Page 23 of 24 FirstFirst ... 13192021222324 LastLast
Results 2,201 to 2,300 of 2304
  1. #2201
    Reputation: Luis_fx35's Avatar
    Aug 2015
    Will do, thank you 😊
  2. #2202
    Aug 2015
    I just overhauled my rear hub and the cones are damaged. Does anyone know what size cones should I get for a 9 ball bearing rear hub? I found a few on eBay but all have different sizes. Have anyone tried replacing the cones with shimano? The rear hub brand is Quando, it is written on the rubber seal by the disk brake mount.
  3. #2203
    Reputation: watts888's Avatar
    Oct 2012
    metric mountain bike cones are pretty universal. and the cost to get them at a bike shop is pretty cheap. I'd rather spend the extra $2 to make sure I get the right ones than guess. The axle diameter is easy, 10mm diameter x 1.0 thread pitch. Not all cones will have the same length though and spacers/washers may be needed.
    Amazon has a $8 mountain bike axle 10x1.0 with spacers, cone nuts and lock nuts. It should give you all the parts you need to fix it up right.
    "a hundred travel books isn't worth one real trip"
  4. #2204
    Aug 2015
    Quote Originally Posted by watts888 View Post
    Thank you
  5. #2205
    Aug 2015
    Which headset did you get? I thought I got the same origin 8 that you got but fork still hits frame. What size frame is your bike?
  6. #2206
    Aug 2015
    Quote Originally Posted by littlereddog View Post
    So, I have an RST Renegade on my GBEM with a 1 1/8 straight head tube with no clearance problems.The Renegade does not hit the downtube. The way I solved the problem was changing the bottom cup on the headset. I bought the origin8 pro 1 1/8 threadless headset off of Amazon for about $30. The bottom cup of the headset is significantly bigger on the origin8 than the stock bottom cup. I didn't bother changing the top cup, because there is no need to. Anyway, I thought I would give it a try. I'm using the crown race that came with the origin8 headset. I didn't have to buy one of the extended crown races off of eBay. The stock one works fine. Here are some pictures of the fork on the bike showing clearance in both directions. Love the fork. Works way better than the cheap Chinese fork discussed above.
    Which headset did you get? I thought I got the same origin 8 pro thredless headset with the sealed bearings that you got but My RST Renegade still hits the downtube . What size frame is your bike?
    Btw, How is your renegade working so far? My brother and I have the straight steerer Renegade and it is a good Suspension fork. My only complaint about this fork is that the lockout assembly under the compression knob is not tightened enough from factory. When it is very cold the lockout knob will seize and if you unlock the suspension the whole lockout knob plus the lower assembly will come loose and it will make you believe that the whole lockout assembly is not working. I overhauled the Renegade last weekend thanks to some OCR videos on YouTube. I decided to tighten the lockout assembly a bit more so it won't unscrew from the fork when the lockout knob seizes and turns the whole assembly insted of just the lockout knob. I also decided to remove the rebound hex key, The rebound adjuster is just a hex key with the blue knob. I don't want to loose the knob.
  7. #2207
    Jan 2016
    Quote Originally Posted by Luis_fx35 View Post
    This one:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    22 inch.
    Renegade is working awesome. I'm not having any of the issues you describe. That being said, I don't often lock it out and I don't use it in super cold weather.
  8. #2208
    Aug 2015
    This one:
    22 inch.
    Dude, that's the same headset I got. Did you use the whole headset with the crown race and everything? I don't know what happened, I installed the bigger cup on the bottom of the headtube and the smaller cup on top and both crown races the black one on the bottom of the steerer tube and the red one on top. The amazon link shows two sizes. 1-1/8 and 1".
  9. #2209
    Jan 2016
    I only installed the bottom cup and the matching bearing. I used the crown race from the headset. I thought you ordered the extended crown race from ebay. Maybe it is because mine is a 22" frame
  10. #2210
    Jan 2016
    Luna Suspension Fork
    https://lunacycle.com/luna-lander-fat-suspension-fork/
    Installed it and tried it out. Haven't done a full ride yet (hopefully tomorrow) but here is a preliminary ride report.
    The crown is smaller than say the RST Renegade. It will be a close (but not impossible) fit with a 100 mm stock rim. I put 100mm rim on it and there is some clearance, but I doubt the rim with as 5 inch tire would fit very well. That's OK, I prefer my 50mm rims anyway. Because the crown is smaller, it will likely work with the older straight downtube bikes. It works with my Gravity Bullseye Monster, but keep in mind, I have the 22 inch GBM and a new bottom cup on the headset that provides a little more clearance. That being said, I wouldn't be surprised if it will work stock on other GBMs of other sizes. There is a fair amount of clearance.
    It feels a lot like the RST Renegade in both weight and quality. Maybe a little lighter than the Renegade. Seems to have pretty good shock absorption. Works way better than the cheap Chinese spring only fork (I have one of those as well). I'm a novice at best, when it comes to fork set-up and pickiness, I just need something to take the bumps out of the horse hoof prints in the ground, so I can't comment on precise rebound and dampening settings, but it will work for some bumpy trails.
    I installed the remote lock-out. You need to loosen the set screw to get the cable in there. Also the cable sheath is pretty loose at both the fork end and button end. I added an endcap to each and it works fine now. You are going to have to remove your grip, shifter, and brake to install the button on the handlebar.
    The steerer tube is shorter than the Renegade. But, it will fit on my 22 inch GBM with one medium sized spacer. So, it should fit almost any bike.
    I don't have a star fangled nut tool, so I messed that up a little. You may want to have your LBS install that for you if you are particular.
    It has a warning sticker saying not to use it for downhill and hard core riding. I think that's just the lawyers. It seems to be similar build quality to the Renegade. I can't see the internal seals and what not, but I can't imagine they would make it unsuitable for similar types of riding.
    Seems to be a fair amount of oil coming out of the stanchions. I'll have to keep an eye on it and see how it looks after a couple of rides.
    In conclusion, I traded my Renegade off of my GBM for this, and I suspect it will stay that way. My Vinson (my loaner bike) will get the Renegade.
    Hopefully this will inspire a real expert to buy the fork and try it out with a better review than this one. But for me, it's a keeper.
    [update] It doesn't like the cold. Get it to around 35 F and it basically won't move. It becomes just a heavy fixed fork. Otherwise, I love it. Works great.
  11. #2211
    Aug 2015
    Pictures would be amazing. Some day 😁
  12. #2212
    Jan 2016
    Pictures
    Pictures would be amazing. Some day 
    OK, here you go. 50mm rim, 3 inch tire Gravity Bullseye Monster-20170505_224950.jpg 50mm rim 4 inch tireGravity Bullseye Monster-20170505_230954.jpg100mm rim, 5 inch tire (not inflated)Gravity Bullseye Monster-20170505_231415.jpgClearance to downtube on one sideGravity Bullseye Monster-20170505_231427.jpgclearance to downtube on other sideGravity Bullseye Monster-20170505_231444.jpglockout trigger and releaseGravity Bullseye Monster-20170505_231452.jpgNote that unlike the Renegade, you can only fully lock-out or have full suspension. No partial lock-outs.
  13. #2213
    Aug 2015
    Thanks for the pictures dude. Looks like a good air fork and quick release also. Lots of savings for all non-thru axle riders. Btw, I learned how to service the Renegades, applied new "slick honey" and fork fluid. Super smooth and silent rides after 6 months of ownership.
  14. #2214
    May 2016
    Tire rub??? where did this come from?
    I have had my GBEM for about a year now and have had no problems with it that I can speak of.
    No major wrecks and I'm not particularly hard on it either.
    After about a year of owning it I decided to treat myself a bit and just picked up a set of 4.0 Jumbo Jim light skins. and put them on tonight.
    Installation went easier than I thought it would.
    Deflated the tires, pulled out the tire levers to unseat one side (almost didn't need it)
    Pulled out the tubes and then removed the tires from the rim.
    Inspected the rims and rim tape (back tires rim tape was a little off center but not bad)
    And put the new tires on in the reverse order.
    I slowly inflated the tires making sure the rims were centered in the tires and there was no bulges in the sidewall.
    I went ahead and inflated them up to around 22psi (because my family was planning on going on a paved bike trail tomorrow morning and I figured why not get a little more efficiency from the higher psi)
    Put the wheels back on the bike, and took it for a spin.
    "What was that?" I thought as I put the pedal down a little.
    I was getting a slight tire rub on the chainstay.
    I took the wheel off and re-seated it in the dropouts and took a closer look.
    When not under load the knobs on the tire just barely clear the driveline chainstay. the stay on the other (break) side has plenty of clearance.
    When my butt is in the saddle coasting straight everything is ok.
    When swerving back and forth occasionally I hear the knobs rub.
    When putting the power down the knobs rub against the chainstay especially with my right foot.
    I have never noticed a problem before now, the side knobs on the JumboJims are noticeably bigger than the Mission Commands so I may not have noticed the problem till now.
    Any ideas?
  15. #2215
    Rippin da fAt
    How much clearance is on the side opposing the rub? Perhaps rearranging spacers on the rear axle/hub or dishing the wheel would resolve your issue.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
  16. #2216
    May 2016
    Re-dishing the wheel is probably an option, thanks for the suggestion.
  17. #2217
    Aug 2015
    Another option/upgrade could be removing the front derailleur and front chainrings and upgrade to 1x10 or 1x9(very affordable today compared to 1x11) It will improve your tire clearance and chain retention. Without expending money on a new crankset, just get a narrow/wide chainring. I got a used sram XO 10 speed derailleur with clutch for $40 on eBay and a 10 speed sram x7 shifter for $20. One Up narrow-wide chainring from JensonUSA and a 10 speed chain for $20 on eBay also. Best investment on my GBM so far, the shifting precision is heavenly.
  18. #2218
    Aug 2015
    Pictures after upgrades. My white GBM is waiting on a SLX 10 speed set up. The narrow-wide chainring is already installed. My GBM pro(black) which is 170mm spaced as well has a similar set up allredy installed.
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-tire-clearance.jpg
    I'm boss and I know it
  19. #2219
    Rippin da fAt
    Quote Originally Posted by EvilSmrk View Post
    Was a thought cause it sounds like there is room to spare on the non rubbing side...
  20. #2220
    May 2016
    First real ride with the Jumbo Jims.
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-adobephotoshopexpress_b530cff6596149b8a0cce19b17f8b590.jpg
  21. #2221
    Reputation: mehlertmj's Avatar
    Jan 2017
    I've been researching the market for about a year now trying to decide which bike will suit me the best and I keep coming back to the Bullseye Monster due to price, availability, and from this thread, durability. However, I am 6'8" and I was wondering how the 22" frame fits the taller riders out there... I currently have a Trek 7.2fx in 25" frame and according to BDs website, the geometry on the GBEM looks like it is actually bigger than my current ride.
  22. #2222
    Hap
    Hap is offline
    Jun 2017
    I have read this entire thread since I just bought a 16" Gravity monster LTD.
    I need help on most everything I do to modify or improve this bike. I hope this thread keeps active and that I may ask questions here. Like I said I need help with most things I will do. New to biking, motorcycles dont get me in any type of shape and would like to ride this bike regulary. Not a trail rider but a dirt sandy side road rider. It is amazing on my road that is gravel and sand with a few pot holes. Any other bike was unable to ride on this road. I also notice on the pavement when I do have to get off the road to the shoulder it is very stable on the loose gravel and dirt while I am letting cars speed by.
    Thanks in advance for any advice I ask for.
    Hap
  23. #2223
    Jan 2016
    How do you remove the front derailleur?
    How did you get the front derailleur off? It looks like it is welded on.
  24. #2224
    Jan 2016
    Quote Originally Posted by mehlertmj View Post
    I'm 6'6" with a 36 inseam. Frame fits fine. Add a renegade or other suspension fork, and it's actually almost a little big. You will probably want to get some wider bars to spread you out a bit. Also, you can save another $100 if you buy it off of bike island with some scuffs instead of pristine from bikes direct. Note that the bike island ones only have the 50 mms rims instead of 80mm, but I have ridden 50s, 65s, 80s, and 100s. My bike has the 50s and the rest just sit. I like the lower rolling resistance.
  25. #2225
    Jan 2016
    Never mind. I figured it out. But not before destroying the derailleur. You have to pull off the bottom bracket.
  26. #2226
    Jan 2017
    Thanks, that is helpful information. Touchť on Bike Island. I've been looking at their website that last couple of weeks. I'm stuck between the Gravity and the FB 5 3.0.
  27. #2227
    Jan 2016
    Get the FB5
    If you have the money for either, I'd get the FB5. It has the tapered headtube, so you have more fork choices down the road. Also, it already comes 2x10, so a 1x10 conversion will be cheaper and easier. Also, it has the 197 rear triangle so you will be able to put the 5 inch tires on it later when you are playing around.
    Now, that being said, I'm good with what I have, because I have found a fork that works, don't want the 5 inch tires (again, lower rolling resistance, I'm 250 and 4 inch with low pressure has plenty of float), like grip shifters, so I have to buy new stuff for my 1x10 conversion anyway.
    The FB5 will give you a lot more upgrade options.
  28. #2228
    Aug 2017
    tldr: 14" Gravity Knockout vs 14" Gravity Bullseye for short woman?
    Hello! I'm about 2/3 through reading this entire thread. I'm a 5'3" woman (~122lbs) and looking to upgrade my Burning Man bike (and hopefully have a bike I can use for more than just the Burn).
    I used to own a Mongoose Beast, which at my height and weight was just waaay too heavy and tall for me. I stuck it out for two Burns and sold it last year. This year I'm looking for something lighter, but not too much more expensive. I almost bought a Framed Minnesota 1.0, but then realized that the Gravity bikes actually come with smaller frame options too.
    I just ordered the Gravity Knockout since it's supposedly intended to be a women's bike, but noticed that I can get a 14" Bullseye Monster on Bike Island for $400. Does anyone know how the weights compare between the stock Knockout and the Bullseye? I know the Knockout has heavy 3" wheels, so I was planning to, at minimum, swap the tubes for q tubes, and then maybe also swap the front tire out for the Panaracer Fat B Nimble. But that starts to even out the $100 price difference. Would I be better off with a stock Bullseye or would I still want to make similar changes there anyway? My husband just bought the Deadeye Monster 19" and we were pleasantly surprised to find that it 's only a little over 36lbs!
  29. #2229
    Dec 2016
    I've built a couple of Gravity Bullseyes. One with 15" frame and another with a 16" frame. My wife fits them both, she's 5'4" 130lbs. The first one I bought from Bikes Direct as a complete bike for $400 (single speed) The second one I bought through Amazon which was a Gravity Bullseye pro frame with a Renegade RST suspension fork for $265 + shipping. I ended up replacing most of the components on the Bikes Direct bike which is why I opted for the frame only from Amazon. Amazon has a Gravity frame only for $100 plus shipping if that's interesting.
    https://www.amazon.com/Gravity-Knock...fat+bike+frame
    If you buy from Bikes Direct check the rear drop out width because I found they very. I would also go for 50mm rims instead of 80mm. With the 50mm rims you can run 26" tires between 2.8" - 3.8". My wife's bike is currently set up with 80mm rims and Surly Nates 3.8 for mud & snow. I plan on building another set of wheels using 50mm rims so she can drop down to a narrower 3.0 tire for summer.
  30. #2230
    Aug 2017
    Thank you for replying so quickly! I'm still very new to doing anything other than buying a stock bike and riding it, and I also need the bike to be ready to go by august 23rd, so I don't think I have the time to learn how to build a bike from scratch just yet.
    This is the bike I've currently ordered: BikeIsland.com - Bicycle Parts, Accessories and Clothing at Affordable Prices with Free Shipping It says it can't take 4" tires on the back, but multiple people here have commented that they've made a few specific tires work.
    And this is apparently the wheelset it comes with (and I believe it is 50mm rims): BikeIsland.com - Bicycle Parts, Accessories and Clothing at Affordable Prices with Free Shipping
    Quote Originally Posted by gumba View Post
  31. #2231
    I heard that the knockout has chainline issues with frame and tire rub. Something about using a 7 sod with a spacer.
  32. #2232
    Aug 2017
    Quote Originally Posted by grooveface View Post
    Hm, yeah, I know there's an issue with using one of the gears, so it requires some minor modification for that. That's why it's sold at a pretty low price.
  33. #2233
    May 2016
    I have a 18" GBEM and we picked up a 14" Knockout for my wife.
    The Knockout fits my wife pretty well (5'4") other than the length of the stock crank arms which are too long for her.
    The stock crank arms are 175mm which force her knee's to bend too much at the top of the pedal stroke causing her discomfort.
    For many people the solution is to raise the seat height but she did not find that comfortable.
    Once I picked up a set of 160mm crank arms for her it resolved her issue.
    The stand over height for the Knockout fits my wife pretty well, however I suspect if I was to put a set of 4" tires like on my GBEM it would raise the stand over a little too tall for her liking.
    On the topic of the chain clearance, for her bike the chain only had issues when using the largest chain ring, She will likely never need that chain ring so I just removed it from the replacement crankset solving the issue for her.
  34. #2234
    Aug 2017
    Ah, thank you for that heads up! I'll pay attention to that and see if I need to make the same adjustment. I'm actually thinking about getting 3.5" Vee Speedsters instead, as from reviews it sounds like people think they're good for beach riding which is pretty much what I'll be doing. I've found a barely used set for just over $70 so I think that's a pretty good deal!
  35. #2235
    Hooligan
    Reputation: dirtdawg21892's Avatar
    Yesterday I actually had a chance took a ride on a GBM again for the first time in years. Man, I miss that bike. Glad to see that this thread is still so active!
    Quote Originally Posted by Optimus View Post
    Hell of a jump, dawg. Even though they're baggy shorts, I'm surprised that you can fit your balls into them.
  36. #2236
    Apr 2016
    Same here, this thread is where I started my Fat Bike research. I actually wound up building one instead of buying a complete bike.
    Sent from my SM-G955U using Tapatalk
  37. #2237
    Aug 2017
    I'm considering buying the BEM as entry before i decide on what actual fatbike I want. My goal is to sell it before i start upgrading (like adding carbon fork, wheels etc.).
    I'm in WI and main goal is snow fun. Also want to use it for mild MTB on trails (and have 5-7 mile paved trail to get to the MTB trails).
    So far I know brakes, tires and drivetrain are not great.My plan:
    - transfer hydraulic discs from another old bike (=free); buy 180 mm rotor for front.
    - Test tires and either wear them out before replacing. Or buy better tires, but once I sell this bike put the old OEM back on.
    - Drivetrain will replace once it wears out or gets damaged (obviously possible when off-road). My hybrid has 2x10 and i could upgrade that to 2x11 and re-use the 10-speed shifter and derailleur (or upgrade fatbike to 1x11 if easily possible)
    - I will decide on handlebar, pedals and stem once I have it if fit requires new purchase (but this is not expensive)
    - I know before assembly i have to lube BB threads, adjust hubs etc.
    I guess I know a bit what I'm getting myself into. Any other recommendations? (Again, don't want to spend a lot, if upgrades become necessary, I buy a new bike)
    some questions:
    1. did someone successfully convert to 1x11? I assume the hub is 10-speed only. If someone did it, what was required to do (besides replacing wheel or hub)
    2. Is the fork rated for 180 mm rotors? I don't want to tear down the caliper.
    3. Is the MEB frame inherently heavier than the Boris? The Boris have hydroformed tubes. Or what is the "out of the box" weight of the BEM?
    4. the Boris and Sturgis had derailleur hanger issues. it looks like they got re-designed and BD also includes a spare hanger. Something similar for the BEM?
    5. With what you know now about the BEM, would you have started out with a more expensive bike to begin with, or would you use a BEM as entry level again? I see many people have upgraded a lot (to much more than $500).
    6. I'm 6' with 34"inseam and weigh 180#. Per BD that puts me on an 18" frame (5'8"- 6'0"). Would you agree on their sizing? In most threads it seems people often are well off getting a number smaller if they are on the edge.
    7. Is standover height a problem? It seems the steep headtube
    8. With the MEB my maximum loss is "$500+ upgrades - resale value". With a Boris the almost same upgrades are necessary but the $500 is a $600 or $700. Would there be a reason to use a Boris as starterbike? (with the idea to upgrade to a 197mm tubeless ready bike later). they do have a $550 boris x5 on bikeisland (but x5 doesn't exist in black, which i prefer). So the Boris would require to be x7 for $650 on bike island (but would have 2x10 and 180mm rotor). From all i read, it seems all tires on all of them are not great. any reason why one of the Boris tires would be worth paying more? Obviously if it prevents me from buying tires immediately, it would be worth it. i can get Schwalbe Jumbo jim for $85 each. Or get other good tires at similar prices. is any of the Boris tires even remotely good?
    My current dreambikes are over $1-2K from direct retailers. But I need riding experience to know what I want. I considered the Boris bikes. But it seems at higher cost I still get 170mm spacing, non-tubeless rims etc. For me it is either dirt cheap, or something like the Sturgis or even better.
    Great thread, I read almost every page. I searched through the thread to answer the above, but didn't really find an answer. I also read almost every page of the Boris and Sturgis thread.
  38. #2238
    Reputation: iliketexmex's Avatar
    Oct 2016
    HerrKaLeun, answering some of your questions:
    - I put larger discs on the front with no issues using a bracket. The front fork seems beefy enough.
    - it comes with a spare hanger, I haven't had to use it.
    - I have a shorter frame (14"), so weight isn't apples to apples. But size was accurate. Mine was about 34lbs if I remember correctly.
    - I am happy with it having upgraded the handlebars and brakes. The 2x system works for the Midwest trails I ride.
    I suspect you are overthinking it. Get the best bike your budget responsibly allows and go ride it. You seem to be knowledgeable enough to have a good idea what comprises you can and can't live with. Simplify the decision by using the 'buy once, cry once' approach. The money you plan to spend on upgrads will go farther if applied towards a better bike. You might be able to sell a GBM and minimize the loss but save yourself the hassle. The bike companies have economies of scale and buying power.
    The GBM is a great budget bike, it allowed me to get into fat biking. But there are real limitations of the bike (straight head tube, drive train, etc.), Those limitations have not detracted from the fun. A better bike would probably be even better. I don't sweat over it.
  39. #2239
    May 2016
    I second HerrKaLeun. Iíve had my BEM for a year and a half and ride it on mtb trails and SoCal beaches. Iíve been extremely pleased with the bike. It is solid, reliable, and fun to ride. I decided to get the bike, ride it, and make as few changes as possible as inexpensively as possible as I gained experience and discovered things that really needed to be improved.
    This strategy has worked extremely well for me. I have made changes to my drivetrain and cockpit, but I have felt no need to upgrade tires or brakes. The Mission Control tires do tend to autosteer, but being careful to adjust tire pressure to suit the riding surface and getting wider (700mm) bars and a shorter (60mm) stem ó less than $50 for both on sale at Jenson USA ó essentially made that problem go away. I took the time to bed in my brakes when I first got the bike, and they have been fine. They are not the most powerful or most progressive, but I have never needed more stopping power, theyíve never caused me any control issues, and they donít mind being squeezed all the way down a steep 1800 foot descent.
    Most of the mtb trails I ride have steep slopes that are quite long. Both my riding partner, who is 15 years younger than me, and myself found the stock gearing too high. I installed a 20T front chain ring which helped, then lost the 11T off the cassette and added a 38T in back for a super granny that solved the climbing problem for both of us. Parts for the drive train mods were under $90 per bike and I did the work myself.
    I added a low end KS Exaform 861 dropper post ($90 from Jenson USA) which works great and a pair of Wellgo MG-1 pedals ($35 on Amazon), and that is basically it. Every one of my upgrades added a few grams, so my BEM now weighs just over 39 pounds, for what that is worth. With the exception of maybe replacing the tires, which are wearing, with Jumbo Jim Snakeskins, thatís it for my BEM. Iím done with mods.
    I was 77 when I decided I wanted to get a fat bike, and I had not ridden a bicycle in about 40 years. It was a semi-crazy experiment, and it turned out to be a tremendous, incredible success. I now know where and how I like to ride, I know what I am capable of doing, and I know what kind of machine I need to do it. For my 79th birthday I am seriously thinking about getting a SRAM Eagle equipped all-carbon Lamere fatty which J. P. assures me will come in under 26 pounds with 4.4-inch Jumbo Jims, a Bluto, and a Reverb dropper post. Way, way, way expensive, but EXACTLY what this old man needs in his waning years.
    I have recounted my personal experience in some detail here because I think what I have done is representative of one really good way to use a BEM. Get one, ride hell out of the thing, and wait until you really, really dislike something before you upgrade it using as little cash and as much brains as possible. Hold off on the big bucks until you truly understand what you need. At some point you will know.
    And, if you read this forum, which you have, you should understand that it is pretty hard to regret getting a BEM.
  40. #2240
    Aug 2017
    Quote Originally Posted by El Geezer View Post
    You made some very sensible upgrades and should be able to re-use most on a new bike. So more an investment in biking than the bike itself. I myself fully count on needing grips saddle (Brooks B17 guy) and possibly pedals... but will keep the OEM parts in a box for the time I sell it. They now come with 700mm handlebar, so I should not need a new handlebar.
    since you brought up carbon fat bikes. i came across the direct sale Canyon Dude. Not available before October (I called). no direct experience with it, but thought you might check it out since you talked about going carbon.
  41. #2241
    May 2016
    The Dude CF 9.0 EX is a nice bike for $3,600 bucks, but the 1x11 Shimano with a 28T up front would not work for me, and the DT Swiss aluminum wheelset is almost a pound and a half heavier than Lamere's 65mm carbon wheels with Tune hubs.
    Lamere has a limited set of proprietary carbon framesets, forks, and wheels, but J. P. works with every customer and custom builds the bike so it comes from his shop EXACTLY the way you want it. He will even ship the bike I am thinking about getting tubeless (with Orange Seal tape and sealant) and do a way better job of it than I ever could. If you go to his website (https://www.lamerecycles.com) and look at the gallery, you will see that almost no two bikes he has built are exactly the same. So, if you know exactly what you want, that is exactly what is inside the box when you open it. No swapping out this or that that is not quite right, blah, blah blah. I'm at the stage of life where this model for doing business has a lot of appeal. What am I going to do with the $6K+ when I'm dead in 20 years of so? Mountain biking a fatty is pretty much my only nasty habit.
  42. #2242
    Reputation: a1pathfinder67's Avatar
    Jan 2014
    dirtdawg,
    I want to thank you. You are the OP'er on this thread and this thread is what sparked my interest in BEM. I have been riding my walgoose(Malus) for over a year now and have really enjoyed it. Spent some time on the Dolo semiwild thread, which was pretty awesome as well. I would recommend those "cheap" mongoose fatties to anyone just starting out. It held up very well. But as with anyone who has ever upgraded from one of those bikes. You realize there limitations. That is why I opted for the BEM LTD.It took me a while to save up for it. Now i have the cash. It doesnt break the bank and you get quality at a reasonable price. I opted for the limited because of the upgraded wider tires. I ride a lot of sand trails here. Plus i like the wider stock HB's and the tapered head tube for possible upgrade. Oh and the black with the red rims. Awesome!!!! Love that color scheme. hahaha. Anyway. Thanks to this site I pulled the trigger on it yesterday. Now just waiting very impatiently. Hope this thread keeps going. Especially in peak fatty season. I will keep you posted and send pics.
  43. #2243
    Reputation: pathfinder67's Avatar
    Nov 2016
    I got the LTD about 2 weeks ago. Love this bike. It does have a lot of potential for upgrade. I have the Vee Bulldozers on mine and they are awesome. They grip everything dirt, leaves, and mud and roll right over everything, including sand(8psi R/7psi F). I will let you know about snow when we get some. I put a shorter stem on immediately and changed out the pedals for some old bigger flats I had laying around. I shaved down the seat post about 1.5 inches.(Way too high stock). My future plans are ditching the front derailleur and going 1x8. Also I plan to go tubeless. Best place to lose weight is in the wheel set. Rotational mass/resistance...blah blah. Its all greek to me but its a proven cheap upgrade. I am not a weight or speed junkie. Just want it as light as possible without major changes. That will be pretty much it for me. Other than that this bike shreds up hills, down hills, over stumps and sand. Its awesome!!! I will keep you posted.
  44. #2244
    Dec 2017
    Dirtdawg, like the post above, would like to thank you as well. This has been a world of useful info, and a fun read as all you all show your bikes and adventures. I am the fence between the BEM and the 2018 GBEM XX 10 speed with hydro brakes. I know i will want to change the wheels to 80mm tubeless compatible eventually. I found some wheels that might do the trick,
    https://www.thebikesmiths.com/produc...nt=42860835410
    only thing is they say "Does NOT fit REAR disc spaced front forks". I cant find any info on how the brake/fork are set up on these bikes, front or rear disc. Can anyone chime in on this? Also would the extra cost of the bemXX be worth it if i change the rims? i will go 1x11 anyways with those wheels, so what left is the tapered head tube- only useful if i go susp?, and hydro brakes. Decisions decisions lol
  45. #2245
    Jan 2014
    Cant get off of my LTD. Loving it. Gear ratio is fine. Brakes are fine too. Maybe Bluto one day. Can be helpful on a lot of the trails i ride. We will see.
  46. #2246
    Nov 2016
    Had the beast in it's natural habitat. Rides like a dream. Tearing up them pines.
    http://ficdn.mtbr.com/images/attach/jpg.gif
    http://ficdn.mtbr.com/images/attach/...attach/jpg.gif
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-img_2805.jpg
  47. #2247
    Reputation: Mr Horse's Avatar
    Quote Originally Posted by JPmtb View Post
    I have that wheel on my front using a Trek Farley fork. Photo attached in case that helps
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-24796712_1478450168940787_1764679359748294059_n.jpg
  48. #2248
    Dec 2017
    Oh man that is some beautiful country, great to see you're getting out there enjoying the bike! Gets me one step closer to pulling the trigger on one!
  49. #2249
    Dec 2017
    Quote Originally Posted by Mr Horse View Post
    Thank you Mr Horse, this should help!
  50. #2250
    No problem.
    Let me know if you need to view it from a different angle.
    The Farley fork is on a GBEM LTD....it's a pretty decent frame. The Blizzerk wheels are good too.
  51. #2251
    Does anyone know the head tube diameters for the LTD frame (tapered)?
  52. #2252
    Dec 2017
    I was looking at that as well while researching offset headsets as i think i would like a slacker ht angle, and the xx looks to be the same frame. It lists 1.125" tapered, so I think those are 1.125" upper and 1.5" lower.
    hope this is helpful.
  53. #2253
    Nov 2016
    Yes it is a standard size. 1.125x1.5. So easy upgrade.
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-fullsizerender.jpg
  54. #2254
    Dec 2017
    Mind made up, going with the 2018 Gbem XX in sapphire blue! Size 16 frame should be on the money , I'm 5'7" with a decent reach and 30" inseam. Checking out shorter stems and better pedals as I type. Pathfinder67, what length stem did you go with?
  55. #2255
    Do you know what the inside diameter is? I'm thinking I may put an angleset in it.
    Here's mine: It's a 16" which makes it fun to ride being 6' 1".....it feels like a BMX bike.
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-24312577_1476579699127834_8727848815790104454_n.jpg
  56. #2256
    Aug 2015
    I picked up the same Frame + Rst Renegade deal for $275. That was the best deal in fat bike history. Mine has green wheelset that I got for $150. Love the bike and the Renegades. Pictures a couple of pages back.
  57. #2257
    Dec 2017
    https://www.canecreek.com/resources/...tion-guide.pdf
    Diameter should be 1.125 and 1.5 , head tube length is 110mm
    Hit up these guys, they have some good reviews and maybe can help with the angleset
    Works Components - Angle Headsets | CNC Bicycle Components | Made in the UK
  58. #2258
    Sweet...
    Yes! That was an incredible deal. I actually bought one just to cannibalize the fork but liked the frame so much that I bought two more to build up.
    The small is my girl friend/ smaller rider loaner bike. It's incredibly nimble.... I like to take it out when I'm riding tighter trails even though I look ridiculous on it. The HT angle is a little steep for my tastes tho, so am probably going to replace the headset with an angleset.
  59. #2259
    Dec 2017
    Got it
    Gbem XX waiting to ride on xmas day!
  60. #2260
    Dec 2017
    Awesome JP.. My XX will get ordered in about 1 month..
    Barber
  61. #2261
    Dec 2017
    Thanks Barber, I know these will be some fun bikes! Hope you get yours soon than later!
  62. #2262
    Hooligan
    if i remember correctly, the GBM uses a front disk spacing, so that should work fine.
  63. #2263
    Dec 2017
    Wheels
    Thanks Dirtdawg, I ended up getting a set of sun ringle complete wheels with a 150mm front(for the GBEM XX though axle) 177mm rear,and ordered correct end caps to fit the rear 170mm spacing
    https://www.ebay.com/itm/NEW-Sun-Rin...-/142499755449
    Gravity Bullseye Monster-received_1793161007361264.jpgGravity Bullseye Monster-received_1793161067361258.jpg
  64. #2264
    Reputation: Birddog1148's Avatar
    Dec 2017
    New to the forum, first post. I guess I am what you call a Clydesdale, 49 years old 5ft 9in right now about 255lb and looking to get a fatbike. Couple years ago I ended up having to ride a bike to work for a few days and it didn't kill me. I ended up upgrading after 1 day from a cruiser bike to a cheep 29 in mtn bike that I upgraded as I wore out parts or felt the need. I find that riding my bike back and forth to work is about the only way I can consistently make myself get exercise. I don't have any illusions of doing anything extreme on the bike I get but I have quickly ruled out a bike from a department store. At this point I am leaning towards a Bullseye monster or the LTD and possibly the Boris X5, I will probably try to do a spread sheet so I and look at the specs in one place. I also am thinking of putting a mushing harness on my 18 mo old Shepard and doing some bike joring. I live in northern Ohio and we have old limestone quarys and access to Sandy beaches to ride on . Sorry for rambling
    Sent from my SM-T567V using Tapatalk
  65. #2265
    Oct 2016
    Quote Originally Posted by Birddog1148 View Post
    the GBM has a straight head tube, which means if you think you want one of the suspension forks, your choices are limited. I guess it depends on what you are looking to do. I have the GBM, I put on a wider handlebar, good flat pedals and bigger disks. All cheap upgrades that have really been great. I have over 1000 miles on it, I still love it. I have no plans for further upgrades, I'll save my shekels to buy a new bike someday. It seems like that's the most cost effective way to get better gear, but it takes longer.
  66. #2266
    Dec 2017
    Quote Originally Posted by iliketexmex View Post
    I ended up ordering the LTD that has the tapered head tube, now I guess I wait.
  67. #2267
    Dec 2017
    So Bikesdirect website says these don't ship till mid Feb. but I ordered 2 different bikes and a tool kit and I have three separate tracking numbers that indicate that the items are at the Fed Ex Facilities or ready for USPS. Bow I am assuming the tool kit is coming USPS so that leads me to believe that my bike will be here Friday if the tracking number is at all accurate. Yay me, I will hopefully be starting out the new year with a new FatBike.
  68. #2268
    Oct 2016
    Welcome to the FatLife GBM style
  69. #2269
    Dec 2017
    I finally was able to order my Monster XX size 22" last night. Only problem was the 22" was out of stock. They had the 20", but would rather go big. I'm 6'6" 255#.. I wonder if I should try to call them and ask if they plan on getting that size back.
    Barber
  70. #2270
    Dec 2017
    Tracking shows my bike in Kentucky, took a day off Friday so I can sign for it, getting excited. Might get to start the new year off riding it to work.
  71. #2271
    Dec 2017
    thanks
  72. #2272
    Dec 2017
    Went ahead and ordered the L.T.D. 22" black/black.. Also ordered a Park Tool Rack..
    WOO-HOO
    Barber
  73. #2273
    Dec 2017
    Man, Fed ex tried to deliver it today, that's pretty good considering I ordered it on a holiday, pics tomorrow when it gets here
  74. #2274
    Dec 2017
    It's here it's here! I take it the blue and white strips are extra wheel liners?
    Sent from my E6810 using Tapatalk
  75. #2275
    Hooligan
    nice! I really like that color.
    yes, they are alternative rim strips in case you would rather have blue rim holes.
    they use to come with really heavy black ones that went behind the colored ones, do they still do that? first thing i did was pull them out. they dont really add any value, just weigh a lot.
  76. #2276
    Dec 2017
    Oh man that looks great , let us know how you like the ride! Enjoy!
  77. #2277
    Dec 2017
    First ride
    Super happy with this bike, I think i could have gone either way in sizing, 16 is what i got, as I was more concerned with standover. Already trying to get my friends into them too, they are going to test ride mine first!
    Put the new bars, stem, and pedals on after a couple rides. Rims will be on soon and will be set up to tubeless. Looks kinda clown shoes with the red and orange, but will look better with the black mulefut wheels.Gravity Bullseye Monster-bike222120.jpgGravity Bullseye Monster-bike113719.jpg
  78. #2278
    Dec 2017
    Awesome so far!
  79. #2279
    Dec 2017
    [QUOTE=Birddog1148;13476994]Awesome so far!
    Sent from my E6810 using Tapatalk[/QUOTE
    Very nice, glad you are liking it, and look at all that snow! I'm on dry trails, don't know if we will be getting much snow this year, but i can hope!
  80. #2280
    Dec 2017
    AWESOME.. My LTD probably wont be here til the end of Feb. I'm wanting feedback from your posts..
    Thanks, Barber
  81. #2281
    Dec 2017
    Quote Originally Posted by barber111 View Post
    Thanks, Barber
    I just ordered this Monday morning amazing how fast it got here. Proper ride in the am.
  82. #2282
    Nov 2016
    Gravity Bullseye Monster-frm1.jpgGravity Bullseye Monster-frm7.jpgGravity Bullseye Monster-frm3.jpg
    Awesome so far!
    How are them H-Billies in the snow? Mine has Bulldozers and I love it!!! Rides great!!!
  83. #2283
    Dec 2017
    Quote Originally Posted by pathfinder67 View Post
ID:	1175060Click image for larger version.
ID:	1175061Click image for larger version.
    Considering my point of reference is some worn out tires on my banana seat bike as a kid awesome. Just took about a 25 min ride down along shoreline drive to Battery Park and back home through the park part of town and only slipped a little a couple of times. Most I have ridden since August
  84. #2284
    Jan 2016
    I bought one for my wife for Christmas, I don't know who's having more fun on it her or I.
    I never realized what a blast these things are to ride.
    I bike itself looks to be of decent quality for the price, I might go with a 1X setup but other than that I don't see the need for many upgrades. I may have to thin the herd as I see they make these in a single speed too.
  85. #2285
    Jan 2014
    Cool-blue Rhythm
    Quote Originally Posted by Craig/Fl View Post
    I am 1 x on mine with the 8 speed and existing 22 T up front. Eventually I will put the money up for full conversion on the crankset. But loving this thing so much. Great ride this morning to close out 2017. 12 F with -5 windchill. Perfect http://ficdn.mtbr.com/images/attach/...attach/jpg.gif
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-img_2981.jpg
  86. #2286
    Jan 2014
    pics is it me or this program
    Attached Thumbnails Attached Thumbnails Gravity Bullseye Monster-img_2983.jpg
  87. #2287
    Oct 2016
    Quote Originally Posted by a1pathfinder67 View Post
    For some reason this happens to me whenever the picture is taller than wide. I found if I crop it to be landscape it will straighten up but otherwise I couldn't fix it
  88. #2288
    Nov 2016
    Thanks, Barber
    Great bike. Love mine. I got mine beginning of November. I cant stop riding it. Trails, sand and snow. So much fun. A lot of upgrade potential. Haven't had the need yet though. Not the lightest bike, but not heavy either. I will keep you posted on durability/performance/upgrades. You will love it!!!
  89. #2289
    Dec 2017
    COOL.. Yeah, I think the reason mine is so far out the 22" frame. Thanks for any and all you want to share.
    You haven't mentioned brakes,, Sufficient ???
    Thanks, Barber
  90. #2290
    Nov 2016
    Thanks, Barber
    I am not sure where you are? The hill you see in my avatar is an anomaly. Still even that is only 185ft above sea level. The pines are very flat. We do have some steep very short descents and very few not so steep long flowing descents. So its hard to gauge if you are in a mountainous area. We definitely have some fast technical trails here though and they are fine for me. I mean I tweaked them out of the box because they were not sufficient coming from the factory. Now they actually stop on a dime with one or two fingers. If you are a downhill guy they may not be sufficient enough. Tweak them and test them in your area before you decide. If you do need advice on new ones I am no expert, but there is a lot of info on this site. So do some surfing.
  91. #2291
    Jan 2018
    Hey everyone. I'm new to the forums and to fat biking in general but I've been reading a lot about the gravity bullseye and I really like it. I plan to use this bike for backpacking/exploring. I'm sure that there are much better bikes for this but I really like and want this one. Plus it's the only fat bike within my budget besides the dolomite which doesn't seem all that great. At this point it's between the gravity bull's-eye Ltd or the new gravity monster xx for $699. That is the absolute highest price that I can go because I still need to get my backpacking gear and stuff. Which one would you guys recommend for me? Will the Ltd suit my needs just fine. Can I attach racks and all of that good stuff to it? Or would the monster xx be more suited towards my needs?
    I don't really care about the fancy stuff. I plan on riding the bike stock out of the box until anything needs fixing. As long as the bike can move at a reasonable pace, hold my weight and belongings, and get me where I need to be I'll be fine. BTW I live in the desert so there's a lot of sandy rocky places out here for me to explore. Also, I was wondering if I should go with 14' or 16'. I'm a 5'5 female and I weigh roughly 200lbs. I think my inseam is a little under 30. Maybe 25-28 or so. I went to Walmart to sit on some of their bikes to try to get a feel for sizes and I sat on one that I would assume had to be around 14' but my legs felt a little cramped. Do these monster bikes run big? Thanks everyone in advance for your help.
  92. #2292
    Nov 2016
    Amplified,
    If you are talking about "serious" bike packing, I would probably recommend a much higher end bike. I am no expert on this subject, but most of the bikes you see doing the really long trips are high end models. You could definitely do some over nights or weekend trips on these bikes though. They are pretty high quality for the price range. I have never ridden the XX. But the LTD has a great gear ratio for hill climbing. Not sure about the sizing. The seat post on the LTD runs too high. I bought the 18" and cut 1.5" off of the seat post. Now its perfect.
  93. #2293
    May 2016
    long term update and cheap suspension
    Hey folks been a long time since I posted on here. Thought I'd share an update on my gbm experience and some initial impression of a cheap air fork I got for Christmas. Love this bike! Had it about a year and put plenty of miles on it with few issues. I'm in middle Tennessee and trails are rocky/rooty. My favorite rides on the fatbike are techy climbs where I can crawl up rocks I see others having to pick and choose lines around.
    Heres a rundown of things I've changed: I completely destroyed my rd last year and replaced with SRAM x9. No compatibility issues and it has served me well. Got some pedals off Amazon
    Imrider Lightweight Polyamide Bike Pedals For BMX Road MTB Bicycle. For Christmas I got a chinese air fork that has been a pleasant surprise. Whool Locking Suspension Air Forks Aluminium Alloy For 4.0"Tire Snow Mountain Bike 26 Fork Fat Bicycle Fork only 2450g. It has made riding a ton more enjoyable no more jarring wrists and hands on rough trails. No issues in the cold that I've read about with some air forks. I've had it out in 20 degree weather. So far thats all I've done but I've just received carbon fiber bars and a shorter stem I'll install once new grips arrive. I saw early in this thread there were cassette problems- however mine came stock with shimano 34T. have had no issues. My only major EQ gripe is the brakes which I can never seem to get to stay tuned. Every few rides they start to rub or make noise. Here are pics from todays ride.
    Gravity Bullseye Monster-img_0653.jpgGravity Bullseye Monster-img_0654.jpgGravity Bullseye Monster-img_0655.jpgGravity Bullseye Monster-img_0656.jpgGravity Bullseye Monster-img_0658.jpgGravity Bullseye Monster-img_0659.jpg
  94. #2294
    May 2016
    no idea why the pics are all upside down...there were right side up on the computer when uploaded...
  95. #2295
    Sep 2017
    I bought my son a dolo and it's ok for riding around town but that's as far as it goes. I'd be afraid to jump with it and the weight will kill you on a hill the thing is a tank.
  96. #2296
    Dec 2017
    I just got my new Bullseye Monster last night and got it assembled. Today on my lunchbreak, I put some air in the tires and took it for a spin. For the 15 minutes I spent riding, it seems like a good bike. Smooth ride and not as bulky as I thought it would be. Can't wait to put more miles on it.
  97. #2297
    Dec 2017
    Comuted today on the Bullseye Monster LTD, almost 4 miles each way. Black ice is slippery, and slush makes your butt wet but enjoyable nonetheless
  98. #2298
    Sep 2017
    Bang for the buck there is no beating them.
  99. #2299
    Jan 2018
    I do love a bargain. Seriously considering the 2018 BEM XX. Do these have a threaded BB?
  100. #2300
    Dec 2017
    Quote Originally Posted by LPRoad View Post
    yes
  1. Gravity Bullseye Monster anyone?
    By formula4speed in forum Fat bikes
    Last Post: 01-18-2016, 03:43 PM
  2. Replies: 37
    Last Post: 07-06-2015, 06:46 AM
  3. bullseye monster
    By Milunchbox in forum Fat bikes
    Last Post: 05-15-2014, 10:41 AM
  4. Dawes BullsEye vs Gravity G29..Opinions Please
    By jimx200 in forum 29er Bikes
    Last Post: 03-12-2012, 04:38 PM
  5. New Trends: Mini-Velo, Retro City, Monster Cross, Monster Tires?
    By bikesdirect in forum Bike and Frame discussion
    Last Post: 01-15-2011, 06:22 PM
Members who have read this thread: 174
