Results 1 to 6 of 6
    help building my fat (non-offset) front end
    I'm trying to build a non-offset front end for my winter bike. I know its not true fat but its what I'm able to do right now. I'm trying to find an economical 100mm hub/fat front and a fork that will accommodate. It seems like Pugsley forks are still unavailable since the recall? Any thoughts are appreciated. Thanks
    nothing to see here
    Reputation: Stevob's Avatar
    Why 100mm?
    I see hills.
    I want to climb them.
    I'd like to be able to swap my front wheel back and forth and don't see a need to go 135mm. is there a reason to go 135 that I'm not seeing?
    Reputation: Velobike's Avatar
    Quote Originally Posted by teleguy03 View Post
    ...is there a reason to go 135 that I'm not seeing?
    No. I reckon 100mm is better because the shorter the hub, the stiffer it is. The 100mm hubs are lighter and cheaper too.
    Latitude: 5736' Highlands, Scotland
    Any thoughts on where to track one down?
    Afraid not, but why not do this? DIY Fat Bike fork from junk.
    It's how I started. You don't have as much clearance* as a proper fat fork, but it gets you rolling, and it's a cheap start.
    It worked perfectly with no issues.
    If you want more clearance, find an old downhhill fork - their stanchions were wider spaced.
  1. Offset wheel building help...
    By Weinerts in forum Fat bikes
    Last Post: 09-28-2013, 08:50 AM
  2. Best cheap 135mm front hub for Vicious GFS Offset
    By GFisher2001 in forum Fat bikes
    Last Post: 06-17-2012, 06:47 PM
  3. Replies: 14
    Last Post: 04-24-2012, 07:01 AM
  4. Replies: 3
    Last Post: 09-12-2011, 07:51 AM
  5. Building a Tranny, front DR
    By older and slower in forum Ibis
    Last Post: 05-08-2011, 07:18 AM
