Results 1 to 33 of 33
    Hope Fatsno Thru Axle Conversion?
    Does anyone know if Hope is going to come out with end caps to make my Hope Hubs compatible with the New Salsa Beargrease Thru Axle frames? I'm not opposed to getting new hubs if necessary - for a 2nd set of Beargrease wheels - but I sure do like the Hope Hubs alot.
    nvphatty
    Guest
    Quote Originally Posted by Fatty In Hamilton View Post
    Sure would be nice if they did to aid in keeping cost down.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Can you not use the pro 2 conversion kit?
    http://www.chainreactioncycles.com/hope-pro-2-conversion-kit-15mm-front/rp-prod30152?_$ja=tsid:46412|cgn:Hope+-+Hubs|cn:Chain+Reaction-UK-PLA-PLA-All-DT-SE|kw:93702UK_Hope+Pro+2+Conversion+Kit+15mm+Front &gclid=COvS7cbkorkCFTMQtAodpQ8Axw
    That would be too good to be true.... Do they make that same conversion for the rear? Has anyone tried to pop these in place of the standard QR?
    Nov 2007
    Why not ask Hope directly?
    I called there and didn't get an answer.... which is why I posted here.... figuring maybe someone had tried it......
    Do you actually have the fatsno hub, or the 170mm pro hub?
    On the HOPE site they call it the PRO 2 EVO Fatsno hub. I have 2 sets - How can you tell by looking at the hub which one it is?
    Nov 2007
    Pretty sure there's only one version. I got mine very early on and they're stamped "Pro2".
    Wrench-O-Phile
    Reputation: Elvota's Avatar
    I spoke to Hope directly and was told no conversion options were available for the Fatsno hubs. But... that was a month or two ago and with all the through-axle options on the horizon that answer may have changed.
    Just keep pedaling...
    visit the sticki chronicles
    So - an Upadate from HOPE - The rear hub can be converted to thru axle with some end caps they sell. The front hub is a NO GO - However in the next couple of months there will be a redesign of the front hub which will be convertible.....
    Sup
    Reputation: Burnt-Orange's Avatar
    Dec 2008
    my Paul hub looks impossible to change to 15mm also
    the inside bearing race is about 15mm so you would not be able to adjust the bearing preload .....
    just in case anyone was wondering
    I am slow therefore I am
    Candy is your last name right.....first name Dick?
    Reputation: ferrstein's Avatar
    I wanted to use a 10mm DT Swiss thru skewer, and someone at Hope told me the same thing. Then someone at Hope told me that what I needed was two non driveside spacers from a rear hub for the thru skewer. I called the US supplier and they sent me some.
    I wonder if those caps could be drilled and reamed for a 15mm axle? Not sure what the diameter of the tube going through the hub is though. That could be the problem.
    FWIW if you don't have a fork picked out yet the 10mm DT Swis skewer is quite nice and is a decent alternative to the 15mm axle.
    turtles make me hot
    Reputation: NYrr496's Avatar
    We popped apart a Hope Fatsno and found a steel axle pressed into the two bearings. A 15mm will not go through. A 9 or 10 will.
    I like turtles
    Hope with thru axle
    Hope Fatsno Thru Axle Conversion?-photo.jpgHere's a hope Fatsno front hub with a 10mm Hadley thru axle. Built for me by Lacemine29. Like one of the posters said, ask for two non-drive side endcaps.
    i don't give a shift
    Reputation: collideous's Avatar
    Quote Originally Posted by Burnt-Orange View Post
    my Paul hub looks impossible to change to 15mm also the inside bearing race is about 15mm so you would not be able to adjust the bearing preload .....
    Seeing the new Fatback carbon fork, I'm actually thinking of doing just that to my Big Boy. No external preload needed if you add a sleeve between the inner races of the two bearings. Done it on my home-made hubs. They held up fine through many years of use.
    blogging @29in.CH
    I bought one of those TransFat forks that comes with a new hub but wanted to use my Hope Fatsno hubs instead.
    After spending two weeks sparing with Hope in the UK (US team was clueless) they said they had built up a conversion and will be offering new QR15 Fatsno hubs sometime in November. Tried to get some early parts and they then came back and said the brake rotor offset on the old Fatsno will prevent it from working on the new fork.
    After noodling on it a bit, I sorted out how to use the axle caps, spacer, and seals from the hub that came with new the fork, with the body, seals, and bearings from my old Fatsno. That and some 5mm spacers to get the rotor offset now has me riding on my old Fatsno on the new suspension fork.
    Hope Fatsno Thru Axle Conversion?-img_2031.jpgHope Fatsno Thru Axle Conversion?-img_2030.jpg
    Certified Moots Whore...
    Reputation: Something Clever...'s Avatar
    Feb 2005
    just ordered a set of rear non-drive side pro 2 end caps for 10mm thru axle to use on my front fatsno hub. pulled off the standard qr end caps and there is a silver axle protruding from both sides. the 10mm rear non-drive side endcaps will not go into place because this axle is in the way. any suggestions? do i remove the axle? i would assume this would weaken the hub
    The axle can be removed. It supports the QR caps and is the inner bearing surface (outer bearing surface is the hub itself). I don't know how the 10mm caps interact with the Fatsno hub bearings but you can check that after taking the existing axle out. I did find out (the hard way) that the Hope Pro 2 Hub parts do not necessarily work in the Fatsno. Check the Hope website. It provides an exploded view of the hub.
    http://www.hopetech.com/webtop/modul...ntExploded.pdf
    Feb 2005
    removed the axle, but the end caps are not the right size. they just wiggle around freely and would fall out if not fixed against the fork when installed.... argh...
    turtles make me hot
    Wait... The end caps fall into the bearings??
    I thought with that inner tube pressed out the end caps for a 15 thru were too big for the bearings.
    I like turtles
    Where are you guys finding Hadley 10mm through axles for fatsno rear hubs??? They have to be for 170mm width, all I see are 135mm listed online. I got the end caps for mine from Hope and it works just fine. I am using a 10mm titanium aircraft bolt that is long enough, but it uses hex heads on each side. Does anyone make a 10mm quick release skewer long enough to go through the 170mm hub? That would be ideal.
    hope hubs do that if you don't use the circlip.
    doesn't do much of anything other than slow down popping the wheel back in in the field.
    sun ringle demon hubs don't even have the circlip!!
    If steel is real then aluminium is supercallafragiliniun!
    Feb 2005
    i am talking about the front hub, not the rear hub
    turtles make me hot
    Quote Originally Posted by Something Clever... View Post
    That's what I'm asking about.
    I like turtles
    Feb 2005
    there is no place for a circlip. i am familiar with hope pro 2 hub conversions and the fatsno is a different animal.
    i removed the qr end caps and the axle and was planning on just pushing in the 10mm end caps. problems is they are extremely loose and would literally fall out if not sandwiched between the fork leg and hub. i can't see this as being a fix.
    Feb 2005
    with the axle removed. the endcaps sit directly up against the bearings. there is nothing to hold them into place. there are no rubber o-rings or seals to press in to keep the endcaps in place.
    to NYrr496: a 15mm thru axle will not fit through the bearings.
    Feb 2005
    can you take a couple shots of the hub with wheel removed from the fork? do the end caps come out easily and are there any seals in front or behind the end caps? what seems to be holding the end caps in place? sorry for all the post. trying to get this sorted before a week long trip to the beach.
    Quote Originally Posted by NYrr496 View Post
    The Hope Evo Pro2 QR15 end caps are too big for the bearings that came in the old front Fatsno hub. I used the QR15 end caps that were in the hub that shipped with my TransFat fork. Those caps slid nicely into the ID of the Hope bearings.
    I have no idea if/how the 10mm caps can be made to work with the Fatsno.
    turtles make me hot
    If Hope doesn't make a way to fit a 15mm thru through these I think I have. I'll give them a little more time to produce something.
    I like turtles
    I talked to Hope and the "new" Fatsno hubs will be compatible with their QR15 conversion kit. They should be released anytime now. Unfortunately, they have no plans to provide a conversion for the "old style" Fatsno hubs.
    They said: "The whole fat bike craze caught them off guard and we did not apply the same standards to the original Fatsno that we do to the rest of the Pro2 product line..." this is why the current QR conversions for the regular Pro2 do not work on the old Fatsno. That won't be the case going forward. They will use the same standards.
    Send a message to this friendly Russian guy on ebay:
    anemchinov2012
    and he will machine you a 21cm long M10 rear axle at a reasonable price. Add some low-profile nuts and spacers and Hope pro II evo 10mm thru axle end caps and you are good to go with a light weight axle.
    Tony
  1. Rear Hope Pro 2 hub thru-axle conversion
    By countgrover in forum Wheels and Tires
    Last Post: 03-25-2015, 08:59 PM
  2. Replies: 3
    Last Post: 09-13-2013, 07:34 PM
  3. Replies: 5
    Last Post: 05-13-2013, 12:14 PM
  4. Hope Hub Axle Conversion
    By Atomik Carbon in forum Wheels and Tires
    Last Post: 04-26-2013, 02:51 PM
  5. Hope pro2 evo rear hub axle conversion
    By mint355 in forum Wheels and Tires
    Last Post: 06-23-2012, 08:15 AM
Members who have read this thread: 7
