Results 1 to 37 of 37
    Reputation: TahoeBC's Avatar
    Hauck-Bicycles Hub Spacers Converts 135 to 150mm includes offset disc brake mount
    Just came across this, spacers and a disk brake mount offset for Hope Hubs, so you can switch your 135 spaced hub to 150 for a Bluto fork.
    Hauck-Bicycles Hub Spacers ? Converts 135 to 150mm | FAT-BIKE.COM
    Bluto Fork Spacers for Hope 135mm to 150mm WITH offset brake adapter. ? Hauck Bicycles
    Looks like they have a Salsa Adapter also
    Salsa Adapters for Bluto Fork — Hauck Bicycles
    Reputation: winkster's Avatar
    Mar 2012
    I am using their spacers for Hope hubs. The fit is perfect and very easy to setup. Using the Hauck spacers saved me $100's and I can easily go back to the carbon fork if I want to, doubtful though.
    Good to hear, I just ordered a set
    aka bOb
    Reputation: bdundee's Avatar
    Quote Originally Posted by winkster View Post
    I am using their spacers for Hope hubs. The fit is perfect and very easy to setup. Going the Hauck route saved me $100's and I can easily go back to the carbon fork if I want to, doubtful though.
    Not really the Hauck route but I'm super stoked they are marketing it and it's working for people and it's not just sitting idle. Now if I could only get them to give me a black set.
    Edit: Hell I would be happy with a "Hey bOb thanks for giving us the idea"
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Should have patented that idea
    Quote Originally Posted by bdundee View Post
    aka bOb
    Quote Originally Posted by Shark View Post
    Prolly not going to be worth the time, not enough cash to make it worth it. I would rather just have my over sized ego stroked a little bit.
    Feb 2012
    Bob, was noted on Facebook that there is plans for black ones.
    Hopefully not too long of a wait.
    Bob thanks for getting the ball rolling on this for sure, you have my utmost gratitude! sure hope black is available, cause I ordered mine in black!
    Know the feeling...been there with Mickey Dee's
    Maybe we should...?
    Did kind of wonder if there was a connection. Seemed all too obvious.
    I'll be...no contact us link...no phone, except for their dealer in the same CO. town...
    Now if they can just make some for my two Hope 170 rear wheels so I can run them in all these damned 190 spaced bikes. The list of Bluto-compatible 170 rear spaced frames is pretty short.
    Quote Originally Posted by deuxdiesel View Post
    Yes working that problem now. Salsa frames, On One frames and the old spacing 907 frames. Anyone can add on to this list I would appreciate it.
    I got my spacers, just took a couple days for them to arrive, seemed to be well made, have yet to buy a Bluto though so I have not tried them out yet.
    aka bOb
    Looks good but a little warning not all calipers have enough adjustment you might have to dremmel the holes on the adapter some.
    Sep 2012
    Fatback 135 and 170 hub adaptors would sell like hot cakes in Alaska.
    I should have taken a photo of the brake adapter from another angle, it has a slotted shaped hole for added back and forth adjustment, but thanks for the tip in case there is not enough.
    I'd like to see one for a Borealis hub, I'd buy one of those also, this will be for my 29+ wheelset.
    aka bOb
    Quote Originally Posted by TahoeBC View Post
    Cool they did it for ya!! Oh and it's not hard to take your Borealis adapters into a local machine shop and have some made but in 7.5mm longer.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I need a caliper adapter for a 200mm rotor. 180 won't stop my big ass.
    I like turtles
    Yep ^^ I'm currently using 200mm rotors, so either gonna switch to 180 for summer riding with the Bluto, or see if I can add some washers or something to get it to work with my 200.
    Dec 2013
    Does anyone know exactly which hubs these work with?
    I believe I want this one in "front disk spacing"
    Hope Pro 2 Evo Fatsno Front Fat Bike Hub - 135mm Spacing
    And would this be the appropriate salsa hub?
    Salsa Front Conversion Hub 2 135/142mm Black
    Finally got around to getting a Bluto, the new end caps could not have been easier to install, pull out old ones, put in new ones, took all of 10 seconds. I used 10mm of washers in order to keep using my 200mm Rotor as the brake adapter they provide is for a 180mm rotor. Just got back from a ride and dam the fun level has been turned up to 11!
    Oct 2013
    So, how do we get a set outside of the US? OS postage isn't that difficult...
    turtles make me hot
    TahoeBC, how's the 29+ clearance in that Bluto? Looks good.
    I like turtles
    Plenty of room, here is a better photo
    For sure on the suggestion to get a set of these made for Fatback 135's. Lots of those bikes out there from the past 5 years. If you can get them for the Fatback Hadley hub, I'm all over if.
    turtles make me hot
    Thanks.
    I like turtles
    aka bOb
    Quote Originally Posted by RickyB View Post
    It's really not rocket science. If you have removable caps just tame them off, take them to a machine shop and tell them to make 2 just like em only 7.5mm longer. I think my set cost me 25 clams.
    I do not see them on his website yet, but if you ask nice he might spin some up for you, working perfectly!
    super old thread, i know, but I'm desperate
    anyone know where i can still buy these for a borealis?! tried their facebook, eBay, website. no dice. any help would be GREATLY appreciated
    Intense Carbine C
    Intense Spider 29 C
    Ventana El Comandante
    Borealis Yampa
    9:Zero:7 Al
    Soma Wolverine
    Surly LHT
    Rippin da fAt
    I saw a losing for a spacer set a while back, but yeah I looked up Hauck a month or so back and found nothing and tried calling the number on the facefvck page to no avail. There is a company making fly fishing reels and such that was associated with Hauck but they parted ways, seemingly on less than good terms. So worst case is a hub and relace is on your horizon.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Quote Originally Posted by lifeis11 View Post
    The last I've heard is that if you contact Borealis, they will set you up with a new hub.
    just spoke to them - no dice. full boat on a new hub from them if i want to go that way.
    they were hip to the fact that some folks had been machining endcaps, but nothing they have ever carried or could point me to.
    *sigh*
    the search continues.
    Intense Carbine C
    Intense Spider 29 C
    Borealis Yampa
    9:Zero:7 Al
    Soma Wolverine
    Surly LHT
    Quote Originally Posted by BansheeRune View Post
    yeah they seem to have totally vanished. what a shame. cant imagine im the only one out there who wants to do this...
    Intense Carbine C
    Intense Spider 29 C
    Borealis Yampa
    9:Zero:7 Al
    Soma Wolverine
    Surly LHT
    wouldn't spacing the rotor out in the traditional way make more sense than using an offset brake mount?
    yeah, and i would probably go that route
    its the hub spacers im after
    Intense Carbine C
    Intense Spider 29 C
    Borealis Yampa
    9:Zero:7 Al
    Soma Wolverine
    Surly LHT
    Do you have a dimensioned drawing? I have a lathe.
    aka bOb
    Any machine shop can make em.
  1. Replies: 5
    Last Post: 08-26-2013, 11:51 AM
  2. Replies: 3
    Last Post: 02-05-2013, 08:59 AM
  3. Post mount brake spacers - Where to find?
    By tmoffett in forum Brake Time
    Last Post: 07-17-2012, 09:08 AM
  4. Hydrolic Disc Brake Piston offset?
    By Mattlikestobike in forum Beginner's Corner
    Last Post: 09-26-2011, 04:53 PM
  5. FS: CODA 150mm 4 bolt brake disc
    By jam36a in forum Cannondale
    Last Post: 04-28-2011, 10:41 AM
