Page 4 of 4 FirstFirst 1234
Results 151 to 179 of 179
  1. #151
    Quote Originally Posted by OldHouseMan View Post
    Interesting comment. Surly, Salsa, Heller, Voytech, Ventana, Nicolai, Fatback, Devinci, Specialized, Trek and Reeb all list a shorter wheelbase than the Wozo. In some cases the wheelbase is much shorter than the Wozo.
    Yes, cs, sorry for the confusion
  2. #152
    Quote Originally Posted by sml-2727 View Post
    i contacted 4 kona shops and all of them said the wozo is sold out til april, they also said its NOT available in a frame only option.
    Canada only, that's why I made the trip. They had two large and two medium, I got one of each, no idea if the others are still available.
    Buy mine, the price is very reasonable, certainly beats driving to Canada.
    Got my first ride on the Wozo with 4.8 Minions, nice ride, frame feels much smoother than the Beargrease. Gonna bust some downhill flow trail tomorrow , see if I can keep it open the whole winter.
    Edit: The medium Wozo is SOLD, it leaves for its new Utah home on Monday
  3. #153
    Quote Originally Posted by OhioPT View Post
    How much do the frames weigh?
    Bueller, Bueller...
  4. #154
    Bueller, Bueller...
    The medium is wrapped for shipping, but with seat clamp, foam, cardboard, and tape it was aroun 5#. Honestly, it's probably close the weight of a Big Honzo which weighs ?
  5. #155
    ok, thanks!
  6. #156
    The White Jeff W
    Reputation: jeffw-13's Avatar
    That sizing is crazy. Im 6'3" and just going off the ETT and reach numbers I'd be on a medium WOZO lol. In fact the M reach is longer than my XL Yelli Screamy.
    No moss...
  7. #157
    Quote Originally Posted by jeffw-13 View Post
    Yeah, seriously, I was thinking the exact same thing! I would need a 450mm seatpost for the 17" seat tube on the Medium. Not sure if that would stress the frame too much?? Jeff, build one up so I can take it for a spin
  8. #158
    I ride large frames in all bikes, but after looking at the frame specs I was sure I'd ride a medium Wozo. Then I spoke to a shop guy in Winthrop who rides a Wozo, he's my size, and he said the fit is not as big as it seems.
    He was right, the large fits perfect, 40mm stem, seat centered on the post, 150mm dropper fits just right. I'm running a 20mm riser bar with the stem slammed.
    If I bump the fork to 120mm then I'll probably run a flat bar, otherwise this Wozo is perfect.
    6'3", you need a XL or you'll be running a long stem with a lot of seat post showing.
  9. #159
    The White Jeff W
    I was hoping you would
    No moss...
  10. #160
    The White Jeff W
    Quote Originally Posted by Nurse Ben View Post
    Thanks. That was my experience with the Satori I had. It fit smaller than the numbers would indicate.
    No moss...
  11. #161
    I just ordered a Wozo and it should arrive this weekend. Who has the maxxis minion rear 4.0" in stock I can purchase from? I'm hoping to get the Exo version.
    Also making these tubeless any different than with standard size tires?
  12. #162
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Quote Originally Posted by GspotRider View Post
    Try Universal Cycles currently in stock
    https://www.universalcycles.com/shop...&category=5792
    #THELEGEND
    2016 RSD Mayor
  13. #163
    Did you get a frame or a complete? I thought the completes came with a rear 4.0 minion.
  14. #164
    The website says jumbo jim 4.0".
    I just ordered some 4.8 minion FBF and 4.0 minion FBR. Man, I will be annoyed if they do come with the minions after all!
  15. #165
    Quote Originally Posted by OfficiallyColin View Post
    A more recent picture
    Hi Colin, nice bike man. Can you tell me what fender to buy or make for this bike and fork?
  16. #166
    strider
    Jj 4.0
    I got a complete WOZO a few months ago. They come stock with JJ's front and rear. rear is a 4.0 and the front is a 4.8. Plenty of clearance on the rear with 80mm Mulefut rims. I am considering swapping the 4.8 JJ to the rear and putting a Minion FBF 4.8 on the front for a little more grip. Not sure about the rear clearance though. Maybe I'll get my caliper gauge and do some measuring before my ride today.
    Has anybody had success running a 4.8 on an 80mm rim in the rear yet?
  17. #167
    I just got mine here in Canada and indeed it came with JJ's. I had sweet time in the snow and it was a blast. The JJs were a bit washy in the front at times, and I just mounted a set of Minions.
    I think the 4.8" JJ will fit in the back but may rub a bit. You may need to move the axle back for more clearance. I jammed my axle all the way forward as I wanted as short a chain stay as possible.
    My second ride on the Wozo was in melting snow after it rained. What a hard slog! At least I could ride!
    Untitled by avyoung, on Flickr
  18. #168
    I'd swap the rear rim to a 65mm, then you can run 4.8 tires on the rear with no problems. I use a Large MargeLite.
    Quote Originally Posted by rvercoe View Post
  19. #169
    I'm running a dunderbeist in the back on a 80mm rim. It's fine for snow but for dirt with lots of grip I think it will rub when pedalling hard or cornering hard. Too much flex at the chainstays. There is over .25 inch clearance on both sides with the wheel moved back
  20. #170
    Rocks belong
    If this pic doesn't make you want a fat bike, not sure what will...
    I like 'em long, low, slack and playful
  21. #171
    PSA: bikeexpress on Pinkbike
    They are reporting Wozos in stock including an XL.
    It's gonna be a long, long winter, best get yourself something fat and green for cuddling
  22. #172
    Nov 2016
    Nice Bike
    I am running a 4.6 Flowbeist on the front and 4.0 Vanhelga on the back runs great in the snow lots of traction!!!
  23. #173
    Nov 2016
    My Wozo
    So far no trouble with 4.0 Vanhelga on the back in the snow. Flowbeist 4.6 tires is great up front!!!!
  24. #174
    Apr 2014
    Quote Originally Posted by Erock503 View Post
    So any feedback from riders on the snow yet? Very surprised more people aren't gushing over this thing. Maybe all the owners are too busy riding them? I expected to see a lot more reviews, this thing is nuts!
    I was wondering this as well, looks great on dirt. Curious to see how the wozo rides in snow?
  25. #175
    Yes we are too busy riding because they are awesome everywhere. I rode it through deep snow and everything in between. The short rear end and long front seems really good. I'm 6.2 and riding a large with a 50mm stem. Maxxis fbf 4.8 front dunderbeist on the back on 80mm rims. Haven't had a problem with float around here. This bike has been at least as good as my old kona wo with bud/Lou combo
  26. #176
    strider
    Snow Machine
    Quote Originally Posted by Mr_X40 View Post
    That sums it up. Too too busy rip'n the pow pow on the WOZO! This thing rips on any terrain and definitely on snow. To give you an idea, there are many great experienced snow bikers on the local trail network here in WY and I have KOMs on several of the downhills and rolling tracks with my first season snowbiking. So the power of the WO-ZO is strong in this bike.
    I am now starting to plan ahead to when the white stuff melts. I am working on a 27.5 x 3.0 wheel set for the dry season and will drop a report on how that rolls now that I have my quiver-killer one bike for all-seasons and conditions.
  27. #177
    Well, my riding has been nearly all snow; we haven't seen dirt for a few months, so my opinion on how the Wozo rides is all about snow performance.
    So the short chainstay thing, people wonder how it can be helpful in snow. Well, you know how it is when you start climbing a hill as the back end starts slipping, you can grunt up the hill and sometimes the tire will stick, but there are times when you need to lift the front end to get the back end to bite.
    With the Wozo, I 've been able to "pump" the front end up and down to get the rear wheel to grab. The pumping action is 100% about short chainstays; think manuals and wheelies.
    I've had longer wheelbase snow bikes and they were not as good for climbing as the Wozo because they don't manual well. On the flats, all bikes are the same. On the downs, once again those short chainstays take the prize, easy to maneuver, manuals, jumping, all the things you expect from a Honzo snow bike.
    I may get a day of dirt riding this weekend; heading toward Seattle, fingers crossed that the trails are dried out enough for riding.
    @rvercoe: 27.5 x 3 is gonna drop your bb really low, you might want to do some measuring.
    A 27.5 x 3.8 would be better or even a 29 x 3.
  28. #178
    Nov 2016
    Snow Riding
    Quote Originally Posted by clchapman130 View Post
    I agree with Nurseben rides great in the snow,I studded my winter tire 45north Flowbeist and vanhelga and it is amazing.Lots of grip climbs like a billygoat!!!
  29. #179
    Feb 2014
    Delete.
  1. Kona Wozo
    By nitrousjunky in forum Fat bikes
    Last Post: 12-30-2016, 04:46 AM
  2. Help with my first bike - KONA WOZO or KONA BIG HONZO DL??
    By stew1818 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 08-19-2016, 02:43 PM
  3. Kona wozo
    By stew1818 in forum Fat bikes
    Last Post: 08-15-2016, 02:43 PM
  4. Replies: 5
    Last Post: 02-04-2014, 01:10 PM
  5. Replies: 1
    Last Post: 01-02-2014, 04:09 PM
