Results 1 to 90 of 90
    The Hub Destroyer Returns In Glorious Victory
    I have destroyed the best of the best....so what is next? Who will be my next victim?
    preston
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Damn dude you're hard on equipment. Does anyone make a steel hub shell?
    No moss...
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    That sucks, but it's not the same as killing the drive mechanism.
    Looks like an Onyx? What width, and which rim do you have it laced to? Spoke bends look harsh from that angle.
    Quote Originally Posted by mikesee View Post
    How dare you question the Hub Destroyers ability.
    The Hub Destroyer shall let the hub remain Onyxmous. It is a 197mm hub laced to a Nextie Gen II 90mm rim. There is slight damage around the nipple hole in the rim from when the spokes jammed into the brake disc and locked up my rear wheel.
    Oslo, Norway
    Feb 2012
    Test the American Classic hub.
    Espen Wethe
    www.kindernay.com
    Kindernay on BikeRumor: https://goo.gl/iQtWxu
    Aug 2003
    Quote Originally Posted by Espen W View Post
    Tee hee.
    Jon, what did Onyx say when you called?
    Tee hee.
    Is this hub you speak of worthy of such consideration?
    I don't know who this onyx is that you speak of, but it just happened a few hours ago. They have not responded yet. Wheel was laced at bikeman.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Have you ran the DT Swiss yet? I remember you killed a Hope fatsno already.
    Too bad King hasn't made a fatty hub.
    Quote Originally Posted by Shark View Post
    I have killed Hope twice, 907, I9, and now this one. Have not tried DT Swiss
    Even though I could not afford it, I have told King numerous times I will pay for a one off King 197mm hub. They said no. Only rear hub I can depend on it seems.
    Time for an Origin8 or Novatec.
    Jason
    Disclaimer: www.paramountsports.net
    Feb 2006
    Quote Originally Posted by jonshonda View Post
    DT Swiss is supposed to be pretty bomb proof, not crazy expensive either. Worth a look.
    You know, it might just take time (CK fat).....I asked trek about a fat ex9 back in '12. They said no. Look what they are finally doing.
    Reputation: mtuck1's Avatar
    So was there a spoke issue, or is the flange failure ultimately the root cause?
    Clearly, it is the user, if he kills all the hubs he rides, no hub is gonna stand up to the Shonda!
    Maybe you can get someone to machine an SS hub body for the Onyx guts?
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    All hail the hub destroyer!!
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Dec 2016
    Just trundling along a gentle firebreak...
    clearly you need to do something else for fun.. like maybe lumberjack competitions, or maybe change the way you ride a bike..
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    sumpin ain't right.
    "ORANGE IS THE NEW BLACK"
    May 2005
    If you have not yet tried DT then what are we supposed to say? In this case the buyer is also the rider....so lets call all this rider error! :-)
    Reputation: solarplex's Avatar
    Apr 2014
    Uh...try a dt 350 and then get back to us, all ill say is good luck.
    Fatbike, XC bike, Gravel Bike....
    Reputation: Velobike's Avatar
    Quote Originally Posted by jeffw-13 View Post
    Strangely I was thinking about that the other day.
    It's not as if steel hubs have to be heavy, I have some that are as light as good quality alloy (decent vintage road stuff), and when you look at the width of fat hubs, steel may actually be a better material especially if a large diameter centre was used.
    Latitude: 57º36' Highlands, Scotland
    Reputation: SeaHag's Avatar
    Damn, I pick up my new Borealis wheel set with the 197mm Onyx hub tomorrow...Hope I am fortunate enough to avoid similar fate.
    I've never destroyed one in the spoke flange as you have, but I've torn the guts out of everything I've tried including an older DT Swiss/HUGI hub three times. After a bunch of research, I decided to go with Onyx for the sprag clutch hoping to avoid any more walk outs...but now you've got me a little worried.
    I expect them to stand behind their product with the prices they charge.
    Oslo, Norway
    Feb 2012
    American Classic had major issues (when made by Chin Haur) until approx 2005, but have held up very, very well since that.
    The AC fatbike hub is the only fatbike hub that we have not had issues with on our production bikes.
    I have put mine through some serious stress. Hours upon hours upon hours of climbing very, very steep stuff in the 26/42 with resulting massive chain tension.
    Basically straight up the sides of mountains with the sandstone like grip of 5.6's at 0.5psi. Spent Easter last year doing that for 35 hours or so.
    On many occasions, on long stretches of mountainside so steep that I could barely turn the 26/42 gear standing out of the saddle, I expected the ratchet mechanism to blow apart, but it has held up beautifully.
    I have met with Bill Shook (AC founder) many times, and he definitely knows what is going on inside the hubs (same cannot be said for many of the other hub engineers that I have met with)
    Espen Wethe
    www.kindernay.com
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    I agree that the AC mechanism is robust, but it doesn't have very good "engagement speed", shall we say? If it is their classic cam design, the degree of rotation before engagement is going to turn a lot of people off.
    But otherwise I have seen no issues running my AC hub single speed on my 29"er.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    You did it again
    I had a circa 2008 American Classic hubset. I never had any issue with the engagement but I did brake the rear disk side flange. The hub had a pretty easy life on an XC bike and I'm typically not a hub destroyer. I got no response from America Classic so I threw it in the trash, laced in a DT Swiss 240 and never looked back.
    Dec 2011
    I'm confused as to how you guys do this. I have to believe you're (no offense) 300 pounds and enjoy stand-up granny-gearing on 30% slopes for hours in 0 degree weather on 2XL tires at 1 psi.
    gone walk about
    Mar 2012
    help Mr Wizard!!
    Feb 2006
    Shot in the dark, have you tried a different wheel builder?
    If he's broken all the big name fat bike hubs, and you're suggesting he build with your hubs because your hubs are so much stonger, I call bullpuckye.
    If I was Shonda, I'd get a machinist or even Onyx, to make an SS hub body, then move along.
    Of course if you make the flanges stronger, that will cause the stressors to shift elsewhere.
    So John, do you ever break off teeth on your cogs or chainrings? How about broken chains, cranks, or BBs?
    I ran Onyx on a mountain tandem, they're tough.
    Maybe Shonda is like the Chuck Norris of mountain biking?
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by Nurse Ben View Post
    Hmm, didn't know that I owned stock in the American Classic company, but I learn something new every day
    I run them on my own bikes and I ran them on the high end models of the Diamant and Nakamura brands.
    Our test riders blew apart pretty much anything under the sun, including the hip brands. Especially when the bikes were still QR.
    The record was less than 10 minutes from unused to destruction (early QR Novatec). Many others (including the expensive) brands did not last more than a couple of days to a few weeks.
    Our main test rider actually became known internally as the Destroyer (well, actually the German word for destroyer) at one of the major hub companies that we helped developing fatbike hubs for.
    The engagement mechanism on the AC works very well, here is some info, including a video by none other than Bob Roll:
    Enduro Mag ? Inside the freehub of an American Classic MTB disc hub
    That said, it seems that the engagement mechanism of Jons current hubs stands up the the abuse, and that the hub shell is the current issue, and that could happen on other hubs with strong internals, including AC.
    Espen Wethe
    www.kindernay.com
    Reputation: dRjOn's Avatar
    looks like 2 cross on the spokes? broken flange? i'd echo Shark and consider discussing the situation with a different wheel builder - not to say the one you use or if you build yourself is not good - i'd get a second opinion though. Mikesee, here, would be an obvious choice.
    Feb 2005
    All the same failure mode, all the same wheelbuilder? Considering how generally rare that type of failure is, and how generally decent quality the hubs used so far, are, yeah, you might want to try a different builder.
    Just a casual observation, looks like a lot of crust around the elbow and in the hole, you do a lot of salt riding? If so, rinsing better or starting to, can only help too.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Different wheel builder for both of my hub shell failures. My last builder was bikeman (aka carver bikes), I went with them cuz they had experience w/ nextie rims. I told them I wanted the strongest wheelset possible.
    Yes there is salt on the bike, it rides on my 1up rack on the back of my truck. Salt only does harm when it gets wet....so washing my bike isn't done often in winter.
    The is the first failure in the field according to the hub manufacturer, and they have been very awesome with customer service.
    I did question the need for the cutouts in the nds hub flange, and they noted I could have a custom hub made w/o the cutouts or switch to a centerlock hub, which has no cutouts. A custom hub is 3-4 week lead time, but it would be cool.
    I was giving them shit about how the only hub I have never had issues with is my Chris Kings, and he told me they use the exact same material and supplier as CK. But I countered with the factopper CK doesn't but cutouts into the flanges, and he said they us different machining methods to reduce weight that aren't available due to there hub mech.
    Reputation: bikeny's Avatar
    Good to hear that the manufacturer is working with you. I don't think it matters that they are using the same material and supplier as CK. It's what you do with that material that matters, and the fact that CK doesn't make a fatbike hub. CK also machines everything in house, all the way down to their bearings, so can keep very fine control over tolerances and such. The stresses on fat bike hubs are much higher than standard hubs. When a manufacturer just takes their standard hub and widens it, problems will arise, depending on how overbuilt their normal hubs are. Lateral stresses in particular are exponentially higher on a 190mm hub vs. a 135mm hub.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I've also ruined a few hubs/ cassettes/ drivers but nothing like jonshonda. I bow to the master of disaster.
    Lately, I've been on Hopes. My 907 is a 197 thru axle frame. I currently have three sets of wheels. After a few different failures, I seem to have scienced out what works for me.
    On my 100mm rims shod with a 4.8 Knard on the rear wheel, I was climbing like a mountain goat. The bike started shifting badly. Upon inspection, I found I had stretched the rivets on my cassette because my 24 tooth granny ring was putting me on the fourth cog which only had 5 rivets. I also "wrinkled" the alloy Hope driver.
    The LBS guys had never seen that before.
    Shimano warrantied the cassette and I upgraded to a steel driver. I also swapped my granny to a 26 tooth to put me on the next cog ring with six rivets. Everything seems to be staying together now, but I divide my riding between the three wheelsets so I can't be sure how much longer everything is lasting.
    I completely ruined a 907 (Chosen) hub before these Hopes. I've never ruined a flange though.
    I like turtles
    turtles make me hot
    Quote Originally Posted by GiantTurd View Post
    And what's wrong with that?
    Really, Man... What's the problem?
    I like turtles
    turtles make me hot
    I like turtles
    Human Test Subject
    Reputation: Volsung's Avatar
    You make me feel better about all the weird things I break.
    Reputation: Bacon Fat's Avatar
    Mar 2016
    What were you doing when the hub cracked? Cranking up a hill? Landing a jump or JRA
    i'm kind of surprised at some of the thoughts re fat bike hubs being more of an issue, as my un-educated guess would have been that a fat bike hub would have seen *less* stress than a normal width hub.
    the triangulation is massive so stiffness of the wheel as a whole is not an issue if built well to good tension and in this instance, i would not expect a particular difference with the spokes detensioning (which as i understand it, is a risk for flange stress - when the hub is hanging from just a few spokes, rather than pulling on all of them all the time).
    of course under drive you have to have a stiff enough tube between the flanges to turn the non drive side of the wheel - but with a big ol' flobby tyre rolling around i cant imagine the force differential there being excessive....
    the bearings have a wide stance on the axle and the stays to rear hub forms a solid triangle as well...
    am i missing something?
    i know nextie tend to recommend very high tension max. i never push to that sort of tension as i dont see any real benefit over 100kgf (see wheel fanatyk for thoughts on this...) - worth thinking about.
    Reputation: Twimby's Avatar
    Jun 2013
    I am the ying to your yang. 5,000 km on the original Fatboy 2014 Hub, that everyone one broke. I am probably 20kg lighter. Lots of salt, beaches work though. I wash after every beach ride
    I realize that. But you're in the industry and you were shilling, so I called it.
    You need to be honest, esp as an engineer, to say that one hub maker has a stronger flange than all other major high end brands, that's ridiculous. John destroys internals as well. You need to follow his hub destruction pattern.
    Destroying a Novatec isn't even worth mentioing, that's childplay.
    Feb 2005
    When in doubt, look at environmental factors.
    Never in a million years would I carry my bike on a rear rack in the winter, the salt plume created as you drive is insane.
    I carried this torch in another thread, some sided with me, others did not. One guy had to eat his words when he, doing the same as you, had a catastrophic hub failure as the thread was going on.....
    I don't want to come off as pedantic, just saying, if you want a solution, time to look at all the behaviors and factors. If I get salt on my bike, a nice, long, gentle, hot water bath is always the first priority as soon as I get back home. I don't see failures, or corrosion nor do others who follow the same regimen.
    - FrostyStruthers
    Dec 2011
    No judgment, I'm just making the point that this must be caused by a fairly extreme combination of factors. I've got several thousand fairly rough miles on the notoriously assplosion-prone Novatec without issue and people here are totally destroying $500 "bombproof" hubs. I've ridden a variety of bikes since the eighties including many years of both MTB and road racing without seeing anything close to the picture above. It's just out of my realm of experience.
    Oslo, Norway
    Feb 2012
    Where did I say that one brand has a stronger flange than all other major high end brands?
    Espen Wethe
    www.kindernay.com
    Oslo, Norway
    Feb 2012
    Quote Originally Posted by MendonCycleSmith View Post
    True.
    At the back, especially of a station wagon or similar type of car that generates a low pressure area at its tail, the bike gets absolutely saturated with a fine, salty mist. Had the alloy nipples of one bike literally fall apart after one such ride at the back. (They had been fine for 2 seasons of riding and carrying the bike on top of the car ).
    If it can't be carried inside the car, put the bike on a roof rack and keep a decent distance to the car in front (avoid tailgating trucks) and it is amazing how salt free the bike will stay, even on roads absolutely drenched in salt, like over here (from late October to well into April)
    Espen Wethe
    www.kindernay.com
    Let's get along now ladies!! Espen didn't come across as shilling when he detailed his experience w/ AC imho. He was just providing feedback.
    Regarding the forces placed on fat bike hubs vs standard width hubs, you need to understand the added amount to or rotational mass and extra grip of these massive tires, as well as the braking capabilities. All of these put more stress on bearings and hubs. The further from center you mount bearings the more leverage is applied to those bearings. If I were to build my own rear hub, I would either increase the size of the bearings, or double the amount. I would also NEVER let weight weenies take material out of the flange....just uncalled for.
    I have broke two XT cassettes too, the carriers just break at the rivet.
    Regarding the salt....I'm not too worried about it but do plan on making wheels covers in the near future.
    Oslo, Norway
    Feb 2012
    Yep, wheel covers is a good idea.
    Stress corrosion cracking is an issue in a salty environment:
    https://en.wikipedia.org/wiki/Stress_corrosion_cracking
    Micro cracks forming from heavy tension loads in the areas of highest stress (like around the spoke holes and flange cutouts). Cracks that would probably not cause any issue in a fairly corrosion free environment. However, add a corrosive element to the equation, in this case road salt (and the additional cr..p they add to it) and voila. Problems.
    Espen Wethe
    www.kindernay.com
    i know some shimano hubs went through a phase of cracking along the freehub body and hopes had a habbit of cracking along the hub body out to the flange recently - ive had both happen to me.
    as for the bearings being further from centre - i can understand if that is one bearing but within reason (and we are talking about 55mm here) and with generally (at least) 2 bearings in a hub shell does that still hold? afterall, hubs generally have issues if the bearing stance is too *narrow* and a large radius lever and force is being applied. the distance from the frame to the bearing on each side is the same and the increased stance (wider triangle) should promote rigidity. could this transfer more force to the bearings? i'm not sure...its an interesting thought.
    traction IS high - but at the same time the flex from the tyres must mitigate some force transfer....
    hopefully it is clear enough that i'm genuinely interested in this - not trying to score points!
    fwiw, i have about 9 sets of DT swiss hubs on the go --- 350's, big rides, 440's 240s of varying widths and types and some old school 340's and the only issue i have ever had with them over the last decade is a 240 front that cracked around the flange after the bike fell off an uplift truck in Rotorua and was dragged up a hill with the front wheel leveraged in a contraption to hold the bike on the trailer, putting massive force on the wheel.
    i'd echo some others on this thread and ime at least, DT are ne plus ultra.
    turtles make me hot
    JH, could you do us all a favor and build a wheel with a Bike Hub Store hub?
    Who knows... It may last as well as the pricey hubs.
    I like turtles
    The crap they put on the roads these days eats aluminum about as well as it eats steel. The factory aluminum rims on my Element looked like hell after only 3-4 winters.
    Minnesota Off Road Cyclists www.morcmtb.org
    Feb 2005
    All due respect to your sovereign decision making processes?
    If you desire to solve the problem, get it out of the salt for starters. Not being too worried, and some wheel covers, won't solve the problem, just move it elsewhere, you'd rather rot your cranks, stem and every single bolt on the thing, instead?
    Salt (and the spent fracking fluid they now spread on the roads too, lovely), love nothing more than eating soft metals.
    Salt kills metal and should be respected as the enemy it is....
    - FrostyStruthers
    Mendon....it will be ok. I have no other method to transport my bike. Not going on the roof of my gx470, not going in my vehicle as I have car seats in the second row.
    Nrr...you build me some bhs wheels and I will ride them!!
    Clydesdale Gear
    Reputation: Razor Hoof's Avatar
    Nov 2015
    When Jon pedals east, the day lengthens. When he pedals west, the day shortens.
    I'm glad you're not as hard on forks since I bought one from you a while back.
    Clydesdale Gear
    www.razorhoof.com
    ...Salt (and the spent fracking fluid they now spread on the roads too, lovely), love nothing more than eating soft metals.
    When I had a yacht I got very familiar with the term "crevice corrosion" in which the salt would quietly corrode away the iron component of stainless steel while leaving it looking perfectly ok - until it broke. I ended up using galvanised fittings for reliability.
    Sounds like something similar may be going on here.
    turtles make me hot
    Damn. I wish I had some parts in stock. I want to see how long a BHS hub would last.
    I like turtles
    Jon; concerning your thoughts about the dangers of salt; when salt is wet, it is in a dissolved state, when dry, a solid state. It is when in the latter that it is the most abrasive.
    That being said, not saying that that is at the root of the hub failure.
    May I suggest that you market yourself; by creating a destructive test standard. Any hub that would meet or exceed the "Tested by Jon" seal of approval would have to be the height of envy.
    Quote Originally Posted by Sand Rat View Post
    ...Any hub that would meet or exceed the "Tested by Jon" seal of approval would have to be the height of envy.
    And I suspect would be a useful weight weenie repellent...
    is buachail foighneach me
    Reputation: sean salach's Avatar
    If he's broken all the big name fat bike hubs......
    .....except Hadley/Fatback and the above mentioned DT and the above mentioned AC. So, not quite all.
    Why so uptite?
    Dec 2005
    I'm glad I am not as strong JH. I'd get sick of building wheels.
    Collection of fun carbon & titanium bikes
    @tgi_cycling
    Sure, salt is bad, but John breaks well before salt would have had any effect.
    I used to have a reputation for breaking ski bindings, folks blamed my technique, they called me a liar, there was all kinds of ugliness.
    If I built hubs for a living, I would pay John to test them.
    So what hub is next on the list? Might as well try DT.
    Any there hubs with the flanges tilted inwards in an effort to minimize the spoke bend leaving the hole? When triangulated in a build this would keep the forces in the plane of the flange rather than a component normal to the flange.
    Nexties are pretty much center drilled 2.5mm offset, VS a Clownshoe with 40mm between the holes. All things being equal in a build except the rims, I'd think that a narrower drilled rim would cause more stress in the hub flanges.
    Quote Originally Posted by bme107 View Post
    I agree. The nexties look cooler, but I like the offset spoke beds of the LB 90 rims. Seems much better for bends.
    I've broken three hub flanges, all were on mountain unicycles, two hubs were Ti and one was aluminum.
    The Ti hubs had cutouts that made them prone to cracking, the aluminum hub just get old and fatigued.
    I also spun loose quite a few press fit spindles until they started welding the flanges to the spindles.
    When it comes to hub bodies, steel is real.
    Strangely I never broke spokes or cranks.
    Reputation: skiahh's Avatar
    preston
    Project321
    Welcome to PROJECT 321 - Manufacturer of High-Quality Aftermarket Accessories for Your Bicycle, Automobile, Motocross Bike and Quad
    Quote Originally Posted by Razor Hoof View Post
    Which fork was that...the Manitou? I am on an Avalanche open bath pike now, so life is good!!
    Quote Originally Posted by NYrr496 View Post
    How about we arrange something for next winter? Even though we just got a foot of snow, highs are in the 60's and snow will give way to dead grass and mud soon. Riding in the summer isn't nearly as hard on my rear hubs as winter riding is.
    Quote Originally Posted by sean salach View Post
    True. I was really tempted by the DT swiss, but a good friend of mine was also curious whether or not the onyx could stand up to my abuse before he bought a pair. After a year of use we felt pretty confident. He bought a pair of customized onyx hubs after snapping the axle on his 907 rear hub, two weeks later I break my onyx. haha
    Quote Originally Posted by EBG 18T View Post
    That makes two of us! wait
    I had honestly just driven to work and back in a snow storm prior to taking the picture...that is why the salt looks so nasty. That is not an every day thing fellas!
    For what hub is next.....I gotta stay with Onyx for now. I can't just dump a $500 hub after one year of use. If I have more issues, I will ask them for custom machining which they at willing and capable of doing.
    I think that's a great idea. Might as well have the flanges be parallel with the spokes right?
  68. #68
    Aug 2003
    Onyx is a great company, run by smart people, with hubs being ridden hard by a diverse crowd, worldwide.
    If this was a problem they saw consistently they'd already have addressed it. Clearly they haven't seen it before.
    Alternate materials are one possible solution. My guess is that instead of screaming Henny Penny, losing their shit, and going back to the drawing board over one hub that died at the hands of a known lightning rod, they'll simply rejigger the program to omit the tiny weight-saving holes from the flanges, and that'll solve it.
    Worst case, maybe they'll offer a forged-then-machined shell option.
  69. #69
    turtles make me hot
    I'm in.
    I like turtles
  70. #70
    Clydesdale Gear
    Nov 2015
    It was the Manitou. I've since converted to a Pike also, but I'm still running the charger damper.
    Clydesdale Gear
    www.razorhoof.com
  71. #71
    Well said Mike. If it breaks again then I expect some wizardry will take place w/ regards to hub design.
    I'm in.
    BHS winter games 2017
    If you are a big dude Craig at Avalanche will rock your world with the open bath cartridge.
  72. #72
    And if you are a smaller dude like me.
  73. #73
    He will rock you pretty hard too. Its just that the pike has a hard time playing nice w/ higher weight riders. I don't think I have seen a single complaint from craigs work, regardless of size, fork or shock.
  74. #74
    Just wanted to update the thread to say how awesome Onyx was handling the issue. No fuss, no blame placed, lightning fast communication and zero out of pocket cost for me. They even etched custom graphics on my hub.
    It was less then 5 business days from when I dropped it off at UPS to when it was back at my door.
  75. #75
    Dec 2014
    I just did this a few weeks ago on my XT cassette. Sheared the rivets on gear 4 and 5. I turned into a single speeder for a few days...Gear 3 was too low to keep up with the group, leaving gear 6 as my only option. Lots of standing and mashing...
  76. #76
    ...They even etched custom graphics on my hub....
    At a guess -
    "Don't buy this hub 2nd hand from jonshonda"
    in nice italic script.
  77. #77
    bigger than you.
    Reputation: Gigantic's Avatar
    It this point, it may be time to say that it's not the hub, it's you, Jon...
  78. #78
    turtles make me hot
    Quote Originally Posted by Velobike View Post
    At a guess -
    I just doubled over laughing.
    I like turtles
  79. #79
    I want action footage
  80. #80
    gone walk about
    Mar 2012
    Quote Originally Posted by Gigantic View Post
    we knew this, it's jon that requires the mind bend.
  81. #81
    Haha. Not for resale.
    What do you mean it's me?
  82. #82
    Harmonius Wrench
    Thank you for that update. It is good to read about a company that stood behind their product and acted promptly to resolve the issue for you. I wasn't so fortunate several years ago with a hub failure on my first fat bike, so I am happy to see it work out for you.
    I will be considering this company's product a bit more seriously due to this result.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
  83. #83
    I should also add I sent them my entire rear wheel which they relaced with new Spokes and nips
  84. #84
    Reputation: jpfurn's Avatar
    Oct 2014
    I made the switch from I9 to Onyx and couldn't be happier. Nothing better then riding in the woods and actually hearing the surrounds and not the buzzzzzz! On top of that they roll like butter and are super durable. I won't built with anything else from now on. I'm selling a 150/177mm 27+ wheel set now to fund a FS plus build. Hit me up if you know anyone looking, thanks!
    27 Nextie/Onyx 150/177mm - Buy and Sell Mountain Bikes and Accessories
  85. #85
    Human Test Subject
    Have you ever had your pedal stroke looked at by a professional? Is that even a thing?
    I've been worried about mine for a while. I commute a lot and lean right/push off left from stoplights. This (and technically being a Clyde) causes me to destroy left pedals. I even broke an Ultegra spindle on the NDS.
  86. #86
    Quote Originally Posted by Guitar Ted View Post
    They make good hubs and as a prosummer I find the company to be super responsive. I'm on my fourth set, still have three sets, sold one set (should have kept it). No issues, love the feel, don't miss the noise, can't say that notice the weight.
    I have DT also, which are good hubs too, but Onyx is in it's own class.
  87. #87
    Haven't seen anyone suggest you try the Syntace HiTorque MX rear hub.
    Their freehub design is a bit like the DT ratchet and apparently has a stellar reputation for durability. And (relatively) inexpensive: about $200 at current exchange rates.
    Available at r2-bike.com and bike24 among others.
    EDIT: oops, nevermind, forgot you'd need 177 or 197 for your bikes. I got here thru searches on freehub failures and overlooked the forum name!
  88. #88
    Quote Originally Posted by Volsung View Post
    Learn to ride a unicycle, you're pedal stroke will improve tremendously because unicycling requires even strokes to control lean.
  89. #89
    Reputation: Desert Diesel's Avatar
    Aug 2014
    Get your geek on...
    7075-(T6 Assumed) is tougher than bull balls. There's no appreciable plastic deformation but cleavage planes are visible.. The crack is clearly a brittle fracture (intergranular).
    Agreed... micro cracks + NaCl = Fail
    Why micro cracks? Improper or no stress relief plus stress concentration created by a big man. Lots of material being removed to rough out a hub. Proper stress relief is a must. NaCl helped it along but the nexus of this issue is quality assurance.
    Rules to live by...
    1. Never settle more for less.
    2. You pay what you get for.
    3. Never make the same mistake once.
  1. Changing Jobs :leaving my glorious commute:
    By GPcruiser in forum Commuting
    Last Post: 07-07-2016, 09:59 AM
  2. Today is a glorious day
    By KevinGT in forum Brake Time
    Last Post: 06-16-2015, 05:01 PM
  3. How did this happen? Thoughts, theories, glorious stories welcome
    By dbhammercycle in forum Off Camber (off topic)
    Last Post: 02-20-2015, 09:51 AM
  4. My glorious return to mountain biking!
    By Clifton J in forum Beginner's Corner
    Last Post: 10-18-2014, 10:41 AM
Members who have read this thread: 16
