Page 2 of 2 FirstFirst 12
Results 101 to 193 of 193
  1. #101
    Quote Originally Posted by mikesee View Post
    I think the main difference in your experience vs. mine is partially in where we live (your trails get a lot less snow and a lot more traffic) and partially in the experiences we've had on the ITI route. Once have I seen the Yentna hard and fast. Once has the trail from Nik to McG been hard and fast. The rest of the times they have been somewhere between difficult-but-doable and impossible to ride.
    That probably true. I tried riding buds last year, thinking I would take them to Nome, but all the ice killed that idea. Then it was just like my backyard from Mcgrath to Unk - mostly firm and fast, then tons of ice on the coast
    Don't get me wrong - I have seen the yenta soft - it was super soft in 2012, but bigger tires wouldn't have helped. Smaller tires would have been better, given they push though snow faster.
    I am amazed you haven't seen the Yentna fast more than once - you where there in 2013 right? It was mostly pretty fast riding all the way to mcgrath that year.
    Thanks again for posting this stuff, it is pretty interesting watching your thought processes.
  2. #102
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by spruceboy View Post
    I left 2 days ahead of the race in '13, and the Yentna was work. Mostly rideable, but low pressures and you certainly weren't coasting anywhere. That actually describes the conditions we had until about Pass Creek, then they got better and better to the finish.
  3. #103
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I went to an endurance seminar a few nights ago, put on by people that do the ITI and other endurance races here in AK. For shorter races where you are sure of the conditions, a better snow-tire can be a good idea. For longer races with extreme variability in the conditions and course/terrain, a good studded snow tire may save your life or at least save you from having to be rescued. These longer races/rides are more about good "all around tires" than choosing the best snow tire or the best ice tire, at least according to the riders putting on the seminar. It looks like there are some newer options coming out with the Wrathchild and studded XLs, and of course grip-studs. Sure, you might get into conditions where 2XLs would work and skinnier tires would not, or you may have completely fast conditions where they'd be a real drag. You also might have conditions where no tires will work and you have to be prepared for that. So in that light, just as with much winter riding, a "jack of all trades, master of none" tire is a pretty safe choice. I'd wager it's safer than specializing just due to how negatively that could affect you in the worst conditions.
  4. #104
    Reputation: bikeny's Avatar
    Thanks again Mike for posting all of this stuff, it's really interesting to me. One tire question: Did you guys consider a 27.5 fat setup at all, specifically the Gnarwhal? I'm guessing it would be fast for certain conditions, but not wide enough for variable conditions? I wonder if it would be a good replacement for a studded D5 setup? Should be similar width but roll faster?
  5. #105
    Aug 2003
    Quote Originally Posted by bikeny View Post
    We did test a B Fat Gnarwhal setup for 5 or 6 rides. Alas Jeny's frame was built with 26 x 4.8's in mind, and the B Fat's edge knobs sit a bit taller (closer to the BB) than any 26 x 4.8" tire. Clearance was tight to the chainstays when the tires hadn't yet stretched, and we knew they were going to stretch so we removed them from the running.
    Jeny wasn't sure she could tell any difference in float or traction from Bud/Lou to the Gnarwhals. She was running them unstudded.
    Pete Basinger has ridden the B Fat setup on our backyard trails since then. He's racing ITI this year, and is currently debating between PSC 2XL's, B Fat Gnarwhals, or maybe Bud/Bud.
    B Fat Gnarwhals were several millimeters wider than D5's, and a few mm narrower than Bud. All on 82mm rims. I didn't write the numbers down together all in one place so I'm not quoting directly. Gnarwhals had a good chunk more volume than D5's, and seemed virtually identical to Bud.
  6. #106
    So they were ruled out for fit issues, not performance issues, interesting. If the performance was similar to Bud/Lou, that sounds promising. What frame is she using? I don't remember reading that anywhere.
    I'll be interested to see what tires Pete B. ends up using.
  7. #107
    Aug 2003
    She has a custom Meriwether that was designed/built to have good clearance for Bud/Lou, and the shortest possible chainstays that'd fit those tires.
  8. #108
    is buachail foighneach me
    Reputation: sean salach's Avatar
    Probably wouldn't be that expensive/time consuming for Whit to swap out to adjustable dropouts, if she wanted to experiment with taller tires. Obviously not something you would want to do with less than two weeks till race time.
  9. #109
    Aug 2003
    Quote Originally Posted by sean salach View Post
    I'll let him know you say so!
    I love B Fat and ride it often. She's more ambivalent about it, and likes to switch between 26 x 5 and 29+. If she/we decided to experiment with B Fat for her, I'd likely just flip this chassis and ask Whit to build a new one.
  10. #110
    slow:biker
    Dec 2009
    Two questions:
    What are your preferred studs to use in the Vee Snowshoe?
    If running Bud/Bud combo do you flip the direction of rotation for the rear tire?
    Many thanks for the interesting thread.
  11. #111
    Aug 2003
    Quote Originally Posted by eastman115 View Post
    Two questions:
    Studs: For this event I don't think it matters too much. No sane person is riding the limits of their studs in this environment and that far "out there". They're more to keep a person upright in the event that they encounter some ice they weren't expecting, than to allow you to ride every off-camber glaciered stretch of trail along the way. Stock Vee, Nokian, Schwalbe, or 45N are all pretty much the same in that respect.
    If we were talking commuting on black ice all winter long in some high-latitude city, my answer would be different.
    Bud direction: Both in front orientation. More important to roll efficiently than to get every last bit of dig. The difference is small but over ~300 miles efficiency matters.
  12. #112
    Reputation: Larry Endomorph's Avatar
    Jan 2011
    Please pardon my ignorance. Front orientation is Propulsion or Cornering? I'm guessing Propulsion.
    Many thanks.
    Out to ride
  13. #113
    Rippin da fAt
    Propulsion would be your rear wheel.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
  14. #114
    Aug 2003
    Camp notes.
    Newbies to the ITI might be surprised to learn that it is possible to complete the entire Knik to McGrath route without sleeping outside. There are private homes, BLM cabins, and commercial lodges spaced intermittently along the route, such that if your pace is good and your luck holds, you'd never need to deploy your bivy gear at all.
    Think about that for a moment and you might start to wonder why you'd carry the extra ~7+ pounds of gear if you didn't have to.
    In a word, safety is why you carry it. There is never any guarantee that the conditions will be good enough to get from one lodge to the next cabin, or the next, in any reasonable amount of time. The trail isn't groomed and weather is unpredictable: Plan to sleep in a lodge, carry no bivy gear, then a ground blizzard blows the trail in or a snowstorm buries it, and your pace and plans just went out the window. What then? Cuddle up in spruce boughs? It has happened and it will continue to happen to those that are willing to gamble with their personal safety. Hopefully the end result will be nothing more than entertaining stories shared by those who've been humbled. I have a few of my own -- for another time...
    Out of respect for the place and desire for their own safety, most people carry a puffy jacket to wear when they stop moving, and a sleeping bag and pad so that they can get some meaningful rest. How big of a jacket, pad and bag are up to you to determine, based on how long you think you'll need to sleep, what the temps are, and what kind of sleeper you are. Volumes have been written (and will continue to be regurgitated) on the subject of sleeping comfort -- handily distilled down to inflatable pad vs. closed cell foam pad, and down vs. synthetic insulation in your jacket and bag. If you arrive at the ITI start you should be able to intelligently discuss at least some of these theories and explain why you went the route you did. Most importantly, you should have at least a few nights of experience camping in the gear you plan to take.
    Jeny has been busy this month, and especially on the weekends, getting out and riding alpine snow all day on Saturday, camping that night with the gear she's carrying, then waking Sunday, cooking a meal and melting snow to refill her bottles, then closing the loop back to the start. She understands that there is no better way to learn than to make mistakes, and the more mistakes she makes now, the fewer she'll make in the ITI when the stakes are higher.
    The lodges and cabins along the way are spartan in luxury but often seem heaven-sent despite that, largely because when your life is distilled down to what can be dragged in a sled or fit onto a bike rack, the simplest things like food and heat are most appreciated. Stumble exhausted out of a -30* night into a warm building and that alone is enough: anything beyond that -- like a $5 can of Coke or a $20 cheeseburger -- is just gravy. Because of this allure, and because there are ~70 people participating in the ITI, the lodges are *busy*. Think a little more about this and you'll realize that it is very difficult to get meaningful rest inside any of these buildings because people are constantly coming and going, packing and repacking, excitedly talking to friends when they arrive, rummaging through food and trash bags, burping, farting, clomping around in boots, and just generally doing anything other than being quiet. The person that can sleep regardless of external stimuli will do well here. If you need anything resembling uninterrupted quiet to sleep, you should plan to sleep out.
    Jeny is planning to sleep out.
    Just because you ditch the chaos of indoors does not guarantee that all is well. There are a handful of things that you need to do, and to understand, in order to ensure solid rest.
    First, the event is only a ~week long. Getting 8 hours of sleep a night isn't needed. I *like* seeing some of these landscapes (both inside and outside of my head) through the filter of darkness tinted with a teeny bit of sleep deprivation. The experiences are much richer, the stories more compelling.
    Maybe that's just me? Quantity aside, when I do settle in I want the sleep to be short but of quality. I shoot for at least an hour, and never (intentionally) more than 4. 90 minutes seems to be the magic number for me -- less than that and I'm still groggy and grumpy. More than that and, after the initial moment or two of rumminess wears off, I feel rejuvenated and ready to move.
    It goes without saying that if you're only going to sleep for 90 minutes, you don't want to waste another 90 setting up and breaking down camp. You want to be fast, efficient -- not just so that you can maintain your forward mojo, but also because breaking camp in the cold is *cold*: You haven't been moving to generate any heat, and until you pack up and move you aren't going to. Learn to be quick by thinking proactively about how and where to pack your gear. If you have to think about where something is your toes just went numb. If you unzip a zipper or peel back some velcro and find that what you sought is indeed somewhere else, your fingers are now numb too. You'll be surprised at the speed with which your extremities begin to chill straight out of the bag in the morning.
    Over the last ~month Jeny has refined her camp setup routine to where she needs only to remove the bag from her rear rack and she has her entire "camp" within: Bag, pad, puffy, cookpot, food, and stove. Fuel is kept separate for many reasons, but is handy in a bottle cage on the bike so that once she's setup and in her bag, she can reach from the comfort of her bag to grab that bottle and start melting snow.
    But I'm getting a bit ahead of myself.
    First, you need to pick a good spot, and "good" is both different and relative every time out. My goal is always to find shelter first and foremost. We don't carry a tent, mid, or tarp on the ITI because the weight, bulk, and time spent setting up and tearing down aren't offset by the meager protection they offer. It's no warmer inside of a tent than out, but it can be quite a bit wetter due to condensation from exhalations. I'll never use a bivy sack in winter again after experimenting and learning how much moisture they trap next to and inside of your sleeping bag, thusly degrading the insulation.
    We sleep out. And that means we need to be protected from wind and falling snow. Trees offer good shelter, although if you set up camp in a grove of cottonwoods and it snows overnight you might wonder about the truth of that statement. When I say trees I mean conifers, where the needles can catch any snow that might otherwise land on (and melt on) you.
    So the very first step is to find a spot that's quiet, and that means getting off of and away from the trail. Stomp a path out into the trees, far enough so that other nocturnal travelers don't even notice you're there. Jeny had an anxious moment a few weeks ago when a midnight trail groomer saw her camp and came to check on her -- but never got out of his snowcat to do it. There was never any danger but as the cat approached her location it was hard to convince herself that she wasn't about to be tilled into corduroy. Once the driver saw that she was safely ensconced in her bag he flipped it and left her to sleep. His intentions were admirable but her adrenaline hit couldn't subside quickly enough. She'd never have woken had she been better hidden.
    The trick to sleeping under conifers, as any To Build a Fire fan will tell you, is to remove any snow that might fall on you before you set anything up. How? Put on your jacket, pull the hood over your head, close all zippers, bow your head, and then kick the snot out of the trunk until the last bombs have whumped to the ground around you. Good? Good.
    Next. stomp a trench out next to a big tree. Why big? Bigger circumference of protection, plus (hopefully) a healthy trunk to lean against while melting snow. The trench is necessary because the snow is deep and soft -- stomping it out packs it into a ~level surface to sleep on. Make the trench big enough that you can't inadvertently touch the edges and knock loose snow down onto yourself. There is an art to finding the right size: I'm not here to tell you how to do that, I'm here to encourage you to go out and find out! An added bonus is that the stomping warms you a bit before you shut down the turbines for the night.
    Above is Jeny's campsite from last Wednesday, after she'd placed her bike and stomped the trench but before she'd laid out her bag and pad to start cooking.
    Our camptime habits include walking the last ~1/4 mile to "cool down" and cook any residual moisture out of our layers, eating a few hundred calories while walking so that the fire is stoked before we get into our bags, changing into dry socks as soon as we get into the bag, and rehydrating a hot meal to give our bellies fuel for both recovery and heat production through the night. If we're tired enough we'll often pass out before brushing teeth, but the feeling of fur on teeth is usually the second task I take care of when I wake. The first being the need to pee, which is almost always what wakes me and signifies that it's time to move again.
    Clearly there is nothing exhaustive about what I've shared here. I intend it as a springboard to get people to think about camping not in the abstract -- but to go out and do it and learn to be good at it.
    No time like the present.
  15. #115
    Reputation: dRjOn's Avatar
    interesting! ... no bivi sac -- i'm guessing the sleeping bags are waterproofed? or is the conifer cover generally enough?
  16. #116
    I've made the mistake of not knocking snow off of a tree before. Nothing like a giant, fluffy snowball to the face to wake you up.
    I've had good luck with condensation by using two large Heat Sheets blankets, taped on two edges with gaps between each piece of tape. Keeps snow off, weighs a few ounces and has enough air flow to breathe pretty well.
    Doing this race, or showing up to any situation where you're sleeping in a room with other people, requires bringing ear plugs. Unless you're a 'nothing can wake me up' kind of person. Some people even bring eye shades/sleep masks.
    Also, snow is very absorbent. If you wake up in the middle of the night and have to pee, but aren't ready to get up, you can just unzip the bag enough and pee into the snow without exiting your bag. Assuming you have the right equipment to pee horizontally...
  17. #117
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Some great stuff in here, Mike. Makes me want to bivy in the snow tonight.
  18. #118
    Aug 2003
    Quote Originally Posted by dRjOn View Post
    Most modern/good bags have a DWR that's good enough. Also keep in mind that good winter bags have enough loft that if snow falls on them, there isn't enough of your body heat coming through to melt the snow. It just sits there at ambient until you roll over, and then it falls off. If you have a ridgerest (or other pad with little nooks and crannies for snow to settle into), the snow can slip off your bag and into these nooks. If you roll over on top of that snow, then you'll wake to find little puddles in those nooks as your body heat is able to melt the snow that finds it's way between you and your pad.
    The conifers are big in many places -- such that you can burrow and in be untouched except by wind driven snow.
  19. #119
    What are your thoughts on pedals? Given that there could be deep snow conditions that require extensive walking/pushing, platforms may be preferred. Most platforms I see marketed now have nasty little studs. I say nasty because I ripped my hand open on such when trying to re-seat a chain. And so when pushing, those pedals can snag clothing. I am surprised that the market has not produced a high end "foldable pedal" for the fatbike market. I think that would make pushing a little easier.
  20. #120
    Aug 2003
    Quote Originally Posted by trailnimal View Post
    Pedals are like religion to people in winter races: Suggest that they're doing it wrong and you'll find yourself in the midst of a holy war.
    Jeny and I both prefer to ride clipless in winter. Our local trails are soft or softer, and being clipped in gives you better control of the bike in marginal conditions.
    It is easier and less expensive to arrive at a warm boot setup when using flats. The tradeoff being that you lose some of that fine control when things get really technical.
    No right answer, no wrong answer, just compromises to choose between.
    I have, in ITI's past, taken a long-handled hex wrench so that I could remove my pedals for long stretches of pushing. In 2010 my pedals were off of the bike for almost 2 days -- from just past Puntilla Lake to roughly the Dalzell Gorge. Never even thought about riding in that section, so deep and unconsolidated was the snow, and it was nice to not intermittently thwack my shins on the pedals.
    For summer fatbike/beach/packraft trips I think flats make more sense for lots of reasons. And for some of those I've used QR pedals like these.
  21. #121
    Rippin da fAt
    Hell, you oughtta try a pair of Straitline Defacto's, They will surgically remove your shins... But you will never slip a pedal while you're riding.
  22. #122
    So, what tires did you guys end up settling on ? It is looking a bit slow this year - the iditasport guys are not exactly tearing up the trail.
    I am now debating putting the buds on.. Hah - that is what I get for shooting my mouth off
  23. #123
    Aug 2003
    We were debating that this AM. And then we saw OE's flyover vid from ~Puntilla to ~Rohn, which has always been a black hole of trail info. The info gleaned there, coupled with the Iditasport guys (lack of) speed, makes it seem like Bud/Bud is a slam dunk. Will be installing them this evening, then boxing her bike tomorrow.
  24. #124
    Dec 2016
    Two wake ups till go time! Good luck to Jeny and the rest of you!
  25. #125
    Aug 2003
    The mental mind.
    The ITI starts in 2 days!
    There is little that can be done to increase fitness at this point. Jeny can rest and show up recovered and ready to go, or she can not, but she can't get any stronger.
    I dropped Jeny at the airport at dark-thirty this morning, and she'll transit through several other airports before arriving in Anchorage this evening. If you're anything like a normal human being, you spend lots of time "devicing" while killing time in airports. In that way Jeny is normal. She'll read a little news, maybe catch up with friends and family, possibly get some actual work done.
    Undoubtedly she'll also check a few weather websites to see how things are shaping up along the route. My experience is that the more you look at those seemingly innocuous forecasts, the more you're sewing the seeds of uncertainty in your own preparation.
    Weather forecasts being what they are, you come away from each one less sure about what they're telling you. 60% chance of sun is virtually the same as a 40% chance of snow, but the way that you prepare for and react to each is emphatically not the same. The more you think about the likelihood of snow, the more you wonder how prepared you really are for it.
    Specifically:
    -If the snow is light and dry, and it comes in on a wind, then the trail will drift in and traction is very difficult to find. Bigger knobs on your tires are quite beneficial to the end of riding vs. spinning your rear wheel and digging holes, or being able to control the front end of the bike. Even though we've tested, discussed, tested, and retested tires, and made the decision to run Bud/Bud based on past conditions and current forecasts, Jeny wouldn't be human if she looked at these forecasts and didn't wonder if that was the right choice.
    -If the snow is wet and heavy it becomes easier to ride, but it has the ancillary effect of weighing down the ice on the frozen waterways that constitute the bulk of this route. Pushing down the ice pushes water out on top, creating overflow. Ever pedaled or walked through standing water at -20*? It happens, and if you're unprepared for it you're going to have a bad day.
    Where am I going with all this?
    If at this stage you have any cause for uncertainty with any of your preparation, the littlest things will cause you to second guess the steps you've taken to get here. Second guess enough steps and suddenly the most prepared person is debating whether to start at all, or considering adding a dozen pounds ("We pack our insecurities") of ultra-lightweight gear to their kit. This isn't specific to any one demographic or individual, although it does tend to hit us CDO folks harder.
    The solution?
    Simple: Remind yourself where you've been en route to this moment.
    When Jeny first made the decision to head north back in early January, I sat her down and shone a very bright light in her eyes, then explained to her that she could start the event the very next day and do really well. A lifetime spent outside in similar conditions has familiarized her with what she'll experience up there. She nodded in agreement but I could tell that she was skeptical. Then I explained that since she had 6 weeks left to prepare, we'd leave no stone unturned doing just that. And we have -- well, *she* has. Jeny buckled down, focused and really put in the necessary effort to dial in her fitness and gear. When I reiterated that to her yesterday she again nodded in agreement, but again I could tell that she was skeptical. And I get that -- there are just so many variables involved that you can't help but to wonder which of them you could or should have spent more time with.
    To that end, all Jeny needs to do is go back to the beginning of this series of posts and re-read each one to realize that she has, indeed, prepared in a way that will deliver her to Knik Lake on Sunday morning as prepared as any ITI rookie will likely ever be. She has scrutinized every piece of clothing she'll wear and done research to understand what sort of options she has. Then she's gone out and ridden (and pushed, and camped) in each piece, overandoverandover, for the past ~6 weeks. After each ride she's made some minute adjustment (cutting, sewing, amending) to each piece of gear -- usually to make it fit better or to become more invisible when worn -- and then she's gone out and ridden some more. Again, and again, and again.
    Apply that process not just to your clothing, but also to your bike, your food, and your safety kit, and what do you get? Eventually you get a sense of confidence at having left no detail unexamined. Or at least you should. Once you've been out on the actual trail and seen how well things work, then that confidence can begin to sink in.
    But Jeny's not there yet: She's got a long 2 days before she pedals away from Knik and can begin to understand this for herself. In that time she'll meet lots of new people -- mostly fellow racers -- and she'll have a multitude of conversations about the race, the route, the weather, and always more talk about gear. It is cyclical and seemingly interminable. As with the weather forecasts, each of these conversations leaves you with a sense of uncertainty about the prep you've done to date. Invariably someone will ask how you plan to deal with X scenario and, even though you've thought it through, experimented, and have a solid answer, *their* answer might be different from yours, and this'll give you pause.
    There are very few black and white answers to the scenarios they'll face out there. The one certainty is that if you have confidence in the solution you've devised -- whatever it is -- then that's good enough. Never having been out there makes it difficult for some to grasp this simple truth.
    Last point about the mental aspect of traversing the Iditarod Trail: Things never go exactly to plan. You're pushing hard in an unforgiving and potentially hostile environment for too long to do everything 100% perfect. Mistakes happen to everyone, sometimes in rapid succession. Dwelling on them -- beating yourself up -- does little to teach and less to get you further up the trail. The person that can make a mistake, digest and embrace the lesson, then drop it trailside and move on is the person that emerges victorious from the ITI. And from life...
    Jeny is a gifted athlete with a lifetime of outdoor experience, and because of this she sets very high expectations for herself. Failing to live up to them -- whatever that means to her -- can send her down a mental spiral that's difficult to pull out of. To the end of combatting that she's devised a handful of strategies to keep herself on track. Slowing down, stopping for a break, grabbing a midday catnap, preparing and then eating a hot meal -- all of these serve to keep her from getting too far ahead of herself. Staying in the moment is The Most Important Thing. Those are popular words these days, and might not get through to everyone.
    So I'll put them differently. Thinking too far ahead can be crippling. Thinking of each task to be completed as sequential, and not cumulative, might be the best single piece of advice I can offer this late in the game.
    The 2017 ITI starts this Sunday at 2PM Alaska time. You can follow it here.
  26. #126
    good luck!
  27. #127
    Rippin da fAt
    Jeny, be safe stay warm and kick arse!
  28. #128
    Reputation: watermonkey's Avatar
    Go Jenny, Go! Have a great race.
    I would advise not taking my advice.
  29. #129
    Reputation: farleybob's Avatar
    May 2012
    Go get em Jeny! Have a great and safe adventure!
    Gettin' Fat!...That's Where It's At!
  30. #130
    Reputation: mtuck1's Avatar
    Good luck, and safe travels!
  31. #131
    Hope to see everyone go by tomorrow at Flathorn Lake!
  32. #132
    Reputation: Velobike's Avatar
    Being prepared, you don't need so much luck.
    But nonetheless, good luck Jeny.
    Latitude: 5736' Highlands, Scotland
  33. #133
    Reputation: volksbike's Avatar
    Nov 2015
    Great thread to read and learn from. Goodluck Jeny!!
    GBM, Pugley & 9:ZERO:7
    Surly Ogre Rigid 29er - RAGBRAI 2013
    TREK Alum Hardtail 29er - Recon Fork
  34. #134
    Very soft heading out from Ayshire to Flathorn Lake, some people pushing at times. A group of us headed out to Flathorn, some of us rode from Knik Lake. We cheered on the racers and offered them beer and goodies. Riding back sucked nearly as much. Was warm, upper 20s. Pictures maybe tomorrow when I get time.
  35. #135
    Jenny?Jeny and The Race.-gopr5622s.jpg This is at Flathorn Lake where we setup an impromptu checkpoint offering beer, cookies and lots of encouragement.
  36. #136
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Go Jeny, Go! 74.1miles and having a rest, looking at the tracker.
  37. #137
    "She won't be racing, will emphatically be touring the route. "
    HaHaha....LOL!
    in third place!
  38. #138
    Aug 2003
    HaHaha....LOL!
    in third place!
    It's easy to get sucked into the fast pace of the first day, especially when conditions are good. That, and it's easy to want to get the Yentna over with ASAP!
    But she stopped and slept for 3+ hours this AM, and has taken breaks for cupcakes and coffee at both Skwentna and Shell since then.
    I assure you she is going a lot less hard than she could, and her pace will likely continue to slow as she works her way up into the mountains.
  39. #139
    beer thief
    Dec 2002
    She looks to have one of the lightest loaded bikes, judging from the photos. Pretty much all the others have a big roll on the handlebars.
    I'd be interested in hearing what she's using for navigational aids. Some of those guys have a regular dashboard up front.
  40. #140
    Aug 2003
    Quote Originally Posted by radair View Post
    Her bike is packed *tight*, but I don't think it's particularly light. She's got a lotta food, a full-on MSR XGK stove and ~30oz of fuel, plus enough bivy gear to sleep out comfortably every night. In a word, a touring load.
    Most racers bikes are probably a lot lighter. Very few racers carry stoves: it's easy enough to refill on water ~once a day at the lodges/checkpoints. If you get thirsty you're working hard enough that you can eat snow for awhile.
    Massive roll on/under the bars has never made sense nor worked for us. Speeds are so slow and front end so often lacks traction (because the snow doesn't stick to itself, so how can the tire stick to the snow?) that putting extra swing weight and/or mass up there just makes you work harder to keep the bike on the trail.
    The bulk of her gear/food weight is centered in the frame bag or lower bottle cage. Insulation (to be accessed when camping) is on the rear rack -- bulky but not particularly heavy. Sleep pad under bars. Snacks at hand inside pogies or in bottle cages on fork legs.
    She has paper maps for navs, but not sure where those ended up stashed. She has her phone with Gaia, which means easily accessible topos even offline/out of cell service, and the phone's gps locates you on those topos. Pretty slick.
    Recharging her phone and camera with current from the SON dynohub. She runs her Luxos U light off of it at night, but the Luxos also has a USB outlet that you can use to charge devices when the light isn't needed. Also pretty slick.
  41. #141
    JT1
    JT1 is offline
    Feb 2017
    Thanks so much, Mikesee, for creating and continuing this thread. It's been fascinating to have a ring-side seat to training, other preparation, and for virtually following along.
  42. #142
    beer thief
    Dec 2002
    Good info. I also use Gaia extensively, mostly for trail planning, and wondered about battery life (it sucks on my phone). Those SON dyno hubs look awesome. As do the Luxos U lights.
    May 2012
    Any weather updates?
  44. #144
    Aug 2003
    The phone and Gaia are not for constant use -- more to refer to if you come to an unmarked junction. Early in this route that happens constantly, but after you leave Shell Lake it's sort of hard to get off the main trail -- it's almost (almost!) always obvious which is the main trail.
  45. #145
    Aug 2003
    Quote Originally Posted by farleybob View Post
    Check Puntilla Lake, Alaska for what she'll see today. Check Nikolai, Alaska, for an idea of what she'll see after today.
  46. #146
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    Looks like a few days of clear and cool weather coming up, which should be good. I've been following my buddy Jay's progress, and it looks like yesterday was a slog...
    Edit - just checked TL, looks like Jeny is doing well!
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
  47. #147
    Aug 2003
    Andy Romang's snap of Jeny and her bike at Knik.
    She's loaded heavier than most on food, fuel, and stove, and "just right" on bivy gear.
    Attached Thumbnails Attached Thumbnails Jeny and The Race.-iditarod-trail-invitational-2017-february-26-2017-0347-x4.jpg
  48. #148
    Thanks for the updates, Mike. I've been watching progress on Trackleaders. It appears there has been a lot of pushing. That can't be much fun for hours on end.
    It also appears that Bud/Bud was a wise choice given the conditions thus far.
    Is there much cell coverage up there? You think it would be nice every once and awhile to throw in an ear piece and check in at home...
  49. #149
    There's no cell coverage for most of the course. Sat phones work in most places.
  50. #150
    Aug 2003
    cell coverage
    She sent me a text from Shell, and I've bumped into slednecks just shy of Finger whom were standing on top of their sleds to eke out enough signal to check in at home. Beyond that I don't think there's any, and to many that's a big part of the allure.
  51. #151
    Aug 2003
    Quote Originally Posted by Once Bitten View Post
    It's tempting to think so from the outside looking in. And especially watching the top 5 transit from Puntilla to Rohn through the night and today. Sure hasn't seemed like studs were needed.
    Taking the opposite stance, you could also posit that a smaller, lighter, smaller-knobbed tire is easier to push.
    Their collective pace says that it's either rideable or it's not, and maybe tire selection is moot.
    Having said that, Pete (on 2XL's) has slowly but steadily been reeling in Clinton as they approach Rohn. So maybe bigger is better.
  52. #152
    May 2012
    Jeny and The Race.
    I read Craig Medred's report about the three leaders and the ground blizzard on the way in to Rohn. It got me thinking about navigation. It seems like it would be very easy to wander off trail and get off course and potentially lost in that situation. Mike, what do you rely on in those situations? Do you rely solely on your GPS, or is the trail marked sufficiently for you to follow the route? I assume it's a combination of both?
  53. #153
    Aug 2003
    I've found GPS to be of little use on this route. The trail is rarely in the exact same place from year to year or even storm to storm. Where it stays static is in the trees -- and you don't need a GPS to know you're on it there. Out in the open as it is from Puntilla up to Ptarmigan, where Jeny is heading today, the location can and often does change with each snowfall or wind event. Markings are rare and inconsistent, so the trail ends up being laid down fresh by whomever the next person through happens to be.
    Thus you end up finding it with your feet, and knowing that you've lost it because you're suddenly wallowing in up to your knees. You don't really get "lost" per se -- it's not like you're going to go postholing up some random valley -- you just might lose the trail for a bit before finding it again with your feet.
  54. #154
    Aug 2003
    I'm getting pinged from every direction by people wondering about Jeny. The Trackleaders site is, by far, the best way to follow along and see progress.
    For those for whom that's not enough, I've dug up some pics of approximately what she and her trailmates are seeing today. Keep in mind I don't know what the conditions are like out there in this moment, so although locationally these are accurate, it may not look like this, to them, at all!
    First thing this AM she saw this.
    Around lunch she'll see this.
    Dinner should bring something like this.
    If they're attentive there'll be evidence of animals everywhere -- like these sastrugified wolf tracks.
  55. #155
    But how are you doing? Sending your new bride away on this adventure into the known yet unknown, confident in her preparedness and mindset....
    Constantly hitting the refresh button or business as usual?
  56. #156
    Aug 2003
    Quote Originally Posted by bme107 View Post
    I just checked the box that refreshes it every 60 seconds...
    First night was rough trying to follow into the wee hours, but now that she's found her groove I'm good with it. Only needing to check in, uh, get up to pee, 2 or 3 times per night...
  57. #157
    Without closely scrutinizing the tracker too closely it looks like she is doing great.
  58. #158
    May 2012
    She's in the middle of a long section and looking good! ( At least to the untrained eye of this blue dot watching fanboy!)
  59. #159
    May 2012
    Is there a cabin along the route where Jeny and others have stopped, or are they just making a group bivy?
  60. #160
    Rippin da fAt
    This made me think of Jeny. Hope all is going well for ya!
  61. #161
    Aug 2003
    There are big (relatively speaking) trees there and it should be sheltered from the wind they've been pushing all day.
    If there's a cabin it's news to me.
    One way to know for sure: If they're still there at ~8 tomorrow morning it's a cabin. If they're moving again in the wee hours it's because it's cold -- and there's no cabin!
  62. #162
    May 2012
    Temps in Rohn and Nikolai look to be around -30F. It looks like clear and cold with light winds. Hopefully the trail is in good shape for riding!
  63. #163
    Aug 2003
    Yep, it's a real winter race this year.
  64. #164
    She is doing real well. Smart moves. There is going to be some crazy stories about being in Puntilla and Rohn.
  65. #165
    Dec 2016
    Mike----this is riveting stuff. I've learned so much from reading through this thread.
    This is something that's been on my mind: you showed the wolf tracks above....does anyone feel the need to carry protection of any kind? Like a firearm or even a knife?
    I bet some of the spots on the trail are inhabited *enough* to ward off wildlife, but I'm picturing some of the more remote sections...sleeping by yourself...in the AK woods...
  66. #166
    Quote Originally Posted by pescador95 View Post
    As far as I can tell, there are only two or three documented fatal wolf attacks on humans in all of North America. It's a non issue. There is much, much easier prey out there for wolves in Alaska's winter than some strange smelling multicolored ape floating on what must have the equivalent appearance to a wolf of an alien spaceship to a human. No one goes out into the wilderness without some sort of knife. It would be foolish to do so. Not from a perspective of somehow fighting off a pack of wolves with no training in knife fighting, but for processing kindling for a fire, cutting cord, or the significantly more plausible likelihood than a wolf gang fight that you'll need to use your knife to get purchase on ice to pull yourself out of the creek you just fell into.
    It's entirely possible that one or two racers have carried a pistol at some point. Where they carried it that kept it accessible and protected from becoming so covered in frost to the point of being barely functional during an all day athletic event I don't know. They would be much more useful for procuring ptarmigan, hare or spruce grouse should you happen upon one on the trail. But then you would have to spend the time cleaning and cooking it, instead of just shoveling some gorp or mini peanut butter cups down your throat. You would also need to figure out some way of securing it for the flight back.
  67. #167
    Rippin da fAt
    Somehow a fresh game supper sounds far better than powdered eggs!
  68. #168
    Dec 2016
    Wolves would be the least of my worries.... I'm picturing grizzlies, moose, mountain lions (?). An encounter may be unlikely, but I would at least *think* about it possibly maybe potentially occurring. I don't think I'd carry one personally, just wondering out loud if someone had been seen sporting a sidearm or something.
    Banshee---I was thinking the same thing! If I were truly "touring" the race, I would at least think about trying to find some fresh game to munch on while I was out there. Not that I'm a good shot or anything
    So many layers to the ITI experience. Really cool.
  69. #169
    Ambassador of Chub
    Jul 2015
    No mountain lions in Ak, and grizz hibernate this time of year. You'd be lucky if you see some wolves at a distance.
  70. #170
    Thingamejigger
    Either the tracker has gone mad or it looks like Jeny has turned around? Hope everything is ok out there!
  71. #171
    Biggest non weather related risk on the trail is probably moose. A few facts about moose and AK:
    -If you encounter a moose that insists it's you that is in her way, simply getting out of her way, off the trail, will completely solve the problem. She will trot past, you'll wade through snow back to the trail and be on your way.
    -The Iditiarod trail is somewhat regularly traveled in most sections.
    -By AK Dept of Fish and Game laws, if you shoot a moose in defense of life and property, you are responsible for salvaging the meat and surrendering it to Fish and Game. You're probably looking at 500+ pounds of meat. You're on a trail, you won't get away with skipping this step. Your tire tracks and boot prints are going to be all over the place at the kill site.
    It's simply not worth shooting a moose in defense of life and property. They might not even be willing to consider 'unwillingness to yield the trail' a justifiable reason for doing so and will cite you for poaching and wasting meat.
  72. #172
    Dec 2016
    Yikes...good to know, Sean.
    I don't know the first thing about cleaning anything larger than a rabbit, let alone how the hell I would haul 500 lbs of moose meat to the nearest AK F&G station.
    Anyways, didn't mean to derail the thread. Hope Jeny's still givin 'em the business!
  73. #173
    Temp is accurate, the winds were not light though!
  74. #174
    Aug 2003
    Quote Originally Posted by Flying_Scotsman View Post
    The gut bug that laid a few other people low out there finally caught up to Jeny in Nikolai. She headed out in the wee hours for McGrath, but had to stop and bivy after ~7 miles. The bug took a lot -- literally and, uh, figuratively -- out of her. She's back in Nikolai now, resting and rehydrating, and will fly back to Anchorage from there.
    She knows she didn't have a choice in how things turned out, but any normal human would be at least a little bummed at not making it to McG. I'm incredibly proud of all that she achieved -- both in the lead-up and once on the ground in AK -- and I think she has every reason to be just as proud, too.
  75. #175
    beer thief
    Dec 2002
    A great effort in difficult conditions. You both have good reason to be proud. Great job Jeny!
  76. #176
    Sep 2013
    Nooooo....That is awful news! Mike, you and Jeny have so much to be proud of! Cheers to you both and to perhaps making another run at it next year!
  77. #177
    May 2012
    First of all, Congratulations to Jeny for a valiant effort! It was great fun following her pink dot as it made its' way across the frozen tundra! I am so sorry to hear the bug has caught up to her, she was so close!
    Secondly, Thanks to Mike and Jeny for allowing us to share in the preparation and planning for her first ITI attempt! This has been fun, informational, inspirational and just a darn good time! I can't wait to read all of the post-race reports!
  78. #178
    Reputation: Cold Trigger Finger's Avatar
    Aug 2015
    This winter's trail weather and conditions remind me of the old saying up here . Alaska, where men are men and women win the Iditarod. My hats off to all the participants.!!! And . It sucks that with all the Big event situations, like pushing a loaded bike for miles and miles in deepish sugar snow . Then cold weather and lots of wind. We're overcomeable. But a microscopic bug laid out so many racers.
    The biggest problem I've had with working in the arctic, isn't the weather, long hours , work. It's getting so sick I almost need to be medivaced out.
    She sure did great given all the obstacles. I hope it won't dampen her want to race again.
    Thank you Mike for taking us along for the ride !!
    Imho this thread should become a sticky, or at least a seasonal sticky for race preparation.
  79. #179
    Aug 2003
    Quote Originally Posted by Cold Trigger Finger View Post
    Really well put. I've been to Nome 4 times, Unk 5 times, McGrath 9 (I think) times. And none of those trips held a candle in difficulty to the year that I got sick at the start and nursed myself just far enough to require assistance getting back out. I spent 2 days laid up in a cabin and couldn't have walked 20 feet much less made it the ~15 miles of mostly downhill that I needed to get back to Puntilla. I think Jeny was in a similar state today, and I've only heard third-hand reports but I think the Diederich twins got to that point on their way up to Puntilla a few days ago.
    It's a hard pill to swallow, made moreso knowing that you have ~350 days to wait and ruminate on it until you get to try again.
  80. #180
    Rippin da fAt
    Saddened to hear this news, Mike. With all the support and effort that went in, Jeny's a trooper beyond words. Thank you Mike and Jeny.
  81. #181
    Jan 2013
    Sad news. Just having the guts (pun unintended) to line up for this thing is more than 99.9% of us would do, myself included. Now she is all the more prepared for a run next year. Good on you Jeny, I'm impressed!!
  82. #182
    Professional Crastinator
    Reputation: Fleas's Avatar
    I am/was really enjoying this thread. Great first attempt!
    In my mind, I am thinking "Geeze, everyone/everything is so far apart and remote, how can you get sick out in the wilderness?"
    So, for those in the know, is it avoidable? I realize you have group lodgings in places, and maybe food service or whatnot.
    Would you say there could be a "strategy" for avoiding such illness other than the isolationist method? I think road racers (like TDF) go to some effort to avoid contracting any bugs or eating the wrong food, etc. It still happens, but in those races it would seem there is no avoiding the throngs and masses.
    Again, we who vicariously ride with you hope you'll go try again!
    -F
    It's never easier - you just go faster.
  83. #183
    I went on a supported bike tour with Adventure Cycling. They were real good with establishing "good hygiene" around any of the food tables. Mandatory gloves off, hand sanitizer and dedicated serving utensils. I'm sure it is harder to maintain this in the more frantic race environment and tight confines of a remote cabin, but they probably all picked it up back in Anchorage.
  84. #184
    Feb 2017
    This has been an exceptional post as in making it personal, informative and very real. Thanks for sharing some much of your hard earned experience. If the stars align we will be reading about Jenny's ride next year.
  85. #185
    Aug 2003
    Quote Originally Posted by idahomer View Post
    We caught up via Skype last night -- first time since she started from Knik. I don't think she caught herself saying it, but I twice heard her mention specific things she would change "for next time".
    It's a sickness in it's own right...
  86. #186
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Awesome!!!
    --Peace
  87. #187
    ... "for next time"...
    -F
  88. #188
    Mar 2005
    There was a woman I knew in Anchorage back in the 90s who used to hunt while bikepacking on the Kenai Peninsula. She had a lightweight .22 she used to shoot grouse and ptarmigan and anyone who bothered her I assumed.
  89. #189
    jeny jo
    Reputation: jenamin's Avatar
    Aug 2005
    ITI Story Number 1
    First and foremost: THANK YOU to everyone here who sent me well wishes, luck and good energy! I feel so very lucky! I mean that.
    I thought I would start telling little stories of my ITI experience. I can't get it all out in one bit long write up, so I thought I would just start telling stories one at a time when they present themselves in an inspired way.
    So....
    ITI Story Number 1:
    I really want to tell ITI stories... but I have no idea where to begin.
    Photo Credit: Missy. Me, rolling out of Skwentna, after biscuits and gravy. It was COLD. And ice-foggy out.
    I will start by posting pics taken by Missy Schwarz, (and of Missy), because it was her motivation and frank clarity that enabled me to leave Puntilla, and inspired me to leave Rohn. I could have nested in both places for weeks.
    Photo Credits: Missy. Me, I believe on our way to Shell Lake and Ham Sandwiches? Possibly somewhere else.
    If you know me, you know that I am not so good at The Suffer. I struggle with how to move through The Suffer gracefully ... or at all in most circumstances. At Rohn, early in the morning while snuggled deep into our sleeping bags outside of the Rohn tent, I blurted out to Missy: "I can't deal with The Suffer. How do you deal with the Suffer?"
    Her response: "Drop The Suffer."
    "But HOW." I asked.
    To which she replied: "I don't know. Just drop it."
    Whereupon she packed up her shit and rolled on.
    It took me another 4+ hours to pick up the pieces of my brain, body and soul... not to mention completely repacking my entire pony and kit (I find this act to be so peaceful and therapeutic!!) ... and rolled out solo. I don't know EXACTLY what planted seeds of motivation, inspiration, energy, light into my being, but whatever it was, it kept me from flying out of Rohn on plane, and moved me along on my Pony instead. So many people were seriously injured, seriously sick, or seriously something ... that I felt that my nerve-damaged hands, compromised knees, and inadequate Suffer Tools had absolutely no damn excuses. Besides, all I had to do was break things down into small steps from there. Bear Creek Cabin. Nikolai. A potential bivvy on my way to McGrath if I had to/wanted to. McGrath. That's tangible enough. Right?
    The BIG of AK wilderness is beyond comprehensible. We are quiet (sometimes), tiny creatures sllooowwwllllllyyyy moving through it. Or trying to, anyway.
    Thank you, Missy. Thanks for being so real and present (and so effing hilarious) for the days we got to ride together. Thank you for being such an amazing ****ing badass that I could do nothing but try and reflect that badassery back at you.
    A picture of Missy. My favorite picture from the whole trip, I think.
    The FUNNIEST story of my entire ITI experience came of a moment that, to me, reflects the depth of bonds and connections made while out on the trail: All along Missy demonstrated the ability to eat at least 2.5 times more than I could. My 3/4 of the Biscuits and Gravy order to her 2+. My almost 1-ish dinner meal to her 2+. It was impressive.
    When we were at Rohn, we were given 2 brats. I covered mine in ketchup and mustard. Missy ate hers plain. I got through 1.5 of mine before I felt like I was going to seriously puke if I ate another bite. Not one to make such a mess in a shared space, I handed her my remaining 1/2 brat. She squinched her face up and said: "Yeah, I'll eat that if you can get all that shit off of it [ketchup and mustard]". So... what did I do? I looked at it, licked it clean in one long lick, and handed it back to her without a thought. I don't think I even looked at her face. I just handed it to her and it was gone. Poof.
    Photo Credit: Missy. Me, somewhere, out there. Possibly on our way to Puntilla. Possibly on our way to Shell Lake. Can't tell
    In looking back at this moment, it is the one moment that continues to make me absolutely giggle. The miracle of this moment is that Missy did not get sick. Which tells me that I 'contracted' whatever sickness I got AFTER I left Rohn.
    Photo Credit: Missy. Pic of myself.
    Anyway. Many more stories to come as I find motivation to write about them. And many, many more pictures.
    Again, thank you, Missy.
  90. #190
    beer thief
    Dec 2002
    So awesome. Thanks for sharing
  91. #191
    JT1
    JT1 is offline
    Feb 2017
    Jeny,
    You are an inspiration. Thank you for sharing with us.
  92. #192
    Rippin da fAt
    You're a trooper, Jeny. Glad you had the opportunity and went for a monumental adventure of a lifetime.
    Thanks for sharing the story and pix.
  93. #193
    Feb 2015
    This has been a very informative and interesting thread for sure, thanks for posting the follow up stories as well. It sure looks like a daunting adventure, it's been a great read so far, thanks again for sharing your experience.
    '07 Spec Enduro
    '14 Salsa Mukluk 2
    '16 Salsa Bucksaw GX1
  1. Replies: 1
    Last Post: 04-28-2016, 04:02 AM
  2. Replies: 1
    Last Post: 04-28-2016, 04:00 AM
  3. Replies: 4
    Last Post: 06-12-2013, 01:33 PM
  4. Prairie City Race Series - Race #3 photos and results are posted!
    By CactusJackSlade in forum California - Norcal
    Last Post: 04-18-2013, 09:30 PM
  5. Replies: 8
    Last Post: 04-07-2012, 08:16 PM
