Results 1 to 24 of 24
Thread: Groove 200
    Groove 200
    Guys,
    I can't find a lot of techo stuff on the WB Groove 200's. I'm try-ing to find out if the 29'er set is simply a 26'er set with a spacer in them or a completely different animal.
    Anyone know?
    Cheers,
    Al.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by alanm View Post
    Guys,
    Anyone know?
    Cheers,
    Al.
    You don't need to internally limit the travel to use a 29" or fat wheel/tire combo.
    In other words, they work with big/tall wheels right out of the box--no mods necessary.
    Probably the most maintenance free damper on the market today, too.
    Oct 2011
    so will this fork work with a fat tire?
    Reputation: Velobike's Avatar
    Just checked the owners manual. No more info there either. Looks like it needs disassembly every 30-40 hours for servicing, so I'm not a suitable prospect for ownership - my idea of maintenance is oiling the chain whenever I can't remember when I last did it...
    Latitude: 5736' Highlands, Scotland
    Oct 2011
    just did a little reading and it says you can't have a neck over 5 1/2" so i'm out
    Well guys, that's 3 against and 1, sorry Boys, but Mikesee and I are gonna wind up at the front of the pack....... I just bought 2 new Groove 200 forks
    I'll report in when they're fitted. TBH, the purchase may be a bit premature as 1 set is for the Longtail I'm building and it's still in pieces at the LBS waiting to get bits brazed on!!!
    Al
    Well guys, that's 3 against and 1, sorry Boys, but Mikesee and I are gonna wind up at the front of the pack....... I just bought 2 new Groove 200 forks...
    I love it when someone else does the testing on the expensive bits.
    Let us know the clearances when you get them. There's not much choice in bouncy fat forks at the moment.
    Aug 2003
    My maintenance "schedule" for suspension products is to ride them til they begin to fail (that can manifest itself in many different ways) then take appropriate action.
    I rode my Groove 200 for two seasons of (mostly) lift-served DH and never did a single thing to it. My main DH riding partner is on his third season and he does less "maintenance" than I do.
    There may be a more maintenance free fork on the market, but I've never heard of it. Just a bonus that these can be modded to get anywhere from ~140 to 200mm of travel, as well as fit fatties on reasonable rims.
    WB also had a crown/axle set that would allow a 120mm spaced hub to be used with the Groove 180/200--thus giving an extra 10mm of clearance 'tween the pipes. I had two of these, but have since sold them off. I'm sure a call to WB could get you a line on another...
    MC
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    Quote Originally Posted by mikesee View Post
    MC
    We might have some 120mm spaced crowns. If anyone is interested, call us.
    Edit: We have three sets. There is 4.5" of room between the legs with this setup. Your choice of a Groove 200 or a Groove 180 (180 can easily be spaced down in travel if desired).
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Quote Originally Posted by NoahColorado View Post
    Are you going to make any more of the wider crowns in the future?
    Guys, Sounds like we've all been trained at the same maintenance school......
    Re the wider crown; would have been nice but I have mine now. (well, they're on the way)
    Velo, I'll let you know how it works out, via a thread on here.
    Al
    I email'd them the other day, they said w/ a 65mm rim & reg. fat bike tire (Endo, Larry, etc.) there was approx. 5mm left to split for clearance. They didn't tell me about the wider crowns so I'm assuming that's w/ the standard issue. 2.5mm between the tube & tire is not enough for me. Especially for the investment. Unless they're going to make the wider crowns available to the public, a used Mav or MCS's Lefty set-up look like the best choices for now.
    Sounds like the wider crowns are available to the public- see post #9.
    There's also the Risse Trixxxy:
    Risse Racing - Downhill Mountain Bike Forks
    I have no experience with them, but they are similar, dimension-wise, to the Groove.
    GUIDANCE COUNSELOR
    Quote Originally Posted by ward View Post
    Well if I were a betting man I'd guess we've had these three sets of crowns for quite awhile, so until we don't have any left - I don't think we'll be making more.
    NOAH SEARS
    MRP - Brand Manager
    Quote Originally Posted by Andy FitzGibbon View Post
    Only 3 sets though (of the wider crowns). I was wondering if they planned on producing them as a regular option. Sounds like they had a few made up for a special purpose and have a few left over. They certainly didn't mention them in they're email.
    The German Answer "Wide Flame" may very well make it to this side of the pond someday as well. The model used on the Sandman is a wider-than-stock Flame too, if I'm understanding what I've read right... and currently only available on the Sandman. It's an interesting fork. I thought I read somewhere that the version for fat bikes was symmetrical- air & oil in both sides... kind of cool- if one side failed, the other side might get you home. Might help flex wise compared to the Mav too.
    Just hoping some susp. co. gets something going that fit's the fat stuff. I'd like to see a traditional (non-inverted) fork for 135mm spacing w/ reg. drop outs (would have to have a big 'ol brace too)... might be useful w/ 29ers too. Would also have more clearance at the DT than inverted and lighter than the double crown ops.
    Edit: Oops, missed your answer there N. Colorado G.C. Thanks for the reply. Looks like the Groove might be more fork than needed for allot of fat bike uses anyhow.
    -Cheers!
    Hey NoahColarado, Did you get my PM?
    Al.
    Sandman might sell you one, if you inquire- I'm not sure if they're keeping all of the available forks for their complete builds or if they will sell them separately. You are correct that they are a special wider-than-stock model. As I recall they do use a low-pressure air spring in each leg.
    GUIDANCE COUNSELOR
    We produced 120mm spaced forks when that seemed like the direction the DH market was going, only later did we change the spacing to 110mm. So the crowns we have left over were from the DH 2.0/3.0 days, before we called that line of the forks the "Groove". We have a 10mm spacer you can install on the axle for 110mm hubs in this application, you have to dish your wheel accordingly.
    We weren't trying to deceive anyone, not are these "special" parts, they're simply leftover, NOS.
    Cheers
    NOAH SEARS
    MRP - Brand Manager
    We run a Groove 200 on a Sandman Outback tandem. It's downtuned to something like 130 mm travel. Works like a charm, zilch problems paired to a 70mm rim and 3.8 tire. A 4.8 BFL on the same rim fits "just".
    But I'd never put it on a solo bike not meant for downhill... it's huge and a heavy bugger...
    not FAT free
    Reputation: RFX big foot's Avatar
    Mar 2011
    here is what can be done :
    2002 Turner RFX
    7 " travel front & rear
    80mm rims
    50 lbs
    my best bike ever
    it's not finished yet, some cosmetics needs to be done and paint ... black paint !
    bike was built April 2011 and i rode it 85 % of my mtb time and I just couldn't decide when to take it apart and finish project, i like this ride a lot !
    i know i'm going to hear ... who need 7" travel and 50 lbs !!! ...but its hard to believe how well it handles all obstacles, log overs, and rock gardens and JUMPS until You try it
    BTW it's 3 X 9
    Attached Thumbnails Attached Thumbnails Groove 200-turner-rfx-big-foot-091.jpg
    Reputation: bighit's Avatar
    That's some next level stuff right there, fat DH!
    I got to get moving on this.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    More info required....
    Guys,
    Anyone know if the Groove 200 steerer tube is a press fit or threaded fit?
    And I can't seem to get into the parts section on the WB site to purchase some hubs for it.
    Can someone else have a peek to see if they can get in? TIA
    Al
    Guys,
    Al
    It's a press fit in the lower T and a clamp fit in the upper T
    caminoloco,
    Thanks Mate.
    Al
