Results 1 to 38 of 38
Thread: Half Fat
    Reputation: drofluf's Avatar
    Dec 2010
    Half Fat
    Firstly is it OK to ask about 'Half Fat' on here?
    I'm considering putting a fat front end on my Swift.
    Was planning to use the rigid fork on a 26" wheel and I think I can fit a 3" tyre in there.
    Is 3" fat enough?
    Will that combination affect the handling too much?
    Or should I get a dedicated fork? If so any recomendations?
    If you need me I'll be at the bar
    Feb 2005
    To quote whoever it was back in the days of MTV (Billy Idol perhaps?)
    Your too much is never enough.
    Is 3" enough? No, not for this crowd.
    Go fat, even if only on half, it'll be okay. And yes,get a proper fork to do it the right way.
    Then get ready to ask yourself, why didn't I do this sooner
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Reputation: Velobike's Avatar
    Don't waste your money on a 3" tyre unless you have one lying around. The volume of a 3" is much less than that of a proper fat tyre of around 4". If you look at the area of the cross section you'll see why.
    Tyre 3" =1.5x1.5x ∏ = 2.25x∏
    Tyre 4" = 2x2x∏ = 4x∏
    ie the 4" tyre cross section is 77% larger than the 3"
    If you calculate the volume of the toroid, you'll have an even bigger difference.
    You may be able to squeeze a fat tyre into your Swift fork if you use a narrow rim. A Black Floyd on a 40mm rim is 82mm, and a Larry slightly more, so if you can get hold of a rim that size you may be able to fit in to your existing fork.
    The best option?
    Buy a Pugsley 100mm fork.
    Build a wheel with a 80mm rim obtainable from Classic Cycle in Germany (only 50) and you'll need a 36 hole hub.
    Don't waste money on a rim strip - too heavy - duct tape does the job.
    All this will sell easily on eBay if you don't like it
    Then you've got the front end of your fat bike sorted. A few rides and you'll be ordering a frame too.
    Shame Singular don't do a fatty.
    Edit: Volume of a torus (ie tyre)
    Latitude: 5736' Highlands, Scotland
    Dec 2010
    Thanks, a little maths has convinced me to do it properly! Better start saving those pennies.
    I could fit a 4" tyre into the fork, but if I inflated it the wheel wouldn't turn!
    I've got the parts on the way to put a Fat Front on my SS 29er. I went for a fork and wheel. The idea is to go half fat now as an interim solution until I have the scratch for a full fat. All the parts will transfer to a future build.
    So far this winter I've been riding a lot with my fat bike buddies. I can usually ride about 80% of what they can on my 29er. The parts that usually suck the worst are the loose downhill sections where my skinny front digs in and/or washes out. I expect the fat front will help a lot there. It won't help for climbing (obviously) and will probably only marginally improve overall float.
    I'll report back once I've got the parts and battle tested the setup for a few weeks.
    Dec 2011
    Quote Originally Posted by BobShort View Post
    Which tire do you plan on using?
    Witty McWitterson
    Reputation: ~martini~'s Avatar
    Half fat Swift you say?
    <a href="http://www.flickr.com/photos/48107563@N00/6141803911/" title="DSC_6286 by unclefuzzy_ss, on Flickr"><img src="http://farm7.staticflickr.com/6165/6141803911_d54f1b90e9_b.jpg" width="1024" height="685" alt="DSC_6286"></a>
    As you have already surmised, going all the way fat is a much better way to go. If you're on a Gen I Swift, an Enabler fork[what I'm using] steepens the head angle to 73*. Yes. You read that right. You can feel it as you ride, but not to the degree you'd think. The big ass tire that you're mounting up does a fantastic job of slowing it all down again, so you still end up with a nice riding, sharper cornering mountain bike.
    Just a regular guy.
    Quote Originally Posted by Northender View Post
    BFL on a Darryl rim. The BFL on the 80mm rim will be closer in diameter to my 29er rear tire.
    I got bored and had an extra 26" Maverick wheel kicking around so I took my Trek 69er SS and fattened it up. Added a 2.4" Maxxis Ardent to the rear, that's the most it will take, and it's great in the mud and hard pack frozen dirt we've got in the Northeast. Don't know how it will do in the snow, but we'll see. Clearance around the fork isn't an issue, but then again it was an AM rim, not a fat rim.
    http://www.shutterfly.com/lightbox/v...fd7207a7b1fe91
    Forgot to mention that it's a Husker DU, here's a close up looking straight at it. It's measuring pretty close to 90mm wide on the AM rim at 15 psi. I rode it around 10 psi, and it never rubbed at all. I think a 50mm rim would be perfect.
    Dec 2005
    Here is my half fat. Works better than I thought it would.
    Jan 2009
    Since we are talking about Half Fats, here is mine I converted today (2007 29'er Spec rockhopper disc comp).....lack of snow in MinneSNOWta.....still need to cut steer tube and it will be done.
    does a pair of gazzis in a full carbon frame and fork qualify as half-fat, or all-chubby or just plain "pissin'off the locals"??
    not sure where to post my bike right now....
    If steel is real then aluminium is supercallafragiliniun!
    Reputation: BikeShopMonkey's Avatar
    pug front, spiked 29er back SS. a winning combo
    so my afro now sticks out of my helmet.
    Reputation: atom29's Avatar
    Feb 2010
    OMG is that an Edge rim on an Access frame?
    Reputation: trumpus's Avatar
    These pics have got my blood pumpin'! I really want to build up a Misfit DiSSent as a fat front/half fat 1X9 or 1x10. My wife is going to kill me!
    Reputation: Tripower's Avatar
    Jan 2011
    I love the half-fats
    And the full fats.
    I've been getting in a lot of winter riding this year. For the most part my SS 29er has been getting the job done, but I won't lie, I have the itch for a fatty. I decided to throw on a fat front on my bike for the rest of this season, with the intention of moving it to a full fat next year.
    I've been out for a few rides and am getting a feel for the new setup. This is my impression so far.
    The handling is a bit odd due to the shorter fork and slightly smaller wheel. The head angle ends up being somewhere around 73 deg. The big wheel slows the handling down, but there are some auto-steer quirks that took a little getting used to. If I was going half fat long term a longer fork (e.g. Enabler) would have been a better option, but I went with a moonlander fork because it fits better with my future build plans. Overall the bike does feel different, but once I got used to it it was okay.
    Going uphill the fat front doesn't help much. Obviously. It helps a little keeping the front end planted and tracking straight, but that is about it.
    Going downhill the difference is night and day. Sections I was digging in or washing out are now point and shoot. All smiles! Definitely bomber in comparison to the skinny front.
    On the level the front does help steamroll and brake trail for the rear. And perhaps the best benefit is it helps a lot with stability and control. Situations that used to require finesse are now much easier.
    Overall I like it! And I'm looking forward to a fully for next season!
    Quote Originally Posted by Tripower View Post
    And the full fats.
    Tripower, what's the rim on the back of both Jones bikes? Is the same rim on both bikes?
    Jan 2011
    The Ti Jones rear rim is a 47mm KH.
    The Steel Jones rear rim is a P-35.
    Reputation: NOBBY605's Avatar
    Velocity P35 rear. 2.4 Racing Ralph
    Rolling Darryl drilled front. Larry
    My Swift was built with a half-fat option in mind.
    I built it with Enabler forks and a 135mm non-fat front wheel now ... ready for a fat-front to just drop in as required.
    That hasn't happened yet tho' - in part as the Swift is still being finished off, but mostly as I think I'll go straight to full fat now anyway ...
    Reputation: the locust's Avatar
    Jan 2005
    so curiously enough this bike island frame happens to be designed around a 450mm AC fork, Rare nowadays. I had a bunch of parts in the parts bins including a lovely white Pugsly fork so i decided to drop a couple hundred on the frame and build up a half fat SS bike. The rear wheel is a WTB i19 Tubeless rim laced to a x7 hub, the front wheel is actually off my pugs for the moment but im going to build up a sweet fat front wheel with a marge lite rim and maybe a husker du tire. inital impressions are this thing is gonna be a blast but ive got to get it out for some more rides soon. (like 20 min from now)
    Jan 2009
    my cousin liked how I converted mine, so we went to the bike swap and got a great deal on an offset pug fork ($20)!
    before:
    after:
    mine and my cousins:
    Human Test Subject
    Reputation: Volsung's Avatar
    half fat
    Am I doing this right?
    Quote Originally Posted by Volsung View Post
    Perfect...
    It aint gonna ride itself
    Reputation: MauricioB's Avatar
    Oct 2007
    Photoshop fake
    May 2010
    Moonlander drag racing!
    Feb 2012
    Personlally, I really like the skinny up front and fat in back set up. The other way seems kind of backwards to me. I like having more traction and weight on the back and not up front. Ofcourse all fat is better...
    Human Test Subject
    Here's another view. GF messed up her foot so I haven't had a chance to test ride it yet.
    It's a 700 x 28 so the diameter is a lot smaller than a BFL.
    Feb 2010
    Please please please be a joke.
    Did I catch a niner+?
    Been enjoying this for a couple weeks, has done great in the snow much better on tracking in the loose slushy stuff.
    Moderator Moderator
    Reputation: AshevilleMTB's Avatar
    Oct 2014
    How much would it cost to convert to a half fat?
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by AshevilleMtBiker View Post
    With all the people converting to suspension forks, you can probably find a used steel fat fork and wheel fairly cheap....
    Lord Thunderbottom
    Reputation: TitanofChaos's Avatar
    half fat = full regret
    did it, just ended up costing me more money than buying a fatbike complete from the start
    Today I will do what others won't, so tomorrow I can do what others can't
    Moderator Moderator
    Oct 2014
    Quote Originally Posted by TitanofChaos View Post
    10-4
    Mar 2012
    Blew the rear hub out on the way to the trails last week, so I HAD to go half fat. Borrowed my buddy's 29er rear wheel to get me through the ride. The wheel was all the way over to the drive side, but surprisingly did well. A lot lighter in the back then my regular fat wheel.
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Looking at my parts bin I had. Enter project barbike. Kind of polishing a turd but this is more like Coprolite.
    ptarmigan hardcore
  1. cook bros stem
    By ckevlar in forum Vintage, Retro, Classic
    Last Post: 02-21-2006, 11:17 AM
  2. Fat rider, fat arse, fat saddle
    By GrumpySmurf in forum Beginner's Corner
    Last Post: 02-17-2006, 08:00 PM
  3. Tour de Fat!! in Boise August 27th
    By smilycook in forum Idaho, Montana, Wyoming
    Last Post: 08-16-2005, 07:31 AM
  4. Fat Chance year model help
    By Mojo Troll in forum Vintage, Retro, Classic
    Last Post: 06-04-2004, 05:37 PM
  5. Fat burners = higher LT?
    By amex420 in forum XC Racing and Training
    Last Post: 06-02-2004, 03:05 PM
