Results 1 to 6 of 6
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Hope 170mm rear hub - bolt on??....
    Anyone know if the Hope rear 170mm fatsno hub is able to be bolted on instead of QR?
    Searching only show the bolt-on kits for the other hubs, no info about 170mm version.
    On that note, assuming no, what's the longest QR you can get??....I think I'll need one in the 235mm range or so, maybe longer.
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    oldmanmountain: OMM XL Rear Skewer
    sadly no listing of actual length.
    "ORANGE IS THE NEW BLACK"
    Nov 2008
    I could be wrong but I think the bolt on hubs have a difference axle than the QR or TA hubs. Which would make me think that you can't convert a fatsno to bolt on.
    Nov 2007
    From Hope's FatSno product page:
    "With the bearing change comes a new axle. The old 15mm axle is now replaced with a 17mm version. This means total compatibility with Maxle and Maxle Lite (reg) 12mm bolt through."
    Nov 2008
    I thought you were wanting this: Hope Rear Hub Bolt-On End Caps > Components > Wheel Goods > Hub Small Parts | Jenson USA Online Bike Shop. I don't think thats possible as Hope doesn't make a 170mm threaded axle.
    Now if you wanted to get a custom 170mm x 12mm through axle made, that might be possible.
    Feb 2006
    Quote Originally Posted by Sasquatch1413 View Post
    Yah, that was the idea from the link, toss on new end-caps onto the fatsno hub & bolt it onto the frame.
    If my plan works, I will need to increase a 200mm QR + 35mm in length, so I was hoping I could just bolt-on and avoid trying to source a longer skewer.
    It is still in the initial stages though, just trying to get all ducks in a row
    Thanks for the assistance guys.
  1. hadley or hope: which 170mm hub
    By dRjOn in forum Fat bikes
    Last Post: 04-29-2014, 06:36 PM
  2. 170mm Hope Hub
    By Velobike in forum Fat bikes
    Last Post: 10-23-2012, 02:15 PM
  3. Hope Pro 2 Evo SS and Thru-bolt???
    By Winky in forum Singlespeed
    Last Post: 11-17-2011, 02:04 PM
  4. Hope Pro 2 Bolt On to QR
    By Mr Pink57 in forum Wheels and Tires
    Last Post: 09-19-2011, 04:26 PM
  5. Hope 9mm tru bolt
    By mvi in forum 29er Bikes
    Last Post: 01-02-2011, 06:25 PM
