Results 1 to 8 of 8
    May 2014
    High/volume/low/pressure/frame/pump/for/fat/bikes.
    Does/any/company/produce/and/offer/a/low/pressure/high/volume/frame/type/air/pump/for/use/on/fat/bikes?..Specifically/designed/for/fat/bike/tires/and/low/pressure/..For/instance,/a/pump/that/takes/only/a/small/number/of/strokes/to/get/results...The/reason/I/ask/is/that/one/shouldn't/need/a/pump/designed/for/higher/PSI/and/dozens/of/pump/cycles/to/acheive/a/change/of/pressure/from/say,/3/PSI/to/10/PSI...A/pump/that/could/be/carried/on/a/water/bottle/holder/for/instance..A/ump/I/ould/crry/alongso/that/I/coul/easily/and/quicky/pump/back/up/after/lowering/pressure/on/a/stretch/of/snow.Fatties/are/here/to/stay..Isn't/it/about/time/for/a/fatty/frame/fit/air/pump?
    Ambassador of Chub
    Reputation: Smithhammer's Avatar
    Jul 2015
    /have/you/tried/the/search/function/and/or/looked/at/the/first/two/pages/of/this/forum/?
    "The only way we can truly control the outcome of a ride is not going on it, which is a choice I'm unwilling to make." -K.B.
    Rippin da fAt
    0.o Slash key needs removed...
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    May 2014
    Space/bar/not/working..
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    W/t/f/?
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    will rant for food
    Dear freightbike, please copy a space character anywhere from this page by using your mouse to select a single empty character, hit CTRL+C to store it, then hit CTRL+V every time you want to have a space character.
    When I was young, my dad took my keyboard to discipline me, I used the right click function of my mouse to send him a short email.
    He was so mad, and I had to work to get the entire computer back after that.
    Quote Originally Posted by Drew Diller View Post
    I lol'd
    Loves moped riders
    Aug 2013
    Even.the.period.key.makes.it.a.lot.more.readable,d on't.you.think?
    (it inserted a space before I edited to check. Wonder why?)
  1. High Volume Low Pressure Pump
    By dancing james in forum Fat bikes
    Last Post: 11-09-2015, 11:08 PM
  2. Do I need high volume floor pump?
    By drabina in forum Beginner's Corner
    Last Post: 10-31-2014, 09:13 AM
  3. High Pressure and Volume Floor Pump
    By Dictatorsaurus in forum Tooltime
    Last Post: 06-25-2013, 05:47 PM
  4. high volume/low pressure floor pump
    By thecanoe in forum Fat bikes
    Last Post: 04-08-2013, 06:10 AM
  5. Low pressure/high volume pump
    By asmallsol in forum Wheels and Tires
    Last Post: 08-07-2011, 04:38 AM
