Page 7 of 8 FirstFirst ... 345678 LastLast
Results 601 to 700 of 710
Thread: Jumbo Jim
  1. #601
    Reputation: Zinzinnati's Avatar
    Jan 2011
    Quote Originally Posted by Lars_D View Post
    Holds up great. I cut the bit in half and pushed it into the drill far enough that only the right length stuck out.
    I may have missed an earlier post of yours, but how deep a pocket did you make? I like how high your studs are sitting in your tires and I'm considering doing this to a set of juggernaut sport tires. Just to confirm, you used a 5 mm drill bit?
    Cheers.
  2. #602
    Reputation: Dilligaff's Avatar
    Nov 2015
    I feel compelled to mentions something about the JJ Liteskins. A friend has run them for the last 6 months and had 11 flats on the rear tube and one on the tire itself. He said he pretty much plans on a flat when he goes out and is surprised when he doesn't get one.
    He switched to a FBR and hasn't had a single flat so he plans on a FBF as well. While the tires are nice and light, the weight is starting to add up with all the patches. He also said the traction with the BFR is light years ahead of the JJ.
    Nothing to see here, move along folks.
  3. #603
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Quote Originally Posted by Zinzinnati View Post
    Cheers.
    1/8 inch drill bit. Depth is roughly the height of the nobs which varies across the tire. Here is my video on how to do it...
    https://youtu.be/OBHdNKajdQc
    --Peace
  4. #604
    Jan 2016
    Quote Originally Posted by Dilligaff View Post
    That is why I am running Snakeskin Tubeless! Will find out how they hold up.
    I have a Maxxis Minion FBR with the EXO protection and I think the tire is too heavy.
  5. #605
    Jan 2011
    Thanks for the response and thanks for the video. I'm going to give it a go with a drill press and my juggernauts. I'll post my progress in another thread.
    Cheers
  6. #606
    Quote Originally Posted by Steve_MTB_22 View Post
    Been riding the liteskin tubeless here in Michigan all summer. Not one issue. I had to top it off a few times through the summer but that's probably due to a poor tape job.
  7. #607
    Jan 2016
    Snakeskins set up tubeless are bulletproof. I've been mashing through sharp rocks and branches without a single worry.
    Edit: 4.8s though, but nevertheless; perfect for summer. Light, decent tracktion, very strong.
  8. #608
    Jan 2011
    The Juggernaut knobs are not broad enough to support a tire stud (measured some nokian studs that I have). I may have to find a used jumbo Jim to try the studding on.
    Thanks again.
  9. #609
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    I'm intrigued - how are some of those patches on the inner surface of the tube?
  10. #610
    Nov 2008
    Looks like pinch flats, generally caused by too low of pressure for given terrain resulting in rims strikes.
    Quote Originally Posted by JackWare View Post
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
  11. #611
    Jan 2016
    Been running JJs 4.8 and 4.4 tubeless with Snakeskin sidewall on some trails with quite a few rocks with no flats.
  12. #612
    I have a set of fresh JJs 4.0 snakeskin looking for a good home. PM with offers. Located in WA.
  13. #613
    I'm in the market for some new winter tires and was wondering if the actual mounted width of your 4.4 is true to the diagram in post #589. I've got Marge Lites and RDs, so wondering if it would fit either as a rear option on a Pugs.
  14. #614
    Ka-coo-ka-cha!
    Reputation: snigs's Avatar
    Feb 2010
    Happy to report that the 4.8 LS JJs are very good in the snow. Broke trail in 3-5 inches of fresh, light powder on some steep climbs at Hayden Green Mountain in Colorado, today (if you know the climb at the W Florida main lot, you know how steep that one is). Temps in the teens, cloudy, 3 psi, Mulefut 80s tubeless using the SunRingle strips and tape (flawless setup, highly recommend for sanity maintenance), first ride with my new 9zero7 Whiteout, 28/42 low gearing. Badass. Great everywhere else, even on a new switchback that has a steep entry. Super satisfied. Only stopped riding because my big toes were damn cold!
    Next ride, moar deeper!!
    Get a bicycle. You will not regret it, if you live. ~Mark Twain, "Taming the Bicycle"
  15. #615
    Mar 2015
    How are the 4.4 JJ's coming out for size and weight compared to stated values? i have the 4.8's and love them but i am thinking about the 4.4's on a set of 65mm rims.
  16. #616
    Rippin da fAt
    Quote Originally Posted by Jefflinde View Post
    4.4's on 65's sounds rather nice!
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
  17. #617
    Jan 2016
    On the 4.8 inch tires the 4.8 dimension is running 4.5xx on a 80mm Sun Ringle Mulefut ~ 8 psi
    On the 4.4 inch tires the 4.4 dimension is running 4.2xx on a 80 mm Sun Ringle Mulefut ~ 8 psi
    The picture of the tire on my bike is a 4.8 and the 4.4 solved the clearance problem. Hope this helps.
    My opinion is go for the 4.4 on the 65 mm rim if you have the clearance and want more tire volume.
  18. #618
    WNC Native
    Reputation: nitrousjunky's Avatar
    Any chance of pics of what the tire profile looks like on your Mulefut?
    Curious how much rim protection this combo gives, as I'm debating whether to try this on my Mulefut rims or switch to some 65mm rims with 4s.
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
  19. #619
    Reputation: watermonkey's Avatar
    I'll try to get you a pic of JJ 4.0 on my 65's later this morning. They look appropriately proportionate on the 65's and ride really really really well...on dry. Don't think this would go on snow (edit - the kind of snow I ride around here).
    I would advise not taking my advice.
  20. #620
    WNC Native
    Quote Originally Posted by watermonkey View Post
    I'll try to get you a pic of JJ 4.0 on my 65's later this morning. They look appropriately proportionate on the 65's and ride really really really well...on dry. Don't think this would go on snow.
    Sweet, I would like to see pics of that combo too!
  21. #621
    While they might not be ideal on snow, it doesn't hurt to remember that the fat bike revolution was started by bikes with 65mm rims and tires with basically no tread.
    Latitude 61
  22. #622
    Jun 2010
    Bought two LS 4.40's. One was 1128g, the other 1145g.
    Running them tubeless on Marge Lites. Very pleased. Fits the rear of 170mm 9:zero:7 frame well. 4.8 LS on front.
    I liken these tires to Dugast for cyclocross. Probably the lightest and most supple for the size. Work well in soft snow when aired down appropriately.
  23. #623
    Dec 2016
    4.0 versus 4.8 ?
    Question for you guys who have ridden the JJ's snakeskin...if you had to choose either the 4.0 or 4.8" size to run on a bike that could comfortably run either, which would you choose and why?
    I need to commit to one size or the other for a build I'm having done...will be running tubeless on mulefut SL 80s. Most of my riding will be dryer conditions (sandy soil, rocks, grass, some trail), with a few snow rides each year.
    Why so uptite?
    Dec 2005
    Quote Originally Posted by Coyotefred View Post
    For drier conditions I prefer the narrower 4.0", just a tad bit faster. If these 4.4" versions become easier to get that would be a nice option.
    Collection of fun carbon & titanium bikes
    @tgi_cycling
  25. #625
    Dec 2016
    Yeah I was thinking the 4.4's too, but my builder says they'd be considerably more expensive compared to the other too.
    I think I remember reading that the 4.8s are really closer to 4.3/4.4 on the rim, so wondering whether that means the 4.0s are closer to 3.6-3.7"?
    Quote Originally Posted by EBG 18T View Post
  26. #626
    Rippin da fAt
    I'm stickin with 4.8 due to the feel and ride. 4's aren't as comfortable to me. I'm not trying to make a Jeep into a dragster either, just rockcrawling and hitting sand, snow and loose forest floor style riding. The 4.8 doesn't break loose as easy as 4.0 and riding pressure is lower for more traction in addition to their already super sweet fatness. My JJ's roll very nicely as well with zero self steer when I air em down. A wee bit more BB clearance as well with 4.8.
  27. #627
    Reputation: Bacon Fat's Avatar
    Mar 2016
    My JJ 4s measure 3.9+ on 80mm rims.
  28. #628
    Jan 2016
    I have been putting miles on my 4.8 front and 4.4 rear JJ's with snakeskin. Riding in MA/NH area winter things have been great.
  29. #629
    RM Blizzard? I was pretty ticked off when my 4.8 didn't fit. They made lots of clearance everywhere else, and then stuck the stupid seatstay bridge right in the way.
  30. #630
    Jan 2016
    Yes RM Blizzard for me 2015. I went with 4.8 in front for the sand/snow and 4.4 in the back for clearance (and I have plenty of clearance) I posted tire dimension on an 80 mm Mulefut previously. I have a couple of buddies doing the same in front and going with the biggest they can fit on the back depending on their frame. I also run Beaver Guard fenders front and back.
  31. #631
    I just picked up a 4.0 for the rear, right before the 4.4 came out (doh!). Do you think the 4.4 would fit with grip studs?
  32. #632
    Dec 2016
    So you'd be running 4.8s in back too if you had the clearance?
  33. #633
    Jan 2016
    Picture 4.4" JJ on Mulefut 80mm
    Answering a few previous questions: 2015 Blizzard Size M- My fender is .035" thick and mounted tight to the seat stay crossbar. I can get a .25" wood shim in between the fender and the rear nubs then gently spin the tire. When I go up to a .30" wood shim it gets tight. So the clearance without a fender at 7 psi is somewhere between .285"- .335".
    Do your math on the grip studs. The lugs on this tire are lower profile in the center. Search this string a previous poster even has a link to his method of installing studs. He seems very experienced and did not stud the center which is a loss. My opinion after riding this bike the past couple of years is to use the JJ tires for all around usage until there is lots of ice. Then I would put on a pair of Dillenger 5s. Not sure what is new this year. I own a set of Vee Rubber SnowShoe XLs and although they are better on the price point, I think the Dillenger 5s have a better rubber compound that does not snowball as much, 5s have the self sharpening studs, and as I recall I think the 5s were most likely slightly lighter (you should check those numbers). I was sketchy on the 5s initially because I ride a lot of pointed rocks and was concerned about tearing the sidewall- would probably reconsider as riding buddy has the 5s and they have held up well. I also have another buddy with the 4s which do not float as well as the 5s in heavy snow but are a great tire.
    I would only run a 4.8 on the back if it were light which is why I bought the 4.8 initially that was rubbing. I bought the Maxxis Minion FBR late last year with side wall protection and that tire was way to heavy to spin. That is why I went with the JJs. 4.8 will give you better float but the 4.4 will be sufficient from what I have seen and is a little lighter if you are going to run it all year as a 2nd bike like I do. Glad it turned out the way it did because the 4.4 is a nice option for the rear.
  34. #634
    Dec 2016
    Hey thanks...very helpful information!
    [snip]
  35. #635
    Mar 2015
    I am not sure where your builder is looking but the 4.4s are the same $$$ as the other 2. Bike24.com has them for $5 more then the 4.0 and $5 less then the 4.8. Also I have not heard of the 4.8s being smaller then stated by much if any. I am running the 4.8 on 100mm rims and they are huge. I don't have them on now since all our trails in MN are ice but if you can fit 4.8s I would go that route. If not then get 4.4s. The 4.0s to Lee seem too small and didn't ride as well. I replaced the 4s I had with the 4.8s and never looked back.
  36. #636
    Reputation: FlowinFlo's Avatar
    The Jim 4.4" also is a nicely fitting tire (in this case on a Mulefut) for the rear of an On One Fatty:
  37. #637
    Dec 2016
    This was the review I had read where the measured width on the 4.8 (at 10psi on a 100mm...maybe that is the diff?) was around 4.4
    https://www.bikerumor.com/2015/01/01...at-bike-tires/
    Good to know on the 4.0s being a little on the small side....I think the 4.8s are probably the way to go. Do you like to how they roll for your non-snow riding (when it finally melts in MN?!)
  38. #638
    Mar 2015
    I love how they roll. We have kinda loamy dirt in the spring and summer and then I dries out and packs down in the fall. The JJs stick extremely well on everything. They are also super fast on pavement when I ride to the trails. I have had one puncture but is was the stump of a small tree cut off at an angle. Like a pungy stake so I can't really fault them. Over all I have been very happy with these and the weight is amazing.
  39. #639
    Mar 2013
    I only have 2 rides on my JJ 4.8's but they roll a ton faster than the stock 4.6" Ground Controls that came on my Fatboy. Each tire also weighs about 150 grams less then the GC as well in the Snakeskin variant.
    This is on dirt as we don't have much of the white stuff here in NC.
  40. #640
    frl
    frl is offline
    Jul 2014
    20 psi I measured jj4.8 LS at 4.6" on 90 nextie rim.
    If your frame can handle 4.8". Just go for it. 4.8" soften the condition mutch better. And they role faster then 29er racing Ralph. I tried. Side by side. All so against 27.5+. Way faster on every thing. Don't remember what brand. They where using tubes. I run tubeless. And tubeless helps with rolling resistance. That was on 1980 g wheelset 80 mm carbon singel wall.
    JJ 4.8" LS is the tyre for me. Make fat biking even more fun.
    Got 2 pairs of them. One pair with almost 300 Schwalbe studs in each tyre.
  41. #641
    Dec 2016
    Hey thanks everyone for the feedback...the 4.8s sound like a great choice and what I'm going with!
  42. #642
    Reputation: foresterLV's Avatar
    Dec 2016
    My bike came with 4.0 JJ standard, which were pretty good after skinny mtb tires, discovered fat biking on them. Then I upgraded to 4.8 JJ (liteskin) tubeless+100mm chinese carbon rims and the upgrade feel was huge... Better on sand, snow, everywhere. 4.0 started to feel like 2.4 mtb tires. I have two bikes, one 4.0 on alu 80mm rims and 4.8 on 100mm, and 4.8 rides faster everywhere I can go, faster in terms of time spend on standard course + fun factor.
    But need to note that my weight is 95kg+, I suspect that 4.0 might be better at lower rider weight.
    Had punctured JJ 4.8 twice (in about 6 month riding?), typically on wood branches (or whatever happens to them making then as sharp as awl on the road being ridden over). No problemo with tubeless sealant, just keep going and inflate with handpump if pressure drops too low. Had 1 puncture on 4.0 JJ once too, same wood awl.
    Problems encountered:
    1) on very low pressures liteskin (dont know if snakeskin is different) rear tire like to burp at bead and sealant starts to go away. You can even press sidewall with finger to make air to escape. Dunno if its for all tires or just JJ? Need to be carefull when riding at low pressure.
    2) Front tire washouts on ice (any speed) or snow going downhill (i.e. relatively fast).
    Will try to get 45nrth flowbeist/dunderbeist for a new bike build, and see if the mentioned problems will be reduced. The price differencw is huge though! JJ go here at 60-70 EUR, while beists at 130. So for a pair you need to pay more then twice.
    Sent from my SM-G900F
  43. #643
    Rippin da fAt
    There's a pair of JJ liteskin 4.8's on both ends of my Mayor and I love em. At the moment they are tubed with Surly Lite's and have been highly reliable. I've not been so inclined to tubeless as it makes a tire swap go from 5 minutes to a three ring circus getting that chore done.
    Ice requires the use of studded tires, pure and simple. I tired 4.0's that I borrowed from a friend to test and was unimpressed. My collection of 4.8's just feel better all around. I ride both + and fat with Sarge and Mayor year round cause they are plain groovier than small tires.
    With your tubeless setup, if there's burping from low psi and a simple squeeze, another layer of tape is in order. Bud/Lou do this with single wrap of gorilla tape. A double wrap cures it. I ran the Surly's (Which are the loosest fitting tire on the market) with 2.5f, 3.0r for sand riding and had the burp and sealant leakage. I still have been way too lazy to tubeless the JJ's. Gotta say, I love the feel of the JJ's. Springy and trialsy, indeed!
    They are the cat's meow...
  44. #644
    Dec 2016
    Moved my 4.8 JJ liteskins to 80mm alu rims (non tubeless ready) and tubeless seems to work just great, no air leakage for two hours ride or any signs of sealant coming out of the beads, was using two layers of gorilla tape (adds 100g!) indeed. Was not running at low pressures today though.
    As side effect JJ on 80 rim are considerable narrower than on 100mm rim, differency can be clearly seen when putting two wheels together. I suspect 4.6/4.5 tires on 100mm rim will be close to 4.8 tire size on 80mm.
    BTW have noticed that Schwalbe sealant (same as Stans) on JJ decreased tire internal diameter by few millimeters - it accumulates on the bead base. Removing sealant-grown tire from tubeless ready 100mm rim required use of motorcycle tire levers, no way it could be removed with hands or plastic bicycle tire levers. When installing tire to new rim I didnt removed sealant build up, sticks good and you need less tape at bead base.
  45. #645
    Nov 2016
    Lars_D, thanks for the video! I studded my tires awhile back with some stainless sheet metal screws. I had great grip, but it was temporary. I'm not on to find a new method to get carbide studs into my tires, and it looks like you've got it down.
    My question is this: Do you recommend a drop of marine sealant or super glue in each hole that you drill before putting the stud in? Or have yours been holding well without it?
    Anchorage, AK
    Quote Originally Posted by aflage View Post
    Unless you want to stud the center row, marine sealant is not required, the studs will stay in just fine. If you do stud the center row, you'll likely lose some studs over time, but I would be hesitant to use sealant for fear that the lug would come off with the stud and damage the tire.
    I had my 4.8 hand studded Jumbo Jim (front is a dillinger 5) out on the snow machine trails over the weekend. I was really impressed. When the snow was firm and the pressure was high, the rolling resistance was low and when the snow was soft and the pressure low (so that the side lugs could engage) the grip was good. Grip on ice was also excellent. I was very pleased.
    --Peace
  47. #647
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Lol this is why people run tubeless
  48. #648
    Rippin da fAt
    Hell, I haven't had but one flat with my JJ 4,8 LS's and it was caused by a goathead. 4 years I've been running the same tubes with my 3 pair of tires. 2 weeks of riding in the Tucson area which is a cactus factory and not one flat. Might be going back to tubeless but am on the fence cause it does create maintenance issues and tire changes are a marathon.
    That pic shows 4 patches from clydes style riding. The rest from various sharp objects. Yeah, tubeless is a good choice if your haunts are loaded with tire poppers.
  49. #649
    May 2016
    Seems like JumboJims have become the tire of choise among russian fatbikers.
    But schwalbe's quality control seems to have gotten worse over time.
    My friends and I have purchased sets of 4.0, 4.4 and 4.8s via bike-discount, all LiteSkin versions
    Weights are as follows:
    4.0 - 1120 and 1125 grams (sic!), 1093 and 1091 grams
    4.4 - 1120 and 1150 grams
    4.8 - 1167 grams (sic!)
    Though, I have to say, my previous two sets of 4.0LS were lighter, but requred sealant. This heavier set I setup tubeless without a single drop of sealant, and they hold air perfectly
    Also, I saw a picture of partially studded tires, but has anyone tried studding cental rows as well?
  50. #650
    Sep 2015
    Quote Originally Posted by adam1367 View Post
    I love the Jumbo Jims and would buy a studded Schwalbe fat tire if they came out with them in a heart beat.
    I've studded and used jj4.0's, and they're my wife's primary winter tires when there's not a lot of snow. They work great, but there is no studding the center tread, not enough depth.Jumbo Jim-schwalbes2.jpgJumbo Jim-schwalbes1.png
  51. #651
    Reputation: Kirkerik's Avatar
    Apr 2016
    So you are just drilling a hole in the tread block and pressing them in w the tool?
    They are the studs w the wide flat and inverted "T" bottom?
  52. #652
    Oct 2014
    Has anyone run 4.0 jumbo jim on 80mm Mule SL? Just curious but am guessing the rim is too wide. Any insight would be appreciated. My stock wheels are 80mm width and trying to avoid having the change them to run 26x4.0 in the summer
  53. #653
    Anchorage, AK
    Quote Originally Posted by Averbuks View Post
    They should be fine.
    --Peace
  54. #654
    May 2016
    I'd say 80mm rim is perfect for JJ4"
    Ran JJs on 80mm as well as on 60mm (internal). Liked cornering on 80mm better. 60mm feels a bit squishy given the same pressure (or rather comfort level than actual PSIs)
  55. #655
    Anchorage, AK
    Quote Originally Posted by Kirkerik View Post
    Yes, I have studded them also and that is how it is done. Here is a short video...
    https://www.youtube.com/watch?v=OBHdNKajdQc
    --Peace
  56. #656
    I run JJ 4.0 on 85mm HED rims with no problems. Love it.
  57. #657
    Rippin da fAt
    The 80mm rim makes for a better profile for floating on sand and loose dirt/snow. It also makes it possible to run at lower psi without issue. 4" is a non issue on 65's or 80's. There are the folks that like to run em on 47's, ewww...
    Frankly, I'll continue to use the 4.8's cause they ride well and roll very well. I enjoy my JJ's without drama on 80's.
  58. #658
    Oct 2014
    Quote Originally Posted by BansheeRune View Post
    Thanks for the input I appreciate it! First Fat bike for me. I am about 160 pounds suited up, and recommendation on what type of PSI I should be running the JJ 4.0 tubeless with the 80mm rims? I was thinking around 8-10 psi?
  59. #659
    Start there and you'll probably head lower once you get comfortable with it.
    I'm 175-180 kitted up and it's not unheard of to find myself on a 4.0 w/ 65mm's at about 4psi front and 6 psi back in the summer charging east coast XC pretty fast. Touch more may be warranted depending on roots/rocks but not much.
  60. #660
    Rippin da fAt
    Good starting point. You will find a fat 4.0/4.8 to be extremely pressure sensitive. It's unlike skinny bikes entirely. Drop pressure in 1 psi increments and ride between pressure drops.
    I too am 160 #'s so can run nearly flat tires in sand and snow. Mostly running in the 4-6 psi range with liteskin's with no issues. Only flat I've ever had was a goathead in the front.
    Take some time and play with the bike on smooth ground to get a feel for tire flex.
  61. #661
    Anchorage, AK
    It looks like Schwalbe is upgrading the compound on Jumbo Jim
    --Peace
  62. #662
    Reputation: mr_manny's Avatar
    May 2016
    looks like Bike24.com has the Best prices I've seen on Jumbo Jims
    thanks
  63. #663
    Reputation: Blue66's Avatar
    Sep 2016
    Best prices on Jumbo Jims - r2.bike is also a good adress in Germany:
    https://r2-bike.com/Fat-Bike-Tires::Schwalbe_1
  64. #664
    Anyone have width dimensions for the three sizes of Jumbo Jim's on a 65mm rim?
    My new frame won't fit Minion 4.8 on a LM, need a 1/4" per side; 4.8 Minion is 4.25" at the knobs, casing is a better fit.
  65. #665
    I just measured 4.5" at the knobs, 4.3" at the casing for JJ 4.8 snakeskins on Borealis 65mm rims (tubeless). Summer tire pressure set at 9 a while back, might be more like 8 now, I didn't dig out the low tire pressure gauge to check.
  66. #666
    May 2016
    JJ 4.0 LS, 10 psi
    rim: 60mm (internal), chineese carbon oem (a la nextie)
    99mm (at knobs)
    94mm (sidewall)
  67. #667
    Nov 2016
    Jim users,
    I was considering getting these,
    the 4.0 size is super light and has great reviews on that rolling resistance place
    but...
    I ride mainly on pavement for my commute, with dirt/gravel only for a small bit of fun after work.
    and those knobs look really widely spaced, like they'd be noisy and potentially worn to death in short order on pavement.
    anyone have experience/advice on how well they do versus pavement?
    worried that I'd just ruin them and it'd be a waste...
  68. #668
    frl
    frl is offline
    Jul 2014
    On pavement. The jumbos are great. Used mine for 2 years on everything. They got a bit worn. Still much left.
  69. #669
    Mar 2016
    I pump the JJ up to around 15 psi for the pavement, they roll great, make a little noise but not nearly as bad as other fat tires
  70. #670
    Nutrailer
    Aug 2016
    If anyone is interested - Merlin Cycles in the UK are selling 4.0 Liteskins in the old Pacestar compound very cheaply to clear their stock
  71. #671
    Anyone tried the new addix speed grip compound yet? Specifically, I would love these tires to grip wet rock and roots better over the pacestar compound...
  72. #672
    Rippin da fAt
    Quote Originally Posted by xenologer View Post
    Jim users,
    but...
    I run the 4.8 LS version and hafta say, they roll very well and do not require absurdly high pressure. Running em @ 10 psi max and mostly around 6-7.
    I love em and although I couldn't care less if tire hum or buzz as I'm cookin along, they are very quiet. Rolling resistance is lower with the JJ 4.8's than my D5's and they're actually quieter. I love em cause the feel of the LS version is very compliant and traction is good since the tire can conform to the surface and hold on tight. Sure there are other tires with better performance for dirt but with the all around performance of the JJ's, I'm a happy camper. Sand performance is very nite too, especially if I lower the psi and let em squish a little.
    I'mm not a clydes or a basher so LS works nicely. Had no issue running em in Arizona for my 2 week vacation in January.
    Mayor stumping on the campaign trail...
    QUOTE=GspotRider;13291537]Anyone tried the new addix speed grip compound yet? Specifically, I would love these tires to grip wet rock and roots better over the pacestar compound...[/QUOTE]
    Haven't tried the new compound as of yet, but hafta think about it just the same. I would be happy to have a pair in 42a single compound.
  73. #673
    Nov 2014
    Quote Originally Posted by GspotRider View Post
    No experience in the wet but they do grip in the dry better. I just mounted one in the front and it feels like a completely different tire. You can really feel the extra grip and damping. The compound even feels way stickier similar to 45nrth tires. I think you need a studded tire for wet roots but the new compound feels like it will grip everything better which was one of negatives of the JJ for me. It did not grip like other tires in any direction and has led to more than a few tire washout (front and rear) induced low-side crashes.
  74. #674
    Very encouraging! I have a set of maxxis minions that I was going to remount to replace my aging JJ, but hated the extra rolling resistance over the jumbo jims. I think you have inspired me to order a new set of Speedgrip jumbo Jims. Thank you.
    Quote Originally Posted by rcracer2 View Post
  75. #675
    Quote Originally Posted by Nurse Ben View Post
    JJ 4.0 LS, 10 psi
    99mm (at knobs)
    94mm (sidewall)
    My records show 4.0 LS on 65mm as 98mm
    and 4.8 LS on 65mm as 110-114mm.
    Have not recorded any info posted about the 4.4's.
  76. #676
    Anchorage, AK
    How does the rolling resistance feel compared to the Pacestar compound?
    --Peace
  77. #677
    Nov 2014
    It's on the front so I can't tell any difference. Schwalbe says it's 94% of pacestar and according to
    Fat Bike Tubeless Vs Tubes - Rolling Resistance
    my rear tire is using 25.1W now at 11psi (1.5W/psi between 12&8 psi) so at 94% of that the new rolling resistance would be 26.7W
    Adding a 1psi should get me back to about 25W; so it does sacrifice some straight line speed, but it can be recaptured by increasing pressure and the new compound's damping feels less bouncy due to the increase in damping so it would cancel some of the effect of higher pressure. I'll be doing the rear tire swap soon!
  78. #678
    Nov 2014
    ..and for rotating weight watchers like myself
    JJ 4.0 liteskin Addix sample 1: 1100g
  79. #679
    Any 4.4 results? Would it be fair to say that the sizng is honest, ie a 4.4 is 105-107mm in width on a 65mm rim?
    Anyone want to trade a fresh, matched set of Minion 26 x 4.8 120tpi for a set of JJ 4.4 Snakeskin?
    [QUOTE=bme107;13293307]My records show 4.0 LS on 65mm as 98mm
  80. #680
    Music & Bikes
    Reputation: fokof's Avatar
    JJ 4,4 Snakeskin
    107mm Knob to knob on 85 rims
    1235g
    "There is a big difference between kneeling down and bending over" -FZ
  81. #681
    I overlooked the bead to bead numbers before. Not exactly what you're looking for but should have mentioned it.
    4.0 - ???
    4.4 - 245mm
    4.8 - 265mm
  82. #682
    Thanks,
    That's helpful, I can interpolate and expect ~105 on a 65mm rim.
    Now I just need to find a set.
    Quote Originally Posted by fokof View Post
    JJ 4,4 Snakeskin
    1235g
  83. #683
    I really love the jumbo Jim!
    Does anyone else also wish they made it in Addix Soft compound to handle wet roots and rock better in steep terrain?
  84. #684
    Rippin da fAt
    What I would really love to see is a tire company that will let you select every aspect of a tire.
    1. Casing size.
    2. Casing construction (TPI and # of ply's)
    3. Tread pattern.
    4. Rubbuh compound.
    Damn, would that be awesome or what?
    On the JJ, yus, softer compound for the lighter rider would be a major benefit.
  85. #685
    1. Casing size.
    3. Tread pattern.
    4. Rubbuh compound.
    Damn, would that be awesome or what?.
    Yes, very much so.
    You can custom spec many complete bikes. And a few sneaker companies are doing the same.
    Tire production doesn't seem that agile to me though. Definitely need a dedicated line or department for it.
  86. #686
    Rippin da fAt
    Quote Originally Posted by bme107 View Post
    Yes, very much so.
    The casings are made and complete before the tread zone is applied and subsequently vulcanized onto the given casing. The tread does not exist until the vulcanization process takes place with a casing with tread blank placed into a mold, then fully inflated and baked to create the tread pattern. Bake for 20 minutes and out comes a fresh tire.
    I don't think it would be that hard for it to be possible. This could be done with fewer mold swaps if the computer spits out orders with tread pattern choice being the same as well as tire size. Tread rubber durometer is chosen and applied as a blank, the mold is ready to go and doesn't care about durometer or 2 ply casing vs 120 tpi single ply. Just a pipe dream for some of us tho'. Yup, custom sneaks for my bikes would be awesome as it gets!!
  87. #687
    My understanding of the process is a bit different than your 1st 2 sentences.
    Continental https://www.youtube.com/watch?v=TN1lrm79Bdg
    Starting at 3:40 the tire is assembled on a single drum layer by layer to completion. You'd either need several extra raw material feeds linked up to the station or a way to make the assembly drum mobile to rotate between feeds. After all the layers are on there it is released from the drum where then the circular strip of "tire" is placed around the mold form and into the oven.
    Schwalbe https://www.youtube.com/watch?v=V0P3oQWo22A
    Starting at 4:20
    The tread blank is positioned before the casing leaves the assembly drum.
  88. #688
    Rippin da fAt
    Yes, the blank is placed before leaving the expansion drum. Having tires of 42a, 50a and 60a can be easy enough. The tougher part is vulcanizing machine setup. As in, giving you the tread pattern choice. There could be a list of tread pattern choices along with rubber compound and 27, 60, 72 and 120 tpi casing choices. At the start, a company would have to put effort forth something very few people are willing to do, let alone companies.
    Again, compound, size, are the two constraints. It would have to be done in runs of compound and size.
    Larger calls for a compound might be done on two days. Smaller runs on a single day. I know this is just a pipe dream but I thought it would be great to share such an idea. We all know how subjective tire choice is after all, it's as subjective as pressure we might ride em at.
    And the blank is just that, lemme choose the tread pattern before the vulcanize takes place!! Not looking for excuses as t why it's impossible!!
  89. #689
    Fat Biking & Health Rider
    Reputation: MikeTowpathTraveler's Avatar
    Aug 2015
    Coming up on 3600 miles on Jumbo Jim 4.0's that came stock on the Haibike Full FatSix. Mostly asphalt riding, with hard pack canal towpath trails and NJ Pine Barrens sugar sand roads in the mix.
    For asphalt, I run max pressure, 30 psi (I know, I know! But it works for me! ). Good amount of wear on the center tread blocks on the rear tire which means I'll be in the market for a new rear tire. Not bad for near 4k miles on a 52 pound plus fatbike, I think.
    Pulling this bike out of the box for the first time, I really felt a distinct difference in the tread hardness compared to the Ground Controls on my Fatboy.....they were definitely softer. So I figured they would wear a lot faster than the Specialized. I sure was wrong.
  90. #690
    Anchorage, AK
    This test does not speak well about the Addix compound. I'll stick with the original version of Jim for the time being...
    https://www.bicyclerollingresistance...dix-speed-2017
    --Peace
  91. #691
    Dec 2016
    Jumbo Jim 26 x 4.0 @ 20 psi mounted on a Surly Rabbit Hole 50mm rim measured at the knobs (widest part) 3.8” (96.53mm). Also clears on my Manitou Magnum 27.5 boost fork.
    Mounted on 80mm rims @ 20psi 4.00" (101.7mm), measured at the knobs
  92. #692
    Apr 2016
    I have been getting a little bit of weeping of sealant through the sidewall of my JJ 4.0 LS. Not losing any pressure and only when on trail but thought i'd mention it.
    I generally run anywhwere from 5-7 psi in rear (where JJ is) depending and I weigh 155#
    The tires are the things on your bike that make contact with the trail.
  93. #693
    Sep 2013
    What sealant are you using? There have been several mentions here on MTBR about recent shipments of Stan's being less effective than in the past. Coincidentally, or not, I purchased a quart jug of Stan's a couple of months ago and refilled a very thin walled Continental tire with it and it has been weeping like crazy.
  94. #694
    Apr 2016
    I had an old bottle of stans laying around so I think I used that first in the spring but have added some Serfas Tire Rx.
  95. #695
    Dec 2016
    Here's a better shot on jj 4.0 on 50mm rims @ 20 psi. I rode at 20 psi to the trail, then down to 9&10 psi.
  96. #696
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    I never posted my 4.0 Light Skins on Velocity Duallys 40mm and Paul hubs. I'm swapping out my summa fat for 27.5+ Nobby Nics 2.8 but I'll keep these for beach rides.
    ptarmigan hardcore
  97. #697
    Reputation: Qyota's Avatar
    Anyone put Grip Studs in a 4.8 JJ? I just bought a bunch, so I'm hoping they'll work, at least in the outer 2 rows of lugs.
    190mm 9:zero:7, Bud & Lou on HRDs, X9 crank running 1x10.
  98. #698
    Jan 2015
    Anyone ever race JJ 4.0 on groomed track?
    I've never had much luck on snow packed trails with them, but never been on groomed trails with them
    I have two sets of tires, JJ 4.0 and VanHelgas. VanHelgas are a sure thing for grip, but I imagine also slower than the JJ. Unless the JJ cant grip, then VanHelgas are my only option.
  99. #699
    Rippin da fAt
    With this season being lacking, I've been less than inspired to change tires. Riding my JJ 4.8 liteskin tires on groomed is no worries. The Bud/Lou allow for more aggressive riding tho. I do ride em soft in snow of any kind for traction as opposed to float.
  100. #700
    Jan 2015
    Would you feel confident racing the JJ on groomed?
  1. Schwalbe Jumbo Jim tire?
    By scubaklook in forum Fat bikes
    Last Post: 3 Weeks Ago, 05:31 PM
  2. Jumbo bottle cages out there besides the "Anything Cage"?
    By Gyro_t in forum Bikepacking and Bike Expedition
    Last Post: 01-25-2016, 11:09 PM
Members who have read this thread: 319
