Results 1 to 11 of 11
    Bad cat!
    Reputation: montana_ben's Avatar
    Oct 2010
    Go left young Muk...
    Just wanted to throw up a few pics, mostly by way of thanking Craig (Mr.MCS) for pulling the trigger on getting these clamps made up. Even got spokes and advice so I didn't have to mess around with spokecalc and re-purposing the rolling Darryl was a snap.
    It was driving me crazy seeing my Lefty max dangling uselessly from my Prophet, and now all that sweetness (well about 110mm of it) is smoothing out the tromped-on refrozen crud out there at the moment. The ride just got sweeter...
    Dec 2010
    Looks fantastic, well done!
    Have you got anymore pictures showing the hub and clearance between the tyre and fork?
    (Tyre spelt like that 'cos I'm English)!
    Feb 2005
    Looks great Ben! Thanks for posting pics of them in the wild!
    Just got word today that my NOS Leftys should be shipping from Cannondale.
    Spreading the fatty love, far and wide now!
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Quote Originally Posted by MendonCycleSmith View Post
    Hi Craig, can you tell a little more about the NOS Leftys? Travel? Damper? Cost?
    Thanks…
    Reputation: Lone Desert Walker's Avatar
    Sweet.
    Feb 2005
    Quote Originally Posted by rasse1977 View Post
    Thanks…
    2005 alloy Max 140 shells, with the ability to drop in the short 100mm (original spec travel) or long 140mm (original spec travel) 2012 PBR/XLR dampers.
    The dampers are then tweaked to the desired/appropriate travel/ A to C, for the end users situation.
    Need more details? Drop me a line.....
    - FrostyStruthers
    Reputation: ferrstein's Avatar
    Awesome! I figured it wouldn't be long until somebody put one of these on a Muk. Lovin' mine on my Pugs... headed out for some more single track in the AM.
    Reputation: ionsmuse's Avatar
    Looks pretty moto.
    What does it do to the HTA?
    Feb 2005
    Quote Originally Posted by ionsmuse View Post
    Looks pretty moto.
    Depends on what fork you utilize.
    Older Ti legged DLR 100's are 480mm a to c.
    The Max 140 structures are 520 at 140, and lose commensurate a to c with travel reduction.
    Totally tunable as far as initial set up goes. So as long as you factor that into what you do, it can remain the same or be tweaked to personal choice.
    - FrostyStruthers
    Bad cat!
    Oct 2010
    Didn't do the math, but have a digital angle gauge, which read 70 degrees when zeroed on the floor and stuck on the headtube in stock form. With lefty on, (and topped out in the clamps, max possible travel) 69 degrees. Picked up 1/4" at the BB, so now 12 1/4".
    For me, both of those are good changes...
    RE: clearance between fork and tire, no pic at the moment, but looks to be about 12mm between sidewall bulge and the breather filter cover bit the way it's currently setup, there are variables at work for sure with a fork that can be rotated in clamps that project from the headtube and can also be rotated, and wheel offset adjustability... For me I had to get my hands on it to really see how it all relates.
    Feb 2005
    Quote Originally Posted by montana_ben View Post
    So true. It's kind of hard to articulate just how flexible the set up really is, glad you're figuring it out...
    - FrostyStruthers
