Results 1 to 31 of 31
    Reputation: danaco's Avatar
    Grip Stud Group Buy
    I will put together a group buy, needs to be minimum of 1000 studs. I will purchase 300.
    I would ship by USPS small flat rate box cost, divided cost of stud shipping from manufacturer and PayPal fee if money is not gifted.
    will rant for food
    For anyone leery of doing this, there is some decent demand for these sometimes. I organized a successful group buy in the past, I think there have been two buys so far? Can't remember. I have enough on hand so I'm out this one. They're expensive but they last and they are easier than other DIY studding techniques.
    Reputation: x3speed's Avatar
    Price per hundred?
    Nov 2007
    Grip studs are to much money
    crown point socket screws...$5 per box!
    Where do you get those?
    Nov 2007
    Justsockets.com
    Reputation: TRAIL CRANKER's Avatar
    I would think you would gorilla glue them in ? They would likely come out easier because of the finer thread to hold them in the knobbies??
    13 On One Fatty
    08 YETI 575 BLK. C.King Hubs/Hadley
    96 Specialized Stump Jumper FS Tweaked
    Couldnt work the link
    Sep 2012
    Group buy price?
    And what qty is needed for bud/Lou ?
    Loser
    Reputation: Jisch's Avatar
    I bought and was charged for $20 worth of those from justsockets.com a month or so ago. I never got the product and I can't get them to respond to email or phone calls. Buyer beware, it was only $20 so I'm not spending a lot of time trying to recover the cash I guess.
    Sent from my HTC6500LVW using Tapatalk
    Feb 2013
    I'm interested in 100 but I think I need the $11.95 manual install tool (4000-M). It wouldn't make sense to buy the tool and pay shipping through grip studs separately.
    Can the group buy include purchasing the 4000-M and paying the extra amount for it, or is installation without it easy? The power tool bit would also be OK if we needed to buy in some type of "bulk".
    I assume a check is the preferred payment method.
    I'm going to experiment with rock riding. It was over 80 degrees here today so there isn't any ice.
    2012 Moonlander, Bud&Lou, 780 mm bars
    Quote Originally Posted by easterntide View Post
    Group buy price?
    They are 75 cents each, thats a 25% discount plus a bit of shipping. Yes, they are expensive but nothing will come even close to their durability and bite, they go in easy and they don't come out, rarely anyway as long as they have good depth like Bud and Lou tire lugs to thread into.
    I would recommend no less than 100 per tire, 150 per would be optimal. They weigh 65 grams per 100.
    Set screws will not stay in and sheet metal screws have big heads. The whole point of true tire ice studs is they are tungsten carbide pins that are significantly harder than any screw you might use. The pins are very thin allowing them to easily penetrate ice given the overall weight of you and the bike. Sheet metal screws have large heads and don't bite very well and once you hit the pavement or rocks, they wear quickly and get smooth. Grip studs have a fairly large screw body with deep sharp threads and a flat base so they hold in well and resist puncturing the inner casing of the tire unlike screws. Screws are fine for motos, different animals all together in application.
    If you're interested let me know and I'll get a list going. You won't be disappointed !
    Quote Originally Posted by streetNslime View Post
    Yes, the install tool should be used for best results, I agree. Let me know which one, the are two, one is a screw driver style the other has a hex that can go in a drill, not recommended or put that one in your own hand tool.
    So payment, PayPal is easiest but at a cost of nearly 3% or you can gift it and there's no charge. Checks are sort of OK, you know what I mean ! Would rather not but probably will. I can take CC's but that is 3% added too.
    move on up...
    Reputation: Forged1's Avatar
    Dec 2011
    Count me in for 200 #1000 studs and the #4000 install tool. Thanx Danaco
    Jan 2014
    Reputation: Way2ManyBikes's Avatar
    Grip Stud Group Buy
    Deleted
    Marty
    12 JamisDakar650B
    14 FarleyBlue,Bluto,i9-Hed,4.JumboJims
    14 FarleyBlack,Jackalope
    17 Farley 9.6 Under Construction
    Reputation: campykid's Avatar
    Count me in for 300 studs and #4000 install tool.
    So if I'm counting right here, looks like 900 so far.
    Dec 2008
    I'm good for 150, and a #4000 tool. Thanks!
    Sep 2012
    250 and the 4000tool here as well. Thanks for organizing this!
    OK we've got enough now for an order, I will inquire with Grip Stud on Monday and get it organized.
    Jan 2014
    I have been lurking on here for a while because I liked what I have been learning. Tonight I saw about the group buy and registered so I could say I would like to get either 125 or 100 studs along with the hand tool. I can pay with paypal if that is easiest for you. I was not sure what you meant by gifting? If it meant calling the payment a gift then that would be OK with me. If you already have your number Owell. And thanks for taking the effort to put it together.
    Ted
    Quote Originally Posted by Seakers View Post
    Ted
    Ted
    I need to keep the order to denominations of 100, I've got two here that want a quantity that ends in 50, that makes 100 so that's OK.
    PayPal charges the seller 2.9% unless that money is stated as a gift. That means I am not charged the fee if "gifted"
    So I'll take all orders as long as the total number come out to a number that can be divided by 100. I won't order until next week sometime. Need to get everyone sorted out and confirm the order with Grip Stud.
    200 studs plus #4000 install tool for me. Will PP as gift when ready
    Thanks for setting this up
    Reputation: temporoad's Avatar
    Quote Originally Posted by x3speed View Post
    Try this company the have everything McMaster-Carr They are available in stainless steel.
    BBB (big beautiful bike)
    dumb ass
    Reputation: mtnbykr©™'s Avatar
    Quote Originally Posted by Retep View Post
Name:	Cone point socket screws.jpg
    wanna explain how you made these work??
    Baby seal walks into a club.
    Bearer of bad news for Grip Stud group buy.
    I called today, Grip Stud will not offer more than 10% discount anymore. The last group buy apparently got a 20% discount I just found out, that was about two years ago when Colin worked there, his replacement, Sharlee will not go more than 10%. I apologize, I should have inquired with them first, I assumed we could get a similar deal again. I believe one group buy was 25% discount, that was what I was going by.
    If someone else wants to take over from here an pursue this further, go for it, for myself I'm going to bow out, sorry.
    Thanks for the interest and again, I apologize, didn't mean to be misleading.
    Jan 2014
    Quote Originally Posted by danaco View Post
    Ted
    Ok I would like to order 150 if it works with someone else or 100 if not. That is a slight change from above. And the #4000 tool for power tool. I will PP gifted when you sort it out.
    Thanks Ted
    Thanks Ted
    Please read my thread above.
    Jan 2014
    Sorry, For some reason your thread was not there when I made my post. I am out but thanks for putting the effort to it.
    Dec 2008
    Yeah, Thanks for trying Danaco. Another time perhaps....
  1. Replies: 19
    Last Post: 03-20-2018, 06:26 AM
  2. Grip Studs group buy part II, winter 2012/2013
    By Drew Diller in forum Fat bikes
    Last Post: 01-08-2013, 08:17 PM
  3. Stud it yourself?
    By fotooutdoors in forum Fat bikes
    Last Post: 12-15-2012, 01:11 PM
  4. Replies: 4
    Last Post: 09-20-2012, 10:54 AM
  5. best grip platform pedal to use with power grip straps.
    By package81 in forum General Discussion
    Last Post: 09-11-2011, 10:58 AM
