anyone any thoughts on this for a high quality 170mm hub?
im not sure about I9 internals at present...which unfortunately makes me not sure about the paul hub...
what im looking for: easy servicing, durability solid engagement. ideally the cassette body should be removable with minimal tools.
what i dont care about: degrees of rotation before engagement, weight, colour, and in some regards initial cost.
ta muchly.
I have the Hope FatSno and the Hadley Fatback 170mm rear hubs. This is the first Hadley hub and the fifth(?) rear Hope hub I've owned.
I've been riding mostly the Hope. It works very well, as I expected. It's 130 grams lighter and can be had for less than half the price of the Hadley. Guess which I'd get again?
If you want a black rear Hope 170mm, I have a brand new/unbuilt one (and appropriate skewer) sitting in the basement with your name on it which I can send to Sean
dRj0n: I'd say don't overlook the Paul Comp Paul Components Rhub 170mm rear hub with I9 driver. Best of both worlds (Paul Components quality and I9 engagement + I9 Quality) in a 170 setup: Paul Component Engineering - Disk RHUB 170
The hubs are pretty easy to service with minimal tools and both company's provide excellent service in my experience. The engagement IS worth the consideration in my opinion.
dRj0n: I'd say neither now that Paul Comp came out swinging with their Rhub 170. Check out the Paul Components Rhub 170mm rear hub with I9 driver. Best of both worlds (Paul Components quality and I9 engagement + I9 Quality) in a 170 setup: Paul Component Engineering - Disk RHUB 170
I agree completely, however the price point is a make or break deal for some.
@nvphatty: I completely understand where you are coming from. Price is a stumbling block on this one for many. It is worth it IMO if you save your lunch money. I am impressed. So much so all of my wheelsets have been switched to I9 (classic hubs, not their proprietary setup). The engagement in tech is a game changer for me and I was really happy to see Paul and I9 come through with this collaboration.
My complaint with the Hopes are the amount of noise they make, and the front hub is rear brake spaced.
My complaint with the Hadleys are the weight, and price.
I packed mine with a med weight grease (pedro's) around the inside of the hub shell, it brought the noise down to a very acceptable level. Ive since put close to 1000 miles on my fat bike & still more quiet than stock, & no issues with performance.
I did the same on my wife's bike that also runs hope hubs, & now she says the are "too quiet" & wants the clicking back....lol....
(initially she complained that they were too loud!)....can't win.
"No one's interested in something you didn't do."
FREE BEER! (tomorrow)
If you grease the pawls of a Hope hub it runs quieter than the recommended Oil lube...
If you have a problem with a Hope product despite its age an email to them usually gets a reply saying `send it to us and we will look into it`
A few weeks later you recieve a replaced part or repaired part and if you ask they invite you for a factory tour with riding time on Hope spec Orange bikes and a goody bag to take home afterwards...
You're lucky... I'm one of many people who have leaky diaphragms on my Tech levers... Hope refused to help me at all on 3 separate e-mails.
[/QUOTE]
Really? 130 grams difference in the rear hub? That's huge. Hadley used to be considered light hubs. What are the actual weights of both?
I have 2 sets of Hadleys and one 170mm rear hub. They all work great and are easily rebuildable with all parts and tools available and it's literally a Mom and Pop store in the USofA, which is nice to support when you can.
But they are expensive and 130grams is..a.. huge. That's well over 1/4 lb for you metricly challenged individuals.
No it never stops hurting, but if you keep at it you can go faster.
I considered Paul hubs for my new wheels build but the flange spacing from disk mount was a bit off putting considering the price. Im kinda understanding what they are trying to achieve with a equally dished wheel but surely there has to be some strength loss in not moving that flange out to the disk mount.
3rd set of Hopes on the way..... maybe next time.
If you want to do a really light weight build, do Paul WHUB front, Hope rear. Hope front hub is quite a bit heavier then the WHUB. In the end, color choice pulled me away from Paul hubs.
> It is important to note that the Disk WHUB is designed for front disk rotor spacing. There are several 135mm forks on the market like the Salsa Enabler and Surly Pugsley fork that accept rear wheels with rear disk rotor spacing. These forks will not work with the Disk WHUB.
Since I use Hadley, I run Hadley. Tools, bearings, parts are all the same, so why not! Plus they are made local(america), designed even more local(Alaska), and proven to work where I need them to(below -20).
