen: 815g (latest production run)
    Heaviest: approx 930g (production run from this spring)
    Bead to bead: approx 231mm
    (They measure 4.2'' on a 80mm rim @20psi and 4.5'' on a 100mm at the same pressure)
    Espen Wethe
    www.kindernay.com
  46. #146
    Oct 2010
    Mike came in just today. 935 grams. 23mm bead to bead. My Jumbo Jims are almost as light and probably a better overall tire. We'll see.
    CRAMBA Chairman
  47. #147
    Reputation: thecanoe's Avatar
    I'd like to see the durability of the 4.0's on real life riding before I spring for them. The weight savings must sacrifice some durability.
    Santa Cruz Tallboy
    Moonlander
  48. #148
    RAKC
    Everything is a trade off that's just a given. Saving weight means less material. So they arent going to be as durable as a 1300g tire. Like everything gonna have to choose what is most important.
  49. #149
    How would these do in dry, loose, dusty conditions as a front?
    I'm dissatisfied with my FBN (it seems to wash out a lot).
  50. #150
    Mine J-Pros came in at 844g and 845g. My first set (returned) came in at mid-750ish. These new ones have a smooth tubeless-ready bead instead of the earlier serrated style.
  51. #151
    Reputation: DubzOxford's Avatar
    Nov 2012
    Look what just came in the mail. Both weigh exactly 882 grams with the rubber band. Note: These are the 4.0's
    Fat and Single
  52. #152
    Nov 2014
    Has anyone tried 4.0 or 4.5's in snow yet?
    If so, how did they work?
  53. #153
    RAKC
    Read the last couple pages, all is answered there
  54. #154
    Nov 2012
    First impressions. The tires mounted up super easy tubeless on my 65mm Light bicycle carbon hoops. Had no leakage anywhere, which was nice for once. I took my Pugs out for the maiden voyage this morning. Dirt roads were solid and the trails were a mixture of leaves, solid dirt and a little mud from the sun drying out the wet spots. Right away I thought the Kenda's made less noise then my Husker Du on the pavement. I was stoked to think maybe they would roll better then the Du's. This was not the case at all. I was getting dropped coasting on the downhills by guys I usually are side by side with. Then when we got into the trails the bike felt very sluggish compared to my Du's. It got to a point I got off the bike to check to make sure my brakes were not applied. We continued to hit more trails and the feeling of high resistance was still there. Once we got off the trail we hit some more dirt roads. I know these roads well and I know how my bike should feel on them. Again, I continued to get dropped on the downhills and the climbs. The tires just don't roll very well. I got home and checked tire pressure. 11 in the rear and 9 in the front, Exactly what I run the Du's at. Maybe I was having an off day in the saddle, I really hope so. The Kenda seems like a great all around tire. I will need to put some more time on them before I condemn them and go back to the Du's.
    Fat and Single
  55. #155
    Sep 2015
    Quote Originally Posted by DubzOxford View Post
    Don't bother, the Husker Du's are way better, those Kenda's are superb in weight, but that's all. Those Kenda's are superb on flat beach conditions or dryland.
  56. #156
    Jan 2014
    The 4.5 is a big boat anchor, the 4.0 probably a not so big boat anchor :-)
  57. #157
    Sep 2015
    Than you need more body weight lol
  58. #158
    Jan 2013
    Been riding the 4.0 pros for a few days now. they made my crestone feel way lighter but they don't roll very well at all. switched back to the 4.0 jumbo liteskins today. better tire in every way but weight and price.
  59. #159
    Nov 2008
    I just got my pair and here's my initial thoughts:
    1. They are LIGHT. But they are also very low profile in the knobs and very, very thin. I ride mainly beach with sand and rocky Puget Sound areas....we'll see how they hold up.
    My Borealis Yampa with a well warn Knard and a 45N Dillinger up front weighted 26 pounds. The Kendas mounted up on my Marge Lites tubeless super easy. Easier than any tires I have tried prior. The tires are also the most true I have tried...no hops and no wobble.
    My bike now weighs 24.1 pounds...just about two pounds off the bike!
    First ride was on trails with some water and mud. I did not notice the drag some have mentioned. Set up tubeless I felt these rolled faster than my prior set up. They gripped well but in the slimy mud they slip but grab (while the Knard just slips).
    I am looking forward to see how these work on Sand...many of my friends cut their Endos and Larrys down for sand and I think these may be perfect they way they are....especially for a 3 season tire. I am unsure how these would be on snow.
  60. #160
    Sep 2012
    I've had the 4.0 Pros for a few weeks now. The posters talking about the tires not rolling well, eh disagree. I've been riding the midwest on them so no snow (i wouldn't ride them in snow) on both river trails and some of the nicest real mountain bike trails wisconsin has to offer. That said these roll fast and climb faster, the 4.0 is rough on the down hills with a rigid fork. I'm still crossing my fingers that a tire with low knobs like the Jugger in a 5" will make production some day. Until that day these are a great fast tire for someone used to riding fast 29er's etc.
  61. #161
    Quote Originally Posted by MichaelHumpal View Post
    What tires were you on before?
    Sent from my A0001 using Tapatalk
  62. #162
    Sep 2012
    Quote Originally Posted by Negotiator50 View Post
    I've owned Ground Controls, Dilly 5s, HuDus, Vanhelgas, demo'd tons more.
  63. #163
    I'm pretty inexperienced with tubeless but the sidewall leaks seam excessive. I hope 6oz of stans is enough to seal it all and i need to keep adding air and shaking every hour to keep them from going flat and falling off the bead. Did anyone else experience this?
  64. #164
    RAKC
    Welcome to kenda tires. The 29er tires I had did the same thing. Can't get feather light tires and expect much rubber in the side walls. But that's why I use home brew sealant, so much better at dealing with that problem than stans imo.
  65. #165
    Quote Originally Posted by yeroc40 View Post
    Wow!
    I wouldn't bother going tubeless with these.
    I'll stick with tubes with some sealant in them.
  66. #166
    Jan 2013
    I had mine tubeless on nextie rims and they sealed up great, surely did not have seepage like your photos show. I only ran them for a couple weeks and switched back to jumbo jims, the rolling resistance on mine sucked, I see others that say they think they are fast though. I guess it's one of those YMMV.
  67. #167
    Jan 2014
    I dont know what tyres you guys were running before mounting the juggernauts, but surely not jumbo jims, even the winter setup, 45nrth flow and dunderbeist have less rolling resistance than the juggernauts. And the beists roll lot heavier then the schwalbe's
  68. #168
    Quote Originally Posted by fagro View Post
    Wow!
    But the sealant makes such a lovely pattern on the sidewalls.
    Surely it's gotta be worth it just for that ? LOL
    Fat Biker
  69. #169
    Jul 2015
    I picked up a pair of the 4.5 Jug sports (couldn't resist, $90 shipped for the pair). On a 93mm rim, the carcass is only a few mm wider than the stock 4.0 Chaoyang, AKA Fat Be Nimble. The 4.0 measures 100mm at the carcass and I didn't get an exact measurement on the Jug. Lug-to-lug measurement is notable wider on the Jug though, which it should be. The specified vs actual measurements of all fat bike tires, even on very wide rims, is maddening.
  70. #170
    Reputation: bepperb's Avatar
    Quote Originally Posted by BadgerOne View Post
    You need to compare bead to bead measurements.
    Measuring width of the non-flattened (by the ground) section of a snow tire, or really any fat tire, doesn't make much sense to me even though you see it all the time in reviews. If the cross section is taller but the width is the same, the contact patch will still be wider. And if you just put them on, it might change as well as they stretch.
    FWIW, I think the Jugg 4.5 should be 245mm bead to bead, and the FBN somewhere closer to 217. That's a lot more volume even if your width measurements don't indicate it.
  71. #171
    Reputation: MegaMustang's Avatar
    Which tubes for the 4.5" Juggers
    A laugh... and then a quick advice request...
    I got a Moto FB4 Comp a couple weeks ago THIRD hand. Needless to say, I got a pretty good deal on it and have had fun getting it back into top running gear along with moving some hot rod parts from the parts shelf to my green piggy that is destined for winter beater status.
    First thing I bought for the bike was a set of 4.5" Juggernauts. I figure they'll get me around well in the relatively mild winter here in Virginia. Plus, the price was irresistible ($89/pair and free shipping via Trail This on eBay). I'll probably go to a set of 4.0 tires for casual summer trail riding.
    Anyway, I pulled off the Vee Missions and found this tube inside. OMG...LOL... SIX patches! Six!
    Surprisingly, this Vee Rubber 4.0 tube has held up to some pretty rough rides I've put it through over the past couple weeks.
    So the Q...
    I know for a 4.0 tire, the usual advice is to go with the Q-tubes 2.4-2.75 tube. But what about for these 4.5 inchers? Have you run the Q-tubes in the bigger tires with good luck, or should I just go ahead and get the Ultra-Light Surly tube (3.0-4.8). Something else?
    Thanks in advance!
    _Matt
    I just wanna ride...
  72. #172
    Jul 2014
    Quote Originally Posted by MegaMustang View Post
    So the Q...
    Thanks in advance!
    _Matt
    Not the Qtubes, but I've run the Specialized 2.3-3.0X24" tubes in the Bud/Lou without issue before I switched to tubeless.
    '17 Cutthroat
    '16 Bucksaw Carbon
    '15 Fatboy Expert
  73. #173
    Nov 2015
    I've got the Q-tubes on Snowshoe XL 4.8...so far so good, though only about 30 miles in on easy/moderate terrain. Oh...and that tube is good comedy, thanks!
  74. #174
    *hangs head in shame*
    Other than that triple patch monstrosity I see no problems with 6.
    I've seated beads on 4.8s with 26x2.3-2.5 but never rode them, only rode in 3.8s.
  75. #175
    Reputation: Klainmeister's Avatar
    Running the 4.5 Sports and feel they are absolutely slow. Compared the 4.7 Bulldozers, a somewhat scientific coasting test informed me that the rolling resistance is hugely worse on the Juggernauts. Considering swapping them at this point. Grip is there, though, for sure.
  76. #176
    Jul 2015
    ^^ Exactly how I feel about them. The weight is fine, and the thin sidewalls allow good flex, but they are pigs to ride. If I leave them on, by spring I will be in the best shape of my life.
  77. #177
    Jan 2009
    I set my Surly Wednesday up with Juggernaut Pro 4.0. I can't make it out to the woods until this weekend. I will not be riding snow, I live in Tampa. So, the Juggarnauts are just for dirt.
    Testing these tires out on the street, the tire behaves strangly at slow tight turns. It's a form of self steering. I think the rubber is thinner under about 3/4 inch of the tread on each side. It almost seems when you get on that edge that it must flatten out and the bike wants to pull on that edge.
    Has anyone else experienced this on the Juggernaut 4.0 Pro? If so, does it ride better on the dirt trails?
  78. #178
    Dec 2013
    All my fat tires feel like shit on the street when run at the pressures I run them on the trail.
  79. #179
    Jan 2009
    Matto6,
    Thanks. Your right I won't know anything until I get on the trail and test them out.
    Another question: My digital tire pressure guage sucks with presta valves. I was thinking of either getting a Meiser (analog) 15psi presta or 30psi presta. Anybody using either of these with success on their fat bikes?
  80. #180
    Dec 2011
    I think there may be a whole thread on gauges for fatbikes somewhere
    "Buy the ticket. Take the ride." -Hunter S. Thompson
    "Life is too important to be taken seriously." -Oscar Wilde
    "Single speeds should come in cans" -Me
  81. #181
    Reputation: traditiionalist's Avatar
    May 2014
    Okay here's my question..... would the juggernaut 4.5 sport be a good choice for a mud/snow tire? I already have a spring/summer/fall, but are they that slow that I couldn't use them all year long and keep up (actually I am faster) with a group of 26" rider's?
    A ebay seller has them for $89.99 a pair, that seems cheap enough but decent enough for a knobby tire.
    I'm not looking for a speed demon tire, just somthing that I can keep up with my 15mph average speed.
    I do alot of log rides (some up to 140 feet long) and need these tires to have some bite on logs.
  82. #182
    Juggs 4.50 Sports grip great, but are real pigs on damp trail
    I bought a set of the 4.5 Sports (probably from same seller -- BTW, very good seller - fast shipping). However, I felt like the tires were like tank tracks. Really solid and confident grip, but took A LOT more effort to go the same speed as I did on 4.0 Vee Missions -- to be expected.
    The Juggs went on very easily and are impressive once on the wheel... especially the big wheels I am using (100mm and 80mm).
    I rode them on a cool, misty day -- mid 40s (Fahrenheit). I set them both at 7.0 psi (with the Vee Rubber tubes). Getting on the bike for the first time after installing, I noticed I had to swing my leg higher and was now an inch or so higher up (probably more BB and pedal clearance). When I rolled around the parking lot, I noticed no self steer (surprisingly). They seemed stable and quite agile for their size.
    As I first dropped in, I was impressed with the grip. Wow! However, within the first few minutes I noticed a big increase in required effort. After 30 minutes or so, I was convinced that these tires were really slow rollers and felt like they were super heavy. After a 2 hour ride, I was pretty sure they were coming off immediately.
    It's probably not a fair comparison, but I put a set of 4.0 Panaracer FBNs for the next ride (from same ebay seller) in the same conditions (two days later) and flew around the same course with much greater ease.
    Back to the Juggs. I don't think they are bad tires, they are just massive overkill for the conditions I rode them (here in northern Virginia). I'm keeping them for when I ride in much harsher conditions -- super sloppy or snow. I would think that with even lower pressure (5-6 psi), they'll ride over most anything -- though with a good bit more effort.
    Hope this helps a bit.
    _Matt
  83. #183
    May 2014
    _Matt
    Matt, that helps alot. I think for a winter tire that won't break the bank these are my best bet. I'm not a speed demon, not looking to break any strava times. Just looking to have fun. I'll use these for winter, early spring when it's mud and maybe fall depending on how they work out for me. I think these paired with fbn would be probably the best setup for around $200.
    Just curious though, what kind of riding do you do? Where are you located to get an idea of the trails your riding. I'm in NY, so rocks,roots,mud,logs,snow you name it we pretty much have it. I'm guessing the juggernauts are a durable tire.
    Edit:saw a 4.5 pro on ebay for $60 each are they better than the sport? Same size knobs?
  84. #184
    Dec 2014
    Quote Originally Posted by traditiionalist View Post
    Same tire, but Pro will be a lighter tire since it's not a wire bead.
  85. #185
    I'm very surprised to hear this. I was really looking forward to these as a fast summer tire. Strange that they're so light but roll so slowly...
    Perhaps they'll roll better once "broken in"?
  86. #186
    May 2014
    Quote Originally Posted by ultraspontane View Post
    I'll be ordering a pair within the next few days... I'll let you know my observations. Coming from a 2.3 nevegal on a 26" tire I'm used to slow rolling tires.
  87. #187
    Sep 2015
    Superfast tyre if you take the 4.0 120tpi.
  88. #188
    That's not what the ride reports are saying.
  89. #189
    Sep 2015
    Got two guys here who have them on their Inferno fatbikes, they are holding up with 29ers easily. I just was a little too late with ordering these, and they are out of stock for a while here in Europe. May be they had other series than? Because what I have seen there were hardly knobs on those tyres and asked if they had any problems to stay on the bike in muddy conditions.
  90. #190
    Jan 2015
    Here's an interesting review from fat-bike.de The Kenda Juggernaut 4.0 Pro is the lightest FATBike tire
  91. #191
    Feb 2015
    Quote Originally Posted by matto6 View Post
    Not mine.
    Both Ground Controls and Barbegazis' feel fine the the pavement at 5 PSI - no self steer, no strange behavior at all.
  92. #192
    Your Best Friend
    Reputation: Silentfoe's Avatar
    I've had the Barbegazi's for two weeks now and have ridden them in a lot of different conditions. As much as I like them, they do have horrible self steer. I don't know how anyone could miss it.
    I'm a mountain bike guide in southwest Utah
  93. #193
    Feb 2015
    ZERO self steer on my Barbis down to 5 PSI
  94. #194
    Quote Originally Posted by Silentfoe View Post
    I think steering geometry can play into the equation.
    Latitude 61
  95. #195
    Feb 2015
    Yep - head angle can play into it, no doubt.
    I have zero self steer on the Farley 7/Barbis.
  96. #196
    Your Best Friend
    Not really. It's the tread design. It doesn't have a center line of treads and actually two parallel lines of tread just off center they conspire to fight control of the tire. I've used a bunch of different tires and I'm not shy saying something I spent a bunch of money on isn't perfect.
  97. #197
    Boom headshot! I've noticed this forum has more than it's fair share of confirmation bias.
  98. #198
    Then there's the, "This happens to me so it must be true for everyone else in all circumstances." bias.
    Latitude 61
  99. #199
    Dec 2011
    Can't we all just get along????
  100. #200
    Feb 2015
    I'm not going to sit here and tell you that you're not experiencing what your experiencing, but I don't think the treads are working against you in the way you describe. It doesn't work that way.
    I appreciate that - we need more of that around here quite frankly.
    All I can say is that I know what self-steer is as I experienced it in an acute fashion with the 2013 Kona Wo and those V tires. The Barbagazi tires are very well behaved for me - in fact I rode out to the road this morning to test again at 5 PSI. Absolutely self-steer free.
  1. Kenda Juggernaut...sub-800g tires???
    By OnThaCouch in forum Fat bikes
    Last Post: 12-27-2014, 09:07 PM
  2. Kenda Juggernaut tires?
    By Jisch in forum Fat bikes
    Last Post: 07-20-2014, 02:56 PM
  3. On-One Midge bars = rad. [x-post 29" juggernaut forum]
    By flexiflyer in forum Singlespeed
    Last Post: 11-10-2013, 10:43 PM
  4. 26x4 v. 29x3.0?
    By green mt. boy in forum Fat bikes
    Last Post: 08-14-2012, 09:45 AM
  5. Replies: 34
    Last Post: 02-21-2012, 10:47 PM
Members who have read this thread: 27
