Results 1 to 5 of 5
    Reputation: thecanoe's Avatar
    ghetto tubeless caution
    I set up my BFL's on Clown Shoes using a layer of sil foam and a 24x2.5/2.75 presta valve split tube. With a high volume floor pump and some soapy water, it seated easily.
    Then, I removed the valve core after making sure the bead was seated and installed 6oz of Stan's through the valve with an injector. Pumped the tire to 20 lbs and did the Stan's dance. All good, right? After checking that the Stan's sealed everything, I used a razor blade and trimmed the excess tube close to the rim. When I shook the tire I didn't hear any sealant sloshing around, so I decided to add a little more. When I let the air out, the stretched tube pulled back into the center of the rim with nothing sticking out. Leaked when I aired up.
    Did it over with a new tube and left about 3/8 of an inch of tube sticking out. Doesn't look as neat, but, it worked.
    What are other ghetto users doing?
    Santa Cruz Tallboy
    Moonlander
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Using tape doesn't have those issues.
    Reputation: OFFcourse's Avatar
    Yeah tape it canoe!
    I used the split tube but didn't trim it, as I didn't feel like buying a new tube and setting it up again if I change tires.
    Jan 2013
    Here's a guy who glues the tube to the tyre (post #2): tubeless fatbike made easy
    I've never tried tubeless but when I do then I'll do it that way.
  1. Max psi for ghetto tubeless ?
    By David C in forum Wheels and Tires
    Last Post: 06-23-2016, 10:18 AM
  2. Replies: 5
    Last Post: 02-15-2011, 12:30 PM
  3. Ghetto Tubeless?
    By Ryan97 in forum Urban/DJ/Park
    Last Post: 02-08-2011, 05:48 PM
  4. AZ Ghetto Tubeless XC - PSI?
    By gluvnaa in forum Arizona
    Last Post: 01-24-2011, 08:02 PM
  5. Replies: 12
    Last Post: 01-24-2011, 01:44 AM
