Results 1 to 16 of 16
    HELP!!!! Losing my rear wheel??
    Looking for suggestions.
    My fatty trail bike has 10mm quick release dropouts. When I crank hard on technical uphills, the rear wheel sometime slides out of the dropouts. The quick release is pretty tight already.
    Will switching to lock-nuts help?
    Any other ideas? Surely I am not the only one with this problem.
    Formerly of Kent
    Reputation: Le Duke's Avatar
    It probably has a 10mm in back, FYI. Never heard of 9mm in the rear.
    Iíd get a DT Swiss RWS in the appropriate length and try that.
    Death from Below.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Dt swiss skewers are usually quite good.
    Quote Originally Posted by Le Duke View Post
    Learn something everyday. I thought it was just a US vs Europe naming thing & the numbers were about as factual as tire sizes.
    Does DT Swiss make an RWS skewer for 190mm hubs?
    Rhymes with fartmaster
    Quote Originally Posted by Jimi_Lee View Post
    I had that EXACT problem on my late 2014 frame 9:zero:7 singlespeed until I upgraded to the ďRacerís SpecialĒ $499.99 purple frame and fork deal 9:zero:7 had back in early 2016; thru-axle in rear made all the difference. I was racing Cat1 XC singlespeed at the time, and in two of my races I had that issue (really sucks during a race!!!). Fortunately an off-the-shelf set of 190 - 197 thru-axle adaptors (of which I had a few spares lying around) caps did the trick with my existing wheelset to work with the thru-axle frame.
    Steep-ass uphill out-of-the-saddle torquemonster climbs arenít recommended if youíre running a skewer out back. I havenít had the problem since (well, Dr. Obvious called me, strongly advised me to not take his job away from him) moving to the thru-axle frame. I really hate to offer up advice on upgrading to a thru-axle frame, but itís the only real way to ensure you wonít be experiencing the problem again.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Hope or Salsa both make QR's for fatbikes that may help (170mm or 190mm). The On-One Fatty's used to suffer from this same issue and fitting a hope skewer used to resolve the issue.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Sometimes putting a drop of oil on the locking surface of the QR allows it to be tightened enough to keep the slipping from occurring.
    --Peace
    Reputation: shaquille_o'wheel's Avatar
    Sep 2015
    quick releases are for road bikes. robert axle project will probably have a thru axle to fit your needs
    Jan 2013
    the old Borealis Yampas had the same problem. They sent out a Pauls QR as a warranty item, and it solved the problem for mine.
    Reputation: Mr Horse's Avatar
    I have Hope skewers on one of my bikes. Pricey, but nicey. Never have had any issues.
    Those RAPs or Paul's sound pretty solid too.
    I was considering an expensive skewer, but I had a spare 190mm one. The spare one had a metal cam and sliding surface. You don't want the plastic one, it distorts and releases the tension as it distorts.
    Once I had a metal skewer and a backup, I greased the cam and the sliding surface. Then I tightened the crap out of it. So much I thought I would break. So much I can't release it without a plastic tire lever for leverage.
    I carried the spare with me for a few rides because I was a little worried it would break. Two years, and plenty of rear wheel removals later it still doesn't slip.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I like turtles
    May 2010
    These are the ones to get. Salsa ones are garbage.
    turtles make me hot
    I have Paul's skewers on one of my fat bikes and on the rear wheel of my folding commuter bike. Made a huge difference on the folding bike.
    I like turtles
    Apr 2018
    Have you run into any shops or solutions for converting a Yampa to TA?
    Sep 2013
    Quote Originally Posted by NYrr496 View Post
    I have a Paul Skewer on one of my fat bikes and it holds better than the Salsa by far!
  1. What does losing 1 lb of wheel weight feel like?
    By JackieTreehorn8 in forum Wheels and Tires
    Last Post: 02-01-2017, 07:42 PM
  2. New wheel build losing tension
    By Alias530 in forum Wheels and Tires
    Last Post: 03-27-2015, 07:47 AM
  3. Another tension losing wheel
    By jackovo_joe in forum Wheels and Tires
    Last Post: 02-12-2013, 01:40 AM
  4. Rear tire losing traction on climbs
    By delvermedic in forum Beginner's Corner
    Last Post: 01-29-2012, 09:07 PM
  5. rear shock losing air really quick? 2009 FSR xc
    By shogiPIRATE in forum Specialized
    Last Post: 03-07-2011, 02:07 PM
Members who have read this thread: 91
