Page 1 of 4 1234 LastLast
Results 1 to 100 of 341
    Hooligan
    Reputation: dirtdawg21892's Avatar
    Gravity Quigley: Full suspension fat bike
    Alright, my bike should be arriving today, and as promised im starting a new thread so that we don't have to deal with the 8 pages of garbage that the original one turned into. the point of this thread is to be informative and unbiased in order to help others decide if this bike is something that they may be interested in.
    I will post pictures as soon as the bike gets here.
    Quote Originally Posted by Optimus View Post
    Hell of a jump, dawg. Even though they're baggy shorts, I'm surprised that you can fit your balls into them.
    Feb 2007
    Hope UPS comes through for you. Looking forward to the report.
    It's all good!
    Reputation: blown240's Avatar
    If you could please post the weight of the bike, and any parts that you happen to have off of it.
    Hooligan
    Its in!
    Came with x9 Rd and guide brakes. I'm more than happy.
    Putting it together now
    Reputation: WSUPolar's Avatar
    Sep 2014
    Sweet
    MacGyver is my spirit animal
    -Until proven wrong, assume you are the weak link in any system-
    19 minutes and still no ride video. Sheesh
    Hooligan
    Assembled.
    No shortage of grease either.
    Pedal through the Pain
    Gravity Quigley: Full suspension fat bike-quigley.jpgI picked mine up this morning right when UPS opened their doors. I put it together completely stock, weight for the size Large is 38.9lbs. Upgrading shall commence.
    Edit: Wow, this picture is really crappy. I will try and post better pics as I upgrade.
    Thats a lot lighter than I thought it would be! Probably could get it to 35 relatively easily.
    Reputation: watts888's Avatar
    Oct 2012
    Curious how this guy goes. I have one of the FSX bikes that use the same general design. The main bushing has developed a litle play and I really have to clamp the rear axle down tight otherwise I get a whole lot of flex in the rear triangle. I'm waiting for motob to put one out with a 4-link design or one with a larger rear triangle. I think the short rear triangle design lends itself to a litle bit of twist when riding.
    The Sram guide brakes were a pleasant surprise. The only things I weighed so far were the saddle/post= 734g, front wheel/tire=8lb 3oz, and pedals=423g. Parts swapping is happening now. Replacement saddle/post (Phenom/RaceFace) =519g, Shimano M520 pedals= 420g. Weight savings so far =218g. More to come!
    Its interesting that this bike is only 1.3 pounds heavier than a Bullseye Monster Pro hard tail.
    Does it look like it will take a bigger tire in the rear than a 4.0?
    Hooligan
    After riding it around a bit Its definitely got some flex and a bit of a Bob problem in the 22t ring. The high pivot is much less noticeable in the 36 because the chain tension is much more in line with the swingarm.
    Overall though it's a solid bike.
    It doesn't have a whole lot of suspension travel, but it certainly takes the edge off.
    Next to the normal fat
    I'm also less worried about this now that I've seen it in person
    Looks beefy enough to hold up.
    I already have a new hub waiting to be laced up, and a 26t ring on order. I will be looking for a nubby stem and some wider bars, but other than those I think it's going to be a great trailbike.
    Hooligan
    Quote Originally Posted by blown240 View Post
    Yeah, I think it will. I will take a shot of the tire in the swingarm but it looked like it had some space.
    Thanks for the pics. How much travel do you think it has?
    Also, can you please measure the BB height and the distance from the BB to the axle?
    Any chance you could post the size of the shock?
    I have a backup bike with a 6.5 x 1.5 upgraded Monarch (the 3 setting one) that looks about the same size.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by dirtdawg21892 View Post
    Looks like rear tire clearance will be determined by the travel of the rear wheel. Better check clearance with the shock fully compressed, too.
    I have a feeling this bike will eat rear hub bearings.
    Quote Originally Posted by Harold View Post
    Why is that? Honest question, not starting anything...
    since 4/10/2009
    Quote Originally Posted by watts888 View Post
    A similar design non-fat bike is stated to have a flexy rear end, specifically at the axle. One owner agrees that the bike has some flex. In some discussions I had with I9 staff earlier this year, hub flex on fatbikes is a real issue. I strongly feel like hub flex is why so many people report trashed bearings on the rear ends of their fatbikes. AND, thru-axles are documented to stiffen things up as compared to QR skewers.
    So, given that the bike is already stated to be flexy and given what I know and suspect already, I think this bike will eat rear hub bearings.
    Makes sense. Thanks
    Reputation: MUSTCLIME's Avatar
    Loose the front derailer, get a 42 tooth rear cog and run a 26 or 30 in the front...like I said in the first thread on these, the pivot is way high. This thing was never going to be anything but a inch worm machine. A clutch rear derailer would not be a bad idea ether, the chain is going to be all over the place with the big wheel base changes.
    I would also think about pulling the pivot apart and check to see if it needs lube.
    The bike is never to heavy, you are just to WEAK!
    Hooligan
    Quote Originally Posted by tyrion View Post
    Says 152x31
    Hooligan
    Not much unfortunately. I'm not really sure how to measure that, but I would ballpark it around 80. It's good for taking the edge off though, makes landing a much nicer experience.
    Hooligan
    Quote Originally Posted by MUSTCLIME View Post
    I have a 26 on the way, and if it rides well enough I will stick with it. Otherwise I may suck it up and get a dinner plate for the rear and a bigger front. Honestly the 30t is tempting, but I'm not sure I like the chain angle from the 104 position. I think there will be too much sideload on the larger cogs.
    Apr 2015
    Right on Dirtdawg! I was happy to see you had already started a review/write up on your Gravity Quigley FS. I enjoyed your in depth and on going review of your Gravity Bullseye Monster. I hope that you are able to put as much time & effort into keeping us informed with your new Quigley and you're able to log as many trouble free miles as you did on your Monster!
    I ordered a Quigley Yesterday in Orange!
    Floor to center of BB = 330mm (13in)
    Axle to BB measured centered = 452mm (almost 18in)
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Typically, that design is a little flexier due to the elevated seat stays and suspension "mast" above the single pivot, it allows the rear triangle to act as a giant lever and the only thing in the way is the shock, which is poor at dealing with lateral loads. This sometimes means more frequent shock rebuilds and is the number one reason Foes used a non-rate changing scissor linkage for many years on their single pivot bikes, but now they vary the rate as well. A thru axle won't make a ton of difference here IME, but it is what it is, a simple bike design.
    Just use the spacers on the bearing cups to to adjust your chain line, looks like you have plenty of room between the crank arms and the swing arm.
    Hooligan
    So after 20 miles of tech I'm still not sure how I feel about it. If you can keep it in the big ring it pedals fine, but the 22t is completely useless. I need to install a bash, but I'm still not sure what I want to do for rings.
    That's a tough one.
    What about swapping in a different rear shock? One that has a lockout, or at least propedal.
    Hooligan
    So after one real ride (real meaning that I'm actually putting power down) all the paint has been worn off one side of the ring.
    The other is fine. This is a good indication of too much side load.
    Hooligan
    Oops.
    Sep 2014
    Uh oh.. how many miles?
    Wow! How did that happen?
    So here is the question... Return or replace?
    Almost looks like that tune isn't strong enough to take the twist from the rear end.
    Loser
    Reputation: Jisch's Avatar
    dang.
    Oh no, this really has me worried. Details, man, details! I haven't had a chance to hit the trails on mine yet and by the looks of that, I am not sure I even want to. Please tell us you took it off some kind of insane drop. Come Monday, I am going to get on it hard and see if I can replicate that same breakage to determine if it is definitely a frame issue. Good lord what have we done.
    Apr 2015
    This isn't good on any bike, but this is really bad on a 2 day old bike!
    Hope it was a bad weld under that power coat and not a design flaw.
    But this could be the reason for the uneven chain ring wear. (If there's some good out of this)
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Yikes that didn't take long.
    Reputation: blowery's Avatar
    Aug 2014
    WOW! thats a bad deal there.
    Hooligan
    No insane drops. This was just aggressive trail riding. Personally I'm going for a refund, if it gave out on me that quick its just a matter of time until it did it again. Its a bummer, because I really liked it under certain conditions.
    Hooligan
    I don't think that this will be the norm. I'm rough on my stuff, and have a tendency to find the weak point on frames.
    They should probably just hire me as a product tester.
    Apr 2015
    I fully understand your decision, but hoped that wasn't the route you were going to go.
    Have you contacted BD already? Could they have just sent you a new swing arm? Heck maybe they should send a new swing arm with your refund and ask if you'd please continue to R&D it for a year!
    Feb 2007
    Um, I would be going for the refund, too.
    It's all good!
    Jul 2014
    Doesn't surprise me at all. I have replaced hundreds of dollars in failures on my Boris X9 and I only have like 150 miles on it. Now that some decent bikes are coming out in 27.5+ full sussy I'm going that route.
    Feb 2007
    Cody01 what all have you replaced? My X7 only has about 15 miles in it and I am hoping I don't have the same issues.
    It's all good!
    Feb 2007
    oops. Wrong thread.
    It's all good!
    Hooligan
    Quote Originally Posted by Cody01 View Post
    Yeah, what could possibly go wrong with an x9? It's all name brand stuff except for the frame (which is the same as a 4 season)
    maybe the hub?
    Reputation: Shock_Hazzard's Avatar
    Feb 2015
    Yes, yes you do. As long as I've known you, you've broken a frame a year.
    One is all I need.
    They call me 'Captain Coaster Brake'.
    Carfree and riding 16,000 miles/year.
    Apr 2015
    Quote Originally Posted by Shock_Hazzard View Post
    Well this comment makes me feel a little better! Haha!
    Kinda nervous right about now, but will wait and see as I didn't get the free shipping option.
    Feb 2006
    Pick better lines?
    bigger than you.
    Reputation: Gigantic's Avatar
    Oops.
    I was JRA...
    Reputation: OddTrickStar's Avatar
    Aug 2014
    That's not a weak point in that first pic. That is bad welding. Total fail.
    Looks like it broke right at the edge of the weld, which is the weakest part.
    Quote Originally Posted by OddTrickStar View Post
    As crash investigators, we usually have to send metal out to a lab to determine that. Impressive.
    The non fatty version of that frame doesn't hold up under hard riding either.Get a refund and wait for the motobecane full fatty.
    Feb 2014
    I'm not a crash investigator, but doesn't the second picture indicate that the tube has cracked. So it seems that the weld might be OK, the section of tube below the weld has probably stuck with the weld and it is the tube that cracked under load.
    That's probably worse than the weld cracking - the tube is under designed for the load which applies to all of these bikes, rather than an isolated bad weld which might be down to bad workmanship. It is probably just a matter of time and loading before most of these frame crack (unless there was some random fault in that particular piece of tube).
    Anyway, I'll leave further analysis to the experts.
    Aug 2014
    As crash investigators, we usually have to send metal out to a lap to determine that. Impressive.
    I looked at it wrong. Ignore me.
    Hooligan
    Quote Originally Posted by whichway View Post
    That's what I was thinking. I don't want to be a bearer of bad news, but that's why I wanted a refund and not a replacement.
    But like I said, I'm looking for a bike that I can ride hard. This will probably hold up to the average user.
    Reputation: schnee's Avatar
    Cracks that start at the edge of a bad weld can propagate strangely.
    Not saying you're wrong, just saying you're not necessarily right.
    Disclosure: I built a frame at Yamaguchi, and he spent a bunch of time showing us how bad brazes affected tubes, and it's similar enough to welding - areas of tubing change their structure after the heat gets applied because of their alloy properties - that I feel comfortable saying that much.
    Reputation: theMISSIONARY's Avatar
    well the welds dont look real flash to start with...it could be that and or poor heat treatment or lack there off
    Oct 2012
    when you weld, the surrounding metal in the base material (ie. the tube) is weakened. Commonly called a bad weld, but in reality it's bad heat treatment, welding technique, and post welding heat treatment. End of the day, it's all about the welding procedure. Not saying the tube thickness is too thin for the purpose (I personally think it should be thicker since it's for a fat bike with severe torque), but in this instance, it's all about the weld. I'd still wait to see if motobecane puts out a 4-link.
    Hooligan
    Anybody else get one of these and have better luck than me?
    First trail ride this morning on the Quigley. My initial set up sucked, so I didnít get to ride as hard as I wanted. The Bluto was bottoming out and my tires felt like they were rolling off the rims. I still put in about 10 miles of good riding. I agree with Dirtdawg, the 22t chainring is useless, while the 36 was really good. Of course there was noticeable bob on the climbs, but I found it tolerable. The one thing that does bother me is the bobbing on heavy acceleration. The bike also feels really tall, maybe due to the height of the stem. Surprisingly, I didnít have any pedal strikes. Once I got home, I checked the air in the Bluto and it was less than 90psi, I had set it up at 135psi. Rear shock was good. Tire pressure showed 9psi, but I donít trust my gauges so I now have them at 15psi. I also removed the spacers under the stem to get a better feel. I actually liked the Vee8s and will be putting them on my Bullseye Monster while the Quigley is getting the Fat B Nimbles. So far, I have only been able to shave a 1lb off the weight. The stock stem was actually lighter than my Raceface and the stock bars were only 36g heavier. Overall, I really liked the way the bike felt on the downhills, now I just hope the frame will stay alive. Going for another hard ride this afternoon and see how it goes.
    There is a guy on RatRodBikes that got one. He seems happy with it, but I doubt he rides as hard as you do.
    Oct 2012
    With the suspension, do you really need the lower pressures? I'd think that with dry dirt, you could go up to 10-12 psi and not loose much traction.
  67. #67
    /\ /\ /\ /\ Agreed , plus it won't feel like your tires will roll off.
    Body weight makes a HUGE difference too. I'm 240 without gear, and 12-15 psi is as low as I go anytime in not in snow.
  68. #68
    Apr 2014
    Do let us know if you find a fatbike that can be!
  69. #69
    Hooligan
    Quote Originally Posted by OfficerFriendly View Post
    Well, my bullseye monster has stood up to 2000 fairly abusive miles and has been perfect.
    As for suspended fatbikes, I made the mistake of riding a foes mutz yesterday. I never want to ride any of my bikes again.
  70. #70
    I have been coveting the Mutz myself. Only problem is the cost!
  71. #71
    Sigh...their small standover is 30 inches....to tall for me.
  72. #72
    Hooligan
    true that. even if i sold all my bikes, my car, a kidney and gave hand jibbers on the side i would barely be able to afford a frame.
  73. #73
    Frames are $2500 I think. Plus a bluto, plus everything else. And you wouldnt want to hang crap from such a great base. I get it would be roughly $6k to do it right.
  74. #74
    Hooligan
    ok, good news.
    as expected, BD pulled through and offered a refund or replacement. i emailed them saturday and had the reply by 1:00 PM monday. they really take customer service seriously. every experience ive had with them has been awesome, and i have several other bikes from them that are all great. i would not hesitate to buy from them again, but i think i will be sticking with hardtail frames from now on. i would try a 4bar setup, but in general suspension linkages require a lot more R&D and engineering than what went into this one.
  75. #75
    ok, good news.
    That's good news, but I was really hoping BD would do this: 1) fully refund you 2) send you a new swingarm 3 ) let you keep the bike and product test it for a year. Their costs would be limited and their feedback would be tremendous. Imagine a weekly report on various terrains to demonstrate where the Quigley shines and where it doesn't, its strengths and weaknesses, likes and dislikes, and areas for future improvements. Bikes Direct, I hope you are reading this.
  76. #76
    Hooligan
    Quote Originally Posted by dmars3571 View Post
    I liked this idea the first time you brouht it up and i like it even more now. i'm not sure how to suggest that without coming off like a total d-bag though. they probably wouldn't appreciate receiving an email from a customer suggesting that they both give them the money back and let them keep the bike.
    however you're totally right in that i would ride it and give a thorough review, meaning more publicity to them.
    in the two times i road it I have already answered a lot of questions and had a couple people very interested in getting them themselves.
    the bike would be much more useful to them being reviewed than sitting broken in a box somewhere. (i cant imagine they would do anything with it. even if they discarded the frame they can't sell used parts, right?)
  77. #77
    Aug 2014
    I liked this idea the first time you brouht it up and i like it even more now. i'm not sure how to suggest that without coming off like a total d-bag though. they probably wouldn't appreciate receiving an email from a customer suggesting that they both give me my money back and let me keep the bike.
    however you're totally right in that i would ride it and give a thorough review, meaning good publicity to them.
    Actually they will probably replace the swing arm and sell it on Bike Island at a discount. :-)
  78. #78
    Hooligan
    Quote Originally Posted by Destr0 View Post
    hmm, good to know.
    i thought that BI was mostly scratch and dent/blems. i didnt realize that they sold used bikes on there.
  79. #79
    Oct 2012
    bikeisland sells used bikes on there, but not because they want to. It's primarily returned bikes they don't sell in their shop, bikes damaged in shipping that they can't sell any other way, or someone lied to bikesdirect when they said they didn't use it, but they did.
    They do carry some spare parts on the bikeisland website, but I don't think I've ever seen the swingarms sold individually. If you are serious about using the bike, ask them if they can order a replacement swingarm. If they can, then bring up the possibility of doing further testing. If you end up breaking swingarm after swingarm, they'll want to know about it.
  80. #80
    Hooligan
    they said that they would gladly replace the bike or issue me a refund. they probably dont have swingarms kicking around and therefor would rather just send me another complete that's sitting in the warehouse.
    either way a lot has changed in the 5 months since i ordered it and i need the money more than i need a bike that may or may not break on me again. that being said, i would still gladly test it for them.
  81. #81
    ok, good news.
    The motobecanes do get plenty of R&D and engineering time.That will be a much better bike.IMO The Quigley is really just a recreational bike.
  82. #82
    Refund. That's not a one off failed weld, that's a failed design.
    Just spend the money on a good FS fat frame or stick with a rigid.
    Oops.
  83. #83
    Loves moped riders
    Aug 2013
    maybe the hub?
    I can't speak for Cody, but IME with an x7 the freehub sounded like a train out of the box, and occasionally a chunk inside it locks it or makes it skip a tooth. The GOX crankset came with bolts for the granny ring that were too short, coupled with the fact the bosses weren't threaded all the way to the face, and only had 3-4mm of thread engaged--not to mention the fact that the BB was ticking--after fifty miles. I had a little interchange with a rep, and decided I would just fix the crap--my fault I bought it and believed it might be anything but crap.
    I just hope the frame stays solid--looks like a cosmetic second, but alignment is OK.
    The geo is nice as well.
    Sucks to see broken frames though, at least with the component fails there are easy options.
    Whoa, hold on there, someone will have to break a front triangle first.
  84. #84
    Apr 2015
    Quote Originally Posted by Nurse Ben View Post
    Just because one of the first bikes delivered and the swing arm has failed doesn't automatically make a "failed design"! Its a bad deal this one broke!
    Mine arrives on Friday and I may be singing a different tune next week!
    Not everyone has the coin for a ~"proven" FS fatty design!
    If the Quigley works out for others then it'll be a plus.
    Gravity bikes are not equal to many name brand bikes in more
    ways than one! (I think everyone knows this!) But it appears they are standing behind their product in this case and offering a refund or fix at customers choice.
  85. #85
    Hooligan
    Quote Originally Posted by mxer View Post
    Certaintly not by the people selling them. Obviously sombody designed it, but Its all just open mold stuff with stickers on it.
  86. #86
    Hooligan
    It's not spec'd like a recreational bike. You don't buy 4 pot calipers, a 120mm bluto and an x9 RD for recreational riding.
    Maybe they could pair this thing with x5 stuff, some novelas to stop it, and one of those suspension forks you can get for $100 from alibaba. It could sell for like $700 and be a decent entery level FS
  87. #87
    beer thief
    Reputation: radair's Avatar
    Dec 2002
    Maybe someone should define recreational. Many people doing lift-served downhilling are just recreational riding, unless they're pros in training. Recreational riding certainly includes freeriding, hucking, all-mountain, enduro riding and aggressive XC. But the Quig would not be a logical choice for most of these.
  88. #88
    Let's be honest folks, this was a questionable design to begin with, then the first one out of the box has a cracked swing arm in less than a week.
    Anyone who buys a full suspension fat bike is going to want to ride it on rough terrain, otherwise what's the point of having full suspension.
    Good luck with your bike.
    I'd recommend sticking with a rigid unless you have the cash to buy a quality FS frame.
    Quote Originally Posted by Back-to-Doo View Post
  89. #89
    bigger than you.
    is it too early to say "I told you so"?
  90. #90
    I don't think anyone was expecting a Mutz or a Bucksaw, I'll admit that I was surprised that the frame failed structurally.
    It's a shame for sure, I like the brand as a less expensive way to get riding and test the waters; I got a Lurch for that very reason.
    The swing arm would probably survive if it was steel. Maybe the next frame will have a lower pivot or even a multilink design.
    My Mutz frame, shock, and fork cost double the complete price for the Quigley, so not really accessible to all.
    Quote Originally Posted by Gigantic View Post
  91. #91
    Aug 2014
    They put out a bike with bad suspension design that is known for brake jack/pedal bob. If you are going to go single pivot at least make it a much lower pivot.
    So far reports are massive bob in low ring (almost useless) limited travel
    2nd busted swingarm in 2 days with wear patterns showing side loads
    Thats not really a good start. Are there any other reviews on this? I applaud them to try and make one more accessible to people, but whats the point if the design (geometry) sucks and it's potentially not very reliable?
  92. #92
    Feb 2014
    This is funny to me.
    A guys bucksaw cracks, and it's okay cause sh*t happens.
    This guy's Quigley cracks, and it's because BD has sh*tty R&D or none at all, and because duh, it's a Gravity.
    Not saying the two are equal in any way, just that the response to both are very different.
  93. #93
    Hooligan
    Quote Originally Posted by Shinkers View Post
    this is true, and in general i'm very much a sh!t happens kind of guy, and always willing to give a second chance. the only reason i reacted differently to this is because we were all a bit skeptical of the design to begin with. the fact that it broke the second time that i road it just confirmed my concern that they tried to jump on the FS bandwagon before they had worked the kinks out of the design.
  94. #94
    I think I'd be even more angry about a Bucksaw failure if it was mine.
    I suppose anything can break, so maybe the Quigley is not as "big a deal" since we all sorta had low expectations to start. I was rooting for the underdog
    Knock on wood, but I haven't had bad luck with bikes, I have not broken a frame, fork, or swing arm. My bad luck is with hubs (muni and bike/tandem), so I get the beefiest ones I can afford.
    I rode a Lurch for a while to "explore my options", I got a Mutz coming, so if it breaks (I can't imagine it) I will be peeved. I plan to ride my Mutz big, all the time, no holding back, it's my monster truck
    My only regret is that I just got a DeVinci Atlas, which I really like, but I have a feeling the Mutz will end up being my daily driver.
    I still gotta rub my head in wonderment that BD didn't produce a frame with a more proven design, they have the technology and access to designs, so why not do it right to start?
  95. #95
    Aug 2014
    Part of the problem with the response here is this is the first Quigley to get a review and it cracked. There are quite a few Bucksaws in the wild and only one failure that we are aware of. Now if the other Gravity bikes do not share the same fate then it is a fluke - right now the jury is still out on that one.
  96. #96
    I will keep giving my reviews as time goes on. So far I have 3 hard rides. I am 210lbs and my riding style is mostly aggressive XC. Most of the terrain I ride consists of rough, eroded, rooty downhills where I can huck at most 1-2ft drops, a few small jumps where you only travel about 12-15 feet, lots of berms, several ditch crossings that one can bunny hop over, and a couple of log crossings. When I was doing Strava, I held a few KOM's on this stuff, so I would like to think I am putting a good beating on the Quigley. No signs of frame breakage as of yet. To compensate for the bobbing, I have ordered a 26t small ring and a 40t Hope cog for the cassette in hopes of being able to keep it in the 36t up front more. 20psi in the tires seems to be just right for me until I lose a few pounds off my gut. The only side to side flexing I am experiencing is on the really fast, twisty, tight trails but I feel the same thing on my Spec Camber. At this point, with only 4 rides in, I am loving it. The Quig is a heavy pig though, but holy cow, it is fun to ride. I just hope that swingarm keeps holding up.
  97. #97
    Quote Originally Posted by benlowery View Post
    I have not heard the news of a 2nd busted swingarm. Was the breakage similar to Dirtdawgs?
  98. #98
    Quote Originally Posted by radair View Post
    Ok recreational as in rail trails.Better now?
  99. #99
    That is probably how the should sell it imo.Like i said i have seen the non fat version of this frame fail too.
  100. #100
    since 4/10/2009
    holy crap 20psi off road? I top out around 15 for pavement on my Bucksaw.
    And FWIW, I've put my BS through some tough miles. After this weekend, I've passed 300 on the bike so far. The early miles were mostly non-technical, but with lots of sloppy weather. Wet, cold, ice, mud. Lately it's been dry and I've been beating on it. Just spent the weekend in Pisgah and Dupont State Forest. Took the Avery Creek Trail downhill and the top mile is just nasty. BS didn't complain. As I got lower, I got faster, and I was able to hit some of the chunk at speed. No complaints. Dupont was even faster, with some chunk there, also. A couple of times I took some seriously stupid lines. Still the BS didn't complain.
    This is, I think, the key difference between the BS, the Mutz, the Turner (not so many Khan reviews here yet - are the owners out riding them too much to post?), and the Quigley. These other bikes are getting ridden no less hard. It took quite some time before a problem showed up on a BS frame. For the Quigley, it was almost immediately. Doesn't bode well. To be fair, I tried searching for other cracked Quigleys, and I only found this one. Was this one a fluke? Since nobody has hundreds of miles on one yet, it's impossible to say. It will take time and lots more miles with no problems before we can say this one is not a pervasive problem. But again, it doesn't bode well. FS fat does well ridden aggressively. It's kinda the point.
  1. Gravity FSX 2.0 Full Suspension Mountain Bikes
    By Falkster109 in forum Beginner's Corner
    Last Post: 05-12-2014, 06:09 AM
  2. Best Full suspension Bike for $2,000
    By BrokenCobra in forum All Mountain
    Last Post: 07-18-2013, 10:58 AM
  3. Replies: 57
    Last Post: 07-09-2013, 02:22 PM
  4. Which full suspension bike would be the best?
    By TorturedSoul in forum Bike and Frame discussion
    Last Post: 06-03-2012, 09:59 PM
Members who have read this thread: 9
